Author Topic: Bug Reports  (Read 1109632 times)
Offline tbc
Re: Bug Reports
« Reply #700 on: Mon, 18 May 2015, 17:27:03 »
quoting it fine on firefox for win8
Re: Bug Reports
« Reply #701 on: Mon, 18 May 2015, 17:47:12 »
I'm trying to quote someone and am getting a "LOADING..." bar stuck at the top of my page in firefox. Tried several times since 6am.
EDIT: same with IE
And it was this post I was trying to quote:
https://geekhack.org/index.php?topic=33088.msg1749327#msg1749327
I cannot quote that post either, using Chrome on Mac.
There are some users whose posts generally cannot be quoted at all, and other posts that cannot be quoted at random.
But Chrome under Windows 7 works (for me).
Weird.
Re: Bug Reports
« Reply #702 on: Mon, 18 May 2015, 17:56:59 »
Quotes fine for me in Firefox under Linux.
Offline swill
  • builder & enabler
    • swillkb.com
Re: Bug Reports
« Reply #703 on: Tue, 26 May 2015, 10:14:41 »
Can we get the latest Tapatalk version installed on the server to see if it will fix the problems with the 'Unread Posts' (and timeline) being empty?  This is getting really frustrating.
Offline azhdar
  • Praise the AZERTY god
Re: Bug Reports
« Reply #704 on: Wed, 03 June 2015, 02:11:45 »
I've been using the quick replay function for a little week now and sometimes, when I want to quick reply with a quote, the quote won't load. And then if I do a normal reply and try to insert the quote, It won't work.
Azerty Propagandiste
Re: Bug Reports
« Reply #705 on: Wed, 03 June 2015, 15:11:38 »
That happens sometimes.
Sometimes it seems to be a problem quoting one user's posts.
Other times it almost seems random.
Someone said that if you middle click the "Quote" link to open the reply in a new tab, it works every time.  I have yet to encounter an unquotable post to try that.
Re: Bug Reports
« Reply #706 on: Wed, 10 June 2015, 10:17:29 »
Anyone else having trouble with Tapatalk notifications? Mine have stopped working all of a sudden.
Offline wlhlm
Re: Bug Reports
« Reply #707 on: Wed, 10 June 2015, 11:18:55 »
Works for me™ on Android.
Re: Bug Reports
« Reply #708 on: Wed, 10 June 2015, 12:03:48 »
What version of Tapatalk are you using?
Offline wlhlm
Re: Bug Reports
« Reply #709 on: Wed, 10 June 2015, 12:10:16 »
They've pushed out an update today which I hadn't installed yet. I'll see if I get the same problem as you.
« Last Edit: Wed, 10 June 2015, 12:38:10 by wlhlm »
Re: Bug Reports
« Reply #710 on: Wed, 10 June 2015, 12:35:48 »
They've pushed out an update today which I hadn't installed yet. I'll if I get the same problem as you.
I'm still using 4.9.5 because after that version they totally screwed everything up with the user interface.
I'm thinking my notifications worked up until the recent changes that made youtube videos work again...not sure if related or not.  :-\
Offline wlhlm
Re: Bug Reports
« Reply #711 on: Wed, 10 June 2015, 12:42:43 »
The lastest (4.15.5) works fine (on Lollipop).
Judging by how often they changed the UI in the last half a year, it looks like they don't have any sense for interface design and seem clueless trying to get rid of those negative reviews. Makes me sad.
I'd also appreciate it if the app finally stop appending "Re:" to every PM. My inbox is a mess. :mad:
Offline azhdar
Re: Bug Reports
« Reply #712 on: Fri, 03 July 2015, 03:55:40 »
Since we're back online :
- look like embed videos are broken again : https://geekhack.org/index.php?topic=34445.3550
- thread don't always get read when we browse them
Offline iMav
  • geekhack creator/founder
Re: Bug Reports
« Reply #713 on: Fri, 03 July 2015, 04:46:58 »
Those embedded vids play fine for me. What is the behavior you are seeing?
Offline azhdar
Re: Bug Reports
« Reply #714 on: Fri, 03 July 2015, 04:51:06 »
It seems to broke the css of the page :
http://i.imgur.com/ODEfsqs.png
Firefox 38.0.5 on win xp.
I think I saw it too on my personnal computer which is with chrome and win 7.
Offline wlhlm
Re: Bug Reports
« Reply #715 on: Fri, 03 July 2015, 04:54:20 »
Breaks for me as well. Firefox 38.0.5 on Win7. Same behaviour in Firefox 39.
Offline Zeal
    • Zeal Generation Inc.
Re: Bug Reports
« Reply #716 on: Fri, 03 July 2015, 05:17:44 »
GH's SEO seems to be broken? No Geekhack topics show up if you google: ________ geekhack
It has to be typed as    site:geekhack.org _____________ for topics to show up.
