Author Topic: What did you add to your Keyboard today? - Post Your Pics  (Read 5645390 times)
Offline Booper
    • omniclectic.com
« Reply #8600 on: Wed, 03 December 2014, 15:43:28 »
Reoutfitted my poker with granite today! XD
I stared at this for far too long.
TIL - If you have the Chrome extension Imagus you can pause GIFs!
Holy **** that gif is amazing.
Thanks!!    :D
boop!
Offline scubaste
« Reply #8601 on: Wed, 03 December 2014, 16:02:06 »
Don't them LED colour changers stop you bottoming out the switches?
With mine I realised that I cannot bottom out my clears so I took them all of. I was using DSA clears so I assume that they are the same design as the granite set.
They aren't bad on the browns! I still have plenty of travel after the bump before they bottom out. I had o-rings on this Poker and with the o-rings on it + LED covers the keys seemed to bottom out too quickly like you mentioned. I took off the o-rings and it's fine now.
I tried some blue LED covers on a poker with clear switches though and I had the same issue as you. It made the key seem to bottom out immediately after the tactile bump and that sucked :(
I should probably note that I had to sand down my led covers as well to get a nice fit. They were tight and sticky when I first tried them.
Pretty much what she said. The thing I found to be most annoying with them on the DSA + LED covers + MX Browns was the inconsistent feeling when you do bottom out. Whatever change they made wouldn't be so bad if they were just all one feeling, but ultimately I couldn't handle having them on stuff i use regularly.
Offline blackbox
« Reply #8602 on: Thu, 04 December 2014, 11:12:02 »
Amazing gif!
The LAN table!
Offline FrostyToast
  • Litshoard
« Reply #8603 on: Thu, 04 December 2014, 14:34:48 »
I added a Digilog Aluminum case to my 55g.
The thing is 6 ****ing pounds. SIX MOTHER ****ING POUNDS!
Quote from: elton5354
Offline VesperSAINT
  • vpsert
  • #CustomKorean
« Reply #8604 on: Thu, 04 December 2014, 15:02:38 »
They looks so damn good... if it didn't raise the keyboard's height so much, I would've bought one awhile back :(
Offline mogo
« Reply #8605 on: Thu, 04 December 2014, 15:12:59 »
I want to see a six pound keyboard. :O
Offline HPE1000
  • Keycap Paparazzo
« Reply #8606 on: Thu, 04 December 2014, 15:21:16 »
If only they made a black digilog case
Offline FrostyToast
  • Litshoard
« Reply #8607 on: Thu, 04 December 2014, 15:22:10 »
Unfortunately my potato function on my phone isn't working for some reason...
I would have given a picture if I could.
Offline FrostyToast
  • Litshoard
« Reply #8608 on: Thu, 04 December 2014, 15:25:46 »
You could always get it anodized yourself.
There is nothing in there really that absolutely needs to maintain its exact measurements. Caustic acid (for de-anodization) shouldn't eat away too much anyway.
The only problem with that is that it does cost money.
I am planning on putting GMK hyperfuse on this thing once I get enough money to get landing pads, grease, a novatouch, and the caps when the GB starts.
Although I am still questioning the logistics of ABS on topre, even if it is thick GMK goodness.
Offline KebinPls
  • OK
    • Insta
« Reply #8609 on: Thu, 04 December 2014, 21:22:03 »
Got my FC660M today! Also got my magenta and yellow ESC key from Binge today as well! Perfect timing  :D So I added my new keycap to my new keyboard! Also patiently waiting for Toxic to ship to put on this :D
Offline HPE1000
  • Keycap Paparazzo
« Reply #8610 on: Sat, 13 December 2014, 15:25:13 »
Added some washers to the bold mod I did a week ago. Wish I would have realized I needed them from the start because it wasn't fun taking it apart again.
« Reply #8611 on: Sat, 13 December 2014, 15:37:25 »
Are washers required for a bolt mod?  I don't recall reading about them before.
