Author Topic: Ergo Clears for 2 64 key DOXs  (Read 9752 times)
Offline TheProfosist
  • Trade Count: (0)
  • Custom Layouts Only!
« on: Sun, 20 November 2011, 13:09:28 »
Looking for Red, Brown, or Blue Cherry MX Springs and Clear Cherry MX Stems to use to mod Clears to Ergo Clears for my DOX(s). no I mdo not have the switch housing so I will need that as well. I need 64 of each per keyboard. I am currently looking at doing 2 DOXs. The newer and less used the springs the better. I am willing to look at POS boards to save some money if needed i would need a total of 4 2 with Clears and 2 with Reds/Browns/Blues.
[strike]Switch housings found. Still looking for a total of 431 Clear Stems and 431 Red/Brown/Blue Springs of which 128 Clear Stems and 128 Red/Brown/Blue Springs have a high priority.[/strike]
I have 5x PCBs of new housings, 3x PCBs of new Blues and 90x New Clear Switches so far, still looking to fill out the rest.
« Last Edit: Sun, 11 December 2011, 01:18:28 by TheProfosist »
  • Trade Count: (0)
« Reply #1 on: Mon, 21 November 2011, 13:47:09 »
Update OP as I am willing to look at POS boards.
fossala
  •  Guest
  • Trade Count: (0)
« Reply #2 on: Mon, 21 November 2011, 13:49:32 »
I bought some of BiNiRiS a while ago for my poker. PM him he may have some left.
  • Trade Count: (0)
« Reply #3 on: Mon, 21 November 2011, 13:52:48 »
Quote from: fossala;456835
Thanks for the info, PM sent.
  • Trade Count: (0)
« Reply #4 on: Tue, 22 November 2011, 10:39:20 »
bump
Offline BiNiaRiS
  • Trade Count: (0)
« Reply #5 on: Tue, 22 November 2011, 13:12:36 »
Quote from: TheProfosist;456837
Never got a PM but I am out of clear stems AND brown springs. I got back from Europe and people wiped me out :)
Just as an FYI, the most important part is going to be finding brand new switch housing. In order to get the crisp feeling out of ergo clears, you need the leaf inside to be brand new. I've used well used stems and springs and with new leafs, everything feels new. It's the first thing to get worn down since it's so fragile.
I have some empty PCBs I could send to you cheap if you'd want to desolder them. No worries either way and good luck, those dox boards are sweet.
KMAC 2 w/ErgoClears
  • Trade Count: (0)
« Reply #6 on: Tue, 22 November 2011, 13:15:14 »
Quote from: BiNiaRiS;457559
Yes I have no problem desoldering when you said empty PCBs what did you mean?
Offline Ascaii
  • Trade Count: (0)
« Reply #7 on: Tue, 22 November 2011, 13:18:47 »
I have several pcbs of blue switches Im selling for 15€ per PCB.
  • Trade Count: (0)
« Reply #8 on: Tue, 22 November 2011, 13:19:52 »
Quote from: Ascaii;457564
blue switches should at least get me the springs. how many boards do you have? and what is the age of the springs/switches?
« Last Edit: Tue, 22 November 2011, 14:13:11 by TheProfosist »
Offline BiNiaRiS
  • Trade Count: (0)
« Reply #9 on: Tue, 22 November 2011, 13:57:32 »
Quote from: TheProfosist;457562
They are empty. Just the PCB and the switch housings. No springs or stems but the housings are brand new. $5 per board (104) + shipping.
KMAC 2 w/ErgoClears
  • Trade Count: (0)
« Reply #10 on: Tue, 22 November 2011, 14:10:23 »
Quote from: BiNiaRiS;457582
Do you have 5 boards available? as I plan to put Ergo clears in my Phantoms as well.
  • Trade Count: (0)
« Reply #11 on: Tue, 22 November 2011, 15:37:28 »
Update OP, new switch housings found. I still need springs and stems. And I am looking for an additional 3 Phantom 7bit Board worth at 101 keys each. The 2 sets of 64 still take priority as those builds will be happening much sooner.
