Author Topic: GH60 Keyboard Project  (Read 866282 times)
Offline damorgue
    • Personal portfolio
Re: [Final Prototyping] GH60 Keyboard
« Reply #650 on: Sat, 27 October 2012, 07:04:13 »
If the prototype works, how many are left for the real GB?
What happened to all the other guys that know how to work CAD programs?
Well, it seems as more CAD guys aren't necessary at this point since several have volunteered already, which is why I didn't.
I dont think you can print metal
Yes you can. I have examples of key caps I printed in my thread.
Offline alaricljs
  • I be WOT'ing all day...
« Reply #651 on: Sat, 27 October 2012, 09:07:14 »
How many are left?  Prototype phase means you have a fab do a small run, in this case 10 boards.  You test them and make sure you got the design right.  Then we do the GB, collect money, and order GB quantity boards.  There is no limit except what we pay for.
Filco w/ Imsto thick PBT
Offline komar007
    • komar's blog
« Reply #652 on: Sat, 27 October 2012, 09:50:49 »
When this board is completed can we get the Gerber's for the community?
The gerbers are in the rev A zip file.
Offline Lorem-Ipsum
  • (╯°□°)╯︵ɯnsdı-ɯǝɹoן
    • mattwall.co.uk/
« Reply #653 on: Sat, 27 October 2012, 10:22:15 »
Wowza! Just came across this thread.
I'm certainly interested.
Currently Using: Corsair K65 (MX Reds)
Own: IBM Model M | Logitech Illuminated | Filco Majestouch 2 (MX Blues) [Waiting for Toxic] | Cherry D-91275
OS: ArchLinux | Herbstluftwm | Termite | Zsh
"In a world without walls and fences, who needs windows and gates?"
Offline SmallFry
« Reply #654 on: Sat, 27 October 2012, 11:44:19 »
I meant once it is completely done, the final designs etc.
Offline komar007
    • komar's blog
« Reply #655 on: Sat, 27 October 2012, 11:52:39 »
Sure, it's open source;)
Offline SmallFry
« Reply #656 on: Sat, 27 October 2012, 12:01:11 »
Sweet!
Offline Skeksis
« Reply #657 on: Sat, 27 October 2012, 12:14:37 »
You all are on such a good way. Following this thread day by day and even getting more exited every da.
Offline __red__
« Reply #658 on: Sat, 27 October 2012, 14:54:11 »
Sanity checking the design will be orders of magnitude easier if you can post the schematic and pcb layout files.
In the tool, mousing over nets is imho the easiest way to debug.
I'm at skydogcon.com right now re-working the conference badges.  Fun times!
Offline SmallFry
« Reply #659 on: Sat, 27 October 2012, 15:17:07 »
They're in a zip in the thread Red...I can't see what post number on my mobile, but they're there.
Offline komar007
    • komar's blog
« Reply #660 on: Sat, 27 October 2012, 15:18:16 »
The kicad files are in the repo.
https://github.com/komar007/ghkb
« Reply #661 on: Sat, 27 October 2012, 15:18:38 »
I also linked the .zip file below the images in the OP.
Offline __red__
« Reply #662 on: Sun, 28 October 2012, 00:19:23 »
Thanjs...
Btw, if anyone is interested in the badge re-work we did at the con, please follow.
« Last Edit: Sun, 28 October 2012, 00:28:05 by __red__ »
Offline SmallFry
« Reply #663 on: Sun, 28 October 2012, 00:31:13 »
Thanjs...
Sweet badge Red!
Offline mkawa
  •  No Marketplace Access
  • (ツ)@@@. crankypants
« Reply #664 on: Sun, 28 October 2012, 08:40:22 »
Thanjs...
Sweet badge Red!
ditto. cool beans!
Offline mkawa
« Reply #665 on: Sun, 28 October 2012, 08:45:47 »
it's looking great komar, bang up job for a first-timer, but i'd like __red__, alaric and bpiphany if possible to please sanity check the design. their collective experience with board layouts for switches is a resource we shouldn't waste! :)
once treble gets up and running we should be able to get small quantities of milled cases out the door at a trickle. in the meantime, test and revise, then test and revise again :)
i know i've been a bit MIA, but i'm hugely behind this effort and i want it to succeed. please don't look at my popping in as skepticism; in fact, it's quite the opposite.
Offline komar007
    • komar's blog
« Reply #666 on: Sun, 28 October 2012, 09:13:42 »
Thanks mkawa. So I'll wait until they say something. I should receive most of the parts tomorrow, so I can check the footprints against them and I'll consider testing to be over.
