Author Topic: It's in the mail...  (Read 3246698 times)
Offline The_Beast
  • I like wood ಠ_๏
Re: It's in the mail...
« Reply #1450 on: Thu, 06 June 2013, 23:05:25 »
Carrera Precision CP8812-T 12-Inch Digital Caliper Micrometer
MLCS 9674 Brass Template Guide Kit
Amico Helical Groove 2.5mm Dia Tip 4 Flute HSS End Mill Cutter
Solid Carbide Upcut Spiral Bit, 1/8-Inch Diameter by 2-Inch Length, 1/4-Inch Shank
Dormer E002 Powdered Metal Spiral Flute Threading Tap, Modified Bottoming Chamfer, M3-0.50 Thread Size
CTD Metric Magnum Super Premium 3.5mm Drill Bit
CTD Metric Magnum Super Premium 2.5mm Drill Bit
Amico 6mm x 6mm Two Flute 2F Straight Shank Milling Cutter End Mill
Amico 2mm x 5mm x 39mm Double Ended HSS A Type Center Drill Bits Gray
Time to make a GH60 Case!
Offline Tarzan
  • formerly known as Greystoke
« Reply #1451 on: Fri, 07 June 2013, 07:16:51 »
I was about to say, that looks like a shopping list for plexi/poly fabrication!  What are you using as a router, if I may ask?  I've seen people recommend using trim routers for plexiglass, not sure my hand is that steady.
Offline The_Beast
  • I like wood ಠ_๏
« Reply #1452 on: Fri, 07 June 2013, 08:58:29 »
Nope, I'll be using wood, since I'm not a fan of acrylic cases at all. I'll be using 2 1/4 horsepower Milwaukee router shown here:
If you're worried about a steady hand use "MLCS 9674 Brass Template Guide Kit" and templates.
Offline Tarzan
« Reply #1453 on: Fri, 07 June 2013, 09:19:31 »
I appreciate the tip!
Offline YoHoJo
    • Memberize.Me
« Reply #1454 on: Sat, 08 June 2013, 08:57:22 »
Ducky Shine II, Blue LED, Brown Switches, My FIRST!
IT WILL SOON BE IN THE MAIL!  :eek:
Offline infiniti
  • I <3 KB
  • Bob was here
« Reply #1455 on: Sat, 08 June 2013, 09:09:41 »
Congratulations!  Be sure to post some pics in the Post your Duckies! thread when you do get it! ;)
Offline YoHoJo
    • Memberize.Me
« Reply #1456 on: Sat, 08 June 2013, 09:11:54 »
Ohh thank you I sure will do that when I get it!
« Reply #1457 on: Sun, 09 June 2013, 16:36:31 »
GON case arrives tomorrow.
And clear switches + 7x cherry stabs.
« Last Edit: Sun, 09 June 2013, 17:33:00 by Sifo »
Offline jksteger
« Reply #1458 on: Mon, 10 June 2013, 11:54:07 »
Vintage Monterey MTEK K104 Clicky Keyboard
http://www.ebay.com/itm/Vintage-Monterey-MTEK-K104-Clicky-Keyboard-/310678881606?pt=PCA_Mice_Trackballs&hash=item4855e78546
I don't know much about these.  I prefer Alps over Cherry and I think I read that these keyboards have blue sliders but they are NOT Alps.  Similar but better than Alps especially with the "offset" striking of the key.
I will see when It's delivered.
Jeremy Steger
« Reply #1459 on: Mon, 10 June 2013, 12:07:42 »
Quite a few things but I'm most excited about trying my first topre board!
Offline Tarzan
« Reply #1460 on: Mon, 10 June 2013, 12:15:35 »
Razer DA 2013
Hayate mouse pad
Aoyue 937+ Soldering Station (went with this one over the Hakko because I only have one small soldering job planned..._
Proxxon 38481 Rotary Tool
« Reply #1461 on: Mon, 10 June 2013, 12:44:08 »
People might not know this, but that is amazing news!
Offline VesperSAINT
  • vpsert
  • #CustomKorean
« Reply #1462 on: Mon, 10 June 2013, 16:17:06 »
Imsto Blank White Thick PBT's from kmiller ~ and Bunnycaps! Oh! and moose mail.
« Last Edit: Mon, 10 June 2013, 16:22:56 by VesperSAINT »
« Reply #1463 on: Mon, 10 June 2013, 16:35:26 »
Oh I've got IMSTO caps in the mail also!!!!
Offline VesperSAINT
  • vpsert
  • #CustomKorean
« Reply #1464 on: Mon, 10 June 2013, 16:36:55 »
The blue ones from kmiller?! Btw, what's the star for for you???
