Author Topic: It's in the mail...  (Read 3068033 times)
Offline pr0ximity
Re: It's in the mail...
« Reply #11151 on: Mon, 14 November 2016, 01:52:47 »
Offline alienman82
« Reply #11152 on: Mon, 14 November 2016, 07:37:02 »
removed.
« Last Edit: Thu, 01 March 2018, 13:41:17 by alienman82 »
Offline slot demon
« Reply #11153 on: Mon, 14 November 2016, 15:14:22 »
Bought the rad away plank keycapset from mechsupply. Probably here in some days: green alps keyboard, hua ak switch keyboard.
Offline funderburker
« Reply #11154 on: Tue, 15 November 2016, 07:29:49 »
KeyKollectiv sleeve, keychain & Bitberry "Lite" from KK Instagram contest.
Keyboard design by Skepur
Offline JaccoW
  • Fire Typer!!
  • Keyboard is Lava!
« Reply #11155 on: Tue, 15 November 2016, 07:44:18 »
A sleeve for my Weaven
|||My other keyboards :
x
Offline losing_ctrl
« Reply #11156 on: Tue, 15 November 2016, 07:49:01 »
Ortek MCK-142 Pro
Offline Heist
  • Warchief of the Horde
« Reply #11157 on: Tue, 15 November 2016, 09:37:40 »
White Blank HHKB :)
Offline mike52787
  • Alps Aficionado
« Reply #11158 on: Tue, 15 November 2016, 09:43:57 »
Ortek MCK-142 Pro
Ive always wanted an alps 122, too bad its ISO.
Offline losing_ctrl
« Reply #11159 on: Tue, 15 November 2016, 12:28:50 »
Ortek MCK-142 Pro
Yeah being ISO is not ideal but I had one of these keyboards long ago and foolishly let it go, so after finding a decent one for sale, I just couldn't resist.
Offline tobydeemer
« Reply #11160 on: Tue, 15 November 2016, 13:35:57 »
mistel barocco white mx clears ; magicforce 68 gat greens ; pokerII with gat greens which was out to get two switches repaired ; grey and charcoal blank pbt oem profile tkl set ; a box of raw gat greens ......aaaand I think that's it. I go through long stretches of not buying any keyboard stuff, and then ALL THE THINGS. Got a burned out gen1 matias clicky that I'm gonna cut down to a 60%, and a terminal 122 model M, and teensies for both of these. I *almost* pulled the trigger on an HHKB, but went with the mistel instead.
// SGI AT101 // SIIG Minitouch  // 87 & 93 & Terminal 122 Model M // Poker II Brown // CMS QFS Gateron Green // Alps GlidePoint Rackmount // DataGeneral 6311 Acer // ...annnnd some other randoms... //
Offline aaron6301
  • Pixel Pusher
« Reply #11161 on: Wed, 16 November 2016, 10:45:46 »
Intel Core i7-6700K 4.0GHz Quad-Core Processor
Corsair H100i v2 70.7 CFM Liquid CPU Cooler
Asus MAXIMUS VIII GENE Micro ATX LGA1151 Motherboard
Corsair Vengeance LPX 32GB (4 x 8GB) DDR4-2666 Memory
Samsung 850 Evo 500GB 2.5" Solid State Drive
EVGA GeForce GTX 1070 8GB SC Gaming ACX 3.0 Video Card
Corsair Air 240 MicroATX Mid Tower Case
Corsair RMx 650W 80+ Gold Certified Fully-Modular ATX Power Supply
It's going to be a busy weekend...
Offline alienman82
« Reply #11162 on: Wed, 16 November 2016, 11:39:16 »
removed.
« Last Edit: Thu, 01 March 2018, 13:39:26 by alienman82 »
Offline dgneo
  • Supervillain
« Reply #11163 on: Wed, 16 November 2016, 11:40:25 »
Nice build! Maximus VIII GENE is awesome, I have the same mobo/cpu/ram setup, can't recommend it enough.