Or, why did you need them in this particular case?
Offline HPE1000
  • Keycap Paparazzo
« Reply #8612 on: Sat, 13 December 2014, 15:52:08 »
Some of the nuts were falling into the holes in the plate, bending the screws and just making it look sketchy overall. This fixed that problem.
« Reply #8613 on: Sat, 13 December 2014, 16:34:08 »
Or use bigger nuts?
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #8614 on: Sat, 13 December 2014, 16:42:34 »
Or use bigger nuts?
Offline HPE1000
  • Keycap Paparazzo
« Reply #8615 on: Sat, 13 December 2014, 17:22:03 »
Or use bigger nuts?
Obviously that would be the way to go, the guide I followed said use these so I did. :P
Offline Evo_Spec
  • (╯°ヮ°)╯︵⌨
« Reply #8616 on: Sat, 13 December 2014, 21:27:44 »
i added/switched out some red switches for blues ones today =)
Also did the top row but i forgot to take pics.
84059-0
GON NerD TKL DTA Edition
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #8617 on: Sun, 14 December 2014, 01:20:21 »
I added a different layout to my JD40.
84068-0
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #8618 on: Sun, 14 December 2014, 19:01:06 »
Painted the plate for my Omnikey:
The pic doesn't show it, but it has a little bit of a red tint
« Reply #8619 on: Sun, 14 December 2014, 20:39:21 »
Interesting way to do the arrow keys. Any specific reason why you chose to do them that way?
« Reply #8620 on: Mon, 15 December 2014, 02:07:55 »
Dude... That gif was epic! Love the purple.
Offline Lord of Narwhals
  • You can call me NaLo
    • A selection of posts chosen with care, prior to remembering your indifference to them.
« Reply #8621 on: Mon, 15 December 2014, 13:08:59 »
I finally have a good Esc keycap!
In the end.. the keyboard's most grand form of existence is as an ethereal bridge between man and machine..    Each depression of the keys, evanescent.. Our transitory thoughts crashing into the web, carving canyons through the internet wasteland such that life may once again flourish..
HHKB Pro 2 Poker II [MX Red]
Offline Hzza
« Reply #8622 on: Mon, 15 December 2014, 14:28:56 »
I've always liked the NERV caps, never watched the show, but they always look nice.
Offline HendyZone
  • HHKB Elite
    • MechanicalKeyboards.co.id
« Reply #8623 on: Mon, 15 December 2014, 14:36:47 »
wohh
amazing photo
amazing gif
Very neat boop :thumb: :thumb:
Offline Doyniish
  • Good you
    • Power Hour Playlists
« Reply #8624 on: Mon, 15 December 2014, 14:37:16 »
Untitled by liddictm, on Flickr
Got some new caps for my Poker today. I think it looks awesome.
Offline Sent
  • Simplistic Serenity
  • ¯\_(ツ)_/¯
« Reply #8625 on: Mon, 15 December 2014, 15:18:44 »
Clean and simple. :thumb:
Offline BunnyLake
  • The OG HHKB Master
  • X
« Reply #8626 on: Mon, 15 December 2014, 15:21:32 »
yeah that looks great
well played
Offline Doyniish
  • Good you
« Reply #8627 on: Mon, 15 December 2014, 15:34:02 »
Thanks guys! I just noticed it matches my backpack hiding down there too!  :p
« Reply #8628 on: Mon, 15 December 2014, 19:21:02 »
it matches the Nostalgia theme on GH quite well too :)
Offline Melvang
« Reply #8629 on: Mon, 15 December 2014, 19:35:14 »
Probably because it is the closest to an inverted T I could come up with and not need a third function key in the base layer and not screwing with F row or the number row.
