Author Topic: Bug Reports  (Read 1135582 times)
Offline Mekberg
Re: Bug Reports
« Reply #1050 on: Tue, 16 July 2019, 07:19:23 »
I have a watched thread that I cannot unwatch. There is simply no action available to do so, where it would otherwise be on other threads. Could be because the thread is locked?
This thread: https://geekhack.org/index.php?topic=98238.0;topicseen
Offline Signature
  • master of puppers
  • * Marketplace Moderator
  • snoozing
Re: Bug Reports
« Reply #1051 on: Tue, 16 July 2019, 07:38:03 »
Follow my guide here: https://geekhack.org/index.php?topic=101528.msg2785011#msg2785011
Offline thickle
Re: Bug Reports
« Reply #1052 on: Sat, 05 October 2019, 02:49:43 »
Not sure if it's a bug specifically, but I've noticed a number of times while viewing the site that one or more of my CPUs is maxed out and Firefox appeared to be the primary culprit.  I've also noticed images taking quite a while to finish loading, which even with a few dozen images for a given IC/GB thread shouldn't take more than a second or two with my 100GB connection.  Most recently, I only had geekhack and two other already loaded pages open, so I can't imagine it was a load issue.  I haven't seen this happen with any other site.
Is there anything to the way the site is coded that would cause this or possibly something else unique about how GH interacts with FF?
Re: Bug Reports
« Reply #1053 on: Sun, 06 October 2019, 21:05:16 »
FWIW I use Firefox all the time to surf GH and have not noticed any behaviour such as you describe.
Re: Bug Reports
« Reply #1054 on: Mon, 04 November 2019, 21:11:27 »
my malwarebytes has been pinging me about "u.teknik.io" on some pages on GH
i'm about 60% sure it's a link someone that someone has in a sig or something, but pls investigate
can export the whole report if you need
Re: Bug Reports
« Reply #1055 on: Mon, 11 November 2019, 13:26:01 »
If you see this pop up again, can you PM me which threads it's appearing in?  It is not uncommon for sig links to trigger these things, especially with how a lot of spam accounts operate.
Re: Bug Reports
« Reply #1056 on: Mon, 11 November 2019, 15:36:13 »
Happens all over the site, I'll keep a log and send it to you.
Offline switchnollie
  • sleever supreme
  • greyhat co-leader
Re: Bug Reports
« Reply #1057 on: Mon, 11 November 2019, 15:45:06 »
I noticed some images here were hosted there, like the first one and kits.
https://geekhack.org/index.php?topic=100282.0
Re: Bug Reports
« Reply #1058 on: Mon, 11 November 2019, 15:51:48 »
does appear to be an image host just based on the fact that i think i get the notifications mostly in IC/GB/Media threads
Re: Bug Reports
« Reply #1059 on: Mon, 11 November 2019, 16:46:42 »
Huh.  Appreciate the info, you two.  :thumb:
A quick google search gave this result.  Looks like it may be flagged because of some rogue content, but the majority is fine.
Re: Bug Reports
« Reply #1060 on: Mon, 11 November 2019, 22:20:12 »
yeah, seems to be another slimg/i.bb/minus non-imgur image host that allows content that may not be allowed on other image hosts
https://geekhack.org/index.php?topic=100415.1300
https://geekhack.org/index.php?topic=103138.0
these three pages all send up flags, unless the flags are delayed in which case this is annoying
EDIT: this page also https://geekhack.org/index.php?topic=103277.50
« Last Edit: Tue, 12 November 2019, 15:32:54 by Puddsy »
Offline dvorcol
  • Discord: dvorcol_5071
Re: Bug Reports
« Reply #1061 on: Thu, 21 November 2019, 13:38:12 »
I couldn't access Geekhack after about noon yesterday.  It was super slow in the morning, and then I was getting 504 errors until about 21:00.  Was it just me?
