Author Topic: GH60 Keyboard Project  (Read 864897 times)
Offline The_Beast
  • I like wood ಠ_๏
Re: [Final Prototyping] GH60 Keyboard
« Reply #700 on: Tue, 30 October 2012, 12:04:56 »
Offline komar007
    • komar's blog
« Reply #701 on: Tue, 30 October 2012, 12:07:07 »
I'm not sure so I'll ask:
if the bottom row is 1.5 1 1.5 spacebar 1.5 1 1.5, then the spacebar will be 7 unit right?
Yes
Offline TheProfosist
  • Custom Layouts Only!
« Reply #702 on: Tue, 30 October 2012, 12:34:47 »
Beast care to make a case for my crazy layout?
« Last Edit: Tue, 30 October 2012, 12:55:38 by TheProfosist »
Offline The_Beast
  • I like wood ಠ_๏
« Reply #703 on: Tue, 30 October 2012, 12:37:13 »
If I have time. School is starting to break my balls with group projects, research papers and I like to volunteer when I can.
I make no promisses but if I have time after doing my "model m" case, I'll hit you up
« Reply #704 on: Tue, 30 October 2012, 12:57:27 »
Well it shouldnt be much different as the model m version just minus the flaps to cover the unused spots
Offline The_Beast
  • I like wood ಠ_๏
« Reply #705 on: Tue, 30 October 2012, 13:03:43 »
Ohh, ok. That shouldn't take more than 5 minutes to change
« Reply #706 on: Tue, 30 October 2012, 13:05:50 »
Well ill post the layout to be sure but the plates going to be different and i prefer standard bottom row.
Offline mkawa
  •  No Marketplace Access
  • (ツ)@@@. crankypants
Offline kravlin
  • Look for me on IRC
« Reply #708 on: Wed, 31 October 2012, 10:29:31 »
Does anyone know where I could pick up a 7 unit spacebar for testing once the prototype comes in? I have the caps/switches for everything else, but finding one of those is more difficult and I'm really not feeling like buying a whole keyboard for a single spacebar.
Offline The_Beast
  • I like wood ಠ_๏
« Reply #709 on: Wed, 31 October 2012, 10:30:13 »
Offline komar007
    • komar's blog
« Reply #710 on: Wed, 31 October 2012, 10:34:36 »
http://deskthority.net/marketplace-f11/doubleshot-replacements-round-4-t1376-2910.html#p80676
Here.
Offline mkawa
« Reply #712 on: Wed, 31 October 2012, 10:41:17 »
tsangan may or may not have more spacebars than the flying spaghetti monster, and they're all ready to ship out, unlike r4
Offline boost
  • BOSTMOBILE
  • NY Giants!!!
« Reply #713 on: Wed, 31 October 2012, 10:46:10 »
TL;DR
Can the standard ansi right shift be used instead of the 1800+fn key?
I also want a prototype :(
-Enzo Ferrari
Offline modulor
« Reply #714 on: Wed, 31 October 2012, 10:52:55 »
TL;DR
Yup, it can handle pretty much any alpha/num area layout imaginable in terms of modifiers.
NP-R (soon) | 21XX | Leggera-G Acrylic | Classic TKL | Frog TKL 8K | GH60revC | R1 86U 45g | G80-2100HDU | G80-3000HAU | G80-3700HAU | QFR V1 | FC200R | Poker X | G80-11900LUMEU
Offline boost
  • BOSTMOBILE
  • NY Giants!!!
« Reply #715 on: Wed, 31 October 2012, 10:55:49 »
TL;DR
Thanks for the super quick answer =)
-Enzo Ferrari
Offline komar007
    • komar's blog
« Reply #716 on: Wed, 31 October 2012, 11:06:33 »
TL;DR
Sorry, the prototype list is closed.
But I'm ordering some more pcbs, so if everything goes well, you can get one later.
Offline OrangeJewce
  • ssk.ℜ
  • King of the Jewce
« Reply #717 on: Wed, 31 October 2012, 11:22:37 »
Hey all,
What firmware is being used for the layouts? I might not be able to commit to it right now with work on the eDox UI still under construction, but maybe you would want something similar for this project (assuming the underlying firmware supports it). That is, a UI to handle editing of the layout of the keyboard?
