Author Topic: [IC] VS9009 R2 by Fusion Lab — Vintech Series No. 2 | A Modern Battleship  (Read 78266 times)
Offline cndisk6
VS9009 R2
Vintech Series No. 2 — by Fusion Lab
318178-0
Discord: https://discord.gg/xe4xKGG9HJ
Instagram: https://www.instagram.com/fusionlab_works/
Google Form: https://forms.gle/soM7ffSWoFqt4oQE8
If you have any recommendations or are interested in working with us, please email us (fusionlab.support@gmail.com) or join our Discord and send us a DM.
Hi,
We’re Fusion Lab, and we’d like to introduce VS9009 R2, the second project in our Vintech series.
Earlier this year, we made a small batch of our first 9009. Some of you may have seen photos of those builds. We were happy to bring the idea to life, but the available screen dimensions kept us from fully achieving the design we had in mind.
For R2, we’ve revisited the display, internal structure, PCB assemblies, and exterior details. This first IC introduces the revised design, and we’d love to hear your thoughts.
Where it started
CHERRY G80-9009, a keyboard built for Reuters terminals. Its large layout, extensive function keys, and distinctive LCD area gave it a character all its own.
We like how clearly it reflects the work it was designed for. The separate key clusters and built-in screen form an interface you rarely see on a keyboard today.
Many of us recognize 9009 through its familiar keycap colors: beige and grey, with muted green and pink accents. We wanted to bring back more of the keyboard behind those colors, including its proportions, layout, and screen.
318195-1
The original CHERRY G80-9009
The idea behind VS9009
Our goal is to recreate the character of the original G80-9009 as a modern custom keyboard, with an aluminum case, redesigned internals, and a usable secondary display.
We’ve paid particular attention to the broad upper section, the spacing between key clusters, and the contours along the sides. These details are a large part of what makes the original recognizable.
It’s a big keyboard, and that scale is part of its appeal.
318181-2
What’s new in R2?
R2 includes changes both inside and out:
Redesigned internals: a revised mounting assembly and case cavity.
New PCB assemblies: expanded functionality and layout support.
A larger custom display: proportions that more closely match the original screen area.
Refined exterior details: updated side profiles and case features for a more faithful appearance.
The display
The screen is a central part of VS9009.
R2 uses a custom high-resolution, 60 Hz display with multipoint capacitive touch. It works as a secondary monitor, built into the long display area above the keys.
This builds on our experience integrating keyboards and displays in Vision75, AG500, and VS06.
The keyboard, display, solenoid, and buzzer are designed to run through a single USB 2.0 data cable. The display does not need a separate HDMI cable or power cable, and the connection does not require Thunderbolt or a USB-C port with video output.
318183-3
Mounting and layout
VS9009 R2 offers two mounting options:
Top mount with a brushed stainless steel plate.
Plateless top mount for soldered builds.
Both the hot-swap and solder PCBs are 1.6 mm thick and support the same layouts. The upper 2u key positions can also accommodate two 1u keys.
The total key count is approximately 150, depending on the layout you choose.
318197-4
Supported layout options for both hot-swap and solder PCBs.
Case and manufacturing
The case is machined from 6063 aluminum using our own five-axis CNC equipment. We handle both the design and machining in-house.
Five-axis machining helps us preserve the case’s angled surfaces and continuous contours while reducing the need to divide exterior features into separate parts.
The case will have a powder-coated finish.
318186-5
Color options
Our initial color options focus on neutral tones that suit the original terminal aesthetic.
McFlurry
318203-6
Linen
318207-7
Classic Gray
318201-8
Sparkle Black
318205-9
Cream White
318199-10
Preliminary specifications
Project: Vintech Series 9009 / VS9009 R2
Designer: Fusion Lab
Case material: 6063 aluminum
Manufacturing: Five-axis CNC machining
Finish: Powder coating
Dimensions: 503.9 × 252.3 × 67.1 mm (maximum height)
Typing angle: 6°
Front height: 19.4 mm
Approximate weight: 8 kg, or approximately 15 kg with the optional internal weight
Mounting: Top mount / Plateless top mount
Plate: Brushed stainless steel
PCB options: 1.6 mm hot-swap / 1.6 mm solder
Key count: Approximately 150, depending on layout
Display: Custom high-resolution, 60 Hz display with multipoint capacitive touch
Integrated functions: Keyboard, display, solenoid, and buzzer
International GB schedule and vendors: TBA
What’s next?
For this first IC, we’re sharing the design and gathering feedback. Further updates will cover more project details, pricing, and international availability.
We’d especially like to hear:
How would you use the secondary display?
Questions and other suggestions are welcome too. Please leave a comment below.
318193-11
Through Vintech, we want to revisit the equipment that inspired us and bring it back to today’s desks with modern construction and functionality.
Thank you so much.
— Fusion Lab
« Last Edit: Sun, 27 September 2026, 06:19:50 by cndisk6 »
Offline cndisk6
Re: [IC] VS9009 R2 by Fusion Lab — Vintech Series No. 2 | A Modern Battleship
« Reply #1 on: Sat, 26 September 2026, 21:26:53 »
 :) Trying to be the first reply
Offline mikademus
« Reply #2 on: Sun, 27 September 2026, 17:04:29 »
I dunno, 15 kilos is a bit on the light side considering that I kill zombie elephants for a living. Can I get it with custom tungsten weights?
Offline cndisk6
« Reply #3 on: Sun, 27 September 2026, 20:31:52 »
Don't be worried; we have a special FULL COPPER edition, which is around 30 kilos. I hope it can at least help you get the first hit in on a zombie elephant. :cool:
Offline demonkoryu
Can't wait to see the production model available to purchase. Please send me a message when it's available!
Offline tavapataor
But that's like... almost 7 Neo80 Cus... Your scientists were so preoccupied with whether they could, they didn't stop to think if they should.
Offline quaks
why is there a windowed key on the pcb layout picture at the position of the home key and none at the scroll lock?
Same with the esc key location. There is no windowed key in the pcb layout but there is a windowed key in one of your renders
Offline cndisk6
We only planned to make aluminum cases, with no plans for copper or titanium versions. These special editions came about because one customer requested them, so you can essentially think of them as commissions.
Offline cndisk6
Thank you so much for your help!!! I will update later.
Offline NightFox99
Yes, please, great project
Offline mikademus
« Reply #10 on: Sun, 01 November 2026, 15:53:18 »
That makes me strangely happy. I'm only worried since I like to bring new keyboards sometimes to show them off. Also, can we call this the "2H Keyboard of Giant Strength + 2 (after some time)"?
Seriously, though, this is one great project, no pun intended!
Offline HungerMechanic
« Reply #11 on: Sun, 01 November 2026, 20:39:17 »
'Please call our private number for pricing details.'