For example:
site:geekhack.org cherry mx switch lubrication guide
vs
cherry mx switch lubrication guide geekhack
geekhack.org cherry switch lube guide (same thing, no GH thread shows up)
« Last Edit: Fri, 03 July 2015, 05:20:19 by Zeal »
Offline iMav
Re: Bug Reports
« Reply #717 on: Fri, 03 July 2015, 05:31:06 »
For example:
vs
Resolving this with google now.  Googlebot stops crawling the site after no long not being able to access it.  I submitted the fetch request.
Re: Bug Reports
« Reply #718 on: Fri, 03 July 2015, 10:44:30 »
Notification emails are coming in out of order/multiples/late
Offline baldgye
  • Will Smith Disciple
Re: Bug Reports
« Reply #719 on: Fri, 03 July 2015, 15:37:36 »
Offline inanis
  • Truly Literally The Cloud
    • SEALWoodworking
Re: Bug Reports
« Reply #720 on: Fri, 03 July 2015, 15:40:59 »
Offline iMav
Re: Bug Reports
« Reply #721 on: Fri, 03 July 2015, 16:13:44 »
So, has this same behavior been identified before and resolved?  (You said "broken again")
Offline tbc
Re: Bug Reports
« Reply #722 on: Fri, 03 July 2015, 17:21:24 »
in this thread https://geekhack.org/index.php?topic=69665.msg1789617
took a look at it.
NOT a css problem.
the page html is being generated incorrectly.
the .post for captain's post is holding all the following posts.
Offline mkawa
  •  No Marketplace Access
  • (ツ)@@@. crankypants
Re: Bug Reports
« Reply #723 on: Fri, 03 July 2015, 17:39:49 »
looks like there are multiple issues. one is a css error in firefox and one is table breakage in a the austere theme
i'm setting up some back-end stuff right now. i'll take a look once we have revision control back up and running and a way to test the fix that's not live.
Offline tbc
Re: Bug Reports
« Reply #724 on: Fri, 03 July 2015, 17:49:06 »
mkawa, it's also on the 'classic' scheme.  or w/e the orange and black one is called
EDIT:
I'm seeing it on chrome as well.
firefox developer edition v41 and w/e the latest chrome is.  windows 8.1
it looks like the youtube player isn't self-closing its div tags properly...
EDIT2:
also...there are TWO 'instances' of the youtube player?  each youtube player uses the same ID twice.  so there are 4 instances of the same ID being used.
can cpt or a mod edit the post and remove the player and see if that changes anything?
« Last Edit: Fri, 03 July 2015, 17:55:29 by tbc »
Offline mkawa
Re: Bug Reports
« Reply #725 on: Fri, 03 July 2015, 18:08:36 »
yes, the way the original code was set up overlays the initial play button on the youtube preview, then fetches the youtube video and layers it on top of the previews. some of this is done with jquery library methods that have been changed in recent versions of jquery.
Offline Jokrik
Re: Bug Reports
« Reply #726 on: Sat, 04 July 2015, 00:37:26 »
Edit: nvm it's the ISP  :-X
« Last Edit: Sat, 04 July 2015, 01:10:43 by jokrik »
Offline XMIT
  • formerly jsoltren
Re: Bug Reports
« Reply #727 on: Sat, 04 July 2015, 07:08:05 »
Is forum search working? I just typed in “Novatouch” into the search box at the upper right of GH, hit Enter, and saw no results. PPW__ on IRC had the same result.
Offline wlhlm
Re: Bug Reports
« Reply #728 on: Sat, 04 July 2015, 07:11:03 »
Same for me.
Offline iMav
Re: Bug Reports
« Reply #729 on: Sat, 04 July 2015, 08:04:44 »
Fixing now.
Offline iMav
Re: Bug Reports
« Reply #730 on: Sat, 04 July 2015, 08:09:48 »
Should be functional now.  We'll see if it continues to update...
Offline wlhlm
Re: Bug Reports
« Reply #731 on: Sat, 04 July 2015, 12:38:57 »
I have occasional problems with threads not getting marked as read:
I enter a thread from spy jumping to the first unread post, but the thread sometimes still shows up in the watched-tab afterwards.
« Last Edit: Sat, 04 July 2015, 12:43:49 by wlhlm »
Offline CommonCurt
  • One of the cool kids
  • 🍒 Beige or Bust
    • My Flickr Page
Re: Bug Reports
« Reply #732 on: Sat, 04 July 2015, 12:42:56 »
I jump to a thread from spy jumping to the first unread post, but the thread sometimes still shows up in the watched-tab afterwards.
Same thing happens to me also.
Some of Ye ole  Keyboards -->
WTB/WTS/WTT ---->
Offline mkawa
Re: Bug Reports
« Reply #733 on: Sat, 04 July 2015, 13:27:25 »
Offline mkawa
Re: Bug Reports
« Reply #734 on: Sat, 04 July 2015, 13:28:17 »
that's a minor race condition in the db queries. i suspect we need to tighten up the transaction settings a bit.
it looks like it has something to do with the all display code.
