Author Topic: What did you get in the mail today?  (Read 25675498 times)
« Reply #28400 on: Fri, 30 January 2015, 21:37:21 »
where can i download these friends
http://www.downloadmoreram.com/
computer to fast to be on gh. need to ascend to higher levels. good bye friends.
Offline baldgye
  • Will Smith Disciple
« Reply #28401 on: Sat, 31 January 2015, 02:49:47 »
Does this mean you've moving to DT??
« Reply #28402 on: Sat, 31 January 2015, 03:37:25 »
I got some DSA blanks to complete the set for my JD40 - anyone see the problem?
Only 1x 1.75 in orange :(
At least I ordered black ones too...
Offline p3lim
« Reply #28403 on: Sat, 31 January 2015, 06:04:25 »
Sadly, the spacebar stabilizers Ivan sent me a few weeks back doesn't fit :<
« Last Edit: Sat, 31 January 2015, 06:08:27 by p3lim »
Offline tigersharkdude
« Reply #28404 on: Sat, 31 January 2015, 08:30:40 »
not in the mail but.. i gave in.
i gave in to the console peasantry.
Bro you hittin up dat Destiny?
Destiny is love
Destiny is life
u level 32 bro? Otherwise you aint 1337
3 31s :(
I'm deaf and can't find a group to run the new raid with :(
People think I must suck since I'm deaf
Offline baldgye
« Reply #28405 on: Sat, 31 January 2015, 08:36:54 »
Destiny is love
Destiny is life
3 31s :(
That really sucks... my ps3 mic is broken so I'm limited with what I can do, also playing on PS3 limits it again... the lack of any match making of any kind for the raids and the fact there is no real way to actually get a group of people together in game is a joke and part of the reason why when I got to lvl 32 I stopped playing and never went back.
Offline DrHubblePhD
  • I am star stuff
« Reply #28406 on: Sat, 31 January 2015, 08:42:30 »
Destiny is love
Destiny is life
3 31s :(
Any GHer is welcome in my clan :thumb:
« Reply #28407 on: Sat, 31 January 2015, 09:22:27 »
Destiny is love
Destiny is life
3 31s :(
GraciaS Senor
PS4? My Psn id is my username here
Offline GSimon
« Reply #28408 on: Sat, 31 January 2015, 09:48:00 »
Darn, wonder if my SmallFry board/future projects will have the same issue.
Offline p3lim
« Reply #28409 on: Sat, 31 January 2015, 09:56:14 »
I don't know yet what is wrong though, might be the plate (which would suck a lot more than if it's the stabilizers)
Some more images, including the problem with the stabilizer: https://imgur.com/a/3RqlH
Offline strict
  • TKL Zealot
« Reply #28410 on: Sat, 31 January 2015, 09:58:25 »
That's okay, just use costar stabs. Costar > Cherry anyway  :thumb:
Offline DrHubblePhD
  • I am star stuff
« Reply #28411 on: Sat, 31 January 2015, 09:58:39 »
Destiny is love
Destiny is life
3 31s :(
GraciaS Senor
ill send you an invite on psn  :thumb:
Offline GSimon
« Reply #28412 on: Sat, 31 January 2015, 09:59:10 »
Oh weird, I figured it was because you had the bend stabilizer wire like I do.
Blasphemy!
Ya'll need to learn to do single quotes.
« Last Edit: Sat, 31 January 2015, 10:02:30 by GSimon »
Offline billnye
  • ability man
« Reply #28413 on: Sat, 31 January 2015, 09:59:51 »
:-\ :-X :confused: :mad:
Offline p3lim
« Reply #28414 on: Sat, 31 January 2015, 10:28:15 »
I tried them both for an extended period of time, and I definitely prefer cherry.
« Reply #28415 on: Sat, 31 January 2015, 11:20:26 »
does that snoozefest still only get 3 posts per day?
