Author Topic: [IC] GMK MTNU Honeywell | $99 Base Kit?!  (Read 124244 times)
Offline Gtour
  • Just a random guy passionate about keyboards.
« on: Mon, 29 June 2026, 08:49:43 »
Interest Check Form | Discord Group
For months, I’ve been considering bringing Honeywell to MTNU, but I’d like to approach it a bit more accurately than previous GMK runs.
Long story short, the CYL runs of Honeywell used colors that differ from those used in the SA run, which are more accurate to the keyboard the set is inspired by. Most notably, the red used for the accents and the alpha legends, which are gray instead of black. Also, the F-row wasn't fully modifier-colored.
Sources:
Original Honeywell keyboard - 1
Original Honeywell keyboard - 2
https://matrixzj.github.io/docs/sa-keycaps/Honeywell/
https://matrixzj.github.io/docs/gmk-keycaps/Honeywell-Co/
https://matrixzj.github.io/docs/gmk-keycaps/Honeywell/
Kitting Renders
Base Kit - Price TBD (targeting ~$99)
Extension Kit - Price TBD
Kitting & Colors Explained
No Numpad?
As many of you may already know, the keyboard that inspired the set features a black numpad (essentially WoB colors).
The idea would be to use standard GMK XW1 and XS1 for two reasons:
First, the white and black used in the SA run (WFK and NN) are effectively equivalent to XW1 and XS1. More importantly, keeping these colors standard would allow users to pair the set with an existing MTNU WoB numpad if they choose to do so.
The other two colors would be standard GMK X2B and XRO3 (RAS, used in the SA run, is a very similar color — making XRO3 a better choice than XP3).
GMK MTNU Stock Colors
The set would also feature two new legend molds inspired by the red accent keys found on the original Honeywell keyboard:
CLEAR RESET — R1 2.00U Backspace
TRANSMIT — R3 2.25U Enter
Why no accented R1 1.00U "BREAK" key?
Simply put, based on my testing, the legend wouldn't fit on a 1.00U keycap. For that reason, I opted to include an accented ''ANY KEY'' instead.
Is the kitting shown final?
Most likely, yes. The goal is to keep the Base Kit as affordable as possible (ideally around $99 for a group buy run).
40s support was excluded on purpose because most of the main appeals of this set wouldn't apply there.
Keyboard Renders
Packaging Design
Not necessarily the final design, but I wanted to take inspiration from the simple packaging design Honeywell uses for some of its products.
The intent wasn't to copy Honeywell's logo, but rather to use a similar Adobe font, Acme Gothic Wide Bold.
I want to thank GMK, Matt3o and all the wonderful people in my Discord group <3
« Last Edit: Wed, 01 July 2026, 11:25:01 by Gtour »
Offline Gtour
Re: [IC] GMK MTNU Honeywell | $99 Base Kit?!
« Reply #1 on: Mon, 29 June 2026, 08:50:17 »
[July 13th 2026]
I'm exploring the idea of offering two Base Kits: a TKL Base Kit targeting around $99, and a Grand Base Kit targeting around $150, without any child kits.
The kits are not 100% final yet, so if you'd like me to add specific keys, make sure to fill out the IC form.
The more requests a key gets, the more likely it is to be added.
Based on the early feedback I've received, these are the missing keys that currently make the most sense to add:
- Accented ISO Enter (Enter legend) | High priority
- Two 3.00u 3-stem spacebars | Medium priority
- A second 2.25u shift | Low priority
If you can’t view Imgur images, check out the renders on my portfolio:
https://gtour.myportfolio.com/gmk-mtnu-honeywell
I'm looking for vendors!
Feel free to send me a DM on Discord (g_tour).
FAQ:
Will there be an International Kit?
I'm open to offer an International Kit through GMK directly. I'll try to include ANSI-NorDEUK support, but no promises as the legend molds haven't been made yet afaik.