  • sleever supreme
  • greyhat co-leader
Re: Bug Reports
« Reply #1062 on: Thu, 21 November 2019, 13:51:42 »
Sometimes sites be down for maintenance n stuff, my cloaker 😔✊
Re: Bug Reports
« Reply #1063 on: Thu, 21 November 2019, 16:43:31 »
Suuuuper slow for me yesterday too, not sure what happened though.  Will see if anyone on the back end can track it down.
Edit: Nothing too unusual, should be resolved going forward.  :thumb:
« Last Edit: Thu, 21 November 2019, 16:48:59 by HoffmanMyster »
Re: Bug Reports
« Reply #1064 on: Wed, 27 November 2019, 04:51:54 »
Site was down for me last night just after 11 UK time, been happening a lot recently.  Something about guru mediation then goes to 504 after a couple of minutes.  It's always fixed by the morning...
Perhaps more annoyingly I'm having problems with the laghing emoji not laughing - it appears as :) followed by ) in case it's just me.  Example :))
Offline Sedula
Re: Bug Reports
« Reply #1065 on: Sun, 08 December 2019, 17:42:29 »
Unexpected search behavior happening: When trying to find this thread by searching for "cajal", it only shows up if I go to "Advanced search" and check the "Search in topic subjects only" box. Searching straight from the top-right search box or from the advanced page without checking that box and there's nothing.
Re: Bug Reports
« Reply #1066 on: Wed, 11 December 2019, 11:29:49 »
Well that's unfortunate.  :|  I'll poke around in the server settings to see if there are any better search options we're not using.
As a general note, as much as it sucks to admit, it's almost always best to use google with the 'site' modifier included.  For anyone unfamiliar, the search in this case would then be as below
Code: [Select]
cajal site:geekhack.orgwhich does lead straight to the desired thread.
PS: Hooray!  Another Milwaukee GHer!  :D
Offline Sedula
Re: Bug Reports
« Reply #1067 on: Wed, 11 December 2019, 12:35:19 »
Good to know; I'll swap to Google for the time being. (Would it be worthwhile to just pipe the default search box straight into a custom Google search, and then leave the "Advanced search" page as-is?) Also, hi, small world!
Re: Bug Reports
« Reply #1068 on: Wed, 11 December 2019, 14:04:40 »
Hmm, that's a good thought.  I have seen sites that do that, but don't see it readily as an option on the backend.  I'll look into it and see what our options are.  :thumb:  Thanks for the suggestion!
Re: Bug Reports
« Reply #1069 on: Wed, 11 December 2019, 14:28:53 »
harass will to do it, it would be a lot better than GH search as it currently stands
Offline nickheller
  • Cherry ML life
    • hickneller.com
Re: Bug Reports
« Reply #1070 on: Wed, 11 December 2019, 15:09:10 »
harass 27 to finish his gb (or at least give an update)  :rolleyes: :rolleyes:
Re: Bug Reports
« Reply #1071 on: Wed, 11 December 2019, 15:43:11 »
i haven't talked to him in months, i know as much as the rest of you
Offline fatboycarney
503 error when submitting GB OP
« Reply #1072 on: Sun, 12 January 2020, 22:33:39 »
Hello
Hope this is the right place to post this, trying to submit my GB new topic and getting the following after it appears to upload to 100 percent
Preview looks fine. No images attached larger than 6-7 MB which appears well within the recommendations. I even went back and put some smaller images in but same thing. I can try and just submit one with no images and see if it works but wanted to post here first.
Error 503 Service Unavailable
Service Unavailable
Guru Meditation:
XID: 1906987912
Varnish cache server
Update
Worked around the issue by trimming the inital submission down and then adding to it afterwards and no problems.
« Last Edit: Sun, 12 January 2020, 23:33:15 by fatboycarney »
Offline Coreda
Re: Bug Reports
« Reply #1073 on: Sat, 11 April 2020, 07:33:57 »
The animated laughing emoticon doesn't work anymore. Noticed this a few days ago in my own post editing preview and again today in someone else's post.
