Author Topic: [IC] Enso-E: split ergo HHKB with EC/MX support (GB: Dec 8-22, 2025)  (Read 27304 times)
Offline CleverKeebs
  • Formerly pixelexip
🚨 THE ENSO-E GROUP BUY RUNS DECEMBER 8–22, 2025! 🚨
Omnitype is the primary vendor for launch.
International vendors will be going live today or early this week.
Group Buy closes December 22.
[IC → GROUP BUY] Enso-E — A Split Ergo HHKB with EC/MX Support
The Interest Check is now closed.
We are no longer accepting responses, but you may still view the original form for reference.
Overview
The Enso-E is now live for Group Buy! This project has evolved through multiple prototype iterations, top-down assembly refinements, and hybrid EC/MX innovations. Today marks the beginning of the official preorder window.
Highlights:
  • Custom split ergo HHKB layout with separated bottom row
  • Hybrid PCB by Cipulot supporting both EC and MX
  • Pogo pin connection between main body & daughterboard
  • Custom silicone gasket socks enabling softer or stiffer configurations
  • 8.125° typing angle
  • 17.3 mm front height
  • Injection-molded PC top shell (transparent or smokey)
  • Multiple metal weight + accent options
Vendor List
The Enso-E is available globally through the following authorized vendors:
  • Omnitype (USA) — Main Vendor
  • Prototypist (UK)
  • Oblotzky (EU)
  • Ktechs (Singapore)
  • Keebzncables (AU)
  • Deskhero (CA)
  • KBDFans (CN)
Colorways & Limited Editions
Sand
— sand-inspired powder coated bottom
— smokey transparent injection-molded PC top
— copper weight + copper border accent
Stone
— custom stone-textured powder coat bottom
— stainless steel weight
— light grey anodized aluminum border accent
Snow (previously “Lunar”)
— white e-coated bottom
— clear transparent PC top
— silver anodized aluminum weight + matching border accent
Botanical
— color-matched to GMK Botanical
— light green anodized aluminum bottom
— clear PC top
— dark green anodized aluminum weight + matching border accent
Titan (Limited Edition — Omnitype Exclusive)
— Titanium alloy bottom (rough sandblast)
— Titanium alloy weight + matching border accent (soft sandblast)
— CNC’d acrylic amber-tinted top
— Includes both EC + MX titanium plate kits
— Serialized with extensive QC
— Limited to 50 units
— Only available on Omnitype
All finishes subject to refinement before fulfillment.
Titan Edition — Image Showcase
Official Group Buy Colors — Image Previews
Botanical
Snow
Sand
Stone
Prototypes
Prototype A
  • Early silicone “tab screw” isolation mount
  • JST connection
  • CNC’d acrylic top
Photos — Prototype A:
Prototype B
  • Custom silicone border gasket
  • Optional bottom-mount gasket socks
  • Hotswap socket cutouts added
  • Increased top-shell gap (double-wall glass inspiration)
  • Extra magnetic attachment point for border accent
  • Updated zen garden engraving
Photos — Prototype B:
Prototype C (Pre-Production)
  • Isolation mount removed (may return in future HHKB variant)
  • Improved silicone gasket border with proper keycap clearance
  • Elongated/optimized border standoffs
  • Custom magnetic top screws
  • Reduced number of required screw/bit types
  • Pogo pins moved to DB for easier assembly
Next Steps
💬 Join the conversation on Discord: Clever Keebs Discord
Thank you for your support — this project has been years in the making, and I'm thrilled to share it with the community.
— Clever / Clever Keebs
« Last Edit: Mon, 08 December 2025, 10:03:18 by CleverKeebs »
Re: [IC] Enso-E: split ergo HHKB with EC/MX support
« Reply #1 on: Tue, 02 September 2025, 14:25:09 »
Approval :thumb:
Offline Manukbs_
« Reply #2 on: Tue, 02 September 2025, 14:31:56 »
GIVE GIVE GIVE
Offline koolkeebs
« Reply #3 on: Tue, 02 September 2025, 18:12:50 »
Would you consider making the bottom row not exploded?
« Reply #4 on: Tue, 02 September 2025, 18:38:59 »
I once made a mock-up with Cherry MY modules with a similar gap to the bottom row, and I think that felt fine to type on, if you're (like me) are using thumbs to hold down modifiers.
There are many "ergo" rubber dome keyboards that have thicker keys on the bottom row, and I think this setup could be the best way you could emulate that without needing custom keycaps.
