Author Topic: What did you add to your Keyboard today? - Post Your Pics  (Read 5500451 times)
Offline blackbox
« Reply #7450 on: Mon, 19 May 2014, 01:56:43 »
I switched my mx browns on my CM QF XT with MX grey switches. Much more satisfied with my board now:)
65209-0
65211-1
65213-2
Sorry for potato pictures
The LAN table!
Offline CommonCurt
  • One of the cool kids
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #7451 on: Mon, 19 May 2014, 02:39:22 »
Welp, it took me way longer than I expected since I had a bit of an issue with lifting pads but here it is. My Kingsaver now has Blue Alps. And it works, I'm actually typing on it right now to make this post. I'm very very happy to finally have this board and have the proper switches in it! :D
Now if only I could find some Alps keycaps/novelties...And I'll post a proper build log later.
Very cool.  Will you be needing that Zero anymore  ;D
Some of Ye ole  Keyboards -->
WTB/WTS/WTT ---->
Offline BlueBär
« Reply #7452 on: Mon, 19 May 2014, 03:51:06 »
I request a typing video!
Offline kohi
« Reply #7453 on: Mon, 19 May 2014, 15:00:54 »
dang, how do the switches feel? I heard the greys are really stiff and fatiguing
« Reply #7454 on: Mon, 19 May 2014, 15:05:33 »
I actually have a little tripod I found the other day. I'll try and see if I can make a typing video.
Please bring this to KeyCon <3
Ok. But now I can only bring 1 or 2 other boards :P
Yes! I'm putting the complicated linear Green Alps I harvested from the Kingsaver into the Zero. Then typing on it a lot :P.
Theres the famous Blue Alp board ey? Looks sweet! I bet it feels cool!  :cool:
It's so ****ing clicky I can't even handle it. It's like Agnes and her unicorn but substitute fluffy for clicky :D.
« Reply #7455 on: Mon, 19 May 2014, 15:22:50 »
Nice, I'm assuming tactile greys? If so now I know there are at least two of these! ;)
« Reply #7456 on: Mon, 19 May 2014, 15:53:29 »
I should mod a board to tactile greys. I like them a lot.
Offline daerid
    • Rossipedia
« Reply #7457 on: Mon, 19 May 2014, 18:06:59 »
How do greys compare to clears?
Offline BlueBär
« Reply #7458 on: Mon, 19 May 2014, 18:08:19 »
They should only be heavier.
Offline Pacifist
  • on hiatus
« Reply #7459 on: Mon, 19 May 2014, 18:28:28 »
Wasn't the spring force graph different?
Offline BlueBär
« Reply #7460 on: Mon, 19 May 2014, 18:35:52 »
I don't think I have ever seen a MX linear grey specific force graph.
Offline phoenix1234
« Reply #7461 on: Mon, 19 May 2014, 19:36:07 »
Yes, it's different. It's because the number of coins in the grey springs are more than in clear springs. It makes the clear has stiffer force. Actually, clear has a unique spring which is very different with light (blue, brown, red) heavy (black) and very heavy (grey, green) springs from Cherry. Therefore, if we compare between Clears and Grey, at first, Clear is lighter but at the bottom out point, I believe they are both heavy the same (100g).
I like linear switches
Offline Zeal
    • Zeal Generation Inc.
« Reply #7462 on: Mon, 19 May 2014, 20:42:43 »
Here you go (Official PDF in attachments)
Picture if you don't want to DL the pdf
Offline blackbox
« Reply #7463 on: Tue, 20 May 2014, 01:30:46 »
Well they are stiff but thats in the nature of the switch. They might be fatiguing for someone who is used to very light switches. I do not find it fatiguing and I type with far less errors then I did with the same board on mx browns.
Yes they are tactile greys. I got them from MK:
http://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=719
« Last Edit: Tue, 20 May 2014, 01:32:43 by blackbox »
The LAN table!
Offline BlueBär
« Reply #7464 on: Tue, 20 May 2014, 04:07:49 »
That's a linear grey, not a tactile grey. Where did you find that btw?