« Last Edit: Sat, 04 July 2015, 13:47:03 by mkawa »
Offline wlhlm
Re: Bug Reports
« Reply #735 on: Sat, 04 July 2015, 14:20:55 »
BTW, is the limitation, that smileys aren't rendered when the post includes a quote with an image specific to Geekhack, or a problem with SMF in general?
Example:
:thumb: :( :P :eek:
Offline mkawa
Re: Bug Reports
« Reply #736 on: Sat, 04 July 2015, 14:58:29 »
it's probably highslide. i'll toss it on the todo list.
please report any and all performance problems you see. at the bottom of every page there is a line like so:
> Page created in 0.092 seconds with 17 queries
it should never take more than a 1s to compute a page. if you see a slow loading page, please paste the link into this thread and the timing data (as above)
Offline baldgye
Re: Bug Reports
« Reply #737 on: Sat, 04 July 2015, 18:53:43 »
Just a heads up, not a life changing issue, but I keep getting server 500 errors when I try and upload an image to my profile gallery!
Offline mkawa
Re: Bug Reports
« Reply #738 on: Sat, 04 July 2015, 19:42:51 »
adsf
Offline mkawa
Re: Bug Reports
« Reply #739 on: Sat, 04 July 2015, 19:50:39 »
fixed
Offline CommonCurt
  • 🍒 Beige or Bust
    • My Flickr Page
Re: Bug Reports
« Reply #740 on: Sun, 05 July 2015, 00:07:45 »
I had a issue with adding a photo to my profile gallery also.  I didn't get a error, but all it did was load the text, and it's not showing the picture.
Now the text just seems to be stuck there.  Can be seen here (Top Left)   https://geekhack.org/index.php?action=profile;area=pictures;u=30202
« Last Edit: Sun, 05 July 2015, 15:44:53 by CommonCurt »
WTB/WTS/WTT ---->
Re: Bug Reports
« Reply #741 on: Sun, 05 July 2015, 00:24:44 »
Example:
:thumb: :( :P :eek:
This has been happening for a very long time.
Re: Bug Reports
« Reply #742 on: Sun, 05 July 2015, 01:34:18 »
I'm seeing some really weird formatting errors.  At first I thought it was my internet connection, which plays up sometimes in wet weather, but it is happening consistently.
For example: https://geekhack.org/index.php?topic=69665.msg1673733#msg1673733
Looks like the following in Chrome and Firefox on OS X:
104513-0
Note that it is CPT's post linked above - I scrolled up slightly so that the previous post can be seen as ok, and CPT's post borks the layout somehow.
Offline mkawa
Re: Bug Reports
« Reply #743 on: Sun, 05 July 2015, 01:43:48 »
yah, i've been seeing that too.
highslide -> broken, parsing error
ultimate profile -> possibly broken
mysterious formatting errors
database writes not serialized
Re: Bug Reports
« Reply #744 on: Tue, 07 July 2015, 06:03:49 »
The "new posts" icon is not disappearing for me in a consistent way.
If I open Classifieds, for example, it shows a dozen threads with new posts.
If I click the "mark read" button the page reloads, but the new posts icons are still there.  If I force-reload the page, they disappear.
Same if I try to view one of the threads with new posts.  For example if I go into off topic and click on the "new post" icon on the "what's bothering you" thread, I see the first new post (by beehatch).  If I go back to off topic, the thread is still flagged as having new posts, and if I click the icon again I go to the same "new" post, even though I have already viewed it.  If I force-reload the off topic index page, the icons disappear.
This is with Firefox on OSX.
Re: Bug Reports
« Reply #745 on: Tue, 07 July 2015, 06:06:39 »
And it won't let me edit the post.  I wanted to add that it happens with Chrome on OSX too, but when I typed that in the modify window and posted, it said I haev already made that post and was I trying to resubmit, which I wasn't.
Offline baldgye
Re: Bug Reports
« Reply #746 on: Tue, 07 July 2015, 06:57:47 »
to continue what Rowdy was saying, when I post in a section (like Media) it wont say that it's 'read' and will still list the 'newest' post as one before... for example in media atm I just posted in 'what you got in the mail' yet it still says the newest post is in 'post your topre keyboard' and that I've not read it
Offline wlhlm
Re: Bug Reports
« Reply #747 on: Tue, 07 July 2015, 07:14:37 »
Maybe it's related to this, which still happens to me:
[snip]
No, seems to be different problem.
« Last Edit: Tue, 07 July 2015, 07:22:07 by wlhlm »
Offline absyrd
  • CPT HYPE PADAWAN
Re: Bug Reports
« Reply #748 on: Tue, 07 July 2015, 07:33:50 »
Posting lag? Both the wyfe and I have the same problem this morning with our posts not showing up unless we close browser and log back in.
EDIT: Also won't let me log out. This is on Firefox.
Re: Bug Reports
« Reply #749 on: Tue, 07 July 2015, 07:44:10 »
I tried to remove the video and I get this error:
An Error Has Occurred!
You already submitted this post! You might have accidentally double clicked or tried to refresh the page.
Spy previously updated itself. Now it seems like it won't automatically update unless I hit F5. I'm on Chrome.