Eg:
That should have been converted to this emoticon (posted as img element below):
Re: Bug Reports
« Reply #1074 on: Wed, 15 April 2020, 15:34:52 »
Eg:
I noticed this too.  Makes me sad.  :(  I use the laughing one a lot.
Re: Bug Reports
« Reply #1075 on: Fri, 24 April 2020, 20:04:46 »
Eg:
Is this really recent thing for you two?  It's not worked for months here...
Offline Coreda
Re: Bug Reports
« Reply #1076 on: Sun, 26 April 2020, 12:54:11 »
Personally only noticed it recently but could have occurred earlier.
Re: Bug Reports
« Reply #1077 on: Tue, 28 April 2020, 19:21:26 »
I can't use Opera to access Geekhack because it said that I was banned after turning on my VPN; however, it works fine on every other web browser. Could anyone tell me what went wrong?
Edit: It has been fixed.
« Last Edit: Tue, 28 April 2020, 20:49:35 by rychaithescienceguy »
Re: Bug Reports
« Reply #1078 on: Tue, 28 April 2020, 23:21:05 »
Eg:
No, it's been going on for quite some time.  I kept forgetting to post about it though, until Coreda reminded me.
Offline TheAlchemist-404
Re: Bug Reports
« Reply #1079 on: Mon, 11 May 2020, 18:02:30 »
Hey guys, i don't know if someone already spoke about it but text scaling on mobile, makes the site painful to navigate
Offline SirTimmyTimbit
Re: Bug Reports
« Reply #1080 on: Sat, 16 May 2020, 03:28:16 »
Not necessarily a bug, but the captchas in quick reply are terrible. You can barely read them. Only way to solve them is to listen to the letters.
Why not implement Google's re-captcha instead?
At what level / # of posts will I not have to do them anymore?
Offline Adelscott
Re: Bug Reports
« Reply #1081 on: Mon, 18 May 2020, 02:42:18 »
Bug in Tapatalk search in thread function. Could be because the plugin is outdated. See https://geekhack.org/index.php?topic=106141.0
Please think about ISO users, add a split left shift to your "alice style" keyboards
Offline user 18
Re: Bug Reports
« Reply #1082 on: Sun, 14 June 2020, 16:14:24 »
For future reference, the ban on VPNs sets a browser cookie, this can be resolved by clearing your cookies (although if you continue to try to access the site through your VPN, it'll just trigger the ban again). See: https://geekhack.org/index.php?topic=57803.0
Avatar by ashdenej
Re: Bug Reports
« Reply #1083 on: Sun, 14 June 2020, 17:25:53 »
I wasn't able to logon using tapatalk for a month or so it worked last week now it is not letting me login in again. I get a few different errors but I'm definitely using the correct username and password.
Using tapatalk 8.8.6 on android 10
Offline user 18
Re: Bug Reports
« Reply #1084 on: Sun, 14 June 2020, 18:00:34 »
If you use tapatalk for any other communities, does it let you log into those?
Avatar by ashdenej
Re: Bug Reports
« Reply #1085 on: Mon, 15 June 2020, 13:14:09 »
Yes other forums work fine.
And geekhack is currently working but it was not yesterday....weird.....
Sent from my SM-G970U1 using Tapatalk
Offline fourpastmidnight
Re: Bug Reports
« Reply #1086 on: Thu, 13 October 2022, 15:56:20 »
I seem to be running into a bug with using a bulleted list in my signature. I properly formatted a list in my signature and proceeded to add additional content. But no matter what, GH seems to want to add an additional closing list bbcode to the signature, resulting in a less than desirable appearance of my signature. I tried searching this entire forum thread to see if this was previously reported, but I didn't see anything, so I thought I'd report it.
My Keebs:
  • Northgate OmniKey Model 102
  • Keychron Q6 (Coming soon)
  • Wasd v3 Hotswap (for my young son)
Heatware Profile
Offline Signature
  • master of puppers
  • snoozing
Re: Bug Reports
« Reply #1087 on: Thu, 13 October 2022, 19:18:13 »
can you Post the raw bb-code of the signature?