« Reply #28416 on: Sat, 31 January 2015, 11:24:37 »
That's probably because you spec'ed a 6.00-unit spacebar in your design, and that's a 6.25-unit spacebar stabilizer. :)
Offline DrHubblePhD
  • I am star stuff
« Reply #28417 on: Sat, 31 January 2015, 11:30:16 »
I think you mean he is ascending to r/truegeekhack
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #28418 on: Sat, 31 January 2015, 11:32:58 »
I did send 6u stab, from my private collection. Perfect with 6u spacebar from Cherry so... But 6u should be like 1 outside cut and one inside cut right?
« Last Edit: Sat, 31 January 2015, 11:37:01 by IvanIvanovich »
« Reply #28419 on: Sat, 31 January 2015, 12:03:33 »
Okay, so I just checked the CAD drawings I sent p3lim for this plate. The distance between the centers of the outside stab cuts (Cherry) is 95.25 mm. Ivan, can you verify that the length of a Cherry 6u stab bar is 95.25 mm?
Distance from the offset switch center to the right side stab cutout center is 38.1 mm (2u). Distance to the left stab cutout center is 57.15 mm (3u).
The centered switch hole and inside stab cutouts are for SP 6u DSA spacebars (stab cutouts both 38.1 mm (2u) from center).
Offline p3lim
« Reply #28420 on: Sat, 31 January 2015, 12:12:18 »
The stabilizer in the image is indeed a 6.00, I have all 4 sizes at this point.
I measured the stabs Ivan sent me, the 6.00 measures ~96.5mm.
Edit: the 6.00 spacebar he sent me was 96.5mm center-to-center, .2mm more than what I wrote earlier (typo)
« Last Edit: Sat, 31 January 2015, 15:47:25 by p3lim »
« Reply #28421 on: Sat, 31 January 2015, 12:26:39 »
I measured the stabs Ivan sent me, the 6.00 measures ~96.3mm.
That's very strange. According to the DT Wiki (edited by 7bit on 31 AUG 14), the dimensions should match the ones I used in the drawing. Can you measure the distance between the stab stems inside the actual spacebar? Maybe we can just bend you a new stab bar that will work.
http://deskthority.net/wiki/Space_bar_dimensions#6_units_.28114mm_wide.2C_3_keymounts.2C_57mm_and_38mm_apart.29
Offline p3lim
« Reply #28422 on: Sat, 31 January 2015, 12:45:48 »
The plate's spacebar cutout is identical to the cad, I measured multiple times to make sure it was not any mistakes made from the cutter.
I asked Ivan through a pm, and he confirmed that the sizes were correct, yet I have a mismatch.
I won't know for sure what is really wrong until I get the keycaps (which I have yet to get).
« Last Edit: Sat, 31 January 2015, 15:50:16 by p3lim »
Offline pexon
  • El Jefe of Sleeving
    • Pexon PCs
« Reply #28423 on: Sat, 31 January 2015, 13:43:21 »
11" Acer Chromebook (yes the chiclet keys are nasty, but its pretty neat bit of kit)
2x 16GB USB Flash Drives
Sleeve for the Chromebook
Now I have an excuse to get a 40% board and to make a cable for it! :D
Offline exitfire401
  • The Force is Re/\l
« Reply #28424 on: Sat, 31 January 2015, 16:50:24 »
Got some of these!
Sprit Disco board is officially happening!
Offline DrHubblePhD
  • I am star stuff
« Reply #28425 on: Sat, 31 January 2015, 16:52:17 »
Got some of these!
How did I not know these existed?  :eek:
Offline Zeal
    • Zeal Generation Inc.
« Reply #28426 on: Sat, 31 January 2015, 16:55:56 »
Got some of these!
The 2x3x4mm RGB LEDs are the hard ones to source...Only Sprit has them afaik.
Offline exitfire401
« Reply #28427 on: Sat, 31 January 2015, 16:56:37 »
Got some of these!
Yeah, he never responded to me about them, so I had to find another source. Got mine off of ebay.