« Last Edit: Mon, 13 July 2026, 07:52:58 by Gtour »
Offline Kokaloo
  • 🤘(• ω •)🤙
« Reply #2 on: Mon, 29 June 2026, 09:22:12 »
the only difference between neutering mtnu and DCS base kits for a reasonable price is people actually want DCS
Offline Gtour
« Reply #3 on: Mon, 29 June 2026, 09:54:29 »
I was waiting for your comment, thanks for bringing a smile to my face with your memes ;D
Well, at least GMK has a spherical profile that is somewhat relevant, compared to SP SA omegalul
Offline spikedsynapse
« Reply #4 on: Mon, 29 June 2026, 09:57:21 »
I would have considered getting this if it were a real basekit, but that is just too little compatibility.
Offline Gtour
« Reply #5 on: Mon, 29 June 2026, 10:00:53 »
What compatibility are you talking about exactly? Apart from the numpad and 40s, which would stay out for the reasons I explained in the thread.
I’d love to hear if there are any missing keys that are actually wanted by a decent number of people.
Feel free to fill out the IC form if you’ve got a couple of minutes ;)
Offline Punkypj
« Reply #6 on: Mon, 29 June 2026, 10:01:11 »
So I see the note about “why no accented iso” but also, my main feedback would be to add the accented iso  ;D I can’t see that killing the cost.
Also would be down for the int kit.
Will you be posting this on GMK discord IC channel? I can’t even see these pics as Imgur won’t load in uk, but managed to find an image on discord.
Offline Gtour
« Reply #7 on: Mon, 29 June 2026, 10:07:36 »
Sorry about that, I’ve edited the first comment with a link to my portfolio site if you want to check out the renders there.
Noted about the accented ISO Enter :)
« Reply #8 on: Mon, 29 June 2026, 10:38:12 »
Do you already have vendors in mind?
Offline Gtour
« Reply #9 on: Mon, 29 June 2026, 10:49:50 »
We already have something cooking behind the scenes, and I’m pleasantly surprised by the interest it’s gotten in such a short time.
That said, I’d prefer to wait until I have more precise information on vendors and a confirmed GB date before making any announcement :)
Offline tanghus
  • BEIGE GUD
« Reply #10 on: Mon, 29 June 2026, 14:00:39 »
If the concern is actually getting closer to a true Honeywell, I would recommend; stop ****ing around and commit to colour matching to an actual keyboard, rather than a previous SA run with who knows which of the keys will actually match. If they ever did at all. As shown in your example pictures, most Honeywell terminal boards aren't using the same white across alphas and modifier legends - It is quite noticeable on the real thing.
Lastly, slashing the numpad seems like a half baked idea considering MTNU WoB numpads are only a feature in full base kits - which are incidently out of stock at most vendors, GMK themselves included.
Actually, scrap that, I just noticed... $99 for this base kit?! Jesus.
« Last Edit: Mon, 29 June 2026, 14:31:39 by tanghus »
Offline DirtyGingy
« Reply #11 on: Mon, 29 June 2026, 14:19:49 »
Honeywell good.
Though, I hope the red is closer to the red from the SP runs.
Offline Fraaaan
« Reply #12 on: Mon, 29 June 2026, 14:30:42 »
>$99 base kit
>look inside
>ANSI TKL
Offline Gtour
« Reply #13 on: Mon, 29 June 2026, 14:42:40 »
The point wasn't to color-match to a previous SA run at all. I was simply explaining, with sources, why whoever designed the SA run (which used stock SP colors) made color choices that were closer to the actual Honeywell keyboard than whoever designed the previous GMK runs.
I highly doubt the white is actually different, it's most likely just a matter of lighting and/or yellowing. Imagine color-matching the LEGENDS of a 40 to 50 year-old keyboard. Unless you have a pristine unit, the color matching is inevitably going to be off.
The fact that MTNU WoB Base Kits are currently out of stock means that hundreds, if not thousands, of units are already in the hands of what I'd guess is at least 80% of the people buying $100+ plastic. And I'm sure they'll eventually be restocked. If you don't own an MTNU WoB set, it's highly unlikely you're much of an MTNU fan to begin with.