Offline tsangan
  • Trade Count: (0)
  • 1000/600
« Reply #12 on: Tue, 22 November 2011, 15:40:05 »
Quote from: TheProfosist;457674
When you're finish assembling with those three 7bit special boards you can sell me one :P
Keyboardless
  • Trade Count: (0)
« Reply #13 on: Tue, 22 November 2011, 15:46:22 »
Quote from: tsangan;457676
Do you want me to make you one also? One of the 7bits is for me the others are for friends so their already all taken. I would have to know how you want the board so PM me with more info.
« Last Edit: Tue, 22 November 2011, 15:56:24 by TheProfosist »
Offline ishtob
  • Trade Count: (0)
« Reply #14 on: Wed, 23 November 2011, 06:12:30 »
i think I might have enough clear stems for 1 for you... i'll have to count it once I get back home, they are going to be from an old POS cherry board
  • Trade Count: (0)
« Reply #15 on: Wed, 23 November 2011, 08:47:06 »
Quote from: ishtob;458170
Thanks any amount helps.
Offline zmurf
  • Trade Count: (0)
    • Cherry G803000LQC With Latest Generation Trackpoint
« Reply #16 on: Thu, 24 November 2011, 01:56:40 »
I thought you where supposed to put brown springs in clear steams to create ergo clears? But blue springs maybe is better?
Is blue springs softer then the original spring in clears? Mine mech keyboard is a Cherry 80-3000LQC... so I already have the clear steams. I kind of like the heavy clear keys, but I was thinking of testing to modify it just for the fun of it. :)
My thought was to put brown springs in. But they are maybe a bit to soft? Maybe I should just go for the blue springs?
Anyway. If anyone have a set of blue or brown springs to sell me that would be great. Or better yet! If I could get hold of both blue and brown springs I could make a keyboard with variable force by using all three spring types. :D
At last! A mechanical keyboard with Trackpoint of my own! Now with Hyper-Scroll! And also Ergo-Clear switches. Ohh... look... custom keys! :D
  • Trade Count: (0)
« Reply #17 on: Thu, 24 November 2011, 01:59:05 »
Quote from: zmurf;458667
Blue/Brown/Red Springs are all the same.
Offline zmurf
  • Trade Count: (0)
« Reply #18 on: Thu, 24 November 2011, 02:08:17 »
Quote from: TheProfosist;458669
Aahh... Didn't know that.. good to know. Thanks. :)
Edit:
Just for interest. If blue, brown and red uses the same spring, does clears use the same spring as black then?
Found out by my self.. no they don't...
« Last Edit: Thu, 24 November 2011, 06:30:04 by zmurf »
  • Trade Count: (0)
« Reply #19 on: Mon, 05 December 2011, 18:18:26 »
bump
Offline bbbbqq
  • Trade Count: (0)
« Reply #20 on: Mon, 05 December 2011, 19:47:46 »
Any interest in 64 clear stems only ?
  • Trade Count: (0)
« Reply #21 on: Mon, 05 December 2011, 19:57:00 »
Quote from: bbbbqq;464862
Yea I would definitely be interested din only the stem.
  • Trade Count: (0)
« Reply #22 on: Sun, 11 December 2011, 01:17:02 »
  • Trade Count: (0)
« Reply #23 on: Sun, 11 December 2011, 03:28:59 »
Also looking for some brown switches to swap in to my SteelSeries 7G
Offline Ascaii
  • Trade Count: (0)
« Reply #24 on: Sun, 11 December 2011, 06:32:52 »
Quick info, the PCBs were sent yesterday. Let me know when they get there!
  • Trade Count: (0)
« Reply #25 on: Sun, 11 December 2011, 06:54:04 »
Quote from: Ascaii;468224
Will do. Im hopefully getting a soldering station for christmas. Itll definitly get a workout if that is the case.
  • Trade Count: (0)
« Reply #26 on: Wed, 14 December 2011, 01:23:10 »
OI now have all the housings that i need as well as blue springs all I need yet is clear stems.
  • Trade Count: (0)
« Reply #27 on: Wed, 14 December 2011, 11:38:01 »
just received my first batch of 90 brand new clears!
Offline kaiserreich
  • HHKB Elite
  • Trade Count: (0)
« Reply #28 on: Wed, 14 December 2011, 11:46:49 »
I hope you like your nuclear switches.
