Author Topic: What did you get in the mail today?  (Read 24967205 times)
Offline sundin
« Reply #50050 on: Wed, 05 July 2017, 09:58:35 »
a new figure for my desk  :)
« Reply #50051 on: Wed, 05 July 2017, 13:24:49 »
Not today (Friday), but got my red white and blue Beauford in. I guess I have a thing for birds.
Sent from my LG-H918 using Tapatalk
Offline esylvester
« Reply #50052 on: Wed, 05 July 2017, 15:10:50 »
172470-0
172472-1
No keyboard stuff today, just pure ear ripping shrills  :p
Offline robotsokk
« Reply #50053 on: Wed, 05 July 2017, 20:29:30 »
Quick snap of my pile of Godspeed  ;D
Soooo stoked to finally have this set in hand. Keyboard glamour shots to come after I get some more work done.
@home      @work Swapping out boards... coming soon     wtb
Offline Rayoui
« Reply #50054 on: Thu, 06 July 2017, 00:08:44 »
Just got this one in today  :thumb:
Mira SE  |  Clueboard  |   B.face  |  HHKB Type-S
Offline alienman82
« Reply #50055 on: Thu, 06 July 2017, 17:39:53 »
removed.
« Last Edit: Thu, 01 March 2018, 11:49:23 by alienman82 »
Offline alienman82
« Reply #50057 on: Thu, 06 July 2017, 18:30:34 »
removed.
« Last Edit: Thu, 01 March 2018, 11:49:20 by alienman82 »
Offline dodgeyhack
« Reply #50058 on: Fri, 07 July 2017, 05:03:48 »
All the bits I need to build this Let's Split!
Soldering station and laser cut bamboo bits for the case. Starting small for my first build.
172604-0
Offline robotsokk
« Reply #50059 on: Fri, 07 July 2017, 10:05:30 »
Excellent choice in soldering iron  :thumb:
Offline dodgeyhack
« Reply #50060 on: Fri, 07 July 2017, 10:12:32 »
Thanks! Glad you approve. My ability at this stage is going to be a hindrance so I want to make sure the equipment isn't. I've not liked soldering before and I suspect the equipment had something to do with that.
Offline sundin
« Reply #50061 on: Fri, 07 July 2017, 11:16:33 »
Gureto! :)
Today was a perfect day!
Offline LiquidEvilGaming
    • LiquidEvilGaming Youtube
« Reply #50062 on: Fri, 07 July 2017, 12:35:28 »
Japanese Alphabet Cherry profile PBT Dye-Subbed Keycap Set
I think it Looks great on the White leopold
172651-0
Current Daily Driver/s
White Leopold 750R MX Reds
Head of LiquidEvilGaming on Youtube
i7 4790k/16GB DDR3/GTX 1060 6GB SSC/256GB Samsung SSD/2TB SSHD/W10
Offline OneNightFriend
« Reply #50063 on: Fri, 07 July 2017, 17:49:02 »
Pretty awesome mail day today!
Offline reaper
« Reply #50064 on: Fri, 07 July 2017, 19:55:44 »
Din Eli
Offline zacheadams
« Reply #50065 on: Fri, 07 July 2017, 21:26:22 »
172683-0
Offline iamtootallforthis
  • Something a lot Funnier
  • I like green stuffs.
    • WTB/WTTF Thread
« Reply #50066 on: Fri, 07 July 2017, 22:11:53 »
Who made those blanks?
Offline reaper
« Reply #50067 on: Fri, 07 July 2017, 22:13:35 »
None other than beehatch!  :thumb:   It's a topre set (Esc + Fn keys).  My potatoe pic doesn't do justice to these keycaps.  :-[
« Last Edit: Fri, 07 July 2017, 22:29:34 by reaper »
Din Eli
Offline SBJ
  • Tactile pls
« Reply #50068 on: Sat, 08 July 2017, 05:51:18 »
Offline suntorywhisky
    • IG
« Reply #50069 on: Sat, 08 July 2017, 08:35:38 »
Got some goodies in the mail. Thanks, Bunny!
Offline sundin
« Reply #50070 on: Sat, 08 July 2017, 08:52:34 »
After several month...
Offline reaper
« Reply #50071 on: Sat, 08 July 2017, 10:51:08 »
Din Eli
Offline alienman82
« Reply #50072 on: Sat, 08 July 2017, 10:53:46 »
removed.
« Last Edit: Thu, 01 March 2018, 11:49:04 by alienman82 »
Offline dgneo
  • Supervillain
« Reply #50073 on: Sat, 08 July 2017, 11:43:59 »
« Reply #50074 on: Mon, 10 July 2017, 17:08:10 »
« Reply #50075 on: Mon, 10 July 2017, 18:03:22 »
Lonk, the blood moon has risen
Offline robotsokk
« Reply #50076 on: Tue, 11 July 2017, 00:22:57 »
Glad I waited till the summer sale to get these... half off!  :thumb:
Offline dgneo
  • Supervillain
« Reply #50077 on: Tue, 11 July 2017, 04:50:27 »
Offline Rob27shred
  • Insane in the Membrane! 👻
« Reply #50078 on: Tue, 11 July 2017, 20:49:12 »
173058-0
Let's Split! kit from Mekhee, gotten 2nd hand on /r/mechmarket. Transparent Smoke case with black PCBs.