I'm not opposed to offering a separate Numpad Kit, though. The problem is that we already know it wouldn't reach MOQ on its own and would most likely have to be saved by vendors. I see people asking for numpads all the time, but the reality is that sales data consistently shows most buyers simply don't care for it.
« Last Edit: Mon, 29 June 2026, 14:45:17 by Gtour »
Offline Gtour
« Reply #14 on: Mon, 29 June 2026, 14:59:42 »
>$99 base kit
>look inside
>ANSI TKL
The problem with most people is that, as we say in Italy, they want to have the full barrel and a drunk wife.
A $99 TKL Base Kit has too little compatibility, while a $135–150 'Grand' Base Kit is often considered too expensive. What exactly do you expect?
All of this while also having little to no understanding of MOQ tiers. When you occasionally see a set with slightly broader kitting than usual while also being a bit cheaper than average, it's generally because the starting MOQ used for pricing is higher than what most sets begin with.
Offline tanghus
  • BEIGE GUD
« Reply #15 on: Mon, 29 June 2026, 15:52:03 »
Colourmatching to existing Honeywell terminal boards is decently feasible, the keys are overall _very_ UV-stable. Below is a pristine unit, showing the off-white legends. And a yellowed unit for comparison. Does this account for all units? No. As for the rest of your comment, yes the source matters.
Cost cutting your set to the bone to tell someone to buy a product 1.5x the price is a bad sell - You should absolutely consider offering a numpad.
>$99 base kit
>look inside
>ANSI TKL
The problem with most designers, as we say here in Denmark, is that they're full of ****.
You can absolutely subsidise a kit completely into oblivion, where actually having meaningful support ends up being more costly compared to a standard base kit, chasing away customers. Turning your argument of MOQ tiers upside down, actually doing streamlined support in the base kit with physical support and then moving specialised kits into as few extension kits as possible is absolutely the way to go for any base kit to be successful.
99 USD for this base kit is not a good deal, and for any ISO user this is an atrocious deal. Not only is the base kit not 99 USD for them - It's going to be substantially more expensive and still yield them 0 accents. ISO support is key physical support, it should not be subsidised. Your extension kit is forcing Alice-users to pay for HHKB-support, HHKB-users to pay for ISO support, and the ISO-users skipping this buy, because why the **** should they pay for HHKB and Alice-support when they only get barebones support out of it.
Your current kitting is bad, but it's not like the whole thing is salvageable. Here's what I would expect from a decent base kit:
Put ISO back into the base, and if you want accents, add ISO accent.
Add alpha tilde and pipe to the base.
Do a proper extension kit and keep the rest there, and add the rest of the split bars.
Move F13, heck I'd discuss moving the "MTNU R2 Up"-meme from the base there as well, and you can consider adding decent 40s support to that to bring in more people to buy your base kit.
If you're committed to splitting the numpad, omit R1 End and Pg Dn and save those for a numpad kit, where you can do split 0 and Equal sign. With adequate accents. But again, there's strength in numbers, and
If you can't do that base kit for 99 USD at that point, what's the ****ing point of splitting the numpad in the first place then.
« Last Edit: Mon, 29 June 2026, 16:08:14 by tanghus »
Offline Gtour
« Reply #16 on: Mon, 29 June 2026, 16:30:23 »
Colourmatching to existing Honeywell terminal boards is decently feasible, the keys are overall _very_ UV-stable. Below is a pristine unit, showing the off-white legends. And a yellowed unit for comparison. Does this account for all units? As for the rest of your comment, yes the source matters.
>$99 base kit
>look inside
>ANSI TKL
Do a proper extension kit and keep the rest there.
This will likely be my last reply, as I'm not interested in playing this yapping game.
You're not talking to someone designing their first set. I know exactly what I'm talking about and why I made the decisions I made. Saying "MTNU R2-up meme" just shows a lack of understanding of what most MTNU buyers (buyers, not yappers) actually want and why they like the profile. Feedback is always welcome, but not with that attitude.
