Author Topic: GH60 Keyboard Project  (Read 866380 times)
Offline alaricljs
  • I be WOT'ing all day...
Re: [Final Prototyping] GH60 Keyboard
« Reply #1000 on: Mon, 03 December 2012, 22:14:09 »
But if you are designing a case, you design it with an integrated plate.
Filco w/ Imsto thick PBT
Offline mkawa
  •  No Marketplace Access
  • (ツ)@@@. crankypants
« Reply #1001 on: Mon, 03 December 2012, 22:36:29 »
wfd, can you please start getting shipping logistics ready so we can get these prototypes on the grill quickly?
Offline fl0w3n
« Reply #1002 on: Mon, 03 December 2012, 23:07:20 »
Are you referring to his Phantom Plate GB?
Offline WhiteFireDragon
    • youtube
« Reply #1003 on: Mon, 03 December 2012, 23:49:55 »
That gives the approximate dimensions of the plate, not accounting for shinanigans along the edges or the amount of clearance there will be around the edges.
The switch distances between each other are conserved no matter what form factor the keyboard is. Even rubber domes use this standard spacing. As for the outer edges of the plate, the left and right side should be the calculated standard 0.375" from switch center to edge, and the top/bottom edge is 0.350" from switch center to edge. If the GH60 PCB turns out to be any different than this, then it will not be a perfect fit in the stock poker case. Likewise, if the plate edges are any larger than what I mentioned, it won't fit with current poker cases.
Well I see 2 options to design the plates. One option is to make it like Beast's current poker plate, in which case the PCB does all the support from the standoffs at the bottom, which the plate only prevents flexing (and makes it feel more solid). A plate like this allows you to use stock poker/pure plastic cases, oneproduct's, imsto's, and trebs' existing cases. The 2nd option is to design the plate similar to KMAC, where there are tabs on the plate that does all the support in holding up the plate and PCB. If you make a plate like this, then everyone will be forced to also get a custom case to go along with it because it won't be compatible with stock and current aluminum cases.
What do you want me to really do? komar hasn't even gotten all the parts yet to ship all prototype stuff to me. I guess I can start looking at shipping supplies, but hard to estimate and ask for shipping money until I get the stuff.
Offline The_Beast
  • I like wood ಠ_๏
« Reply #1004 on: Tue, 04 December 2012, 00:27:53 »
Do both
Offline dirge
« Reply #1005 on: Tue, 04 December 2012, 01:20:23 »
Can someone help me with a plate design? I haven't got the hang of the software yet and was going to layer acrylic as litster does with the ergodox
Thinking about things isn't the same as doing things. Otherwise everybody would be in jail.
Offline mkawa
« Reply #1006 on: Tue, 04 December 2012, 07:58:03 »
overestimate. you know the approximate dimensions so 1.5x and go. it's cool if our reshipping costs are a little suboptimal. THE POWER OF GRAYSKULL IS IN YOUR HANDS WFD
Offline alaricljs
« Reply #1007 on: Tue, 04 December 2012, 08:17:22 »
Do both
This.  We've got plates cheap enough that worrying about quantity limits is a little silly.  There are going to be enough people that want either (or even both).  There is no point in compromising case design.
« Reply #1008 on: Tue, 04 December 2012, 08:52:10 »
WFD, You should be able to fit everything in a medium flat rate box. Simply add a small handling and materials fee, and ask everyone to send payment for shipping. Should make for a quick turnaround on your part.
    • youtube
« Reply #1009 on: Tue, 04 December 2012, 13:27:19 »
This is a list of everyone getting a prototype board. Did I miss anyone?
  • komar007
  • jdcarpe
  • kmiller8
  • TheProfosist
  • WhiteFireDragon
  • lysol
  • __red__
  • dirge
  • Index
  • hasu
  • kravlin
  • engicoder
  • modulor
  • tipo33
  • TheQsanity
  • mkawa_
Offline Glissant
« Reply #1010 on: Tue, 04 December 2012, 13:35:35 »
In before someone says "Me" for jokes.
Offline SmallFry
« Reply #1011 on: Tue, 04 December 2012, 14:48:23 »
Me!
Offline komar007
    • komar's blog
« Reply #1012 on: Tue, 04 December 2012, 17:13:18 »
  • komar007
  • jdcarpe
  • kmiller8
  • TheProfosist
  • WhiteFireDragon
  • lysol
  • __red__
  • dirge
  • Index
  • hasu
  • kravlin
  • engicoder
  • modulor
  • tipo33
  • TheQsanity
  • mkawa_
There's also nebo.
Remove me, you won't ship to me:D
And you can also remove hasu and dirge, I'll ship to them directly.