Offline aaron6301
  • Pixel Pusher
« Reply #11164 on: Wed, 16 November 2016, 11:58:12 »
solid build.  Can't wait to see it.  Lot of ram there!
Thanks! It's a bit overkill tbh. Although if I ever venture back into SFX and editing, I'm sure I can put it to use.
Great to hear! Really looking forward to it.
Sent from my SAMSUNG-SM-G925A using Tapatalk
Offline danwomansan
  • Also known by my real name, ********!
« Reply #11165 on: Wed, 16 November 2016, 14:49:25 »
ViewSonic ku520 and a blue-label model m 122 (not yet sure the model number).
the viewsonic will take significantly longer to get here
both will be my first mechs I will have ever typed on; closest I've come to typing on a mech before was typing on a really good scissor-switch board
it's pronounced "danw omansen", not "dan woman san"
Offline Erikdayo
« Reply #11166 on: Mon, 21 November 2016, 09:28:33 »
I've really been wanting to try the HHKB Pro 2 so I finally ordered one. I think the layout will pose issues while playing the main MMO I play. So I'll need to decide whether to swap keyboards every time I play it or just slowly adjust. Main issue is really that I usually use caps lock for push to talk. I suppose I still could if I switch all my ctrl modifier binds to shift. Adjusting from the standard ctrl position to shift wouldn't be that bad. This means I can't really use ctrl as a modifer anymore, but I guess I don't really need that many binds for my normal use.
Offline Fictiouz
  • That "White" Guy
« Reply #11167 on: Mon, 21 November 2016, 09:34:55 »
SO MANY ARTISANS PCBS AND LUBE ENROUTE.
ALL THE LUBE.
Offline kinglukas38
  • Do you even tactile?
« Reply #11168 on: Mon, 21 November 2016, 09:45:18 »
probably a scam and won't get delivered, but its 'in the mail' :p
I've never done it before, but I'm pretty sure I'm good at it
Offline Fictiouz
  • That "White" Guy
« Reply #11169 on: Mon, 21 November 2016, 09:46:43 »
For that price it's worth the risk IMO
Offline kinglukas38
« Reply #11170 on: Mon, 21 November 2016, 09:50:53 »
My exact thought
Offline [Lewynlight]
  • Formerly Dymloslouire
« Reply #11171 on: Mon, 21 November 2016, 09:52:00 »
let's see...
on the way:
VE.A
ordered:
78g gold spring for vintage black
GMK Carbon Space bar
plane ticket for my weekend getaway..
my wallet's crying again this month..
TGR Jane V1 CE - TGR Jane V2 CE Black Ano - TGR 910 R1 - TGR 910 RE Polycarbonate - TGR 910v3 Prototype - TGR Tris - RS60 - RS65 "Internet Yamero" - RS TKL
Offline Erikdayo
« Reply #11172 on: Mon, 21 November 2016, 10:56:20 »
Oh yea. Should also have a 13" DongleBook Pro in the mail soon. Ordered just over 3 weeks ago so it may just be another week! http://puu.sh/spLzS.png
Offline 00zeRO
  • mechanicalkeyboards.com
  • * Commercial Vendor
  • The 00verseer of Vault 77
    • Mechanical Keyboards
« Reply #11173 on: Tue, 22 November 2016, 08:46:21 »
SA Jukebox R2!
Surely, good times to be had...
Daily Driver: Typist A w/Midnight Dawn | Kailh BOX Clicks
Junktown 2: Now on eBay!
Offline kiwi99
  • that's a gnarly dookie
« Reply #11174 on: Tue, 22 November 2016, 15:13:43 »
Keykollectiv, Brocaps, ETF (soon), Binge (soon) all comin in the mail along with some stuff for the O2 amp I've been wanting to build for forever.
Offline mike52787
  • Alps Aficionado
« Reply #11175 on: Tue, 22 November 2016, 18:54:51 »
Some stuff from alienman82:
OTD The Cheat
OG dyesub set
My Cream alps 60% I sent him to try
and some other assorted ****
Super excited about this package
Offline alienman82
« Reply #11176 on: Tue, 22 November 2016, 19:33:04 »
removed.