The kitting I'm using here is almost an exact copy of Geon's recent kitting. You absolutely don't need a traditional all-in-one Base Kit for a set to be successful, what you're saying is simply incorrect. With this approach, people who only want a limited TKL Base Kit (the vast majority of buyers) spend significantly less money, around 35–50% less. The people who also need the Extension Kit end up paying only slightly more than they would have if those keys were included in the Base Kit. Exactly how much more depends on the starting MOQ tiers of each kit, we simply don't know yet.
This isn't the type of kitting I'd normally do, but I wanted to experiment with it on this set because of the WoB numpad concept.
Also, show me a recent GMK set with the numpad included in the Base Kit that sold for $99. I'll wait.
And if you, or anyone else, wants to run a Honeywell set color-matched to a pristine Honeywell keyboard (assuming we can even agree on what "pristine" means), go for it.
Offline tanghus
  • BEIGE GUD
« Reply #17 on: Mon, 29 June 2026, 16:46:08 »
>$99 base kit
>look inside
>ANSI TKL
Then I shall say the same: This will likely be my last reply because you're clearly not interested in feedback.
Just because it's a copy of Geon's recent kitting, doesn't change my view. Extensive slashing of support in kits like these are harming the hobby, and is essentially leaving money on the table from users
As for your motivations for a kit expanding an existing kit; Sure, that's is great, that's done multiple times in the past and I regard that as a good thing. But if your kit is banking on something that's not generally available currently, how good a selling point is that?
Lastly, I would just like to be perfectly clear here: I am not asking for a 99 USD base kit with a numpad here. Cutting the numpad from the base kit is not a 1-1 price reduction of the base kit which led me to ask the question that if you have to cut this much support, and thus people in the hobby out, to reach 99 USD for this base kit, what is the point versus offering a more classic base kit at a better overall cost.
The whole colour matching thing I'm frankly not going to dig further into.
Offline masje
  • Your neighborhood keyboard designer.
    • masjewerke
« Reply #18 on: Mon, 29 June 2026, 22:27:51 »
Hype! Hoping for Novelkeys for US vendor  :thumb:
Offline lilfat3
« Reply #19 on: Tue, 30 June 2026, 00:00:51 »
Are all these complaints on kitting serious? It's like we got all full size and alice users around the entire world here in this post. Come on, we all know this hobby revolves around TKLs and 60s (and maybe also 65s). Adding ISO accents then this base kit is decent enough. This will definitely be my first mtnu set if it really happens. GLWIC!
« Last Edit: Tue, 30 June 2026, 04:18:30 by lilfat3 »
Offline newzealot
« Reply #20 on: Tue, 30 June 2026, 00:58:25 »
As a newbie to the hobby that started 3 months ago, i always wonder why the base kits do not consist of only the standard TKL.
Meaning a rectangle from the Esc key to the right arrow keys. All the other keys below that and the F13 key should be moved out to another kit.
If you want to have the unique red backspace and any key, why not just incorporate them into the base kit directly instead?
That would totally make sense if your aim is to have the lowest cost MNTU base kit. It might even hit $79 base kit that way.
In fact, why not take that idea further and do without the 6.25U spacebar row. I would be interested to know the weightage of 6.25U users versus 7U users. Are they equally split? Or only 10% of users are 7U users?
Offline Gtour
« Reply #21 on: Tue, 30 June 2026, 01:58:24 »
I would be more than happy to have NK as the US vendor. They're a fantastic vendor for both customers and designers, and the main reason MTNU is still being run consistently today.
Offline Gtour
« Reply #22 on: Tue, 30 June 2026, 02:18:40 »
Are all these complaints on kitting serious? It's like we got all full size and alice users around the entire world here in this post. Come on, we all know this hobby revolves around TKLs and 60s (and maybe also 65s). Adding ISO accents then this base kit is descent enough. This will definitely be my first mtnu set if it really happens. GLWIC!
