Author Topic: GH60 Keyboard Project  (Read 864948 times)
Offline TheProfosist
  • Custom Layouts Only!
Re: [Final Prototyping] GH60 Keyboard
« Reply #850 on: Thu, 15 November 2012, 03:47:14 »
I was just going to cut down the phantom iso plate to size.  It's finding the time at the moment to do anything but post :)
idk if spaceing is the same i know there was some talk about that in the beginning of the thread.
Offline dirge
« Reply #851 on: Thu, 15 November 2012, 04:42:05 »
Wasn't the spacing because the original pokers spacing was off?
Bit you're right I need to check.
Thinking about things isn't the same as doing things. Otherwise everybody would be in jail.
Offline kravlin
  • Look for me on IRC
« Reply #852 on: Thu, 15 November 2012, 11:29:01 »
If someone who knows all the styles of layouts for the board could post them that would be really awesome. I've read through the entire thread and I'm still a little confused on which ones of the suggested layouts it supports.
Offline komar007
    • komar's blog
« Reply #853 on: Thu, 15 November 2012, 15:45:53 »
The third image in the first post tells everything you need.
Offline kravlin
« Reply #854 on: Thu, 15 November 2012, 15:59:56 »
So then there's only 3 layouts? With all the people asking if "it can do X" I kind of figured there were more.
That makes it considerably simpler.
Offline esoomenona
  • Gnillort?
« Reply #855 on: Thu, 15 November 2012, 16:02:52 »
There are a number of different switches that can be placed in different positions.
In doing them differently, I see at least 24 different layouts that could be made (just a quick count, probably more), unless I'm missing something?
Offline kravlin
« Reply #856 on: Thu, 15 November 2012, 16:14:04 »
Ah got it. So as long as they don't overlap then they can probably be switched between. There's nothing keeping the board using one color of overlap.
ok. that makes things a little more interesting. (and this is going to end up with some very interesting keyboards)
Offline Octane
« Reply #857 on: Fri, 16 November 2012, 10:06:41 »
Amazing project guys. I wish I could contribute, but this is beyond my technical expertise. But I will certainly buy a couple. Thanks for this !!
Offline fl0w3n
« Reply #858 on: Sat, 17 November 2012, 14:51:56 »
Haven't checked in since ~10 pages ago, did the prototypes get sent out yet?  Where we at?
I've got a bag of Clears sitting in my drawer waiting to go onto the board...but they might make it to my Filco first if my new plate comes before.
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #859 on: Sat, 17 November 2012, 15:11:59 »
I think they should be coming from the fab to komar next week sometime if I understood right.
Offline SmallFry
« Reply #860 on: Sat, 17 November 2012, 15:15:41 »
^ You did. I'm super excited.
Offline komar007
    • komar's blog
« Reply #861 on: Sat, 17 November 2012, 15:53:33 »
They're in Germany now;)
Offline SmallFry
« Reply #862 on: Sat, 17 November 2012, 16:14:41 »
HELL YEAH!
Offline fl0w3n
« Reply #863 on: Sat, 17 November 2012, 16:48:02 »
Superb.  Very excited to see what the results are :)
Offline dirge
« Reply #864 on: Sun, 18 November 2012, 01:40:47 »
Damn I really need to do that plate!
Offline WhiteFireDragon
    • youtube
« Reply #865 on: Sun, 18 November 2012, 05:40:44 »
Gotta make sure the PCB works first, and it can be programmed properly. Otherwise, any plate layout will be useless at this point.
Offline SmallFry
« Reply #866 on: Sun, 18 November 2012, 12:02:27 »
The plate shouldn't be too bad. The Phantom plates could be cut down (digitally) and they would work.
Offline daerid
    • Rossipedia
« Reply #867 on: Sun, 18 November 2012, 12:46:09 »
If I can reprogram this to have a HHKB layout, put me down for one.
Offline dirge
« Reply #868 on: Mon, 19 November 2012, 04:35:09 »
Can they?  I'm not sure if the keys have been moved slightly.
