Author Topic: [GB] Double shot replacements ROUND FOUR! - SHIPPING!  (Read 1442095 times)
Offline grasshopper
[taking orders!] Double shot replacements ROUND FOUR!
« Reply #1150 on: Sat, 29 October 2011, 05:37:09 »
Quote from: 7bit;441668
It seems the only way out of this is to get a MODIKIER kit.
ie one of:
ROUND3/MODIFIER
RETRO/MODIFIER
NOIR/MODIFIER
DARK/MODIFIER
DARK/MODIFIER/ORANGE
Hmm. But that means I would have to buy a huge number of keys that I'm never going to use. And it still doesn't really work. For example, the kit includes only one single unit Windows key. I suppose you could use WIN for one Windows key and SUPER for the other. But ideally I'd like them to match (given a choice I'd use SUPER for both). Also, there's no single unit ALT GR which is needed on UK keyboards (incidentally this key is also missing from the UK kit). And I'm still not 100% sure about which space bar to order either.
Given all the issues that I've highlighted, I think it might be better if you went back to offering a separate add-on kit for G80-1800 keyboards.
Offline 7bit
  • MX1A-G1DW
« Reply #1151 on: Sat, 29 October 2011, 06:03:14 »
Quote from: Mackem;441698
Since the kit I wanted probably won't be put in due to lower demand (Blanco or whatever it was called), what would I need to order to get:
Black keys with white font (Centered if possible)
Red 'Esc' key (White font if poss.)
RGB keys (Ctrl, Alt, Shift)
Red WASD keys (Again, white font if possible)
Also, I want the keys to be UK ISO layout for a Filco Majestouch.
Write a message to 7bit_r4:
ROUND3/STANDARD
ROUND3/SPACE
ROUND3/RGB
ROUND3/GAMER
ROUND3/UK
EMAIL your email address
Quote from: grasshopper;441704
Right, you need 2 of these Modifier kits.
Can you please make a list of any key you need to be included?
Buy key caps here: Round 5
Buy switches here: CherryMX
Offline grasshopper
« Reply #1152 on: Sat, 29 October 2011, 07:13:25 »
Quote from: 7bit;441705
This is where it starts to get complicated. I think as a bare minumum I'd need the following keys (all single unit for row 4):
CONTROL *2
SUPER *2
META
ALT
ALT GR
Ideally I'd also like the ability to swap the CAPS LOCK and CTRL keys. So I'd also need a 1 unit wide CAPS LOCK key. As far as I can tell the standard G80-1800 CAPS LOCK key is the same width as the one on a G80-3000 keyboard i.e. 1.5 units wide. Assuming that's correct then an appropriate sized CTRL key to make the swap will already have been included in the standard kit.
Offline grasshopper
« Reply #1153 on: Sat, 29 October 2011, 07:27:01 »
Could you also include a standard sized (1.25 unit?) ALT GR key in the UK kit?
Offline 7bit
  • MX1A-G1DW
« Reply #1154 on: Sat, 29 October 2011, 09:28:22 »
Quote from: grasshopper;441721
CONTROL *2
SUPER *2
META
ALT
ALT GR
Because I need these myself, I will add them to the STANDARD kit
I've got to think about Caps Lock.
The 1.75 Control will it. There exist both version  (center, off-center) already in the kit
I will also add the 1.25 units ALT GRAPH, or Alt Gr, depending on style.
« Last Edit: Sat, 29 October 2011, 09:35:15 by 7bit »
Offline 2084
« Reply #1155 on: Sat, 29 October 2011, 10:45:52 »
Which keys exactly are in the Cherry (Moogle) supplement kit? And do they come with stabilizers if needed?
« Last Edit: Sat, 29 October 2011, 11:36:59 by 2084 »
Offline litster
  • rare caps?! THAT'S A SMILIN
« Reply #1156 on: Sat, 29 October 2011, 12:07:22 »
Quote from: 7bit;441385
Try
RETRO/SPACE
When I see the 6.25 units space bar which fits on almost all keyboards with my own eyes and it really fits, I will add it to the standard and tenkless kits.
