Author Topic: What did you add to your Keyboard today? - Post Your Pics  (Read 5645167 times)
« Reply #8800 on: Mon, 09 March 2015, 20:34:59 »
crotch shot
Offline Touch_It
« Reply #8801 on: Mon, 09 March 2015, 20:36:32 »
crotch shot
Not even charging!  You're welcome.  Welcome
Offline bueller
  • MX baller
  • Church of the Ergo Clear
« Reply #8802 on: Mon, 09 March 2015, 20:47:10 »
Built a case/wrist rest for the JD40 today.  Wood is Purple heart and is finished with Tung Oil and then waxed.  The mounting area is routed out so that the bottom is solid.  I still need to get the correct hardware to mount the top plate and a small enough drill bit for said screws, but overall, I am happy with it.
That is so awesome. Although I do find it hilariously ironic that you chose to put a 40% board in such a massive case :P
« Reply #8803 on: Mon, 09 March 2015, 21:20:09 »
someday I'll have a better camera  :-X
« Last Edit: Mon, 09 March 2015, 21:21:54 by noisyturtle »
Offline Badwrench
  • ummmm.....I forgot
« Reply #8804 on: Mon, 09 March 2015, 21:43:27 »
Thanks.  It is actually roughly the width of a 60%.  I measured the distance of my wrists when comfortably resting on a normal tkl and added a little to that for the actual case.  It looks bigger in the photos than it actually is due to the small size of the JD40.  The next one I do will be a little narrower and shorter on the depth as well.
« Reply #8805 on: Tue, 10 March 2015, 04:59:51 »
White double shot keycaps to my Dell AT101W. Also will be swapping the black alps for Matias click switches painting the plate.  Thinking about painting the outside of the case.
What happened to \| ? :p
Offline ApocalypseMaow
  • Kitteh Overlord
  • Say WHAAT...
« Reply #8806 on: Thu, 12 March 2015, 03:18:30 »
Put the Dolch set back on the dolch board... Sad cause it doesn't work  :p
Sure looks nice sitting on the shelf doh!  :))
Offline VesperSAINT
  • vpsert
  • #CustomKorean
« Reply #8807 on: Thu, 12 March 2015, 04:55:28 »
FFFFFFFFFFUUUUUUUUUUUUUUUUUUUUU- WHY WON'T YOU JUST GIVE IT TO ME?!
So good, yo~ I just want to add my CMYW to it~~~
Lol~
« Reply #8808 on: Thu, 12 March 2015, 04:58:23 »
A Dolch set on a Dolch board
And a partridge in a pear tree.
lalala
Offline Karura
  • Professional Canadian
  • SKidata life.
« Reply #8809 on: Fri, 13 March 2015, 22:41:21 »
Poker with Beast Plate and Hammer Case.
Offline VesperSAINT
  • vpsert
  • #CustomKorean
« Reply #8810 on: Fri, 13 March 2015, 22:47:20 »
Splendid keyboard!!! So very very clean. I tend to forget how beautiful blue stems look~
Offline Karura
  • SKidata life.
« Reply #8811 on: Fri, 13 March 2015, 22:57:28 »
Thank you!
Just threw on some caps. Gotta go salvage a capslock and spacebar from another set  :(
Offline Touch_It
« Reply #8812 on: Fri, 13 March 2015, 23:01:20 »
Donor board has a big ass enter thus 1x \|.
#thug life.
Edit.  Not sure why I said the outside of the case vs case but w/e. Lol
« Last Edit: Fri, 13 March 2015, 23:03:37 by Touch_It »
Offline VesperSAINT
  • vpsert
  • #CustomKorean
« Reply #8813 on: Fri, 13 March 2015, 23:24:34 »
Thank you!
