Author Topic: Ivy Bridge or SB-E?  (Read 9405 times)
Offline Reptile
Ivy Bridge or SB-E?
« on: Tue, 24 April 2012, 13:52:09 »
Hey guys so I am currently running a first gen i7 and was planning on upgrading to Ivy but now I have mixed feelings with all the reviews coming out.
I am leaning towards SB-E just because of the proven performance and the upgrade path for Ivy-E in a year or so. Looking to OC on air with a noctua nh-d14 and a lian li a05 with some extra fans.
Opinions?
Home:Realforce 87UB 55g
Work:Leopold FC700R Ergo Clears
Offline IvanIvanovich
  • Mr. Silk Underwear
Ivy Bridge or SB-E?
« Reply #1 on: Tue, 24 April 2012, 14:43:35 »
Put your current system under water and OC it hard if you need more performance and hold on for Haswell. That's what I am doing.
Offline Roguemaster8
Ivy Bridge or SB-E?
« Reply #2 on: Tue, 24 April 2012, 14:59:51 »
[ Attachment Invalid Or Does Not Exist ] 48908[/ATTACH]
If you're going to hold out that long, why not wait for some 10 nm architecture?
CM Storm Quickfire | Dell Quietkey | Unicomp Ultra Classic | KBC Poker
Offline Reptile
Ivy Bridge or SB-E?
« Reply #3 on: Tue, 24 April 2012, 15:01:02 »
Quote from: lysol;580989
I would if I could. It's not custom
sent from my mobile
Offline alaricljs
  • I be WOT'ing all day...
Ivy Bridge or SB-E?
« Reply #4 on: Tue, 24 April 2012, 15:18:09 »
I had been running an e8750 and 8800GTS for I forget how long.  The only reason an upgrade happened is because of component failures.  It's now an i5-2500k and 6870, only a couple months old.  I do game, and at 1920x1200 I've had no issues.  What's this urgent need to upgrade driven by?
Filco w/ Imsto thick PBT
Offline boost
  • BOSTMOBILE
  • NY Giants!!!
Ivy Bridge or SB-E?
« Reply #5 on: Tue, 24 April 2012, 15:26:23 »
SB-e
Sent from my PC36100 using Tapatalk 2
-Enzo Ferrari
Offline absyrd
  • CPT HYPE PADAWAN
Ivy Bridge or SB-E?
« Reply #6 on: Tue, 24 April 2012, 15:43:19 »
What are you using this rig for?
And I wouldn't be concerned with cooling with any of these new intel lines (socket 1155 and up). It is so easy nowadays. The greatest strides I think they've made is the power consumption to performance area.
I run my 2500k at 4.5ghz with a single 5770 right now and pull like 30w from the wall while browsing (and not much more doing light gaming). Crazy stuff.
Offline alaricljs
Ivy Bridge or SB-E?
« Reply #7 on: Tue, 24 April 2012, 16:09:45 »
How are you measuring that 30w?  I am pulling ~100w at idle with my 2500k and 6870 at stock measured w/ a Kill-A-Watt
Offline absyrd
  • CPT HYPE PADAWAN
Ivy Bridge or SB-E?
« Reply #8 on: Tue, 24 April 2012, 16:47:59 »
Kill-A-Watt here, too. Are you downclocking on idle w/ speedstep? Is your GPU fully downclocking?
Are you including your monitor?
« Last Edit: Tue, 24 April 2012, 16:50:39 by absyrd »
Offline Nighted
Ivy Bridge or SB-E?
« Reply #9 on: Tue, 24 April 2012, 16:53:59 »
Well, my opinion is if you don't need PCI-E 3.0 then there really is no reason to upgrade. I probably will keep my 2600k although I may grab an ASUS P8Z77-I Deluxe because I can not over clock on my current GIGABYTE H67 mobo. Yes, I'm rocking an ITX.
^ 100% teleprompter free.
[SIGPIC][/SIGPIC]
Offline Reptile
Ivy Bridge or SB-E?
« Reply #10 on: Tue, 24 April 2012, 17:03:17 »
Quote from: absyrd;581043
Gaming for the most part.