« Last Edit: Tue, 04 December 2012, 17:16:52 by komar007 »
Offline alaricljs
« Reply #1013 on: Tue, 04 December 2012, 19:40:56 »
I'd like to get a hint as to how many people are interested in Cherry stabilizers for this (or other) project.
Offline TheQsanity
  • SmallFry Lovin'
« Reply #1014 on: Tue, 04 December 2012, 19:43:57 »
Since my Poker is "co-star" I wouldn't mind a cherry but it really is kind of the same to me :)
SmallFry! <3
« Reply #1015 on: Tue, 04 December 2012, 19:44:31 »
Well, I definitely need some more. Esp 7x bent wires.
Offline samwisekoi
  • MAWG since 1997
    • Tweet samwisekoi
« Reply #1016 on: Tue, 04 December 2012, 19:45:59 »
I am!  I am!
 - Ron | samwisekoi
p.s.  But not, repeat not in 1 11/16" spacing like the dang Leopold!
« Last Edit: Tue, 04 December 2012, 19:47:31 by samwisekoi »
Offline mm87
« Reply #1017 on: Tue, 04 December 2012, 19:58:01 »
Definitely interested in few sets of stabs + spacebar wires.
Offline esoomenona
  • Gnillort?
« Reply #1018 on: Tue, 04 December 2012, 22:42:30 »
^ plus others here.
Offline dirge
« Reply #1019 on: Wed, 05 December 2012, 02:43:53 »
I would do it, but I can't get litsters wire bender in the UK.  Happy to pass the money on if someone can get the goods for me. :)
Du-Bro E/Z Bender (0-90 degrees and Z bend)
Offline vorn
« Reply #1020 on: Wed, 05 December 2012, 02:44:27 »
I need to get EVERYTHING still. Stabilizers, PCB mount switches, plate, caps...
I refresh this thread as well as the GB every day ;D
Offline KennyR
« Reply #1021 on: Wed, 05 December 2012, 04:33:42 »
Are you me?  ;)
Offline Glissant
« Reply #1022 on: Wed, 05 December 2012, 04:51:44 »
Say what? The group buy is up already? Where?
Offline TheProfosist
  • Custom Layouts Only!
« Reply #1023 on: Wed, 05 December 2012, 04:54:44 »
No were are talking about the proto boards you still need everything for them as you would a full board.
Offline Glissant
« Reply #1024 on: Wed, 05 December 2012, 05:03:09 »
Is what I was refering to :).
« Reply #1025 on: Wed, 05 December 2012, 05:08:12 »
there shouldnt be a GB thread yet... and a quick search in the GB section revealed nothing...
Offline samwisekoi
  • MAWG since 1997
    • Tweet samwisekoi
« Reply #1026 on: Wed, 05 December 2012, 10:20:42 »
I'll take on an Acrylic case design and prototype fab.
I'll use the drawings unless anyone wants to pass a spot on the prototype list...
If so, please let me know!
 - Ron | samwisekoi
« Reply #1027 on: Wed, 05 December 2012, 10:26:01 »
Thanks, sam! You could also use dimensions from the Poker PCB and case, since compatibility with that is a design goal.
Offline fl0w3n
« Reply #1028 on: Wed, 05 December 2012, 10:47:15 »
So just to recap;
Komar is printing PCBs
Beast is making plates
alaricljs is making stabilizers
Sam is making acrylic cases, and other cases already exist (where to find?)
All that's left is switches and keys, right?
« Last Edit: Wed, 05 December 2012, 11:25:43 by fl0w3n »
Offline dirge
« Reply #1029 on: Wed, 05 December 2012, 10:54:25 »
I'll be doing a proto acrylic case if I can get some confirmation on whether the phantom switch spacing is correct on this project.  I "think" it is, just need to know for sure before I get anything made.
« Reply #1030 on: Wed, 05 December 2012, 11:00:30 »
GH60 custom (DIY) keyboard recap:
1. Komar007 designed the PCB and is having them printed. He has had a prototype run done, which is being distributed for testing. Once that is tested, and the final revisions made, the GB will proceed.
2. The_Beast will be having [some number of] plate designs made. Probably about 8 designs, to include ANSI winkey, ANSI winkeyless, ISO winkey, and ISO winkeyless. If we have case-integrated designs and stand-alone designs for those, that makes 8 plate designs for a base run. And I'm sure he will take requests for custom plates, such as lysol's bottom row.
3. alaricljs is *maybe* doing another stabilizer buy. He is gauging interest. On a related note, if you choose a winkey layout, and use plate mounted Costar stabilizers, you can get those from WASDkeybaords.com all day.