Oh nooo~ I hope you find them. I like the theme you're going for on this one. Just so clean, dood. I really should go for a cleaner look for one my MX boards, but I get carried away with color and legends :P I keep my Topre boards for the clean blank look~
« Reply #8814 on: Fri, 13 March 2015, 23:28:04 »
That's really hot. More pictures of this please
Offline Badwrench
« Reply #8815 on: Sat, 14 March 2015, 02:23:58 »
Thanks.  Just for you  :-*
94068-0
I will try to get some better pictures over the weekend.  I left the wood near the window to help with the aging and it is now a bit more purple.  I also added another couple coats of wax to get the color even deeper.   :thumb:
Edit:  Took some pictures outside this morning to better show the colors.  Picture above is a bit washed out, but these new ones are a touch warm.  Someday I will learn to take better photos.
94210-1
94212-2
94214-3
« Last Edit: Sun, 15 March 2015, 12:50:49 by Badwrench »
Offline Prelim
« Reply #8816 on: Mon, 16 March 2015, 06:32:37 »
Thank you!
are those Cherry POMs? where did you got it?
2x GH60 revC - lubed Linjärs 65g / lubed H1s 65g with SPRIT 5mm acrylic plate | Dolch PAC - Cherry housing / Gateron sliders 65g and QMK clips | Raptor K1 G80-1890 stock
Floating on Cherry/GMK caps
Offline bianco
« Reply #8817 on: Tue, 17 March 2015, 05:45:21 »
decided to assemble and use the butterfly/lightpad
Offline Vibex
  • Love y'all
« Reply #8818 on: Sat, 21 March 2015, 12:05:33 »
Oh my god, that is simply stunning. I wish I could make stuff like that. :eek: :eek: :eek:
Offline user 18
« Reply #8819 on: Sat, 21 March 2015, 13:31:30 »
That is one dead sexy board
Avatar by ashdenej
Offline JaccoW
  • Fire Typer!!
  • Keyboard is Lava!
« Reply #8820 on: Sat, 21 March 2015, 13:49:49 »
Jelly of the lightpad.
|||My other keyboards :
x
Offline osi
« Reply #8821 on: Wed, 25 March 2015, 19:47:41 »
95226-0
Offline tigersharkdude
« Reply #8822 on: Wed, 25 March 2015, 21:17:23 »
a Yag Dur from Nubbinator
Offline ctm
  • Hello, world!
« Reply #8823 on: Wed, 25 March 2015, 21:28:42 »
Just added a customized keycap from WASD. :cool:
95243-0
Coming:
Ellipse Model F F62.
Offline Fullcream
« Reply #8824 on: Fri, 27 March 2015, 17:21:16 »
Built a very average case for my Pure out of 1.5mm Mild steel sheet and coated with Plasti Dip.
Offline HPE1000
  • Keycap Paparazzo
« Reply #8825 on: Fri, 27 March 2015, 17:33:15 »
I really like it, great job!  :thumb:
« Reply #8826 on: Fri, 27 March 2015, 17:41:16 »
Nice job!  Goes really well with the Nuclear Data set.  :)
Offline ideus
  • Björkö.
« Reply #8827 on: Fri, 27 March 2015, 18:10:27 »
Oh gosh, this looks super retro. Nice job.
Offline fanpeople
« Reply #8828 on: Fri, 27 March 2015, 19:09:28 »
I'm going to chime in also, that looks awesome. By average you mean AWESOME.
Offline nathanrosspowell
    • nathanrosspowell.com
« Reply #8829 on: Fri, 27 March 2015, 19:53:00 »
Fallout bunker status: CONFIRMED
Offline Fullcream
« Reply #8830 on: Fri, 27 March 2015, 21:19:03 »
Haha. Retro is what I was going for. Pleased with how heavy and solid it is.
I mean it's very average in that, overall it turned out how I planned but I underestimated how easily the 1.5mm wall sheet would bow under the heat from welding. Pictures won't really show that well but there is slight bowing on a couple of faces.