Offline DrHubblePhD
  • I am star stuff
« Reply #28428 on: Sat, 31 January 2015, 16:58:14 »
Got some of these!
link or it doesnt exist.  :))
Offline exitfire401
« Reply #28429 on: Sat, 31 January 2015, 17:02:36 »
Got some of these!
http://www.ebay.com/itm/100pcs-3mm-Round-Slow-7-Color-Changing-3-5-4-5V-20mA-RGB-LED-US-Seller-/251601080330?pt=LH_DefaultDomain_0&hash=item3a9497d00a
Offline DrHubblePhD
  • I am star stuff
« Reply #28430 on: Sat, 31 January 2015, 17:03:43 »
Offline katushkin
  • Too Keycool for School
  • Just the guy
« Reply #28431 on: Sat, 31 January 2015, 17:03:52 »
I never thought I would become a part of the club where people do favours and give you things for free. But it's finally happened. A couple of days ago I received two rather amazing things in the post from Holland.
My first KBK, and my first Hellboy. Seriously awesome. Thank you to Grim Fandango, and also to Beserkfan for thinking of me and bestowing these two amazing Topre caps on me. It is now my duty to get a kickass topre board to compliment them both.
Offline azhdar
  • Praise the AZERTY god
« Reply #28432 on: Sat, 31 January 2015, 17:05:17 »
Got some of these!
You need a special pcb to make them work ?
Azerty Propagandiste
Offline exitfire401
« Reply #28433 on: Sat, 31 January 2015, 17:08:27 »
Got some of these!
Nope. Here they are in a stock poker 2.
« Last Edit: Sat, 31 January 2015, 17:11:06 by exitfire401 »
Offline billnye
  • ability man
« Reply #28434 on: Sat, 31 January 2015, 17:12:37 »
Offline DrHubblePhD
  • I am star stuff
« Reply #28435 on: Sat, 31 January 2015, 17:16:17 »
10/10 would type on with dirty fingers.  :p
Offline Michael
  • Formerly Bro Caps
« Reply #28436 on: Sat, 31 January 2015, 17:18:50 »
Offline billnye
  • ability man
« Reply #28437 on: Sat, 31 January 2015, 17:19:48 »
bruh smh
Offline wupi
« Reply #28438 on: Sat, 31 January 2015, 17:24:43 »
WASD Keycaps for my HHKB, i like green <3  :D
Offline iAmAhab
  • Established member
« Reply #28439 on: Sat, 31 January 2015, 17:28:19 »
Are these from a realforce set?
edit: nvm, found them at EK.
Offline Ngt
« Reply #28440 on: Sat, 31 January 2015, 17:28:23 »
These are really nice shots! I typed once on a model M but I don't know if this is the same as an SSK.
« Reply #28441 on: Sat, 31 January 2015, 17:31:59 »
X-Post from here
Not exactly in the mail but it is cool. Went to the Makerspace. Made these and some other stickers. I've got about 30 that I can give out.
Shoutouts to Booper for helping me out on this! When I die, bury me inside the Louis GH store.
Offline exitfire401
« Reply #28442 on: Sat, 31 January 2015, 17:34:33 »
X-Post from here
I'll take one  :D
« Reply #28443 on: Sat, 31 January 2015, 17:35:42 »
Nice, but I think you could have done better on the GH to be more like the LV though.
« Reply #28444 on: Sat, 31 January 2015, 17:37:08 »
If you get me a graphic you like, I will make them. Need a PDF or JPG.
Offline wupi
« Reply #28445 on: Sat, 31 January 2015, 18:39:15 »
 :thumb:
« Reply #28446 on: Sat, 31 January 2015, 19:27:07 »
Ohhh, I've got a dolly I want to see if you can print.
« Reply #28447 on: Sat, 31 January 2015, 19:44:15 »
X-Post from here
i'd love one if you still have some
i might use it for something some day
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #28448 on: Sat, 31 January 2015, 21:35:44 »
X-Post from here
ooh, those are cool! I'll take one if you still got some
Offline animated
  • uhhhhhhhhhhhhhhhh
« Reply #28449 on: Sat, 31 January 2015, 22:04:34 »
X-Post from here
looks nice, classy  :thumb:
Das Browns, Filco Reds, Filco Blues, Leopold FC750R Reds, B.87 and B.Pad Gateron Blacks 65G Korean Springs, Varmillo VA87MR Gateron Blacks w/ Aluminum Case