  • Trade Count: (0)
« Reply #29 on: Wed, 14 December 2011, 12:30:10 »
Quote from: kaiserreich;470592
just wish I had the DOX to put them in.
  • Trade Count: (0)
« Reply #30 on: Sat, 17 December 2011, 15:00:05 »
BUMP! Looking for more clear stems/switches.
  • Trade Count: (0)
« Reply #31 on: Tue, 20 December 2011, 14:12:02 »
bump
Offline The_Ed
  • Trade Count: (0)
  • Asperger's... SQUIRREL! I'm Anal Retentive *****!
« Reply #32 on: Thu, 22 December 2011, 16:26:07 »
I found some new clears for you on ebay - doubleshots on the boards too! He's got 15 of them! And you can make him an offer too!
http://www.ebay.com/itm/CHERRY-G81-1822HQMUS-PS2-BLACK-KEYBOARD-/230618121302?pt=PCA_Mice_Trackballs&hash=item35b1e94456#ht_500wt_1180
$57 apiece if he doesn't combine the shipping or accept a lower offer. That's 104 clears for 55 cents a switch per board - with doubleshots too! How's this? If you don't want the doubleshots just sent them to me when you get my caps-lock mod done.
I got a new G80-8113HRBUS-2 (sorry they're browns) from him for $93 for my mom - the unstepped caps-lock for myself. So you can trust him. He always puts a picture of the board and model number sticker too! His prices are INSANELY low on most of his cherry boards, and most are NEW too!
He's got 1 other cherry clear board for $62 - still doubleshot and new.
http://www.ebay.com/itm/CHERRY-G81-1800HQMUS-PS2-BLACK-KEYBOARD-/350454964199?pt=PCA_Mice_Trackballs&hash=item5198be5fe7#ht_500wt_1180
Edit: ****!, I think the first might me MY... Somebody geekier will know... The second I have more faith in... "Q" for clears was my basis for these 2... Maybe somebody ask him to pull off a key, he did for the 8113...
« Last Edit: Thu, 22 December 2011, 16:53:47 by The_Ed »
Reaper "frelled" me... Twice... Did he "frell" you too?... *brohug*
I'm camping for a week, and moving twice in a month. I'll get back to you when I can (If I don't then just send me another PM).
R.I.P.ster
Offline N8N
  • Trade Count: (0)
« Reply #33 on: Thu, 22 December 2011, 17:00:56 »
ummm... G81 aren't clears, they're MY.  The caps are still good, but the board is arse to type on in my opinion.
Offline The_Ed
  • Trade Count: (0)
« Reply #34 on: Thu, 22 December 2011, 17:04:34 »
As I said in my edit - I based my asumption on the "Q" for clears in the product number. And I don't think ALL G81 are necessarily MY.
R.I.P.ster
  • Trade Count: (0)
« Reply #35 on: Thu, 22 December 2011, 18:17:39 »
So are any of the links that were posted that have clears?
Offline The_Ed
  • Trade Count: (0)
« Reply #36 on: Thu, 22 December 2011, 19:29:28 »
The g80-3000lqceu-2 that i ordered has clears so i assumed that because those keyboards had a "Q" in their product number they were clear too. The other people are saying that because they're G81's they're probably clear MY switches instead of clear MX.
Edit: Why does everything I order lately have to be out of stock, but still say it's in stock? They just now cancelled it!
« Last Edit: Thu, 22 December 2011, 19:37:07 by The_Ed »
R.I.P.ster
  • Trade Count: (0)
« Reply #37 on: Thu, 22 December 2011, 19:45:16 »
Well still looking for clears or their stems used or new but as always new is prefered.
  • Trade Count: (0)
« Reply #38 on: Mon, 02 January 2012, 02:34:15 »
bump still looking for about 300 clear stems, new preferred but will buy used.
Offline Ascaii
  • Trade Count: (0)
« Reply #39 on: Mon, 02 January 2012, 02:45:05 »
have you not signed up for the groiup buy at DT? We are ordering brand new clears for 0.60$ per switch. Contact 7bit if you would join in !