Quote from: demik;441388
I asked earlier since both my spacebars were removed. He said there might be a hybrid and it would be included. Don't know the status of it yet tho.
Thanks guys.  an included hybrid spacebar with kit sounds good.  I would imagine that would make it simpler to order for new folks.  One thing less to worry about, especially for the Leopold owners.
Offline 7bit
  • MX1A-G1DW
« Reply #1157 on: Sat, 29 October 2011, 13:12:54 »
Quote from: 2084;441782
You need to remove (pull out) the stabiliser inserts fom your Filco keyboard and put them into the keymounts of your new Round 4 key caps.
Those Cherry supplement kits are currently a bit of a '?' becuase I don't have the SVGs for the text, only up and down arrow and the  Caps Lock (handbag) symbol.
Mainly these kits should contain keys which are not existing for old Cherry keyboards with double shots without windows keys.
Offline 2084
« Reply #1158 on: Sat, 29 October 2011, 13:28:59 »
I currently have a keyboard with ISO Cherry Corp keys, missing 2x ALT, 2x Ctrl, 2x Windows,  Contextkey(or whatever it's called) and Capslock. Basically the bottom row of the keyboard. Does this cover the kit?
Extremely bad quality picture, but it shows the keys missing.
  [ Attachment Invalid Or Does Not Exist ] 30322[/ATTACH]
Offline 7bit
  • MX1A-G1DW
« Reply #1159 on: Sat, 29 October 2011, 13:33:07 »
Quote from: 2084;441860
  (Attachment Link) 30322[/ATTACH]
Better buy a new camara first.
Almost any will do!!!!
Can you please tell me if you need 1.25 units keys? These are the keys which will be in the CHERRRYxxx kits.
Offline 2084
« Reply #1160 on: Sat, 29 October 2011, 13:40:57 »
I have a DSLR but it wasn't available so I used the iPod with bad lighting instead ;)
What do you mean with 1.25 units keys? Are those the Ctrl-sized keys from keyboards like Filco?
EDIT: Alright heres a better picture [ Attachment Invalid Or Does Not Exist ] 30324[/ATTACH]
« Last Edit: Sat, 29 October 2011, 13:46:20 by 2084 »
Offline Arcane
« Reply #1161 on: Sat, 29 October 2011, 13:45:59 »
what do I have to do to get a KBDRUNNER in white on red?
tried for example NOIR/KBDRUNNER/WHITE/RED but didn't work...........
Offline tradet
« Reply #1162 on: Sat, 29 October 2011, 14:00:59 »
Quote from: Arcane;441869
Was wondering this too. I ended up using NOIR/KBDRUNNER/RED but probably best to get a confirmation from 7bit.
In general it's a little bit hard how to find out the available colors and color formats for single keys. For example is it possible to get the lotus in red on white?
Offline 7bit
  • MX1A-G1DW
« Reply #1163 on: Sat, 29 October 2011, 14:15:15 »
Quote from: 2084;441868
EDIT: Alright heres a better picture (Attachment Link) 30324[/ATTACH]
Throw your iPod away. Apple is dead! Long live the Unix philosophy (do one thing and do it well).
OK, these are 1.25 units key which will be in the CHERRY kits.
Labels will be 2x Alt, 2x Control, 2x Windows flag, 1x Menu logo. There will be also a Caps Lock key with "Caps Lock", with a down arrow and with that handbag logo on it.
« Last Edit: Sat, 29 October 2011, 14:17:20 by 7bit »
Offline 2084
« Reply #1164 on: Sat, 29 October 2011, 14:28:49 »
Quote from: 7bit;441884
I'm the perfect consumer, I use all the products no matter if Microsoft, Apple or Unix :)
OK thanks, that looks right. So I just need to order ID CHERRYWHITE once and I'm all set for all of those keys?
