Author Topic: [GB] Double shot replacements ROUND FOUR! - SHIPPING!  (Read 1444286 times)
Offline kps
[taking orders!] Double shot replacements ROUND FOUR!
« Reply #3500 on: Thu, 23 February 2012, 12:34:53 »
Quote from: ped;523150
So you're not going to get the ergoDOX? You're going to make your own? In a box? :P How are you going to get a PCB? Could you explain further, I'm curious.
I will document the design after I have done more; I want to have the keycaps in hand before I do the keywells, so that I can guarantee I don't end up with any profile problems. One possibility is modified Kinesis keywells; the other is column-based 'plates' of either acrylic or aluminum. Either way, the keywells will be just wired point-to-point. I'll experiment with the thumb keys after the wells are done. I have relatively small hands so the central thumb columns of the Kinesis are awkward for me.
Thanks, that's what I thought, but was just confirming. Wouldn't the profiles of the keys be incorrect when compared to other keys on the same row though?
It depends how you intend to use them; if they're part of a separate key cluster they don't need to match anything else.
Offline abc123asd
« Reply #3501 on: Thu, 23 February 2012, 14:55:41 »
Does anyone know what the Colourchain PBT is? Its 200 keys for $35
Offline kps
« Reply #3502 on: Thu, 23 February 2012, 15:09:58 »
Quote from: abc123asd;523409
I believe it's like this, not keys. (That picture is the ABS version, I assume.)
Offline captain
« Reply #3503 on: Thu, 23 February 2012, 18:39:26 »
I rather like the symbolRGBY modifiers.  I think all of my orders got killed with the massive reduction of sets.  So, is that list a couple of pages back all that is left of GBround4?  Or are there still things available, like BLOOD/PIRATES (I guess that was killed because it's blood), NOIR/PIRATES, and RED/WHITE KEYBOARDRUNNER, and what of Mac modifiers OPTION and COMMAND?
Welcome to geekhack -- where we like to type -- but don't care so much about reading.
Offline oneproduct
  • @Ubisoft
« Reply #3504 on: Thu, 23 February 2012, 22:42:33 »
Will ROUND3 kits have a grey or black \| key? Seems like in the actual round 3 group buy they had black ones even though you'd expect it to be grey.
Layout: Colemak
Offline metafour
« Reply #3505 on: Thu, 23 February 2012, 22:56:29 »
Quote from: oneproduct;523898
The set I just got from another member has two versions of that key; one in the alphanumeric color and one in the modifier color.
Offline oneproduct
  • @Ubisoft
« Reply #3506 on: Thu, 23 February 2012, 23:06:10 »
Ah yes, a closer look at the round 3 group buy seems to show that that's the case. Awesome.
Layout: Colemak
Offline JSchool
« Reply #3507 on: Fri, 24 February 2012, 00:58:21 »
7Bit - you should probably send out more frequent invoices so we can verify our order changes.
Offline zirb
« Reply #3508 on: Fri, 24 February 2012, 01:52:49 »
Quote from: captain;523640
Check that out => http://deskthority.net/wiki/Round4_Pricelist
I'm pretty sure the only way to get the pirate-flag is via RETRO or NOIR (/PIRATEFUN or /PIRATE125 is available at both sets)
Offline captain
« Reply #3509 on: Fri, 24 February 2012, 03:27:17 »
Oh, dammit!  I forgot that PIRATE only comes in FUN and 125 (both row 1 profile, right?)  I want to deck out an entire keyboard in PIRATE.  I guess I'll have to do my own GB at some point.
Offline zirb
« Reply #3510 on: Fri, 24 February 2012, 03:48:01 »
Quote from: captain;524109
PIRATEFUN is Row1
PIRATE125 is Row4 => modifiers with 1.25 units
Offline captain
« Reply #3511 on: Fri, 24 February 2012, 04:14:17 »
Quote from: metafour;523909
WHAT??  How did you get a ROUND3 set?  I want one of those, or three!  :-P
Oh, that reminds me, maybe I missed it among the 12394807123 Round Four posts... did we get the kerning corrected?!  And will Escape read "Escape" or "Esc    " or "  Esc  "?
I also have a question for y'all with ROUND3 keycaps: how do they fit on a Filco Mestouch 2?  They don't have the DCS Family profile, right, or do they?
« Last Edit: Fri, 24 February 2012, 04:25:29 by captain »
Offline 7bit
  • MX1A-G1DW
« Reply #3512 on: Fri, 24 February 2012, 06:15:14 »
I left some of the popular single keys in. But I would not complain if someone organises a group buy for these, or if the added to the now separately run BLOOD grup buy. I'm not really interesed in keys which come in colors different to what the remaining styles are.
OPTION and COMMAND should still be available with the remaning styles.