The main reasons I want to upgrade is that I cannot stream in HD on my current setup. (might be more video card related; running a HD5770)
But I also have an old server running a dual core xeon chip I would also love to upgrade using my old parts.
It just seems like the time to upgrade for me. Just trying to decide which route to take.
Offline Nighted
Ivy Bridge or SB-E?
« Reply #11 on: Tue, 24 April 2012, 17:06:17 »
Quote from: Reptile;581106
Sounds like your NIC might be your bottle neck.
[SIGPIC][/SIGPIC]
Offline Reptile
Ivy Bridge or SB-E?
« Reply #12 on: Tue, 24 April 2012, 17:20:15 »
Quote from: Nighted;581108
Wait my network card or my internet?
I have 20Mb/s upload. Internet speed is not an issue.
Offline Nighted
Ivy Bridge or SB-E?
« Reply #13 on: Tue, 24 April 2012, 17:22:46 »
Yeah, your network card or chip.
[SIGPIC][/SIGPIC]
Offline Reptile
Ivy Bridge or SB-E?
« Reply #14 on: Tue, 24 April 2012, 17:36:32 »
Quote from: Nighted;581123
wait what? that makes no sense
Offline alaricljs
Ivy Bridge or SB-E?
« Reply #15 on: Tue, 24 April 2012, 18:07:31 »
Well, streaming HD should not be a challenge for the parts of the system that we already know about.  I had no issue with an e6750 and a 450GTS (even some older don't remember what nVidia card had no issue in the same system).
Offline Nighted
Ivy Bridge or SB-E?
« Reply #16 on: Tue, 24 April 2012, 18:09:57 »
Dunno...but your VGA does not affect your network throughput what-so-ever. Streaming is network bandwidth only.
[SIGPIC][/SIGPIC]
Offline alaricljs
Ivy Bridge or SB-E?
« Reply #17 on: Tue, 24 April 2012, 18:13:50 »
Nighted, you're forgetting the bit where you have to decode whatever the stream is encoded in.
Offline Reptile
Ivy Bridge or SB-E?
« Reply #18 on: Tue, 24 April 2012, 19:59:28 »
Quote from: alaricljs;581186
Yes this. thought he was trolling lol
I think he is talking about netflix streaming and not live video game streaming
Offline TheProfosist
  • Custom Layouts Only!
Ivy Bridge or SB-E?
« Reply #19 on: Wed, 25 April 2012, 05:06:02 »
Could you list you full system specs? I have a feeling that your going to wan to wait for haswell as well that is what I am doing with my i7 920.
Offline WhiteFireDragon
    • youtube
Ivy Bridge or SB-E?
« Reply #20 on: Wed, 25 April 2012, 05:25:30 »
First gen i7 is no slouch. I would wait out on the upgrade unless you care about a slightly higher overclock and lower power consumption. I would skip out until the next die shrink on LGA2011.
Offline zeDoktor
    • http://www.hexomega.com
Ivy Bridge or SB-E?
« Reply #21 on: Wed, 25 April 2012, 13:52:24 »
I can stream 720P 30FPS with an i7 960 @ 3.3GHz with decent enough quality and some headroom to spare on the CPU while also recording to hard disk (using XSplit). If you're going for full 1080P then you might have to upgrade but 720P is usually good enough for now.
SteelSeries 6Gv2 / Razer DeathAdder Black  / CM Storm QuickFire Rapid / Logitech G5 BF2142 / Microsoft Sidewinder X4 / Rosewill RK-9000 White / Anker 8200
Offline GeorgeStorm
Ivy Bridge or SB-E?
« Reply #22 on: Wed, 25 April 2012, 14:00:13 »
I would look towards your gpu.
The 5770 isn't that great a card, if you're into gaming, a gpu upgrade would be far more sensible.
A first gen i7 is still a beast of a cpu
Poker with blacks
My flickr
Offline ch_123
Ivy Bridge or SB-E?
« Reply #23 on: Wed, 25 April 2012, 14:39:02 »
I'd agree with the above. Those Nehalem chips are still damn good chips. I mean, it's probably still debatable as to whether the old Core 2 chips are 'obsolete' yet...