Offline SmallFry
« Reply #667 on: Sun, 28 October 2012, 10:40:06 »
So, I was looking at the PCB...Does this have the ability to use regular ANSI Right Shifts, or must you use an Fn key?
Offline komar007
    • komar's blog
« Reply #668 on: Sun, 28 October 2012, 10:43:01 »
Yes, mount the switch in the third position from the right and the stabilizers around it and you're good to go.
Offline TheProfosist
  • Custom Layouts Only!
« Reply #669 on: Sun, 28 October 2012, 15:52:36 »
you should be using that Fn key! Custom Layouts Only!
Offline SmallFry
« Reply #670 on: Sun, 28 October 2012, 19:09:36 »
I'll make my 1unit keys a Fn key. I love the aesthetics of a 1.5-1 type deal:)
Offline BiNiaRiS
« Reply #671 on: Sun, 28 October 2012, 21:04:14 »
put me down for one of these. been wanting this board since dox first started talking about it.
KMAC 2 w/ErgoClears
Offline WhiteFireDragon
    • youtube
« Reply #672 on: Sun, 28 October 2012, 22:08:07 »
I just noticed something about the holes for the Cherry mounted stabilizers. Are there two different PCB-mounted parts we can buy? because all the holes for the smaller size stabilizers (shifts, backspace, and enter) has the larger hole on the bottom, while the larger hole for the spacebar stabilizers are on the top.
Offline komar007
    • komar's blog
« Reply #673 on: Mon, 29 October 2012, 02:32:37 »
The spacebar has the stabilizer upside down, like in the poker.
Offline SmallFry
« Reply #674 on: Mon, 29 October 2012, 07:31:13 »
Sweet deal, that kinda worried me as well. I'm glad we can use Cherry Stabilizers, I much prefer them to Costar's. I prefer simplicity when removing the keys.
Offline jil_jil32
  • Tokyo Press <3
« Reply #675 on: Mon, 29 October 2012, 07:57:28 »
Any chance that we make a full-board LEDs supported PCB? ^.^
« Reply #676 on: Mon, 29 October 2012, 08:19:32 »
Yes, see this thread. It's called 'The Light.'
Offline mkawa
« Reply #677 on: Mon, 29 October 2012, 10:59:52 »
the light is a ways out; the driver ICs we are thinking of sourcing have a 1k MOQ at 5$/ea shipped from germany, and that's just the beginning of the set of issues that project faces.
Offline gameaholic
« Reply #678 on: Mon, 29 October 2012, 12:26:25 »
Interested.
IBM Model M SSK, Filco MJ2 Ninja TKL with Reds ergo-clears, CM Storm QFR 55g Whites, Poker II with Reds
Offline SmallFry
« Reply #679 on: Mon, 29 October 2012, 15:22:30 »
Oof. There has to be a better way to drive the LEDs.
Offline mkawa
« Reply #680 on: Mon, 29 October 2012, 16:45:45 »
not in that little board space
Offline komar007
    • komar's blog
« Reply #681 on: Mon, 29 October 2012, 17:27:32 »
13 out of 16 payments done. That means I have enough to order the PCBs.
The rest will cover the parts, shipping and other costs.
I'm doing final corrections, adding nice logos and stuff. Still waiting for at least one technical opinion on the board layout;) Two people to check is always better than one.
Offline __red__
« Reply #682 on: Mon, 29 October 2012, 17:32:57 »
Kicad doesn't see a link between the ground on P6 and and pad 2 of C2.
I'm pretty sure i do but when my software flags an existing ratsnest i pay attention.
Offline komar007
    • komar's blog
« Reply #683 on: Mon, 29 October 2012, 17:40:21 »
Thanks.
It's a bug, or actually a feature of kicad. It requires actual tracks between everything and doesn't care for planes.
I've changed the layout a bit in the current version, so P6 is actually wired to ground.
EDIT: pushed
« Last Edit: Mon, 29 October 2012, 17:43:25 by komar007 »
Offline __red__
« Reply #684 on: Mon, 29 October 2012, 18:02:35 »
Diptrace does the exact same thing.  I like the feature as it forces you to address everything.
I'm showing my ignorance of this processor (i program on the parallax propeller) but do you need a programming header to install your original bootloader to allow programming over USB?
Offline komar007
    • komar's blog
« Reply #685 on: Mon, 29 October 2012, 18:04:29 »
No, the chips come preprogrammed with a decent DFU bootloader.