Offline 7bit
  • MX1A-G1DW
« Reply #1165 on: Sat, 29 October 2011, 14:31:07 »
ROUND3|KEYBOARD,KBDRUNNER|NONE,ORANGE,RED
RETRO |KEYBOARD,KBDRUNNER|NONE,ORANGE,RED
NOIR  |KEYBOARD,KBDRUNNER|NONE,ORANGE,RED
ROUND3/KBDRUNNER is WA (white) on GX (very dark gray)
ROUND3/KBDRUNNER/RED is WA (white) on RA (red)
RETRO/KBDRUNNER is BFQ (lightblue) on GQM (dark gray)
RETRO/KBDRUNNER/RED is RCQ (red) on GQM (dark gray)
NOIR/KBDRUNNER/RED is WA (white) on NN (black)
I've got a hard time to figure this out for myself. I think, I must renew that color concept.
It is obvious, that the Noir style for example, should come with 'color on black' and 'white on color'.
I'm afraid the best solution will be to say
NOIR/*/WHITE/RED or
NOIR/*/RED/BLACK
Offline 7bit
  • MX1A-G1DW
« Reply #1166 on: Sat, 29 October 2011, 15:40:47 »
Quote from: 2084;441892
Right, but don't forget to add your e-mails address!
« Reply #1167 on: Sat, 29 October 2011, 15:42:00 »
7bit, is it possible to have a stepped caps lock with the same retro theme, one to fit a filco/Leo/etc
Offline 7bit
  • MX1A-G1DW
« Reply #1168 on: Sat, 29 October 2011, 15:53:42 »
Quote from: demik;441919
No.
It will be always a full-touch key, because the keymount must be in the center of the key cap.
Offline N8N
« Reply #1169 on: Sat, 29 October 2011, 15:57:10 »
It's possible to put a stepped caps lock key on a Filco, say - I've done it - but it really doesn't work very well.  (come on Moogle kits!)
Alternately, I wonder if it would be possible to shift the switch over and use an unmodded G81 stepped caps lock...  hmm... getting an idea.  Do I really want to take the risk of completely horking up a Filco board and plate though?
Offline 2084
« Reply #1170 on: Sat, 29 October 2011, 16:29:34 »
One last question:
I might as well order a space key with the same color of the original white/beige Cherry Corp keys, since I'm using the default white Filco right now and it's slightly different.
Do you happen to know the correct original color sample for the lighter Cherry keys? And if you do the corresponding order ID for the that color. Is it the same color which is in the RETRO style?
Offline 7bit
  • MX1A-G1DW
« Reply #1171 on: Sat, 29 October 2011, 16:38:52 »
Quote from: N8N;441922
I own 5 Cherry keyboards which have n-key rollover.
They did all cost less than a Filco!
4 of 5 are new or like new, only one is used.
I will never figure out why people try to use old Cherry keys on new keyboards.
Offline N8N
« Reply #1172 on: Sat, 29 October 2011, 16:43:39 »
Quote from: 7bit;441937
Because the old Cherry keys are better than the keys that come with a new keyboard.  It's one of those "sum of the parts" things...  I took a Filco, a G81 board, and a G80 POS board; the first being good, the second being ****e, the third being OK but a little flexy and unaesthetically appealing, and combined them all.  The result is my favoritest keyboard ever, I think I like it even better than my previous gold standard, the venerable Model M.
If you didn't guess, the recipe was to take the Filco, and put the sliders and springs from a POS board with clears in it, and then top it off with some doubleshots harvested from the G81.  Feels better than any of the three boards did originally, and the sound is so nice, just a nice deep "thock" when the keys top out.
« Reply #1173 on: Sat, 29 October 2011, 20:35:38 »
[ Attachment Invalid Or Does Not Exist ] 30337[/ATTACH]
http://catb.org/hacker-emblem/
You should add the glider to the GB.
They even have a premade SVG:
http://catb.org/hacker-emblem/glider.svg
Offline jpm804
  • KeyCap Assasin
« Reply #1174 on: Sat, 29 October 2011, 23:18:29 »
Sorry just started investment more time trying to get caught up on this thread to put my order in...
@7bit - I remember in the beginning it was possible to order a ****e Cherry Style set with Red print on white for the main keys and Red on grey for the modifers... is that still possible?
I was also interested in a similar set with blue print instead of red, similat to the picture in your avatar with the color of the blue arrow keys.