Offline SmallFry
« Reply #869 on: Mon, 19 November 2012, 07:44:09 »
If they have it isn't the end of the world...just a bit of tinkering then.
Offline modulor
« Reply #870 on: Mon, 19 November 2012, 09:14:02 »
I want the one with the 1.5 mods and the 1 Super keys. That would be sweet!
This is what I meant by 'standard' layout, as it's depicted in the OP, but I'll definitely be trying out several layouts regardless. :D
NP-R (soon) | 21XX | Leggera-G Acrylic | Classic TKL | Frog TKL 8K | GH60revC | R1 86U 45g | G80-2100HDU | G80-3000HAU | G80-3700HAU | QFR V1 | FC200R | Poker X | G80-11900LUMEU
Offline SmallFry
« Reply #871 on: Mon, 19 November 2012, 09:32:20 »
Ah good man! Now we need more bottom row 1unit modifiers...
Offline komar007
    • komar's blog
« Reply #872 on: Mon, 19 November 2012, 12:25:26 »
The boards have come.
More info later:D
EDIT: a bit crap quality pics.
8185-08187-1
« Last Edit: Mon, 19 November 2012, 12:39:37 by komar007 »
Offline fl0w3n
« Reply #873 on: Mon, 19 November 2012, 13:07:27 »
Woot!! Looks awesome.
Offline alaricljs
  • I be WOT'ing all day...
« Reply #874 on: Mon, 19 November 2012, 13:09:15 »
Is that matte black or is it just the photography?
Filco w/ Imsto thick PBT
Offline boost
  • BOSTMOBILE
  • NY Giants!!!
« Reply #875 on: Mon, 19 November 2012, 13:14:28 »
More info later:D
looks great. Can't wait to see it with switches and keys :)
-Enzo Ferrari
Offline The_Beast
  • I like wood ಠ_๏
« Reply #876 on: Mon, 19 November 2012, 13:26:44 »
Hawt damn that looks good
Offline 4LI4Z
« Reply #877 on: Mon, 19 November 2012, 13:55:30 »
More info later:D
That looks fantastic, I love black PCBs.
BLING BLING GOLD SPRING
ErgoClear Filco MJT2 TKL || Apple EK II || Hall Effect Keypad || Cherry G81 HAD || IBM M SSK
Offline GMC
  • Shiny.
« Reply #878 on: Mon, 19 November 2012, 14:01:14 »
This looks very cool.  Can someone confirm it could support
- 2 of 1x keys instead of the normal backspace to give backspace and delete
- Short left shift + a fn key as well as a short right shift + a fn key
WASD V1 - waiting on R4... - MX Brown
KBT Pure - Zinc caps - MX Brown
Cherry G80-1800 ISO WKL - SkiData caps - MX Clear
Offline eon
« Reply #879 on: Mon, 19 November 2012, 14:01:47 »
Looking good! Very exited by this!
Poker MX Red - Photos
Offline komar007
    • komar's blog
« Reply #880 on: Mon, 19 November 2012, 14:08:46 »
It is matte finish. I decided for it because I thought it looks cool. After I saw it I still think it does, but it catches fingerprints very easily and every scratch is very visible, so I think we may go with glossy for production. Maybe all the testers will just vote.
I've just soldered the controller part of the board,  plugged it in and it enumerates as atmel DFU, so things are looking good;)
It looks like it fits the case, but I have some worries that it might be moved a bit horizontally, I'll see when I solder the switches.
That would be it as for news.;)
Offline Batmann
« Reply #881 on: Mon, 19 November 2012, 14:26:32 »
thx for the updates, this is getting more and more exciting (even more since I discovered I don't like my poker layout)
I wouldn't have imagined a piece of pcb could be enough to turn me on!
« Last Edit: Mon, 19 November 2012, 14:48:10 by Batmann »
« Reply #882 on: Mon, 19 November 2012, 14:47:13 »
I've got my case, switches, stabilizers and keycaps ready and waiting...
Offline __red__
« Reply #883 on: Mon, 19 November 2012, 15:29:43 »
Can someone enumerate what i would need for stabilizers.  Thus is a black hole of knowledge for me.