« Last Edit: Thu, 01 March 2018, 13:37:06 by alienman82 »
Offline mike52787
  • Alps Aficionado
« Reply #11177 on: Tue, 22 November 2016, 19:42:45 »
OTD The Cheat
OG dyesub set
that's what you think you're getting
 ;D :( :-X
:eek: :'( :blank:
you probably filled the box with spiders or somethig
Offline alienman82
« Reply #11178 on: Wed, 23 November 2016, 23:25:53 »
removed.
« Last Edit: Thu, 01 March 2018, 13:36:24 by alienman82 »
Offline danwomansan
« Reply #11179 on: Sun, 27 November 2016, 15:50:52 »
okay, now the model m is ACTUALLY in the mail
the viewsonic disappeared from the mail though
Offline Erikdayo
« Reply #11180 on: Tue, 29 November 2016, 09:02:44 »
MacBook Pro w/ touchbar on the way finally! Should have it next Tuesday at the latest. Also have a few ABS Topre spacebars arriving today. All 4 PBT ones I've gotten are warped so I've about given up on that idea. But if I just have a few spare ABS ones around I should have no worries about shiny spacebars.
Offline kawasaki161
« Reply #11181 on: Tue, 29 November 2016, 12:51:04 »
VE.A will arrive tomorrow, already lubed all my leftover Zealios, I don't have stabs for it yet though :(
Offline JaccoW
  • Fire Typer!!
  • Keyboard is Lava!
« Reply #11182 on: Tue, 29 November 2016, 17:20:48 »
A Ramage spacebar.
x
Offline Kilonzi
  • Praise the sun!
« Reply #11183 on: Wed, 30 November 2016, 06:18:32 »
- HHKB Pro 2 Type-S
- HHKB Case
- HHKB Wrist Rest
- HHKB red and blue keycaps for ESC and CTRL
I bought this all in Japan via proxy. I'm so looking froward to it.
Offline d.walkr3
« Reply #11184 on: Sat, 03 December 2016, 09:54:11 »
- HHKB Pro 2 Type-S
- HHKB Case
- HHKB Wrist Rest
Just picked up my type-s jp a few weeks ago. Being my first topre board I was a little nervous going out on a limb without testing the topre switches before buying... but man am I glad I opted for the Topre. You're going to love it... but a fair warning, it may start out un-assuming, but this keyboard will grow on you more everyday that you use it. Enjoy!
Offline z3r0_k00l75
« Reply #11185 on: Sat, 03 December 2016, 10:32:14 »
 I have a "non-working" Redragon K551 coming. Really hoping that the issue is only a loose pcb/cable connection. If not well I get a bunch of Outemu blues and cherry stabs at least. And does it count as "in the mail" if it's at the post office and I have to pick them up Monday but they weren't shipped from anywhere? Cause my local post office just replaced their keyboards with new ones and there is a box there with my name on it and 2 Cherry G80-11900's inside.  :cool: They are dirty and grimy and look like they have been abused for the last 10 years daily. Those black switches have got to be so broken in by now that they feel like a buttered baby's bottom on ice. I honestly cannot wait to pick them up.
Daily Drivers: GON NerD60 (PBT / Gateron Black / UV LED), GH60 Rev.C (PBT / Gateron Black), WASD Code VP3 (Stock / Cherry Clear / White LED), NPKC KC60 (DS PBT / Gateron Green / White LED), Adesso 625UB (White English-Russian Thick PBT/ Cherry Red), Quickfire Rapid (Vortex PBT / Cherry Black), Quickfire Rapid-I (Stock+o-rings / Cherry Red / Green LED), Leopold Otaku (Black Gray mixed Dolch Thick PBT / Cherry Red).