Offline The_Beast
  • I like wood ಠ_๏
Ivy Bridge or SB-E?
« Reply #24 on: Wed, 25 April 2012, 14:46:26 »
If you're upgrading from a Q6600, would SB, SB-E or IB be the best upgrade?
I really feel like my CPU is bottle-necking my GTX570
Ivy Bridge or SB-E?
« Reply #25 on: Wed, 25 April 2012, 15:20:35 »
Quote from: The_Beast;582053
Any of those are years ahead of a Q6600. I guess an Ivy Bridge since you mentioned it.
Offline zeDoktor
Ivy Bridge or SB-E?
« Reply #26 on: Wed, 25 April 2012, 15:44:00 »
FWIW I have a 6950 and I'm streaming ME2 and SC2 without issues. Some of that comes from the setup of XSplit as well. Perhaps giving us a little more info on what you're trying to do or looking more into your applications may help. Sometimes just turning down one of your settings makes everything a lot smoother. Disabling Aero also helps.
Offline Gawkbasher
Ivy Bridge or SB-E?
« Reply #27 on: Wed, 25 April 2012, 16:25:41 »
It's a few things...some onboard NIC still aren't that great (I highly recommend the Intel PRO/1000 GT.).
Also for streaming HD games a lot of people (who want a reliable/stable solution) end up going with some additional dedicated hardware for encoding...either a breakout encoder or a separate PC entirely.  It's really expensive, sadly, and most of the equipment you can buy for it isn't very good.  The most success is had by the people running two PCs.
Topre Realforce 87U 45g / Logitech G9x / Razer Scarab
KBC Poker X (Blue)
/ KBC Poker X (Red)
Offline Reptile
Ivy Bridge or SB-E?
« Reply #28 on: Wed, 25 April 2012, 16:39:36 »
Remember It's not a custom pc. It's a dell xps 8100
Can't overclock :mad:
sent from my mobile
Ivy Bridge or SB-E?
« Reply #29 on: Wed, 25 April 2012, 19:24:48 »
Quote from: Reptile;582137
sent from my mobile
That processor is no slouch though since its a prebuild there isnt much that you can do upgrade wise. You may want to look into the GFX carp option and additional ram. If you are going to upgrade got with Ivy Bridge Sandy Bridge E is going to be too costly for what you need. If you give me a price range I could spec you out a new PC the brands that I most commonly use are listed here http://tinyurl.com/732dkeb . If you have other preference I would need to know.
« Last Edit: Wed, 25 April 2012, 19:27:05 by TheProfosist »
Offline Hak Foo
  • Make America Clicky Again!
Ivy Bridge or SB-E?
« Reply #30 on: Wed, 25 April 2012, 21:17:18 »
The concern with SB-E is that it's one of those novelty enthusiast platforms.  Remember Socket 940/Athlon 64 FX?  Remember that weird last take on the Core 2 series (9775?) where they shoehorned two on an Xeon board?
Yeah, I'd be unsurprised if there isn't much of a path past Ivy Bridge, but OTOH, it's reasonably priced and common enough that there's gonna be some quality mainstream support out there.  (I tend to suspect a lot of the enthusiast boards are targeted to those who love to fix their machines more than use them)
Overton130, Box Pale Blues.
Ivy Bridge or SB-E?
« Reply #31 on: Wed, 25 April 2012, 21:21:49 »
SB-E is not a novelty enthusiast platform. Its meant for Workstations and servers.
Offline Reptile
Ivy Bridge or SB-E?
« Reply #32 on: Wed, 25 April 2012, 23:04:37 »
Quote from: TheProfosist;582381
Workstations yes but not production servers. Would work well as a home server as well.
But they might have found the cause of the heat issue.
Source : http://www.overclockers.com/ivy-bridge-temperatures
They used TIM paste instead of fluxless solder.
i7-3820 for me :tongue1:
Ivy Bridge or SB-E?
« Reply #33 on: Wed, 25 April 2012, 23:08:53 »
yes nearly the exact same chip is available for servers based on the same core architecture may not be called sandy brige e but its very close to the same thing with different features.
Offline Gawkbasher
Ivy Bridge or SB-E?