I put the header just in case, so that we can change it someday.
Offline SmallFry
« Reply #686 on: Mon, 29 October 2012, 18:09:39 »
*waiting* So when does the prototype have an ETA of? I want to get the real deal! :P great work and thanks again for bring open source on this. Perhaps you may want to apply a licence to it to prevent anybody from making changes without giving you credit. :)
Offline komar007
    • komar's blog
« Reply #687 on: Mon, 29 October 2012, 18:13:00 »
The ETA (as for ordering) was yesterday evening, that is 12 minutes ago;)
I think I'll order within a day.
The diodes however will come in like a month or something unfortunately, so they may be here later than the PCBs. We'll see.
I'm not into licenses. I suppose LGPL or one of CCs will be good.
Offline SmallFry
« Reply #688 on: Mon, 29 October 2012, 18:19:45 »
Just trying to help make sure nobody steals your work. ;) Glad to see this all working as planned!
« Reply #689 on: Tue, 30 October 2012, 01:54:49 »
also working on DOX v2 will have that finalizing the plate now didnt want to say too much in this thead about it beacause the boards are very close to each other.
Offline Parak
« Reply #690 on: Tue, 30 October 2012, 08:54:04 »
Kicad always respected ground planes for me, as long as they were called GND and the appropriate pins were connected to the GND net. As long as the plane made contact with the pins, I never got validation errors. Hope that helps :D
Offline komar007
    • komar's blog
« Reply #691 on: Tue, 30 October 2012, 10:20:32 »
Even if you first put a ground plane, then connect some GND point with a trace to that plane, then save, restart pcbnew and refill the zone?
Offline The_Beast
  • I like wood ಠ_๏
« Reply #692 on: Tue, 30 October 2012, 10:32:26 »
hey komar, if you get some time, could you send me a plate layout for the "model m" style of plate? I'd like to start working on a case that covers up the two 1x keys between the 1.5 mods
If not I'll try to find a phantom plate (if there is one) with a similar layout to modify
Offline komar007
    • komar's blog
« Reply #693 on: Tue, 30 October 2012, 10:59:03 »
I haven't started the plates design yet, but I'll let you know when I have something.
« Reply #694 on: Tue, 30 October 2012, 11:23:55 »
The_Beast, you can use the ANSI150 plate drawing from the Phantom designs to get the 1.5-1-1.5 layout. Then just block the 1x between the 1.5's.
The real problem I forsee using standard ANSI with 1.5-1-1.5 mod row on the plate, with covers over the 1x keys on the case top, is what to do about a function key? I guess you could use a 1.75 right shift with a Fn key beside it, but that defeats the purpose of the standard ANSI compatibility. I will probably use that 1x key between the 1.5 mods as a Fn key.
Offline The_Beast
  • I like wood ಠ_๏
« Reply #695 on: Tue, 30 October 2012, 11:30:07 »
(you can just call me "beast", I'm not anal like Demik)
I didn't think of that and I don't want a 1x next to my right shift. Either way I just want a case that covers the 1x key spot between the 1.5 mods. I'll probably make the caps lock my function key since I almost never use it anyways and it's an easier reach for me. Plus at work I have all my AutoCAD hotkeys mapped to the caps lock via Autohotkey
« Reply #696 on: Tue, 30 October 2012, 11:31:25 »
That's not a bad idea. I really like cases that cover that area, as well. Put me down for one when you get it designed. :D
Offline Parak
« Reply #697 on: Tue, 30 October 2012, 11:59:08 »
Well, I don't connect traces to planes typically, although I have in the past for a model F pcb prototype (and what a royal PITA that was) . Either way, they don't disconnect after a reload. DRC is validating stuff just fine. So if I'm doing stuff normally, I label my ground net explicitly in the schematic as GND, then assign the zone to /GND. I bring the zone around the ground pins that need to be connected, and the zone should connect them together, assuming that the traces don't get in the way. If they do get in the way, one could connect pin to pin via a trace on another layer, or do another zone on another layer (which may or may not be a good idea for reasons of interference and such).
Offline The_Beast
  • I like wood ಠ_๏
« Reply #698 on: Tue, 30 October 2012, 12:03:34 »
I'm not sure so I'll ask:
if the bottom row is 1.5 1 1.5 spacebar 1.5 1 1.5, then the spacebar will be 7 unit right?
Offline mkawa
« Reply #699 on: Tue, 30 October 2012, 12:04:31 »
DEMIKBEAR!