« Reply #7465 on: Tue, 20 May 2014, 05:58:17 »
I added this little beauty to my HHKB:
65332-0
Offline bianco
« Reply #7466 on: Tue, 20 May 2014, 05:59:24 »
beautiful collection there rowdy!
« Reply #7467 on: Tue, 20 May 2014, 06:00:58 »
My only two Skulls :)
Offline The feel is of the keys!
  • Click
« Reply #7468 on: Tue, 20 May 2014, 06:10:03 »
Added a new poplar and walnut case with a matching lid in the works.
Great use of scrap wood and a weekend with dad.
Offline phoenix1234
« Reply #7469 on: Tue, 20 May 2014, 06:23:25 »
As far as I know, the grey tactile (dark grey) did not have that kind of document but the force graph of dark grey should be the same (or a bit heavier) because light grey and dark grey use the same spring.
I think the one he enclosed is the one public from Cherry Corp
http://www.cherry.de/PDF/EN_CHERRY_MX1A-2xxx.pdf
Offline HPE1000
  • Keycap Paparazzo
« Reply #7470 on: Tue, 20 May 2014, 06:31:54 »
That is awesome  :thumb:
Offline osi
« Reply #7471 on: Tue, 20 May 2014, 07:34:17 »
The drunken skull. One of my favorites! Looking good sir!
Offline infiniti
  • I <3 KB
  • Bob was here
« Reply #7472 on: Tue, 20 May 2014, 08:36:28 »
Had an idea while exercising this morning: My SP Caps Lock would look better if it were windowed.
So this afternoon, I broke out my toolbox and made one.  The "window" was cut from a translucent SP keycap of the same profile.
#HaveToolsWillMod
Offline Jokrik
« Reply #7473 on: Tue, 20 May 2014, 09:15:07 »
#HaveToolsWillMod
Thats amazing,
which tool did you use if I may know? for sure not rotary tool with cutting disc
Offline infiniti
  • I <3 KB
  • Bob was here
« Reply #7474 on: Tue, 20 May 2014, 09:35:57 »
#HaveToolsWillMod
Thats amazing,
I used a dremel with a cutting disc and then some sand paper.  :'( I marked the cut-out with masking tape but couldn't get the corners square enough.  I think I need a small file.
Another option is that instead of a window, I make the transparent cutout run all the way to the bottom of the keycap.  I think this would be easier.
This was a test before I cut into my center-stem stepped caps lock and my hyperfuse caps lock.
Offline HPE1000
  • Keycap Paparazzo
« Reply #7475 on: Tue, 20 May 2014, 13:40:38 »
I suppose this is the most proper thread to put this, I "added" matte black paint to my vortex aluminum case. I did so much to this and it took an incredible amount of time but it is finally done and I am just letting it dry completely as well as I need to lube the switches before I can put the board back together.
Things I added were the paint, duh, and JB weld to the LED holes to get rid of them, and JB weld to the little gap between the top and bottom of the keyboard case. Might not seem like a lot of work but it was, also I initially painted it a different color before this but I wasn't happy with the paint so I had to strip it all down and sand it, prime it, and paint it all over again.
Potato pics, sorry. (Bad white balance, dusty, etc)
Offline epzy
  • HHKB Fiend
  • ded
« Reply #7476 on: Tue, 20 May 2014, 13:43:43 »
Looks good. :thumb:
Offline HPE1000
  • Keycap Paparazzo
« Reply #7477 on: Tue, 20 May 2014, 13:47:48 »
Looks good. :thumb:
Thanks :D
It's so close to being done but I need to lube the switches before I can resolder it. I just dont feel like lubing switches right now lol
« Reply #7478 on: Tue, 20 May 2014, 14:22:01 »
LOL FRUSTRATION FREE
Great album, I bought the yellow press and the black Vinyl.