4. samwisekoi has offered to help with designing an acrylic case. WhiteFireDragon, The_Beast, damorgue and dirge are also working on case designs. As are others. If you want to use an existing case, our goal is that this PCB will fit in any current Poker/Pure case. Including the aluminum ones made by imsto, treble318, oneproduct, and Duck.
You must install your own switches and keycaps.
I'll add this info to the OP.
« Last Edit: Sat, 08 December 2012, 13:32:45 by jdcarpe »
Offline The_Beast
  • I like wood ಠ_๏
« Reply #1031 on: Wed, 05 December 2012, 11:04:55 »
Y I NO ON #4?
Offline dirge
« Reply #1032 on: Wed, 05 December 2012, 11:06:21 »
Y I NO ON #4?
Least you're not totally invisible :P
« Reply #1033 on: Wed, 05 December 2012, 11:06:51 »
Y I NO ON #4?
Sorry, my memory fails sometimes. I'll edit.
Edit: But I did say, "As are others," to cover my bases there. :D
Offline samwisekoi
  • MAWG since 1997
    • Tweet samwisekoi
« Reply #1034 on: Wed, 05 December 2012, 11:07:10 »
Let's coordinate so we don't run over each other's everyone else's work.  Are you thinking flashy, industrial, minimalist, or some other adjective I haven't thought about?
(Perhaps we should Skype or something.)
 - Ron | samwisekoi
Offline The_Beast
  • I like wood ಠ_๏
« Reply #1035 on: Wed, 05 December 2012, 11:08:32 »
Y I NO ON #4?
you're a poop face
take that -_-
Offline SmallFry
« Reply #1036 on: Wed, 05 December 2012, 11:09:14 »
So just to recap;
Alajarcls is making stabilizers
That's cool, switches and keycaps are abundant.
Offline TheQsanity
  • SmallFry Lovin'
« Reply #1037 on: Wed, 05 December 2012, 11:10:14 »
Mybe add iysols design in op?
SmallFry! <3
« Reply #1038 on: Wed, 05 December 2012, 11:13:28 »
I want stainless Steel Case!!!
« Reply #1039 on: Wed, 05 December 2012, 11:14:00 »
Blue outlines in third image (komar's).
Offline SmallFry
« Reply #1040 on: Wed, 05 December 2012, 11:16:31 »
We should make a wiki page for the group buy. I can make that, or Ron can make a wiki account for you JDCarpe. Either way, my wiki skills are as below in my signature... Some of it is Moose's, but I can do all of what he has done to make a nice GB page.
« Reply #1041 on: Wed, 05 December 2012, 11:18:08 »
That would be great if you can make one, SmallFry. Thanks!
Offline SmallFry
« Reply #1042 on: Wed, 05 December 2012, 11:20:32 »
Yeah, I'll get on that!
Offline samwisekoi
  • MAWG since 1997
    • Tweet samwisekoi
« Reply #1043 on: Wed, 05 December 2012, 11:24:21 »
Wiki account created for user "Jdcarpe".
 - Ron | samwisekoi
Offline komar007
    • komar's blog
« Reply #1044 on: Wed, 05 December 2012, 11:24:40 »
BTW, for those of you who are not familiar with soldering I will provide a switch soldering service.
I'll also order the switches, so you can have a working keyboard (as in 'with switches') shipped if you want.
Offline fl0w3n
« Reply #1045 on: Wed, 05 December 2012, 11:30:54 »
Thank you for the detailed recap.
So for cases, as of right now if we want any of the existing cases, our only chance is finding it used, correct?
As for Sams question on style of case, I personally am a minimalist.
I really like the red in this case, courtesy of DanGWang
Although I'm not a fan of the glossy top, but maybe make three seperate pieces, so we can mix and match the center sandwich with the outer "breads"
Offline dirge
« Reply #1046 on: Wed, 05 December 2012, 11:33:41 »
fl0w3n it's a litster layered acrylic case made for the phantom.
Offline fl0w3n
« Reply #1047 on: Wed, 05 December 2012, 12:02:43 »
Yes I was suggesting a style for the to-be-made gh60 acrylic cases.
« Reply #1048 on: Wed, 05 December 2012, 12:04:47 »
Preliminary wiki page is up, based on the Phantom wiki at Deskthority. Please feel free to take over from here, SmallFry. :)
Offline The_Beast
  • I like wood ಠ_๏
« Reply #1049 on: Wed, 05 December 2012, 12:06:14 »
It would weight more than an SSK but I don't know of any places to have it milled. If I could, I would, but I can't so I shan't
But I'll still look into it if I haz the time