REALFORCE|FILCO|HHKB|KBC POKER X|LEOPOLD|CM STORM|SIIG (GHSS)|IBM SSK
Offline Delphox
« Reply #1175 on: Sun, 30 October 2011, 04:40:31 »
mmmm... RETRO/GAMER/RED would be off-centered red characters over white background keycap?
and NOIR/GAMER/WHITE is black characters over white background right?
I've ordered my keys long ago and all the recent changes in the wiki are turning me crazy...
Offline tradet
« Reply #1176 on: Sun, 30 October 2011, 04:55:58 »
Quote from: dorkvader;442028
(Attachment Link) 30337[/ATTACH]
I'd like that one. Although I find the grid a bit ugly.
Offline tradet
« Reply #1177 on: Sun, 30 October 2011, 04:57:19 »
Quote from: 7bit;441893
Hmm with NOIR/KBDRUNNER/RED giving white on black no wonder it's hard =)
Offline 7bit
  • MX1A-G1DW
« Reply #1178 on: Sun, 30 October 2011, 07:10:14 »
I will add it. I thought about it too but did always forget to add it.
Quote from: jpm804;442068
No. That was the Bianco style.
« Last Edit: Sun, 30 October 2011, 07:13:10 by 7bit »
Offline 7bit
  • MX1A-G1DW
« Reply #1179 on: Sun, 30 October 2011, 08:27:37 »
Quote from: Delphox;442166
Sorry!
RETRO/GAMER/RED is red on light grey
NOIR/GAMER/WHITE is black on white (reverse video)
I've started to make some color samples and descrition for the SVG-graphics keys and will continue that for the ather kits as well!
Offline 7bit
  • MX1A-G1DW
« Reply #1180 on: Sun, 30 October 2011, 08:29:11 »
Quote from: tradet;442168
I will post some alternative version to see which looks best.
Offline Wraul
« Reply #1181 on: Sun, 30 October 2011, 09:18:54 »
Is COMMAND125 part of APPLE? or is APPLE text only?
I think the wiki at one point stated text only but I can't find it now.
Edit:
Is there a inverted gamer kit for DARK/ORANGE? Like very dark grey text on orange.
« Last Edit: Sun, 30 October 2011, 10:45:05 by Wraul »
« Reply #1182 on: Sun, 30 October 2011, 10:40:27 »
Quote from: 7bit;442181
Awesome, what's the code to add it to my order? I want some for sure.
Offline 7bit
  • MX1A-G1DW
« Reply #1183 on: Sun, 30 October 2011, 11:24:57 »
Quote from: tradet;442169
Sorry!
It surely comes in green on pink!!!
Offline 7bit
  • MX1A-G1DW
« Reply #1184 on: Sun, 30 October 2011, 11:26:16 »
Quote from: Wraul;442197
Edit:
APPLE is text-only (5 keys), you need the COMMAND125 keys.
Edit: No.
Quote from: dorkvader;442223
This should be obvious: GLIDER
You can have
RETRO/GLIDER
or
ROUND3/GLIDER
or
DARK/GLIDER
etc.
« Last Edit: Sun, 30 October 2011, 11:30:01 by 7bit »
Offline Internetlad
« Reply #1185 on: Sun, 30 October 2011, 11:43:11 »
maybe I missed it somewhere but I did read the resources provided, I didn't see indented/engraved lettering, only lasered.
Would the indented letters be a possibility here?
"Beep . . . Beep . . . Beep" -Sputnik I
Offline 7bit
  • MX1A-G1DW
« Reply #1186 on: Sun, 30 October 2011, 11:56:00 »
Quote from: Internetlad;442249
'Indented', 'engraved' lettering, only 'lasered'????
ARE YOU CRAZY!!!!
[/size]
The only true way to put labels on keys is to doubleshot them!