Offline sethk_
  • Grand Master Wizard Pizza
  • www.kbdhub.com
    • My webstore
« Reply #8831 on: Sat, 28 March 2015, 10:49:18 »
That has an interesting industrial look to it, I like it
« Reply #8832 on: Sat, 28 March 2015, 16:11:42 »
Thanks Shadovved and LastPilot
Offline mr.squishy
  • I like beer and keebs
« Reply #8833 on: Sat, 28 March 2015, 18:51:15 »
A sick paint job
95513-0
« Reply #8834 on: Sun, 29 March 2015, 01:33:25 »
Excellent job!
That really captures the essence of the old style keycap set :)
« Reply #8835 on: Sun, 29 March 2015, 02:22:47 »
I am gradually completing my second full size Model M, although it does need a bolt mod at some stage.
A couple more keycaps added, before and after ...
95554-0
95556-1
Interesting Tab key - it has only one arrow and no word, the Tab key on my other two have two opposite direction arrows and the word Tab on their Tab keys.  Anyone else seen that?
Offline meow a cat
  • Resistance is futile.
« Reply #8836 on: Thu, 02 April 2015, 01:21:56 »
Both of my boards have the regular one with two arrows and 'tab'.
This Model F Unsaver has something similar to yours:
Boards:
Offline katushkin
  • Too Keycool for School
  • Just the guy
« Reply #8837 on: Thu, 02 April 2015, 08:42:27 »
I want mine :( It looks great.
That looks awesome. I wish my plasti dip skills were that good!
  • Kitteh Overlord
  • Say WHAAT...
« Reply #8838 on: Thu, 02 April 2015, 08:56:34 »
suffer  ;)
Offline baldgye
  • Will Smith Disciple
« Reply #8839 on: Thu, 02 April 2015, 09:01:32 »
suffer  ;)
DAMN MATE THAT LOOKS AWESOME
« Reply #8840 on: Fri, 03 April 2015, 02:33:56 »
That does look similar!  Keycaps swapped all over the place - it doesn't bother me, just something slightly different :)
Offline HPE1000
  • Keycap Paparazzo
« Reply #8841 on: Tue, 07 April 2015, 15:43:09 »
Added a teensy. Vintage tee mount green alps too good  ^-^
Kinda large though.
Offline Baron Von Clop
« Reply #8842 on: Tue, 07 April 2015, 17:33:49 »
A paint job and keyset.
It was tough finding keys the right shade of purple for something that wasn't a crazy price. These still aren't really dark enough for what I wanted, but they will work well enough.
Just waiting for my custom keys to come in from WASD now. They shipped today!
Offline do_Og@n
« Reply #8843 on: Thu, 09 April 2015, 20:30:25 »
In the following thread you will find a very light purple set of keycaps....is this more of the color you were looking for?
https://geekhack.org/index.php?topic=37999.0
Offline fanpeople
« Reply #8844 on: Fri, 17 April 2015, 22:01:31 »
Replaced alt with a code key. Used a spare stem to help stabilise and reverse bent a wire stabiliser for space bar. It is far from perfect but is working quite good, a bit stiff though. also killed right alt with Sharpkeys
I finally have enough random Model M stuff to start playing around.
« Last Edit: Fri, 17 April 2015, 22:04:02 by fanpeople »
« Reply #8845 on: Fri, 17 April 2015, 22:04:09 »
PLEASE TELL ME YOU HAVE A BUILD LOG FOR THIS. I'm way into this <3. Great job!!
Offline retrochick
  • goodbye my wallet
« Reply #8846 on: Mon, 20 April 2015, 10:48:17 »
That's actually a very pleasing lavender for me. Nicely done! What paint did you use for the case? Looking to mod my QFR soon.
Offline jil_jil32
  • Tokyo Press <3
« Reply #8847 on: Tue, 21 April 2015, 04:12:03 »
White Valentine DSA keyset
Offline baldgye
« Reply #8848 on: Tue, 21 April 2015, 04:28:00 »
wow that looks awesome
Offline naasfu
  • The Curator
  • CURSE YOU HE-MAN
« Reply #8849 on: Tue, 21 April 2015, 20:19:23 »
cherry doubleshots in german layout.