They're mostly made by vocal people who more or less belong to the same group. But we've got thick skin here, and we're happy to respond in kind.
The IC form currently shows that around 70% of people (and considering it was likely brigaded by some of these vocal people, the real percentage would probably be even higher) prefer a simple TKL Base Kit.
The overall kitting philosophy will most likely remain the same, but that doesn't mean I'm not listening to feedback that actually makes sense (rather than yapping from people who probably wouldn't buy the set anyway).
As I already mentioned in Matt3o's Discord server, the only additions I currently see worth making to the Extension Kit are:
- A second 2.25u Shift
The Base Kit will remain unchanged in order to stay around the ~$99 price point.
That's exactly the approach I wanted to try with this set. The ~$99 range I mentioned is just indicative and can slightly change based on the starting MOQ the kits are going to priced to.
As for the 6.25U bottom-row: I also was questioning if 6.25U bottom-row is better to include in a limited TKL Base Kit than let's say an HHKB one. After talking with vendors who actually know what they are talking about from experience (not random yappers on the internet who can't control their mouth), 80% of buyers actually use a 6.25U bottom-row. We just don't see them much around on socials so that gives the illusion they are much less of a group of people than they actually are.
Thanks to both of you for commenting with good intention.
Offline tactilesbad
« Reply #23 on: Tue, 30 June 2026, 03:01:20 »
this is peak
peak designer hybris
Offline bluntkrayon
« Reply #24 on: Tue, 30 June 2026, 03:07:00 »
What would be amazing is if GMK shared the MOQ across variants of basekits that work for the regions involved. Some regions are ISO vs ANSI. Some are 6.25u vs 7u. I would never use ISO in my case, but still pay for it, to get the base kit.
I’m more than happy to pay for extension kits, for more niche layouts like HHKB and Alice. Also okay with a numpad child kit. And accent kits.
I think that would be a better outcome for a customer perspective. Probably a nightmare for SKUs though lol.
Offline Gtour
« Reply #25 on: Tue, 30 June 2026, 08:02:29 »
this is peak
Lmao. Coming from you, whose only purpose on this forum seems to be making cheap jokes and taking out your frustration on whoever happens to be around, I'll take that as a badge of honor.
I think I'll frame it and hang it on my wall.
Exactly. From a vendor's perspective, it's usually not worth splitting the Numpad from the Base Kit for GMK runs. It has been experimented with over the past few years on a handful of sets, and it worked better for some than for others depending on the colorway. The main issue is that if the Base Kit sells out, vendors are often left with dead stock of Numpad Kits, which usually translates into lost money.
Again, this isn't how I would normally kit a set. This was an experiment on my part because I firmly believe that most potential buyers and MTNU fans already have an MTNU WoB set lying around, and a large portion of those who don't simply aren't interested in a numpad.
It would be great to have accurate statistics, but based on my understanding and conversations with vendors, 6.25u bottom rows are used far more than people think, and a significant portion of European buyers have transitioned to ANSI (myself included). Of course, it's still important to offer ISO support and an International Kit for that niche of buyers.
« Last Edit: Tue, 30 June 2026, 08:04:28 by Gtour »
Offline Kokaloo
  • 🤘(• ω •)🤙
« Reply #26 on: Tue, 30 June 2026, 11:17:06 »
just imagine how much more insufferable i would be if i was European, this website is so lucky
Offline masje
    • masjewerke
« Reply #27 on: Tue, 30 June 2026, 11:26:07 »
Strongly agree, GLWIC!
Offline mikademus
« Reply #28 on: Tue, 30 June 2026, 14:21:05 »
So I am a full-size and Alice user. I also haven't been able to get hold of a WoB numpad and had to settle for TKL sets until they restock. GMK moves slowly. I have also been waiting for a BoW set for ages. So here's my feedback and my wishes:
* Provide a (separate?) numpad. If you provide both a BoW and a WoB (or your Honeywell white) I'll order both.