Buy key caps here: Round 5
Buy switches here: CherryMX
Offline 7bit
  • MX1A-G1DW
« Reply #3513 on: Fri, 24 February 2012, 06:21:22 »
Quote from: hazeluff;522051
I might jump back on if the change makes Retro a good price. But I hate the symbols.
OK, let's keep it like it is. I just thought about RGBY and not symbols vs. text anyway.
Offline 7bit
  • MX1A-G1DW
« Reply #3514 on: Fri, 24 February 2012, 06:26:04 »
Quote from: ekw808;522525
Hey, I tried to delete my entire order and re-order so that the only purchase I have is the retro set and the spacebar, but I still have the gamer set attached. Also what is the count on the retro set, and the chances of it dropping back down to the original price that many of us were lured to of 80> O_O?
Did you try to remove it by ordering 0 of it?
Chances of the original price are 0 unless it gets more orders!
Offline 7bit
  • MX1A-G1DW
« Reply #3515 on: Fri, 24 February 2012, 06:28:49 »
There existed both. I doubt I will keep the exotic gery variant (costs are higher if we do this key in 2 different colors!).
The very dark grey version looks more symmetric to the Tab key.
Offline 7bit
  • MX1A-G1DW
« Reply #3516 on: Fri, 24 February 2012, 06:35:15 »
Quote from: captain;524125
I hope so!
RETRO and NOIR: Esc, Backspace
ROUND3 and SPH: ESCAPE, BACK SPACE
ROUND3 is DCS and they have abount the same profile as Cherry keys, except for the bottom row (row 4) which is a bit more angled.
Also, they fit the Filcos.
Offline oneproduct
  • @Ubisoft
« Reply #3517 on: Fri, 24 February 2012, 06:43:12 »
Quote from: 7bit;524157
But it should be with just the grey instead of just the black, no? In the retro and spherical sets the \| is the color of the alpha/numerical keys, not the color of the tab key. Also the Dolch keyboard that this is trying to copy has that key in grey. I'll still order it if it's only in black, but it seems to me that grey makes more sense.
Layout: Colemak
Offline 7bit
  • MX1A-G1DW
« Reply #3518 on: Fri, 24 February 2012, 06:55:19 »
Quote from: oneproduct;524161
I will change it to the modifier color in all styles, because of the lower costs.
It is logic vs. symmetry && price.
Offline kps
« Reply #3519 on: Fri, 24 February 2012, 09:02:06 »
Quote from: 7bit;524165
I vote for logic!
Offline oneproduct
  • @Ubisoft
« Reply #3520 on: Fri, 24 February 2012, 09:31:17 »
Quote from: kps;524204
I vote for logic!
Yea, if it's only a dollar or two of difference then I think logic is the better choice. If the difference is like $4 or more then I can understand though.
Layout: Colemak
Offline Curetia
« Reply #3521 on: Fri, 24 February 2012, 10:18:14 »
@7bit
If I want a german ISO-Layout in RETRO with SYMBOLSRGBISO I have to order RETRO/STD125RGBYSYMDE now right?
« Last Edit: Fri, 24 February 2012, 10:21:48 by Curetia »
Offline maladroid
« Reply #3522 on: Fri, 24 February 2012, 10:49:45 »
Surely both logic and symmetry dictate that the \| key match the alphanumerics?  If you make it dark then you will have more dark keys on the right-hand side than you do on the left.
Offline ped
« Reply #3523 on: Fri, 24 February 2012, 13:07:48 »
I know that it's probably not gonna happen and it's too late to be adding things but it wouldn't be possible to make a custom star key like they're making for the 'tsangan add-on' in 'red on black' and 'cream cheese and green', would it? :P
Offline lightsout714
« Reply #3524 on: Fri, 24 February 2012, 14:22:42 »
Quote from: ped;524438
The last thing we need is more keys.
Offline ekw808
  • Ekw
« Reply #3525 on: Fri, 24 February 2012, 15:10:20 »
I tried to do a /clearall of my order and I reordered only the retro and spacebar
[One Keyboard at a time]
« Reply #3526 on: Fri, 24 February 2012, 15:15:14 »
I haven't had an update in a couple days or so. This thing seems to be falling apart though maybe I should just jump ship.
Offline kps
« Reply #3527 on: Fri, 24 February 2012, 16:00:43 »
Quote from: lightsout714;524558
I think 7bit is busy right now with finishing up the Phantom and MX group buys. I expect this one will get finalized not too long after the switches have been ordered.
« Reply #3528 on: Fri, 24 February 2012, 16:10:04 »
Well if you read around he's trying to unload a lot of the kits from this to another person to run. I fully understand but I may just spend the money I have set aside for the retro kit.
Still hoping though as I just traded for a white phantom that would look great with that set on it.
Offline JSchool
« Reply #3529 on: Fri, 24 February 2012, 19:55:03 »
There a way to kick the bot to make it send an invoice?  I want to make sure my changes were made.