« Reply #34 on: Thu, 26 April 2012, 05:31:31 »
Just this!  In fact a trader friend of mine is going with a Xeon E5 2620 and 32GB of RAM for his proprietary platform.
It's still called Sandy Bridge-E.  (at least the E5-16XX are)
« Last Edit: Thu, 26 April 2012, 05:34:27 by Gawkbasher »
KBC Poker X (Blue)
/ KBC Poker X (Red)
Offline feteru
Ivy Bridge or SB-E?
« Reply #35 on: Tue, 01 May 2012, 21:14:23 »
Well, I know that I will be going for SB-E come this summer and my new rig. Going to go for a 3820 and just push it to around 4.5ghz or so. Overall, I think X79 is a much better platform than Z77, due to the higher number of native lanes quad channel RAM, and the better upgrade path.
Offline Reptile
Ivy Bridge or SB-E?
« Reply #36 on: Tue, 01 May 2012, 21:26:33 »
Quote from: feteru;587764
My plans exactly :-)
Well I ordered my case early since it isn't on newegg (Lian Li A05NB) and it has a gnarly dent. Looks like he has more so gotta do an exchange. I would have been pissed if already had all my pc parts.
Offline mkawa
  •  No Marketplace Access
  • (ツ)@@@. crankypants
Ivy Bridge or SB-E?
« Reply #37 on: Tue, 01 May 2012, 23:49:09 »
damnit reptile, why didn't you buy my a05? (i just gave it away btw, hah!)
Offline Reptile
Ivy Bridge or SB-E?
« Reply #38 on: Wed, 02 May 2012, 02:01:53 »
Quote from: mkawa;587851
Lol didn't know you still had it
sent from my mobile
Offline Number_25
    • http://www.keironoshea.info
Ivy Bridge or SB-E?
« Reply #39 on: Wed, 02 May 2012, 09:32:26 »
I am hoping to invest in a new processor soon as the Q8300 is starting to show it's age.
But I've read recently that the second that you touch the voltages, the temperatures skyrocket a fair amount.
However, these were engineering samples.
Offline Nighted
Ivy Bridge or SB-E?
« Reply #40 on: Wed, 02 May 2012, 09:55:44 »
Quote from: ripster;588100
So far I've extended the life of an Intel Atom and Intel Duo with a simple SSD swap.
In this PostPC era it is a relief that from now on I'll just be buying faster and better tablets.  PC's are such a time sink.
Sent From Brother Ripster's iPad
There used to be this guy on IRC who would, at any opportunity, mention his iPod (the fact that he HAD an iPod). "My iPod" this, "My iPod" that. Then there was another guy that would get on the transit and he's hold his iPod out in such a fashion as to display it almost saying, "Hey everyone, I have an iPod". Goddammit it was annoying.
Apple fan boys should be called "iTards".
[SIGPIC][/SIGPIC]
Offline Reptile
Ivy Bridge or SB-E?
« Reply #41 on: Wed, 02 May 2012, 11:04:42 »
Hooray for good ebay sellers :-)
Since it was just the side panel I don't have to ship anything back. He is just sending a new side panel at no cost.
Here is his store link. http://stores.ebay.com/pcpartsplusmore
He has lots of Lian Li stuff :biggrin:
Offline mkawa
Ivy Bridge or SB-E?
« Reply #42 on: Wed, 02 May 2012, 11:58:25 »
i've since moved onto boring antecs. lilis are just too idiosyncratic
Offline Reptile
Ivy Bridge or SB-E?
« Reply #43 on: Wed, 02 May 2012, 18:57:27 »
UPS likes to stab my boxes :rip:
Offline mkawa
Ivy Bridge or SB-E?
« Reply #44 on: Wed, 02 May 2012, 20:19:01 »
ouch! that's pretty brutal.
Offline Nighted
Ivy Bridge or SB-E?
« Reply #45 on: Wed, 02 May 2012, 20:32:44 »
Quote from: Reptile;588560
[UPS likes to stab my boxes :rip:
[video=youtube;PKUDTPbDhnA]http://www.youtube.com/watch?v=PKUDTPbDhnA[/video]
[SIGPIC][/SIGPIC]