Offline Frenky
« Reply #11186 on: Sat, 03 December 2016, 17:17:16 »
I just ordered a "Wooting One" thats coming in February, and a Leopold FC660C on the way for January!!! Wooooooooooooo :p :p :p :p
Offline Slash Emperor
  • Lust for life lost, keyboards acquired.
« Reply #11187 on: Sun, 04 December 2016, 07:44:54 »
Currently en route are:
Whitefox
Zealencios
ps2avrgb kit from Keyclack
THX-00 Ebony
Hoping my Whitefox doesn't have the messed up plate.
Sent from my LG-US996 using Tapatalk
Offline Moistgun
  • Slippery When Wet
« Reply #11188 on: Sun, 04 December 2016, 19:40:37 »
Whitefox
Zealencios
THX-00 Ebony
my secret santa package :D
Also who knows what coming from the same city as romeviiiiiii
:dogethink:
Offline ArchDill
« Reply #11189 on: Mon, 05 December 2016, 01:40:00 »
In transit:
-2 Custom USB cables.
-Navacaps giveaway cap that I won.
I think that is it right now. Got my ETF(ugus) yesterday!
Offline alienman82
« Reply #11190 on: Mon, 05 December 2016, 09:47:34 »
removed.
« Last Edit: Thu, 01 March 2018, 13:30:23 by alienman82 »
« Reply #11191 on: Mon, 12 December 2016, 05:38:14 »
Invasion Pt.2 package is in the mail and I'll get it tonight. Oh, I'm soooo excited!
Offline HerrVoennchen
« Reply #11192 on: Tue, 13 December 2016, 08:51:00 »
my new Cooler Master Pro S arrived already at home and in 1 h on my way home too :) soooo stoked ... sadly there is a EKL Brocken Eco i have to assemble first :D
@work: Keychron K8 Pro w/ Gateron Ink Black v2
@home: CoolerMaster Masterkeys Pro S RGB (MX-Brown)
retired until fixed: Ducky One 2 SF (MX-Black, US-Layout)
Retired: Varmilo Miya Pro DualOS Custom (MX-Black, US-Layout)
Offline W_hinklebottom
« Reply #11193 on: Tue, 13 December 2016, 11:02:17 »
Finally got my TRI-C confirmation tracking number! Ready to get around to building that thing. Feng's POM caps are supposed to be coming soon as well, but, I'm not hoping for anything with that.
Offline needz
  • MK Newb. Pinball Pro.
    • Pindigo
« Reply #11194 on: Tue, 13 December 2016, 11:35:21 »
My first set of Zealios have been 'In transit to destination' since the 8th.  >:D
« Reply #11195 on: Tue, 13 December 2016, 17:27:33 »
Soo. ... interesting evening. After 2 h assembling the new CPU Cooler I finally unboxed my new CM Pro S and you won't believe it... the USB cable and the key puller were missing. The box was sealed. I connected it temporarily with a cable from my kindle. That means calling my seller or CM directly. Hoping someone send me that missing stuff. The board itself is stunning.
« Last Edit: Tue, 13 December 2016, 17:35:35 by HerrVoennchen »
Offline Heist
« Reply #11196 on: Tue, 13 December 2016, 17:32:48 »
Mummy III, my first KWK cap, can't wait!
Offline Brammm87
« Reply #11197 on: Sun, 18 December 2016, 05:31:25 »
Got tracking numbers for my Sennheiser 6XXs and some Suited Up caps. Hype!
pls gief bbv2
Offline A Future Pilot
  • A Descentr
« Reply #11198 on: Sun, 18 December 2016, 16:25:26 »
Currently waiting on a WASD Cherry Switch Tester to decide what switch I wanna get on the Filco I'ma buy, and also some donor keycaps to get me started in my new hobby of making hand-carved wooden keycaps :)
Here's the WW1 Flying Ace standing beside his Sopwith Camel
Offline clappingcactus
« Reply #11199 on: Sun, 18 December 2016, 16:28:47 »
I have a penumbra set in the mail that's starting to look more and more like it's lost forever. :(
Going to wait till the New Year and then file for insurance.
