Author Topic: Mechanical keyboard space bar  (Read 7210 times)
Offline variant
« on: Tue, 26 June 2012, 02:22:45 »
One of the problems I had with the CM Storm Trigger was my thumb when using WASD or ESDF would hit the very edge of the space bar and would become sore with long gaming hours. Also since it was hitting the edge, it reduce my ability to actuate the key. So when jump is bound there, I couldn't time my jump accurately. Is this an issue with all mechanical keyboard space bars or solely the Trigger?
Offline Djuzuh
« Reply #1 on: Tue, 26 June 2012, 02:27:20 »
I suggest you to move your thumb.
Offline variant
« Reply #2 on: Tue, 26 June 2012, 02:36:51 »
Quote from: Djuzuh;622268
Impossible and still use WASD. My fingers are long and I could barely actuate the spacebar as it is. The edge of the space bar hit above my knuckle. I would have to physically move my hand up which would make the WASD and other keys harder to hit not to mention cause pain through my wrist from the weird angle.
Every keyboard I've used prior to this always had a slight curvature on the space bar that gave it a tilt towards me whereas the mechanical space bar seems thin and straight, and combined with the unlevel keys and the height of the space bar from where my hand sat, made it seem like it was actually tilted away from me.
« Last Edit: Tue, 26 June 2012, 02:43:54 by variant »
Offline Djuzuh
« Reply #3 on: Tue, 26 June 2012, 02:58:05 »
Wait, you use your thumb to press on D?
I just do everything with my other fingers, and leave my thumb on space.
Offline variant
« Reply #4 on: Tue, 26 June 2012, 03:00:17 »
Quote from: Djuzuh;622288
No. I use my index finger. I am saying that I my fingers are long and to press keys comfortably, my thumb ends up on the edge of the space bar. I should have specified that it is above my 2nd knuckle.
« Last Edit: Tue, 26 June 2012, 03:10:42 by variant »
Offline stingrae
« Reply #5 on: Tue, 26 June 2012, 03:09:30 »
Quote from: variant;622290
Really need a picture, can't quite imagine your issue...
How big are your hands? :| I have to straighten out my fingers in order to not be able to hit the spacebar with my thumb...Then again I have pathetic non-manly hands...
Filco Ninja Tenkeyless  -Noppoo Choc Mini - Cm Storm Quickfire Rapid
Offline Djuzuh
« Reply #6 on: Tue, 26 June 2012, 03:10:30 »
Quote from: stingrae;622292
Agreed, I can't imagine how you end up on the edge of the space bar.
Offline Lanx
Re: Mechanical keyboard space bar
« Reply #7 on: Thu, 19 July 2012, 05:17:14 »
flip the space key 180, if however your spacebar is offcenter of the switch, i might not work (unless your space already has the extra pre drilled holes) i'd show you what i mean by linking to the mod section, but it isn't there yet, just flip the bar, 50/50 chance it'll work and if it does, you'll prolly like it more.
« Reply #8 on: Thu, 19 July 2012, 18:09:12 »
I flipped my SP spacebars over, and am very happy with the results. This worked on my CMstorm QF rapid, so it should also work with WASD, filco, etc.
« Reply #9 on: Sat, 11 April 2015, 14:26:53 »
Yo quiero uno con luz
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #10 on: Sat, 11 April 2015, 14:34:41 »
Offline Oobly
« Reply #11 on: Sat, 11 April 2015, 14:53:33 »
The Trigger has a symmetrical spacebar, so it can be flipped. Just pull it off, flip it around and press it on again. Gives a better angle for the thumb to rest on without hitting the edges.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline trizkut
« Reply #12 on: Sat, 11 April 2015, 14:54:55 »
Offline Oobly
« Reply #13 on: Sat, 11 April 2015, 15:01:43 »