* Provide an expansion set of BoW modifiers in the same colours as the alphas. Then your kit will work as the effective and sorely missing BoW until GMK makes an official one.
I love to have these classic colourways and am looking forward to the IC and GB. So here's my gratitude for putting in the effort.
A note on pricing: the reason I missed out on the WoB numpad is because of low cashflow preventing purchasing any sets at all (more on this below) and when having landed again, there simple weren't any to get. The point here is that $99 or $159 (or whatever) isn't the consideration that makes me buy or fly. This is already an expensive enough hobby that price sensitive buyers can't cross over the threshold, and us MTNU buyers aren't put off by a few tens of dollars. So it is my feeling that optimising for price is probably focusing on a lesser (though still relevant) variable.
Offline Gtour
« Reply #29 on: Tue, 30 June 2026, 15:14:07 »
We are so lucky
Thanks masje :)
Appreciate the detailed feedback.
Yes, a potential BoW set would use the same stock colors I'm using for the alpha keys here (XS1 on XW1).
Separate Numpad Kits and a BoW Modifier Kit are definitely interesting ideas, and I have no reason to say no to either. Realistically though, they're unlikely to reach MOQ organically, which is why vendors generally prefer the all-in-one Base Kit approach for most sets (with the exception of kits sold directly by GMK and a few extremely popular colorways).
I also partially agree that GMK, especially, has such a high barrier to entry that a $30–50 difference (from a $99 TKL Base Kit to a $130–150 "Grand" Base Kit) is unlikely to make a significant difference for most people already interested in the CYL and/or MTNU profile.
That said, MTNU is more expensive than CYL. We've already seen all-in-one MTNU Base Kits with compromises in kitting and/or accents/novelties that still cost more than their CYL counterparts. I recently saw a TKL Base Kit (with more inclusive kitting than mine, and I suspect it was priced around the lowest starting MOQ) selling for a whopping $160. All of this makes it even harder for new people to give the profile a try.
I think MTNU Honeywell, with a ~$99 Base Kit and a classic colorway, has the potential to appeal both to existing MTNU fans and to people who have yet to try the profile. It's basically a win-win situation that will hopefully make the profile at least a little more popular than it is today.
I'm sure GMK will restock the MTNU WoB Grand Base Kit in the coming months. If we could somehow convince them to offer separate Numpad Kits for classic colorways like Beige and WoB, that would be even better.
« Last Edit: Tue, 30 June 2026, 15:16:40 by Gtour »
Offline mr_foggy
  • neue = nope
« Reply #30 on: Wed, 01 July 2026, 04:54:36 »
Ehhh mtnu is... not my thing.
Still holding out hope for a proper SA rerun though - given geon's recent OCO reruns.
Offline Gtour
« Reply #31 on: Wed, 01 July 2026, 06:53:09 »
Totally understandable.
Having different keycap profiles and different designers' takes on kitting, colors, and design choices for classic sets over the years is part of what makes this hobby so enjoyable to me ;D
Offline Gtour
« Reply #32 on: Wed, 01 July 2026, 07:25:35 »
Small off-topic note that might interest some of you, since it came up in the comments:
As if on cue, the MTNU WoB Grand Base Kit has just come back in stock :thumb:
Offline tavapataor
« Reply #33 on: Wed, 01 July 2026, 13:18:34 »
As if on cue
I had the same thought. Maybe I need to design a kit that takes advantage of the WoB color modifiers lol.
Offline FansForFlorida
« Reply #34 on: Wed, 01 July 2026, 15:10:02 »
I would like a 2u spacebar in the extension kit.
Offline mikademus
« Reply #35 on: Wed, 01 July 2026, 15:22:06 »
But WFT GMK! I ordered the TKL set ONE WEEK ago after you refused to reply to my inquiries about when the grand set it would be restocked. GMK, you are a like a very troublesome child: I love you, but I really want to kill you with fire, too, and the latter more than the former.