Offline SmallFry
« Reply #884 on: Mon, 19 November 2012, 15:34:23 »
Sweet! Thanks for the pictures Komar!
Offline alaricljs
« Reply #885 on: Mon, 19 November 2012, 15:38:13 »
Any 2x or larger key needs a Cherry PCB mount stab... since there is no plate design yet, that's the only option.  onlinecomponents.com sells what you need in regard to 2x stabs, no one we've found sells space bar size stabs.
1/16" wire and a proper wire bender and you can make your own.
Not knowing your layout prefs, backspace, both shifts, enter and space bar on an ANSI layout.  (5 total)
« Last Edit: Mon, 19 November 2012, 15:40:41 by alaricljs »
Offline absyrd
  • CPT HYPE PADAWAN
« Reply #886 on: Mon, 19 November 2012, 15:40:10 »
Thanks for the update. I like the matte black, too. :D
Offline komar007
    • komar's blog
« Reply #887 on: Mon, 19 November 2012, 16:20:06 »
Maybe in the final version. Not in the prototype.
Yes.
Offline MMB
« Reply #888 on: Mon, 19 November 2012, 18:48:52 »
We need to find a vendor to produce high quality cases, and start an IC/GB.
Offline The_Beast
  • I like wood ಠ_๏
« Reply #889 on: Mon, 19 November 2012, 19:44:28 »
I'm working on one.
Do we even have a time frame for when the GB will start?
Offline boost
  • BOSTMOBILE
  • NY Giants!!!
« Reply #890 on: Mon, 19 November 2012, 19:50:05 »
I'm working on one.
You too. ;)
Do you wanna join up on making it?
-Enzo Ferrari
Offline The_Beast
  • I like wood ಠ_๏
« Reply #891 on: Mon, 19 November 2012, 19:53:01 »
I'm working on one.
You too. ;)
Sure, but I'm not sure what you could help on
I plan on getting the majority of it cut by my laser guy, sent to treb to get he edges cleaned up and a bit of milling and then I know an anodizing place that is pretty cheap.
Here's why the edges need to be milled, laser cutting thicker stock leaves serration:
Offline alaricljs
« Reply #892 on: Mon, 19 November 2012, 19:53:47 »
Is treb back in action?  Thought they were still putting things back together.
Offline The_Beast
  • I like wood ಠ_๏
« Reply #893 on: Mon, 19 November 2012, 19:54:27 »
I sent him a PM about this project, no reply. I think he said he'd be back at the end of this month. This is kinda why I'd like to know when the GH60 is rolling out so I can plan stuff n things
Offline gameaholic
« Reply #894 on: Mon, 19 November 2012, 20:13:04 »
What case are you going with?
IBM Model M SSK, Filco MJ2 Ninja TKL with Reds ergo-clears, CM Storm QFR 55g Whites, Poker II with Reds
    • youtube
« Reply #895 on: Mon, 19 November 2012, 20:51:44 »
Beast, based on a quick skim of THIS thread, you're designing the case to have multiple pieces and not CNC'ed from one solid block of aluminum?
Offline The_Beast
  • I like wood ಠ_๏
« Reply #896 on: Mon, 19 November 2012, 21:03:02 »
2 piece, just like my lunch ^___^
« Reply #897 on: Mon, 19 November 2012, 21:35:19 »
I would think the GB would proceed soon after the new year. That gives the testers time to provide feedback about the prototype. And many wallets will still be healing from the holidays until after the new year.
I'm really hoping we can get a 2-piece aluminum case that integrates with a plate, to be available for purchase with the PCB for the group buy.
Offline SmallFry
« Reply #898 on: Mon, 19 November 2012, 21:43:49 »
That's when my wallet grows! Ah the joys of being young...
Offline tipo33
  • "Ski"
« Reply #899 on: Mon, 19 November 2012, 22:17:25 »
I have less time than I thought....  I need to source some switches FAST......
KM4COL    R.I.P.  SmallFry
