Author Topic: [IC] DCS LED Keys - Fill up the Google Form!  (Read 14165 times)
Offline mul7i
« on: Wed, 09 July 2025, 01:51:32 »
Hello everyone, welcome to DCS LED Keys.
I'm mul7i/tom, and I really want LED keys for DCS sets.
IC FORM   DISCORD
I basically asked Signature Plastics if I could run a 4 key extension kit and they said yes.
I am planning to run for some of the recent sets.
Each colorway can be purchased separately, so nobody has to be stuck with keys they don't want/need.
The colors are FIXED, adding extra colors will change the pricing by quite a bit, and will most probably be a logistical nightmare for everyone.
Pricing:
TBA
Vendors:
US - Bowl Keyboards
CA - Mino Keys
UK - Proto[Typist]
EU - KeebSupply
OCE - KeebznCables
KOR - GEONWORKS
SEA/SG - PantheonKeys
SEA/MY - Rebult Keyboards
Colors will be:
1. Beige, GAW - NN
2. White on Black, NN - WFK
3. Red Alert, WFK - RA (Lam Alert run)
4. Lam Alert, WW - RA
5. SMRT, GTD - BBI
Kitting Renders:
Board Renders:
Imgur Gallery
*Other keycaps may not be 100% accurate recreations
Updates
9/7/2025 - confirmed quotations from SP, looking for vendors
11/7/2025 - vendors found
Special thanks to:
Laminar, Piperaceae and Manu for letting me run extension kits for their sets.
Signature Plastics for agreeing to run this tiny kit.
PantheonKeys for helping with sourcing vendors.
« Last Edit: Thu, 10 July 2025, 18:09:37 by mul7i »
Offline mul7i
Re: [IC] DCS LED Keys - Looking for vendors!
« Reply #1 on: Wed, 09 July 2025, 01:52:15 »
Reserved
10/7/25 - Updated Lam/Red Alert Kitting
« Last Edit: Wed, 09 July 2025, 14:02:24 by mul7i »
Offline geonworks
    • GEONWORKS
« Reply #2 on: Wed, 09 July 2025, 01:56:19 »
Let me in as a vendor
Offline mul7i
« Reply #3 on: Wed, 09 July 2025, 01:58:10 »
Hi Geon, will contact you in discord  :thumb:
Offline masje
  • Your neighborhood keyboard designer.
    • masjewerke
« Reply #4 on: Wed, 09 July 2025, 02:00:15 »
so in for this
Offline DirtyGingy
« Reply #5 on: Wed, 09 July 2025, 02:09:14 »
At first I didn't think I would want these, but was going to be supportive. But they I saw the add on for the eyes set and that instantly flipped to need.
Offline twitchytheinsideman
  • UWU UWU UWU UWU UWU UWU UWU UWU UWU UWU
    • Twitchy Homepage
« Reply #6 on: Wed, 09 July 2025, 02:22:18 »
LED gud
Offline xLeHoy
  • weeb board enjoyer
« Reply #7 on: Wed, 09 July 2025, 03:01:07 »
I like me some LED Keys
Offline whirlwind
« Reply #8 on: Wed, 09 July 2025, 03:45:01 »
Best LED windows, let’s go!
Offline Nascent
« Reply #9 on: Wed, 09 July 2025, 03:57:06 »
Yes please
Offline Gemmmmmmmmmmmmmy
« Reply #10 on: Wed, 09 July 2025, 07:29:49 »
Yep I'd be down
Life seems so much smaller
Swim to the moon
Offline Piperaceae
    • DCS SMRT R2 Links
« Reply #11 on: Wed, 09 July 2025, 07:33:39 »
Thank you for matching these to SMRT! This was something I wanted to include but couldn't get into the final kitting, so I'm glad to see the chance for it to happen now.
Offline TjarleN
« Reply #12 on: Wed, 09 July 2025, 08:16:57 »
Awesome, my W1 needs that beige numlock
Offline FatefulStranger
« Reply #13 on: Wed, 09 July 2025, 08:29:13 »
Love this.
If you can do DCS Vert, I’d be eternally grateful 🙏
Offline NoWrinkles
« Reply #14 on: Wed, 09 July 2025, 08:39:17 »
Based, in for a few kits
Offline Rob27shred
  • Insane in the Membrane! 👻
« Reply #15 on: Wed, 09 July 2025, 09:22:11 »
I'd be down for all of them other than Lam Alert (I went with Red Alert in that GB) if this runs! GL with it OP!
Offline getupbuzz
« Reply #16 on: Wed, 09 July 2025, 11:19:12 »
love it!!!
Offline Meepergon
« Reply #17 on: Wed, 09 July 2025, 13:10:53 »
LET'S GOOOOOO, i'm getting all kits except lam alert!
Offline dvorcol
  • Discord: dvorcol_5071
« Reply #18 on: Wed, 09 July 2025, 13:29:46 »
You might want to add a BoW kit, since it tends to be more popular than WoB in GBs that offer both.
Oops, never mind. This was the preference in one Geekark and two KAT GBs, but I cannot find a DCS BoW GB on record.
« Last Edit: Wed, 09 July 2025, 14:11:14 by dvorcol »
Offline mul7i
« Reply #19 on: Wed, 09 July 2025, 13:46:45 »
Thank you all for the positive replies so far!
ONE PROBLEM HOWEVER: I MADE A MISTAKE ON THE LAM/RED ALERT KITTINGS
IT SHOULD LOOK LIKE THIS INSTEAD  :-[ :-[ :-[
I'm back in contact with Signature Plastics for this error and I hope there won't be too drastic of a change in price.
NO PRICE CHANGE
Now to answer these:
I'm running these based on the recent sets that was being run over the past 6-ish months
Adding more colors mean the additional colors will be priced very differently according to their own order quantity.
It would be the same as having separate runs entirely for those specific colors.
« Last Edit: Wed, 09 July 2025, 20:19:09 by mul7i »
Offline dvorcol
« Reply #20 on: Wed, 09 July 2025, 14:05:54 »
Understandable. Also, my suggestion doesn't apply to DCS since there hasn't been a DCS BoW GB. At least, not one logged in KeycapLendar.
Sorry for the bad advice, and good luck with the IC!
« Last Edit: Wed, 09 July 2025, 14:32:25 by dvorcol »
Offline mul7i
« Reply #21 on: Thu, 10 July 2025, 18:01:47 »
Vendors and board renders updated in main post!
No worries, thank you very much for the blessings!
Offline dvorcol
« Reply #22 on: Fri, 11 July 2025, 16:08:56 »
Actually, Signature Plastics has BoW and WoB kits in stock - https://spkeyboards.com/products/dcs-black-on-white-copy
Maybe they'd be interested in adding those two LED child kits to their inventory?
Offline mul7i
« Reply #23 on: Mon, 14 July 2025, 13:11:11 »
I have checked with them but they're not planning to stock any LED extensions as of now.
Offline Dingo_Seven
Re: [IC] DCS LED Keys - Fill up the Google Form!
« Reply #24 on: Sat, 19 July 2025, 11:52:23 »
This is looking good, in for a cuppa sets of the beige rendition :D
Offline mongoose27
  • WKL FTW
« Reply #25 on: Fri, 01 August 2025, 21:55:08 »
I need all of these.
Offline Nascent
« Reply #26 on: Sun, 03 August 2025, 03:08:20 »
Is there a tentative date to run this?