Offline rknize
    • metaruss
« Reply #3530 on: Fri, 24 February 2012, 20:55:13 »
No, you just have to wait.  Sometimes it seems to take a few hours...sometimes in a few minutes.  Maybe it's a cron job.
Russ
Offline JSchool
« Reply #3531 on: Fri, 24 February 2012, 22:00:20 »
Well it's been 4 days.  Lord only knows what the bot has me ordering at this point.  I'll probably end up with a Russian bride.
« Reply #3532 on: Fri, 24 February 2012, 22:09:38 »
Quote from: JSchool;524906
I think 7bit is doing some restructuring right now.
Offline hazeluff
  • 光復香港
    • Hazeluff
« Reply #3533 on: Fri, 24 February 2012, 22:11:05 »
If you do and don't want her, I'll take her. = )
Fight For Freedom. Stand with Hong Kongers
Offline hashbaz
  • Grand Ancient One
  • * Moderator Emeritus
« Reply #3534 on: Fri, 24 February 2012, 22:11:16 »
Quote from: JSchool;524807
Quote from: rknize;524845
I believe 7bit runs it manually.
Offline rknize
    • metaruss
« Reply #3535 on: Fri, 24 February 2012, 22:48:09 »
Every time I have made some kind of error, I got no response at all from the bot.  My request was entirely ignored.  Had to send it in pieces to see what it didn't like.  I think if you send only your EMAIL it will send you back your order.  You can also try setting the qty of something that you don't want anyway to 0 to see if it does something.
Russ
Offline vax
« Reply #3536 on: Sat, 25 February 2012, 02:31:25 »
Someone should code a Group Order Plugin for vBulletin!
Offline rindorbrot
« Reply #3537 on: Sat, 25 February 2012, 04:23:54 »
Just send 7bit_r4 a dummy pm.
Offline 7bit
  • MX1A-G1DW
« Reply #3538 on: Sat, 25 February 2012, 10:25:36 »
Quote from: hashbaz;524925
Yes, I run it manually. There are not so many orders coming in that it would be workt to run it every second.
A web-based solution would be nice, but would not change the fact that the key caps are too expensive.
Offline 7bit
  • MX1A-G1DW
« Reply #3539 on: Sat, 25 February 2012, 10:32:47 »
Quote from: Curetia;524269
@7bit
RETRO/STDRGBYSYMxx
RETRO/STDRGBYSYM125xx
RETRO/STDRGBYSYM150xx
replace xx by the empty word or something like DE, FR, SE, FI, .... COLEMAK, DVORAK
Offline 7bit
  • MX1A-G1DW
« Reply #3540 on: Sat, 25 February 2012, 10:34:23 »
You are in the wrong group buy.
tsangan's group buy is further up and the cream cheese group buy is further down.
Offline 7bit
  • MX1A-G1DW
« Reply #3541 on: Sat, 25 February 2012, 10:35:02 »
Quote from: lightsout714;524510
Yes, we need more orders!!!!
Offline 7bit
  • MX1A-G1DW
« Reply #3542 on: Sat, 25 February 2012, 10:40:23 »
The last message went out today:
Date: Sat, 25 Feb 2012 09:50:48 +0100
Had it been caught by the spam filter?
Offline 7bit
  • MX1A-G1DW
« Reply #3543 on: Sat, 25 February 2012, 10:43:22 »
Send a dummy message to 7bit_R4 .
Offline 7bit
  • MX1A-G1DW
« Reply #3544 on: Sat, 25 February 2012, 10:44:41 »
Do you want her in RETRO, SPH or ROUND3 style?
Offline KylJoy
« Reply #3545 on: Sat, 25 February 2012, 10:47:43 »
7bit, do you know what the cost of each ROUND3/STANDARD set would be if we had 42 buyers for the set?
Offline 7bit
  • MX1A-G1DW
« Reply #3546 on: Sat, 25 February 2012, 10:51:50 »
Quote from: rknize;524958
Just sent a message with a dummy-line myself and it worked.
Maybe you are using trhe wrong keyboard or the wrong key caps?
I'm using a Tipro with Round 3 key caps. had never a problem with these.
« Reply #3547 on: Sat, 25 February 2012, 11:43:41 »
Quote from: 7bit;525530
Got the update thanks.
Offline ped
« Reply #3548 on: Sat, 25 February 2012, 19:22:33 »
Quote from: 7bit;525522
Haha, yeah I knew that it wasn't gonna happen. :D I think I can't join this GB anyway, I'm not sure yet. :/ Decisions. I wish I had an endless supply of money.
Offline oneproduct
  • @Ubisoft
« Reply #3549 on: Sat, 25 February 2012, 19:34:41 »
Quote from: ped;526128
If you ever figure out how to make that wish come true, do share. :)
Layout: Colemak