  • Trade Count: (0)
« Reply #40 on: Mon, 02 January 2012, 02:51:08 »
Quote from: Ascaii;481743
I might have to do that at this rate I was trying to get by without have to buy all new switches due to cost. I guess im going to have to jump in since that is cheaper than I can get even with the amount I am ordering. It says that its closed think I can still get in? Well I sent my order hope that it went through.
« Last Edit: Mon, 02 January 2012, 03:01:19 by TheProfosist »
Offline The_Ed
  • Trade Count: (0)
« Reply #41 on: Mon, 02 January 2012, 15:13:09 »
I just wish there would be a group buy for the 3 spacebar switches. That way people could make keyboards with only spacebar switches. People have been saying someone should try that for a while now. And I think it would be kinda cool. People could also replace the light spacebar switches in their keyboards with the heavier ones. You can't buy those grey 39 switches anywhere. There are grey 39 switches in the spacebars in my clear and my mom's brown so I know what they feel like at least. I believe there are a few places that have a couple grey 37 switches, but not enough for whole keyboards. And I believe there was someone who had about 800 green, someone will remember his name for me. Destroying 104 cherry boards to make a single custom one is not an option. Why would they have a group buy for only 5 of the 8 switches currently produced?! No pcb mounted option?! No diode, jumper wire, or led option?! Blasphemy!! Metal plates detract from the typing experience, and without a diode inside the switch it would be a pain in the ass to make it nkey-rollover! Are these DOX's gonna be 2key-rollover? Or are you going to painstakingly put diodes next to every key? (If so may help you, and guide your iron true.) There, I feel much better now. I don't think this rant really belongs here but seeing that group buy really pissed me off...
R.I.P.ster
  • Trade Count: (0)
« Reply #42 on: Mon, 02 January 2012, 18:01:40 »
Quote from: The_Ed;481968
The DOX has 6KRO and has a NKRO mode we will be putting leds in the switches so diodes will be soldered directly to the PCB. And yes your right the rant is completely in the wrong place. In addition to that if you want stuff done thats not getting done, start it up and get it done your self. How do you think stuff like Group Buys and the DOX and Phantom projects get started?
Offline The_Ed
  • Trade Count: (0)
« Reply #43 on: Mon, 02 January 2012, 21:38:37 »
I'm lazy... And I hate getting the go around with businesses. Whenever I try to buy bulk directly from businesses I either get a warm welcome (extremely rare) or the finger (normal). I'm not the politest of people either when given the go around/finger. They usually like to permanently stop responding to my emails. Quite a few people at one time or another have suggested that somebody should do a group buy for the spacebar switches, but nobody is driven/polite/patient enough to try to buy them from cherry. If SP sold switches I'd say add them to GB4.
R.I.P.ster
Offline alaricljs
  • I be WOT'ing all day...
  • Trade Count: (0)
« Reply #44 on: Mon, 02 January 2012, 22:10:33 »
Cherry as a company is not set up to deal with selling to non-corporations.  With a corporate structure you could easily contact them with a request for MOQ and pricing.  Hell you can do that right now, but don't expect them to accept paypal or credit cards.
Filco w/ Imsto thick PBT
Offline Ascaii
  • Trade Count: (0)
« Reply #45 on: Tue, 03 January 2012, 00:23:27 »
actually we have a source for those elusive space bar switches, but the MOQ is at 1000 pcs.
Offline The_Ed
  • Trade Count: (0)
« Reply #46 on: Tue, 03 January 2012, 15:41:28 »
The grey 39 "MX1A-D1DW"? How much for 1000? All that would have to be done then is an order thread for the other 890 from this unnamed "source". If this "source" has a good enough price I guess I could be the one to organize it. It looks like paypal deducts 30 cents + 2.9%(3.9% international). So I would have to add 15 cents to the price of each switch, and 30 cents to shipping rates. That would make my switches free and cover all paypal fees right? Or is my math wrong?
R.I.P.ster
Offline Ascaii
  • Trade Count: (0)
« Reply #47 on: Sat, 07 January 2012, 16:37:56 »
Im not sure, the geekhack member who has access to the source is blainchen, try pming him, hell know if they have the greys availabl and at what price.