Offline mikademus
« Reply #36 on: Wed, 01 July 2026, 15:27:03 »
Over at r/MechanicalKeyboards, a discussion suggested a MTNU 8010 set. When looking into it, 8010 seems like the Honeywell set with steel blue modifiers. If so, that could be an interesting extension set. That would be a very delicious set: MTNU Honeywell 8010.
Long link to r/MK:
https://www.reddit.com/r/MechanicalKeyboards/comments/1ukw2pg/comment/ouz8vwz/?utm_source=share&utm_medium=web3x&utm_name=web3xcss&utm_term=1&utm_content=share_button
Offline Gtour
« Reply #37 on: Wed, 01 July 2026, 15:50:47 »
Sorry to hear that. Hopefully they'll decide to offer separate MTNU Beige and WoB Numpad Kits in the future :blank:
As if on cue
It's a bit more difficult with modifiers, but if you can come up with something cool, why not?
Long link to r/MK:
I think they're talking about porting SA 8010 (https://matrixzj.github.io/docs/sa-keycaps/8010/) to MTNU. It's a cool colorway, but it's much harder to do because of the large number of new legend molds it would require. It would need strong vendor support to keep the price from becoming insanely high. Maybe in the future, who knows.
Edit: And no, GMK currently can't do UV printing or special effects on MTNU.
Now this is the kind of kitting feedback I like. You noticed the absence of the 2u spacebar.
So let me ask: which non-40% layout actually requires a 2u spacebar? The few 7u split spacebar layouts I've seen use a 3–1–3 split (rather than 2.25u + 2u + 2.75u), and every 60–65% Alice board I've come across over the years supports 2.25u and 2.75u.
I'm sure there are a handful of boards that support a 2u spacebar, but I don't know if it makes much sense to include it here when the goal is to cover only the essentials. Even Geon excluded it from his recent kitting.
I'm curious though, how would you use it?
« Last Edit: Wed, 01 July 2026, 16:02:09 by Gtour »
Offline mikademus
« Reply #38 on: Wed, 01 July 2026, 16:31:36 »
Yeah, true, I was thinking only in terms of colourways, but that's only part of the kitting for vintage systems. Point taken.
Offline schizobovine
« Reply #39 on: Wed, 01 July 2026, 16:42:52 »
Definitely would be "all-in" on this, as MTNU is by far my favorite profile and we need more of it. Thanks for doing this!
Offline tavapataor
« Reply #40 on: Wed, 01 July 2026, 19:55:45 »
Does Preonic count? Apparently there might be another version in the works?
« Reply #41 on: Wed, 01 July 2026, 22:26:48 »
I use a Keebio FoldKB. It is a split ortholinear keyboard that uses a standard keycap set. It has a 2u spacebar on the left side and a 2.75u spacebar on the right side.
I currently have DSS Honeywell on a FoldKB, and it included DSA profile split spacebars, which are useless to me. (They are concave and dig into the side of my thumb.) Fortunately, I was able to find white G20 keycaps that match the white alphas almost exactly.
If MTNU Honeywell does not include a 2u spacebar in the Extension Kit, then it is a nonstarter for me.
Offline newzealot
« Reply #42 on: Wed, 01 July 2026, 23:58:01 »
The BoW Modifier Kit is an extremely interesting idea. Given that the BoW colorway is the best selling keycaps of all time, and the lack of MTNU BoW, i believe there will be lots of people actually buying both base and BoW mod kit. Especially if you eliminate even more keys in base kit to make it such that buying both kits could result in being even cheaper than if GMK itself suddenly release a BoW.
The new Agar Micro uses a 2U with a 2.25U. Agar Mini uses two 3Us. The 40s route is a giant scope creep that is incompatible with your stated goal of low prices. Even the SA A History of Violets, the most compatible kit for SA, become less compatible in their MTNU IC.
