Author Topic: How can I setup media keys on a keyboard without media keys?  (Read 4835 times)
Offline nala
  • sup son ¯\_(ツ)_/¯
« on: Fri, 17 August 2012, 18:04:43 »
Basically that. I searched for it on geekhack but couldn't find a solid answer.
Mostly what I want is volume control, and if possible, play/pause on multimedia.
Collection: Filco Majestouch-2 TKL ~ Filco Majestouch-2 TKL ~  Razer BlackWidowUltimate
Offline Djuzuh
Re: How can I setup media keys on a keyboard without media keys?
« Reply #1 on: Fri, 17 August 2012, 18:07:35 »
autohotkey.
Offline The_Beast
  • I like wood ಠ_๏
« Reply #2 on: Fri, 17 August 2012, 18:10:39 »
autohotkey.
Yup, AHK is something I use every day at a work. It helps a TON
Offline nala
  • sup son ¯\_(ツ)_/¯
« Reply #3 on: Fri, 17 August 2012, 18:32:39 »
Mind sharing the script I need for volume control? I'm running on Win7 just in case. I tried two scripts but one of them didn't work, and the other one needed like a libraries that I couldn't download as the link was down.
Offline Djuzuh
« Reply #4 on: Fri, 17 August 2012, 18:38:35 »
Dude, AHK is very easy. Just learn it. :P.
(And yes, I'm too lazy myself to do it xD).
Offline nala
  • sup son ¯\_(ツ)_/¯
« Reply #5 on: Fri, 17 August 2012, 19:56:37 »
Just for a volume control script? Nah, thanks.
« Reply #6 on: Fri, 17 August 2012, 20:02:37 »
How would you compare Auto Hot Key and Key Tweak?
For those who have used both.
- D Trump 2026-10-24
Offline alaricljs
  • I be WOT'ing all day...
« Reply #7 on: Fri, 17 August 2012, 21:10:29 »
Key Tweak merely mangles the registry to re-map the keyboard.  AHK is an entire scripting language where you can execute actions, send complete strings on a single key press, manipulate windows and do all sorts of nifty stuff.
I use AHK to give me volume and playback control w/ OSD, a minimize window combo, and a few other nifty gadgets.
Found the AHK thread
« Last Edit: Fri, 17 August 2012, 21:14:33 by alaricljs »
Filco w/ Imsto thick PBT
Offline The_Beast
  • I like wood ಠ_๏
« Reply #8 on: Fri, 17 August 2012, 23:01:24 »
Honestly, I would learn the "language" it's pretty simple to pick up and you can always google and final a solution. For instance, at work I need to type in all caps for the drawings I do in AutoCAD. The problems was it was annoying to have caps lock on, forget about it and type an email sounding super pissed. I googled "autocad caps lock" or something like that, I found a script that disables caps lock entirely except in AutoCAD. So if I switch from AutoCAD to outlook, caps locks turns off. If I go from outlook to AutoCAD, caps lock turns back on. A simple problem, a pre-made script and it's hard to work without it now since I'm so used to it.
Same goes for other scripts I've written. Another example is I turned caps lock into a FN key for a layer on my keyboard to do common AutoCAD tasks that aren't associated with a letter. Without these two scripts, I would spent a whole lot more time on drawings because I would have to type the command or move my mouse to find it on a tool bar. I don't know how I drew before these. Defiantly learn the language
Offline stingrae
« Reply #9 on: Sat, 18 August 2012, 01:38:04 »
#IfWinActive    ; works in any active window
~LWin Up:: Return
~RWin Up:: Return
$#F5::SendInput {Media_Play_Pause}
$#F6::SendInput {Media_Next}
$#F7::SendInput {Media_Prev}
$#F8::SendInput {Media_Stop}
Volume_Down::Media_Play_Pause
Media_Prev::Media_Stop
LWin & 0::SendInput {Volume_Mute}
LWin & =::SendInput {Volume_Up}
LWin & -::SendInput {Volume_Down}
return
Turns the left windows key into a psuedo function key doesn't work too well in games though :D so maybe change to control.
And now you have to learn the script to understand how to change this mess :D
« Last Edit: Sat, 18 August 2012, 01:39:56 by stingrae »
Filco Ninja Tenkeyless  -Noppoo Choc Mini - Cm Storm Quickfire Rapid
Offline KeyboardRookie
« Reply #10 on: Sat, 18 August 2012, 04:45:09 »
Even a media key has its own Scancode in windows OS.
You can modify the registry to allocate keys as media keys.
I assume that is most efficient and less risky.
But unfortunately, you won't be able to use combination key like other keyboard which provides media key.
I'm in chronic intoxication to keyboards,