173060-1
All finished up & flashed with the default LS layout. ;D
Gateron Green switches, spring swapped to 80g gold plated springs, & lightly lubed with very thin krytox mix. Ducky yellow dye-sub OEM profile caps for now, plan on getting some DSA or XDA alphas & blanks for it sooner than later. Also gotta get a nice coiled TRSS cable & a DIY USB micro cable kit to match whatever colors I go with on the caps.
The learning curve is a bit steep for me with this board, since it is my 1st ortho, split, & 40% all in one. Been using it for a few hrs now & so far so good though, the more I use it the more it feels like a keeper. It also makes me want to try out some more ortholinear & split boards! :thumb:
« Reply #50079 on: Thu, 13 July 2017, 12:57:09 »
POM keyset and enough Aristotle switches for the Tris.
Thanks, ntw!
Also, Sifo is pretty neat.
« Last Edit: Thu, 13 July 2017, 12:59:01 by romevi »
« Reply #50080 on: Thu, 13 July 2017, 12:57:38 »
Thanks, ntw!
lucky
Offline DKrause
« Reply #50081 on: Thu, 13 July 2017, 13:09:47 »
Project time!
GH60 Satan PCB, case, plate.
120 Gateron Blues, TechKeys 6 key PCB and case, and dice keycaps for that.
I love it when a plan comes together!
Offline gnmar2723
« Reply #50082 on: Thu, 13 July 2017, 17:32:52 »
Es geht mir super gut :p
« Reply #50083 on: Thu, 13 July 2017, 17:43:34 »
I'm jealous
Offline gnmar2723
« Reply #50084 on: Thu, 13 July 2017, 17:49:13 »
I'm jealous
Of the board or the caps? I was planning on cannibalizing it for the caps/switches/case
« Reply #50085 on: Thu, 13 July 2017, 18:29:06 »
I'm jealous
caps xd
Offline smithyithy
  • a l p s
« Reply #50086 on: Fri, 14 July 2017, 12:39:18 »
5 x Noctua 'Redux' fans. Currently I have an AIO water cooler with two fans at the front, and one rear exhaust fan. It runs cool on idle but my ambient room temps are high as I'm in the loft.. So I'm adding 2 more to the inside of the rad for push/pull; 2 to the roof for extra intake, and a much more powerful rear exhaust. Should be nice and cool now even running demanding games.
Installing them tomorrow, will also be a good excuse to open the case up and clean any dust out (it's pretty clean tbh)
KBD75; Alps64 trio; some other stuff
Offline nightdriver
  • life is like t. rex
« Reply #50087 on: Fri, 14 July 2017, 15:18:53 »
stuff that's not keyboard stuff for once:
Offline CommonCurt
  • One of the cool kids
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #50088 on: Fri, 14 July 2017, 17:15:07 »
Nice. Been wanting to buy a concert ukulele for a while now.
Some of Ye ole  Keyboards -->
WTB/WTS/WTT ---->
Offline Arallu
« Reply #50089 on: Fri, 14 July 2017, 18:58:49 »
Offline reaper
« Reply #50090 on: Fri, 14 July 2017, 19:43:10 »
Poisedon's Nematode, I believe it's called.  :)
Din Eli
Offline Sissy
« Reply #50091 on: Fri, 14 July 2017, 23:13:01 »
NOTHING.
for real though, I normally get a package every other day and have not got a single thing all week. I'm honestly shocked
« Reply #50092 on: Fri, 14 July 2017, 23:17:48 »
ill trade you day 25 f or it :(
Offline sundin
« Reply #50093 on: Sat, 15 July 2017, 01:56:00 »
dat fugu look awesome! :)
Offline jonathanyu
« Reply #50094 on: Sat, 15 July 2017, 12:49:10 »
I thought noctua only made fans in **** colour
Offline Lansky
  • Realest motherthocker
« Reply #50095 on: Sat, 15 July 2017, 14:17:57 »
Technically I got it a few days ago. I'm very pleased so far.  ;D
Offline Rob27shred
« Reply #50096 on: Sat, 15 July 2017, 14:52:38 »
Very nice, I am jealous for sure! :P Trying to wait for Vega to upgrade my 980ti, but ever since the Frontier edition got released it's looking more & more like I'll either be springing for a 1080ti or an 1180(?) if NV announces the next gen of GTX cards soon & it's a big enough jump over Pascal.
Offline dgneo
  • Supervillain
« Reply #50097 on: Sat, 15 July 2017, 16:20:56 »
Offline noobas4urus
  • Mod Munky of another realm
    • The Mod Zoo
« Reply #50098 on: Sun, 16 July 2017, 00:03:23 »
Noctua fans kick so much ass.  The Industrial PPC line is really sweet as well.
"You miss 100% of the raffles you don't enter."
-Wayne Gretzky
Offline Cavemann6
« Reply #50099 on: Sun, 16 July 2017, 03:46:13 »
naiiiiceee, hows the fps?