Offline Jocelyn
  • 조셀린
« Reply #1465 on: Mon, 10 June 2013, 16:37:10 »
So much stuff!!!
Did you pick up the blue set  from Kmiller or are you talking about Gray w/ black legends from "I forget who"? :)
« Reply #1466 on: Mon, 10 June 2013, 16:43:55 »
Over 1000 spam-ish posts. :P
Offline VesperSAINT
  • vpsert
  • #CustomKorean
« Reply #1467 on: Mon, 10 June 2013, 16:47:54 »
<3 <3 <3 Ray & 옥 잉어
But really???
« Reply #1468 on: Mon, 10 June 2013, 16:49:56 »
No I'm getting two bags of crap from kmiller...and pink is for posting (err spam) over 1000 times  ;D
http://geekhack.org/index.php?topic=44539.msg924706#new <- all you ever wanted to know and then some about stars
So much stuff!!!
No I got black on gray from L4yercake!
Over 1000 spam-ish posts. :p
and the silver is for even more spamming  ;D
Offline VesperSAINT
  • vpsert
  • #CustomKorean
« Reply #1469 on: Mon, 10 June 2013, 16:57:37 »
Is this forum now promoting me to spam post? ;D
« Reply #1470 on: Mon, 10 June 2013, 16:59:16 »
+1
Absolutely not!
Your pretty good at it already! ;)
Offline Jocelyn
  • 조셀린
« Reply #1471 on: Mon, 10 June 2013, 17:01:08 »
So much stuff!!!
Yes, I got black on gray from L4yercake!
FTFY, Gray w/ black legends was on of two guesses ;)
Offline VesperSAINT
  • vpsert
  • #CustomKorean
« Reply #1472 on: Mon, 10 June 2013, 17:07:16 »
+1
Absolutely not!
This gif could not be more appropriate right now with his character and me posting it in this situation :))
Offline Techno Trousers
  • ʘ_ಠ
« Reply #1473 on: Wed, 12 June 2013, 20:16:40 »
I finally have something to brag about here. Just lucked into finding and successfully ordering a brand new SGI "Granite" 9500900 keyboard! I've been looking off and on for an old school white Alps keyboard (ANSI layout preferred, which made it even harder) for many, many years now. So this is probably the ultimate Alps score I could have ever hoped for. White Bigfoot Alps FTW!  :cool: I need to ping the seller and see if I can get the story behind where they dug these up.
Any other 9500900 owners out there? Got any advice/tips/tricks for me?
25305-0
Offline calavera
« Reply #1474 on: Wed, 12 June 2013, 20:52:34 »
oh god, if the seller has any extras let me know I want one.
  • ʘ_ಠ
« Reply #1475 on: Wed, 12 June 2013, 21:41:22 »
Well, there were two for sale, and by the time I saw it there was only one left. The page counter shows only 12 views total. I'm just glad it was a "buy it now" and not an auction. I can't take that kind of pressure!  :p
I wrote to the seller to ask about the story behind these boards, and if they have any more they'll be selling in the future, so I'll let you know what I hear back.
  • ʘ_ಠ
« Reply #1476 on: Wed, 12 June 2013, 23:13:51 »
Bad news for now: Seller doesn't have any more 9500900s.  :(
Offline davkol
  •  Post Editing Timeout
« Reply #1477 on: Wed, 12 June 2013, 23:23:54 »
edit: wrong thread
Offline morpheus
« Reply #1478 on: Thu, 13 June 2013, 01:58:54 »
A red Topre ESC key
Offline KangarooZombies
  • HHKB Pro
  • ʕ•ᴥ•ʔ
« Reply #1479 on: Thu, 13 June 2013, 02:57:35 »
New monitor, new mouse, new laptop stand.
Really looking forward to the monitor (Dell U2913WM)
Having a bad day?
Offline y0fate
  • The Holy CBass.
« Reply #1480 on: Thu, 13 June 2013, 03:01:06 »
Post a review on the monitor if you can :P I am interested on what you think about the whole 21:9 thing
"No"- Greed
  • HHKB Pro
  • ʕ•ᴥ•ʔ
« Reply #1481 on: Thu, 13 June 2013, 03:03:49 »
Yeah I plan on reviewing it. From what i've seen, the monitor looks really good, and im a fan of the dell stands. We shall see about the resolution.
Having a bad day?
Offline y0fate
  • The Holy CBass.
« Reply #1482 on: Thu, 13 June 2013, 03:09:21 »
I've always loved Dell monitors, but the new resolution seems a bit unpractical when you could get two monitors for around the same price.