As a newbie with 0 MTNU sets, the $30 to $50 difference will tempt me more, but not an instant buy. A $50 to $70 difference though, would be an instant buy. A great example will be the recent GMK British Racing Green (BRG) Round 3 selling for USD$79. It has even lesser keys in base kit than yours, and i bought it instantly.
Offline Gtour
« Reply #43 on: Thu, 02 July 2026, 01:29:53 »
Sure, there are some extremely niche boards that support a 2u spacebar. But considering the design philosophy behind this set, does it really make sense to include it when some arguably more important keys are being left out? I don't think so.
There are already plenty of other sets that support it, so I don't really see it as a first-world problem.
That said, I'll keep it in mind and decide whether it's worth including based on the IC form responses (so please fill it out if you'd like to increase the chances of it happening).
$79 will be close to impossible, for a few reasons:
- As you said, the kitting here is a bit more inclusive than British Racing Green R3, and I'm not going to reduce it any further. In my opinion, it wouldn't make much sense to remove non-accent keys, modifier-colored Pipe and Tilde, R2-Up, or the 65%/75% column.
- MTNU is more expensive for GMK to produce than CYL.
- This set also introduces two new legend molds, which have to be factored into the kit price.
- An important factor that people often overlook is the starting MOQ. That's one of the reasons Geon (and some other vendors) can drastically reduce prices. We don't know what the starting MOQ will be for this set yet.
BoW (Black on White) is definitely not the best-selling set of all time. At most, I'd say it's third or fourth, with WoB (White on Black), Beige, and possibly Dolch ahead of it. That's essentially why we haven't seen a vendor, or GMK themselves, propose an MTNU BoW yet.
The Agar Micro and some other 40% boards do support a 2u spacebar, but as I said, if I'm not going to add support for other 40% legend-accurate keys (and the Micro is even more complicated since it also uses a 2u Left Shift and a 1.5u R3 Tab), then adding just the 2u spacebar doesn't make much sense.
Thank you guys for commenting :)
« Last Edit: Thu, 02 July 2026, 05:55:23 by Gtour »
Offline Fede_Feo
« Reply #44 on: Thu, 02 July 2026, 04:01:13 »
Nice to see more MTNU options lately.
Will there be any novelties?
Offline Gtour
« Reply #45 on: Thu, 02 July 2026, 04:27:35 »
I don’t think it makes sense to include any novelties (since new legend/novelty molds increase the kit price) other than the two new legend molds inspired by the red accent keys on the original Honeywell keyboard.
Are there any specific novelties you’d like to see?
Offline Kokaloo
  • 🤘(• ω •)🤙
« Reply #46 on: Thu, 02 July 2026, 10:42:51 »
since you're so plugged in with geon can you convince him to run dsa sets it's widdawawwy the best uniform profile
Offline tavapataor
« Reply #47 on: Thu, 02 July 2026, 12:50:38 »
…does it really make sense to include it when some arguably more important keys are being left out? I don't think so.
I agree with you, fwiw. Just trying the think through what the outside example might be.
« Last Edit: Thu, 02 July 2026, 12:55:12 by tavapataor »
Offline mikademus
« Reply #48 on: Thu, 02 July 2026, 13:43:08 »
Third or fourth is a pretty good position, though. So I believe popularity or viability or financial sense is not on the plate when GMK decides which sets to go with since they instead just self-produced Jukebox, a garish hellscape of eggshell and mint that won't match almost any keyboard and looks more like a sad meme joke. I might miss something here--I *must* be missing something here!--but I can't fathom why they'd do that instead of a BoW. Not to mention that some pastel nightmare called Papaya or something is being GB:d or produced.
« Last Edit: Thu, 02 July 2026, 13:45:07 by mikademus »
Offline tavapataor
« Reply #49 on: Thu, 02 July 2026, 20:51:00 »
…Jukebox, a garish hellscape of eggshell and mint that won't match almost any keyboard and looks more like a sad meme joke … Not to mention that some pastel nightmare called Papaya or something is being GB:d or produced.
Your friends must think you’re the most fun at parties!