The height and typing angle are not for me though, as I prefer keyboards that are nearly flat. But to each their own.
« Last Edit: Tue, 02 September 2025, 18:40:47 by Findecanor »
Offline CleverKeebs
« Reply #5 on: Tue, 02 September 2025, 19:27:44 »
I replied in Discord but I'll the answer here as well :)
I tested and purposefully chose the exploded bottom row for 2 reasons:
1. Natural thumb resting position this way when your hands are slanted
2. To achieve the right curve without sacrificing design goals, the spacebar either would have to be like it is (which I wanted to do anyway because of reason 1), or the spacebars would have needed to be on slightly different Y-axis positions and not mirrored like they are
Offline mvkb
  • Designer
    • MVKB
« Reply #6 on: Wed, 03 September 2025, 03:23:20 »
This board blew me away when I saw it IRL.
Offline phoenixrage
« Reply #7 on: Wed, 03 September 2025, 12:59:06 »
Unfortunate USB placement given the limitation of the layout/design.
Otherwise, everything else is pretty cool.
Offline CleverKeebs
« Reply #8 on: Wed, 03 September 2025, 13:23:54 »
Thanks friend!
Offline CleverKeebs
« Reply #9 on: Wed, 03 September 2025, 13:26:47 »
I purposefully owned the placement instead of adding a macro column like most Alice layouts do. Making it look asymmetrical to the key layout fit the theme :D
To each their own though! Thanks for looking :)
Offline Anorexus
  • Designer
    • Anorexus Web
« Reply #10 on: Tue, 23 September 2025, 07:43:09 »
Damnnnn... so pretty
Offline CleverKeebs
« Reply #11 on: Sun, 12 October 2025, 11:56:15 »
Alexotos will be streaming Prototype B for the first time today in just a few minutes!
https://www.twitch.tv/alexotos
Offline Daesya
  • 💜 purple supremacy 💜
    • social mediass
« Reply #12 on: Sun, 12 October 2025, 18:29:45 »
me likey
Offline Tune Lab
« Reply #13 on: Wed, 15 October 2025, 03:19:59 »
YES! WE NEED MORE AND MORE EC!
Offline CleverKeebs
Re: [IC] Enso-E: split ergo HHKB with EC/MX support (GB: Dec 5)
« Reply #14 on: Sat, 08 November 2025, 15:33:51 »
New updates added!
- GB scheduled for December 5
- Updated vendor list: Omnitype, Oblotsky, Prototypist, KBDFans, and Deskhero with more potential regions coming soon.
- Updated colorways
Offline Xury46
« Reply #15 on: Sat, 08 November 2025, 19:44:21 »
I don't see Chaos on the list of updated colorways :confused:
Offline CleverKeebs
« Reply #16 on: Mon, 10 November 2025, 03:16:50 »
That's correct. We have plans for a special run of the Chaos theme next year that will feature a custom zen garden pattern and modified weight design. That's something we wanted to do originally with this theme for this run, but it's not quite ready for primetime yet. So now it'll be it's own special edition later :)
Offline Xury46
« Reply #17 on: Mon, 10 November 2025, 09:16:52 »
Sounds good, that works for me. Gives me more time to budget for the board! 🙂
Offline dom
  • allergic to hypocrisy
« Reply #18 on: Wed, 03 December 2025, 03:01:05 »
Overall, the design is interesting, but these points are bummer for me:
• Better timing for the GB (Christmas season is a tough window).
• 2.5U spacebar for the EC version.
• Special edition without limits (no need for FOMO here).
• PC top instead of acrylic.
• And honestly… no logo on top (awful). Side/back/bottom would feel much better.
Anyway, GLWGB :)
Offline CleverKeebs
Re: [IC] Enso-E: split ergo HHKB with EC/MX support (GB: Dec 8-22, 2025)
« Reply #19 on: Mon, 08 December 2025, 12:04:20 »
Group buy is live!
Offline nathanchere
« Reply #20 on: Thu, 08 January 2026, 16:57:10 »
Group buy is live!
1/ Oblotsky doesn't seem to have it? Would like to join wtihin EU if possible.
2/ Did any of the other projects finish because starting this? I saw https://geekhack.org/index.php?topic=123500.0 was supposed to deliver last year but haven't seen/heard anything more about it or found any out in the wild.
Offline nathanchere
« Reply #21 on: Thu, 08 January 2026, 17:29:03 »