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #8630 on: Wed, 17 December 2014, 22:04:22 »
« Last Edit: Wed, 17 December 2014, 22:06:37 by hwood34 »
Offline sprit
  •  Post Editing Timeout
  • Location: The Geek Symphosion :::::: Mechanical Engineering ::: Alta Magna Uniforma :::::: 哀吾生之須臾羨長江之無窮 ::
« Reply #8631 on: Fri, 19 December 2014, 19:44:21 »
MX Stabilizers  :   Cherry OG   vs   Stainless   vs   Gold-plated Edition
101717-0  84484-1  84490-2  84492-3  84478-4  84553-5
« Last Edit: Tue, 26 May 2015, 05:11:34 by sprit »
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #8632 on: Sat, 20 December 2014, 03:04:11 »
Gold stabs, so swagg.
Offline b7ad
  • ゆめうつつ
    • mechblog
« Reply #8633 on: Sun, 21 December 2014, 13:43:26 »
The gold stabs are awesome, Sprit!
Threw some cherry keys on from a NIB 1800HAU I recently received onto my MX Mini.
Not staying on the board but despite the bad photo they look pretty cool on it!
Offline billnye
  • ability man
« Reply #8634 on: Sun, 21 December 2014, 14:28:22 »
Nice caps :D
Offline MGH
« Reply #8635 on: Sun, 21 December 2014, 16:09:37 »
Wow that looks nice
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #8636 on: Sun, 21 December 2014, 17:55:39 »
« Reply #8637 on: Mon, 22 December 2014, 01:04:50 »
Holy crap man.. I want some gold stabs..
Offline WinterIsle
« Reply #8638 on: Mon, 22 December 2014, 07:06:33 »
Added new Black Doubleshots to my 75% 2 months ago.
Offline Battou62
« Reply #8639 on: Mon, 22 December 2014, 08:09:00 »
I seriously question why people want to use backlit caps when Cherry WoB exists. You can never go wrong with WoB Cherry. Gorgeous board.
Offline snoopy
  • The Flying Ace
  • Gone with the Wind
« Reply #8640 on: Mon, 22 December 2014, 10:58:24 »
Just a quick shot... I've build a Dolch Raptor for my gf. She wanted a dark colored board and didnt like the SSK I offered her. So I made this... Now I just have to find a damn candycorn for it.
Offline Battou62
« Reply #8641 on: Mon, 22 December 2014, 11:09:53 »
This is awesome. I love the layout of the 1800. Did the Dolch space bar not work?
Offline snoopy
  • The Flying Ace
« Reply #8642 on: Mon, 22 December 2014, 11:19:13 »
I sadly only had 7x ones. If somebody has one that fits, let me know.
Offline Lurch
« Reply #8643 on: Mon, 22 December 2014, 11:22:12 »
I wish my GF liked my keyboard offerings. :(
Quote from: Flyersfan1
Offline Battou62
« Reply #8644 on: Mon, 22 December 2014, 11:25:29 »
For real. My wife sees my new keyboard and she say "Why does your keyboard look so...old?"
Offline Dubsgalore
« Reply #8645 on: Mon, 22 December 2014, 11:32:28 »
very nice snoop, looking good
« Reply #8646 on: Mon, 22 December 2014, 11:35:27 »
Dolch is always classy, and you already have a nice Esc key, no need to tacky it up with candycorns. :p
Offline snoopy
  • The Flying Ace
« Reply #8647 on: Mon, 22 December 2014, 11:50:51 »
I offered her a SSK... and she said... "I don't want that ugly keyboard, it's so huge and fat. Don't you have a nice one?"  :confused: :confused:
But she wants candycorn, since she saw it on my hhkb... and believe me, it was really really hard to explain that it doesn't fit on her keyboard. She even asked me if I could cut it and glue it on...  :'( :'( :'(
« Reply #8648 on: Mon, 22 December 2014, 12:01:03 »
Get blank white Cherry PBT key and dip dye it.
Offline Lurch
« Reply #8649 on: Mon, 22 December 2014, 12:02:50 »
I tried the same! She started typing on the SSK, I came back 10 minutes later and it was unplugged on the floor.
"I don't like it."
Don't tell her now, but she broke my heart that very day. :'(