"No"- Greed
  • HHKB Pro
  • ʕ•ᴥ•ʔ
« Reply #1483 on: Thu, 13 June 2013, 03:12:35 »
I actually picked it up for 385ish which seems like a stellar price.
Having a bad day?
Offline y0fate
  • The Holy CBass.
« Reply #1484 on: Thu, 13 June 2013, 03:16:15 »
Hell, for almost 50% off retail price that's an outstanding deal.
"No"- Greed
Offline infiniti
  • I <3 KB
  • Bob was here
« Reply #1485 on: Thu, 13 June 2013, 18:57:49 »
Two replacement tips for my Hakko 936, 50 feet of soldering wick to make local shipping worth it, and a couple of LEDs to play around with. ;D
Offline missalaire
  • Great Finder of Great Finds
« Reply #1486 on: Fri, 14 June 2013, 16:58:42 »
Leopold FC700R graphite grey (MX Browns)
70 MX Clear switches
2x Team Liquid key caps
Green Tea Kit Kats
Offline daerid
    • Rossipedia
« Reply #1487 on: Fri, 14 June 2013, 17:26:49 »
4 2x stabilizer sets from WASD
Hakko fx888d with extra tip
Putting the Ergodox together on Sunday, yay!
Offline bianco
« Reply #1488 on: Sat, 15 June 2013, 11:08:20 »
not yet in the mail... but hopefully soon...
coffee keycap set and few others
Offline metalliccharles
« Reply #1489 on: Sat, 15 June 2013, 20:51:07 »
So I've got my first Ducky coming
(Shine II blue LED black switches to replace my Black Widow with LOUD blue switches haha)
I plan on getting the tray painted white and getting blacked out caps.  So I'll be talking to you guys in the project section soon!
Also just picked up the one on the right  :cool:
Offline bueller
  • MX baller
  • Church of the Ergo Clear
« Reply #1490 on: Sun, 16 June 2013, 03:04:45 »
Picked this guy up for $3 today, god bless flea markets! Wish I had've taken a photo before I cleaned the keys up and retrobrighted them, they look way better than what I expected. No idea what the board is as it has no identifying marks but the switches seem to be some sort of cherry white knockoff. Alpha keys and keypad are double-shot too which was a nice surprise! Left the case grubby to show how dirty it was when I picked it up  ;D
Also picked up an unbranded Alps white board with some severe yellowing for two dollars, going to retrobright that next weekend and see if I can bring it back to it's former glory!
« Last Edit: Sun, 16 June 2013, 03:06:28 by bueller »
Offline keymaster
  • Topre Revolution Theorist
« Reply #1491 on: Sun, 16 June 2013, 23:23:45 »
Kensington Slimblade Trackball :) can't wait
« Reply #1492 on: Sun, 16 June 2013, 23:55:16 »
Kailet teased me then gave me a tracking number...
« Reply #1493 on: Mon, 17 June 2013, 00:10:47 »
Even I'm excited about you receiving it :D
« Last Edit: Mon, 17 June 2013, 06:16:37 by Photekq »
Offline Tym
« Reply #1494 on: Mon, 17 June 2013, 06:15:11 »
Does that require its only 1000W PSU?
Offline Luke
    • My Technology Blog
« Reply #1495 on: Mon, 17 June 2013, 07:16:59 »
Is that a 2TU?
« Reply #1496 on: Mon, 17 June 2013, 10:51:13 »
YOU ARE THE ONLY ONE WHO UNDERSTANDS ME!
At least 1000W PSU, anything less and I wouldn't be able to signal the international space station.
Is that a 2TU?
Yes it is a 2TU :)  Beautiful work he's done.
Offline Luke
« Reply #1497 on: Mon, 17 June 2013, 10:54:32 »
Is that a 2TU?
[/quote]
Damn it, they are beautiful! I asked the guy who first posted about his on here a few months back if he could hook me up but it never happened....
Really dissapoint now :-X
Offline ITzNybble
  • Formerly curro123083
  • Nibble or Nybble either way it sounds delicious!
« Reply #1498 on: Mon, 17 June 2013, 10:55:15 »
 :o  sooooo Shiney....must have one for myself....congratz though tis a beauty
WASD V1 Custom - MX Blue
Custom Miami QFR - MX Green
Handwired Redox-Manuform - Box Pink/Box Navy
KBD67 MKII PolyCarbonate - Gateron CJ
« Reply #1499 on: Mon, 17 June 2013, 10:56:37 »
Is that a 2TU?
It's not too late, Kailet is the guy who makes these.  He's going to be travelling until July.  When he gets back I'd be happy to provide you some contact info.  This isn't the only kind of keyboard he makes :)
« Last Edit: Mon, 17 June 2013, 10:58:50 by Binge »