Offline Vibex
  • Love y'all
« Reply #7479 on: Tue, 20 May 2014, 14:23:21 »
I love how all of the stuff you buy from him comes with candy. :p
Offline Zeal
« Reply #7480 on: Tue, 20 May 2014, 14:48:49 »
"Fragile" Contents extremely awesome.  :))
« Reply #7481 on: Tue, 20 May 2014, 15:05:41 »
Gaaah... I put this in the wrong thread but it was totally on top of my keyboard for the pictures.
Offline hehenri
« Reply #7482 on: Tue, 20 May 2014, 15:16:08 »
Bumblebee caps, and Pexon's cable!  :cool:
« Reply #7483 on: Tue, 20 May 2014, 15:53:53 »
Hahahah IT'S SO CLICKY IM GONNA DIE
« Reply #7484 on: Tue, 20 May 2014, 17:29:31 »
Many thanks!
Offline Av180
« Reply #7485 on: Tue, 20 May 2014, 19:24:58 »
That's so nice, im jealous of that colour combo! and that cable mmmmm
KMAC 62g Clear
Poker 2 Stock Red
Leopold FC200RE Stock Clear
Offline hehenri
« Reply #7486 on: Wed, 21 May 2014, 00:17:15 »
Thanks! :)
Offline bexleycorona
« Reply #7487 on: Wed, 21 May 2014, 00:20:44 »
Very nice combo!
I see this a lot where the space bar is pointing towards the typist. Is it made like that or do people just turn them around?
GE Marquette | Rosewill RK-9000 | Rosewill Apollo 9100 | Realforce 87U "EK Edition" 45g Uniform | Unicomp Ultra Classic Black Buckling Spring | Realforce 87U SE07T0 Variable | Dolch PAC65
Offline CommonCurt
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #7488 on: Wed, 21 May 2014, 00:23:00 »
Or you could sell me the Zero if you get board with it ;D
WTB/WTS/WTT ---->
Offline blackbox
« Reply #7489 on: Wed, 21 May 2014, 02:46:43 »
Is it as clicky as the matias standard clicky?
« Last Edit: Wed, 21 May 2014, 02:48:24 by blackbox »
The LAN table!
Offline blackbox
« Reply #7490 on: Wed, 21 May 2014, 04:11:52 »
« Last Edit: Wed, 21 May 2014, 04:14:24 by blackbox »
The LAN table!
Offline foxer
  • Formerly wadeu
« Reply #7491 on: Wed, 21 May 2014, 09:45:32 »
Just changed a few keys. Sort of like the orange.
Unbowed, Unbent, Unbroken.
« Reply #7492 on: Wed, 21 May 2014, 15:39:04 »
Yesterday, Binge transcended into the realm of legends by adding a vinyl record to his keyboard.  Come all, and marvel in his glory.
Offline luisbg
« Reply #7493 on: Wed, 21 May 2014, 17:45:03 »
So aesthetic. Want to build something similar soon.
Congrats.
Leopold FC660M - Brown mx switches - black case - white blank keys :: ErgoDox - Blue mx switches - classic case - black blank keys
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #7494 on: Wed, 21 May 2014, 18:21:05 »
ROFL
65597-0
« Reply #7496 on: Wed, 21 May 2014, 18:43:19 »
ROFL
I wanna play but I don't have a mechanical keyboard with me right now.   :'(
Offline t2russo
« Reply #7497 on: Thu, 22 May 2014, 23:14:12 »
Everything in its right place.
Offline jil_jil32
  • Tokyo Press <3
« Reply #7498 on: Thu, 22 May 2014, 23:29:03 »
I would like to see the whole board t2russo. It's cool!
Offline luisbg
« Reply #7499 on: Thu, 22 May 2014, 23:57:57 »
I got a new board today. My fist mechanical keyboard at that.
Leopold FC660M; brown cherry switches; black case; and just replaced the caps with blank white caps.
Well, replaced all except modifiers. Will do those when I have a second keycap puller.
Will post pictures once I have some colorful modifiers. I added myself to the latest cherry keycap group buy, so will be receiving some soon.
Enjoy your boards!