« Last Edit: Sun, 30 October 2011, 12:23:33 by 7bit »
Offline 7bit
  • MX1A-G1DW
« Reply #1187 on: Sun, 30 October 2011, 13:28:30 »
Offline whiskerBox
« Reply #1188 on: Sun, 30 October 2011, 13:58:20 »
well you know how to suck the money out 7bit just added more to my order
RETRO/GHBS
RETRO/TAPEDRIVEFUN
RETRO/PIRATE125
RETRO/PIRATEFUN
RETRO/GEEKHACK
RETRO/SHOUT
RETRO/DTESC
RETRO/LOTUSESC
« Last Edit: Sun, 30 October 2011, 14:38:50 by whiskerBox »
"I'm on a mission to bring down GH's anarchy of moderators" -RIPSTER jr.
Offline Zehkul
« Reply #1189 on: Sun, 30 October 2011, 14:25:58 »
NOIR/LOTUSMOD125 doesn't seem to work...
Offline 7bit
  • MX1A-G1DW
« Reply #1190 on: Sun, 30 October 2011, 14:34:35 »
Quote from: Zehkul;442329
Sorry, just corrected the wiki:
*LOTUS 7 Lotus keys in one kit (1x Escape, 2x 1 unit mod., 2x 1.25 units mod. 2x 1.5 units mod.)
*LOTUSESC 1 unit Escape
*LOTUSPOS 2 units key to fit on 2 keystems
*LOTUS100  1 units modifier
*LOTUS125  1.25 units modifier
*LOTUS150  1.5 units modifier
NOIR/LOTUS125 should work.
Offline whiskerBox
« Reply #1191 on: Sun, 30 October 2011, 14:40:02 »
Hey can we get the LOD IN RETRO?
like RETRO/LOD = lightblue on dark grey ?  it would just be cool to match it to the set like all the other ones
Offline 7bit
  • MX1A-G1DW
« Reply #1192 on: Sun, 30 October 2011, 14:48:01 »
Quote from: whiskerBox;442335
OK, I will add it. I will update the wiki tomorrow.
Offline whiskerBox
« Reply #1193 on: Sun, 30 October 2011, 14:59:44 »
Quote from: 7bit;442340
Offline Kenistaan
« Reply #1194 on: Sun, 30 October 2011, 19:47:34 »
are someone wanna sell keycaps like this (for my Filco Tenkeyless)? or  this GB can make that one?
[ Attachment Invalid Or Does Not Exist ] 30382[/ATTACH]
sorry if i wrong....i'm really noob at this forum :(
fossala
  •  Guest
« Reply #1195 on: Sun, 30 October 2011, 20:10:46 »
Quote from: Kenistaan;442420
(Attachment Link) 30382[/ATTACH]
You want to order the "round3" set.
« Reply #1196 on: Sun, 30 October 2011, 20:37:30 »
just added round3 tenkless, couple spacebars to go along with that and retro kit :D
hope i did it right.
i want to add some awesome face keys, but im still lost on how to pick colors.
Offline kaiserreich
  • HHKB Elite
« Reply #1197 on: Sun, 30 October 2011, 21:52:54 »
These are the setup I see for the novelty caps, for the KBDRUNNER
    ROUND3/* white on very dark gray
    ROUND3/*/ORANGE white on orange
    ROUND3/*/RED white on red
    RETRO/* lightblue on dark gray
    RETRO/* red on dark gray
    RETRO/* orange on dark gray
RETRO/* white on red
    NOIR/* white on black
    NOIR/*/ORANGE white on orange
NOIR/*/RED white on red
    DARK/* black on very dark gray
    DARK/*/ORANGE orange on very dark gray
What is the difference?
« Reply #1198 on: Sun, 30 October 2011, 22:50:00 »
NOIR/GLIDER
The best way to go.
Are we going with the glider with grid or without? I sort-of like the grid, but am cool either way.
Offline 7bit
  • MX1A-G1DW
« Reply #1199 on: Mon, 31 October 2011, 03:26:24 »
Just send a message to 7bit_R4 with the following content:
ROUND3/FILCO
ROUND3/SPACE
EMAIL your e-mail address.
Quote from: demik;442430
I will take care of the Awesome colors. For most of these keys I've posted a list of color-choices already.
Quote from: kaiserreich;442449
RETRO comes with RCQ red and
NOIR with RA red.
« Last Edit: Mon, 31 October 2011, 03:30:38 by 7bit »