Re: Bug Reports
« Reply #1088 on: Sat, 15 October 2022, 14:29:23 »
Thanks for getting back to me. I really appreciate it. Can you believe it (I'm sure you can  ;)), but when I went to go reproduce the issue, it worked completely fine? Again, I really appreciate you taking the time to reach out to my comment.
Best Regards
My Keebs:
Heatware Profile
Offline Signature
  • master of puppers
  • snoozing
Re: Bug Reports
« Reply #1089 on: Sun, 16 October 2022, 05:36:12 »
Best Regards
All good, glad it worked out in the end  :thumb:
Offline OhNine
Re: Bug Reports
« Reply #1090 on: Thu, 24 November 2022, 10:37:57 »
Well, this isnt really a bug but more like a flaw. Well this is my first day on this site and I decided to make an account. I entered all of my information but when it told me to activate my account by pressing on the email they sent me, that would be fine but. I didnt get any email so the account wasnt activated. Though it was still registered. So i couldnt use the same email or username. I had to use my laptop to make an account and log onto it on my pc so I could even use geekhack, And I really want to change my username back to what it was but it is taken because of my other account. Please fix this so I can go back to my original username  :)
Offline user 18
Re: Bug Reports
« Reply #1091 on: Fri, 25 November 2022, 05:55:22 »
This is a known issue with some email providers, but as far as I'm aware, no fix has yet been found. Please PM me the details of the other account, and I will take a look, and add this to the list of known cases of this problem.
Avatar by ashdenej
Offline fairypenguin
  • zzz
Re: Bug Reports
« Reply #1092 on: Wed, 05 April 2023, 15:05:34 »
I've been needing to change my password, but never receive the required email authentication following a request. This also happened when I set up my account and had to verify it.
Re: Bug Reports
« Reply #1093 on: Wed, 05 April 2023, 16:29:01 »
I'll help with this - PM incoming
PS, happy two year anniversary here!! :D
« Last Edit: Wed, 05 April 2023, 16:30:36 by HoffmanMyster »
Offline Protomartyr
Re: Bug Reports
« Reply #1094 on: Tue, 02 May 2023, 13:35:30 »
Hello! I believe my IP has been wrongfully banned as I'm getting this message when trying to access the site from my home computer:
An Error Has Occurred!
Sorry Guest, you are banned from using this forum!
This ban is not set to expire.
It remains after deleting cookies. I can only access and login from my phone data or ironically from my computer when using a VPN. Is there someone I should PM my IP to possibly get it cleared?
Offline user 18
Re: Bug Reports
« Reply #1095 on: Wed, 03 May 2023, 02:00:30 »
Send me a PM and I will take a look at it  :thumb:
Avatar by ashdenej
  • zzz
Re: Bug Reports
« Reply #1096 on: Tue, 05 December 2023, 22:14:08 »
Reviving a dead thread to ask if a moderator/admin could help manually change my email... :[ Still not able to change my password to one I'll actually remember (and security question doesn't seem to work), but every time I request a reset email, nothing happens. Kinda sucks, since I switched to Firefox earlier this year, and so I have to open Chrome on my desktop (where my account info is saved) any time I want to browse the forum on this account.
Hoping this is something that can be helped. It's a bit of a pickle, lol.
Also open to just making a new account if this is too much of a hassle, though.
Offline user 18
Re: Bug Reports
« Reply #1097 on: Thu, 04 January 2024, 12:12:12 »
I'm guessing you use gmail? This is a known issue, but we don't quite know why it happens. PM myself and/or HoffmanMyster, and we can help you out.
Avatar by ashdenej
Offline ninjadoc
Re: Bug Reports
« Reply #1098 on: Wed, 27 August 2025, 18:02:37 »
Is search broken? I haven't been able to search anything for over a month.
Re: Bug Reports
« Reply #1099 on: Thu, 28 August 2025, 13:38:41 »
It does seem to be. TBH the on-site search has never been great, I'd recommend using "site:geekhack.org" on google or another search engine instead.
That said, I did raise this to the dev team to see about addressing.
