Author Topic: Is this just the way Cherry keyboards feel?  (Read 3229 times)
Offline AndrewZorn
« on: Mon, 13 December 2010, 23:12:06 »
I finally used my MX11900.  Took a while to clean it out.  Missing one of the pieces of a stabilizer... the plastic cross-point insert, so I made do.  Too bad I bought this way too long ago to do anything about it with the seller.  The way I rigged it and the key I put it on make it barely noticeable.
Anyway, this is Cherry Black, and I should hate it.  I only got this keyboard because it was cheap.
This is great.
A little tough, but overall, I can't believe it.
I'm thinking about swapping in some lighter springs or something, but all that aside, I think this might be my new daily driver.  Too bad, wallet.
I can't be in love with Cherry Black though (out of context hilarity)... it might just be the way this board is constructed.  I'm trying to ignore the excellence of the keycaps, but still feel there's something I'm missing.
I just feel like this wouldn't be the same on a Filco.  Do the Cherry-branded Blue/Brown boards feel so much different compared to the Filcos?
I don't want to unwrap my Ricercar SPOS because I know I'll hate the layout and wish I didn't un-NIB it.
Offline fssbzz
« Reply #1 on: Tue, 14 December 2010, 01:47:04 »
i always feel that their switch is kinda lighter then filco/das/ducky.
switch to switch compare like cherry blue vs filco blue. i always feel cherry blue on cherry kb are lighter. i don't know why, maybe because of the caps. or myself
Offline sixty
    • http://deskthority.net
« Reply #2 on: Tue, 14 December 2010, 02:15:11 »
Black switches are awesome. All those wussies that claim otherwise are just not manly enough to handle these awesome switches. Blacks have been my favorite switches for a while now.
So you should not be surprised if you like them, they are a good switch if you give them some time. Like a good horse they need to be ridden in at first... or something.
Offline msiegel
« Reply #3 on: Tue, 14 December 2010, 02:18:32 »
are you guys bottoming out on those blacks?
Offline godly_music
« Reply #4 on: Tue, 14 December 2010, 03:24:08 »
I don't think it's just your problem. Trying not to bottom out with no tactile feedback at all seems tedious, and I challenge anyone to type this way for a length of time without missing keystrokes.
The springs are too stiff to bottom out hard anyways, so it's still quiet. Probably a bit worse on a platemounted keyboard.
Offline Zen
« Reply #5 on: Tue, 14 December 2010, 05:11:38 »
Quote from: msiegel;262700
Of course, otherwise the type-bar won't hit the paper hard enough
and you get blurry characters with bad contrast  ! ...
Offline turbocharged
« Reply #6 on: Tue, 14 December 2010, 08:46:31 »
Quote from: Julle;262712
^That's why I'd love to try out Clear switches. I just can't seem to find a modern keyboard with those switches, especially plate-mounted and with an ISO layout.
Deck Legend Tactile boards use Cherry Clear switches that are plate-mounted.
But I agree about the cherry blacks....I absolutely love them....just butter smooth. Even typing on them feels natural now.
| Deck Legend Fire (MX Blacks) | KBC Poker X (MX Reds) | Cherry G80-11900LTMUS (MX Clears) |  Cherry G80-11900HRMUS (MX "Ghetto Reds")
| IBM Model M 1391401 (BS) | Goldtouch GTC-0033 Keypad (MX Browns) |
[SIGPIC][/SIGPIC]
Offline elbowglue
« Reply #7 on: Tue, 14 December 2010, 08:58:52 »
Quote from: AndrewZorn;262674
Filcos feel similar, main difference is when you bottom out you're not hitting PCB you're hitting plate, which jars the fingers a bit and dosen't sound or feel as nice.  The think is with the ricercar SPOS it actually feels significantly nicer than the usual out of box MX11800.  My main gripe with the layout was the tilda key and I had to remap with autohotkey.  If you liked the MX11800 you'll probably love the feel of the ricercar spos..
My keyboards: Filco Cherry Blue Tenkeyless(daily home), Compaq MX11800 (modded to blacks), Compaq "MX 84u",  Wellington\'s Dampened Endurapro, Pinkalicious Filco Blue Cherry, Chicony KB-5191, Chicony KB-5181, Desko MOS 5023 UP "elbowglue" spos (modded to blues), Siig Minitouch (monterey blue), SMK-88 (blue cherries), Ricercar SPOS
Smallest to biggest keyboards in inches (Length X Height) - Length is most important for a midline mouse position
KBC Poker: 11.6 x 3.9 - HHKB: 11.6 x 4.3 - Siig Minitouch (Geekhack Space Saver): 11.6 x 6 - Deck/Tg3 82: 12 x 6 - Noppoo Choc Mini 12.4 x 5.3 - Compaq "MX 84u": 13.1 x 7.5 - Filco Tenkeyless: 14 x 5.3 - Cherry "ricercar spos" G86-62410EUAGSA: 14 x 7.75 - Topre Realforce 86u: 14.4 x 6.65 - Desko "elbowglue spos" MOS 5023 UP: 14.5 x 8.4 - IBM Model M Spacesaver: 15.3 x 7 - G80-1800: 15.9 x 7.1 - Adesso MKB-125B: 16 x 7.3 - Compaq Mx11800, Cherry G80-11900: 16.25 x 7.5 - Filco Standard: 17.3 x 5.4 - Unicomp Endurapro: 17.9 x 7.1 - Adesso MKB-135B: 18.3 x 6.0 - Cherry G80-3000: 18.5 x 7.6 - IBM Model M, Unicomp Customizer: 19.3 x 8.27
Offline 8_INCH_FLOPPY
« Reply #8 on: Tue, 14 December 2010, 14:21:04 »
If you need to replace that stabilizer, I have some extras.
Notable Switches I have tried:
black cherry, blue cherry, brown cherry, clear cherry, cherry M84, white alps, black alps, cream alps, Monterey blue alps, Fujitsu Peerless, Gateway2000 rubber dome, Keytronic rubber dome, Model M buckling spring, Model F buckling spring, futaba, black space invader
HAPPY HUNTING
Offline ricercar
  • mostly abides
« Reply #9 on: Tue, 14 December 2010, 14:38:07 »
Is there a utility to make a click from the speaker when you press a key? The optional click on my Kinesis Contour taught me not to bottom out the Cherry browns. I'd love a similar experience for my Cherry black 1190x.
I, too, can help with an extra stabilizer or stabilizer wire.
Offline AndrewZorn
« Reply #10 on: Tue, 14 December 2010, 14:58:40 »
I'd hate to bother someone with the postage to mail one small piece of plastic.  But I appreciate the concern and will think about bothering anyway.  I guess the PayPal fees wouldn't be too high on sending 40 cents.
Offline itlnstln
« Reply #11 on: Tue, 14 December 2010, 14:58:40 »
Quote from: ricercar;263035
If you go way back in the Sounds forum, you can find one of Welly's earliest posts about a program like this.  Moreover, I think there are some .wav files there to customize the clicking sound.