Cheers,
IBM Model M 1390120, Otaku Unicomp+RGB, CM QFR Green, Ducky YOTD Red, SSK MKII,
ErgoDox Blue, ErgoDox White
Offline komar007
    • komar's blog
« Reply #718 on: Wed, 31 October 2012, 11:38:20 »
There will be a GUI to set the layout in runtime. Any help will be appreciated;)
As for firmware I have a custom base for it and I'll implement a layout model with layers and much more, hopefully.
Offline Lorem-Ipsum
  • (╯°□°)╯︵ɯnsdı-ɯǝɹoן
    • mattwall.co.uk/
« Reply #719 on: Wed, 31 October 2012, 11:44:57 »
I do hope that this will be multi platform as I use Linux and FreeBSD.
Currently Using: Corsair K65 (MX Reds)
Own: IBM Model M | Logitech Illuminated | Filco Majestouch 2 (MX Blues) [Waiting for Toxic] | Cherry D-91275
OS: ArchLinux | Herbstluftwm | Termite | Zsh
"In a world without walls and fences, who needs windows and gates?"
Offline kravlin
« Reply #720 on: Wed, 31 October 2012, 12:03:33 »
If there isn't a multi-platform solution I'm sure someone could write one (I'd be willing to try, but I'm a complete noob and know NOTHING about how to program a keyboard (even though I can program), no better way to learn than to try though, right?)
Offline salmo
    • messmore.org
« Reply #721 on: Wed, 31 October 2012, 12:10:30 »
I might be able to help with that part once we see it.
Offline OrangeJewce
  • ssk.ℜ
  • King of the Jewce
« Reply #722 on: Wed, 31 October 2012, 15:44:10 »
I'm not sure what you mean, how do you plan on doing this without flashing the micro controller directly? Are you doing a Java UI? or something Platform specific? To be completely open, I only do Windows UI programming.
Loren:
Strike my initial comments. There is a way *cough* java *cough*, but that's not something I'd like to do.
Cheers,
Offline komar007
    • komar's blog
« Reply #723 on: Wed, 31 October 2012, 15:52:34 »
For UI I was considering Java/swing and C++/Qt. Or maybe python/Qt.
The micro will be flashed once and later only the layout will be updated and self-programmed through the bootloader API using a separate raw HID descriptor.
Part of this already works;)
Offline mkawa
« Reply #724 on: Wed, 31 October 2012, 16:00:25 »
java runtimes are unfortunately a mess right now. i'd say python is the way to go, with either the pygtk or pyqt bindings. imo pygtk is cleanest right now but i don't deal with this stuff day in day out so if there are any experts out there pipe up
komar, how do you get flash access to the micro with your board layout? the micro needs to be user flashable regardless of whether the layout can be written via a HID driver
Offline nebo
« Reply #725 on: Wed, 31 October 2012, 16:03:36 »
I still might be able to help with the UI stuff if needed. I just switched jobs and it has a heavy ramp up not to mention me moving so for the next month or so there is no way (and then the holidays :D) but I don't think we're that pressed for time yet.
As for interface, if we want multi-platform I was reading in to it and really Java/swing would still be "easiest" but c++/qt would work. I just don't think it needs to be super fancy or all that "holy **** I need this so fast and responsive" so and swing lets you have a lot of stuff for free. Just my opinion though.
« Last Edit: Wed, 31 October 2012, 16:05:22 by nebo »
« Reply #726 on: Wed, 31 October 2012, 16:06:16 »
Here is the layout that I have planned
Looking for a stainless case for the final model probably going to go with a cardboard one for the proto
Offline komar007
    • komar's blog
« Reply #727 on: Wed, 31 October 2012, 16:26:24 »
The micro can be flashed using stock DFU bootloader.
And yes, gtk is an option too. I actually prefer it, but I don't know how well it integrates with windows.
Offline nebo
« Reply #728 on: Wed, 31 October 2012, 16:29:24 »
The GIMP uses GTK+ if I remember right, even on Windows.
Offline mkawa
« Reply #729 on: Wed, 31 October 2012, 16:36:07 »
gtkwin works well. pidgin, gimp and several other large projects use the bindings pretty extensively, so it's unlikely to give anyone fits
Offline OrangeJewce
  • ssk.ℜ
  • King of the Jewce
« Reply #730 on: Wed, 31 October 2012, 16:39:12 »
Alright, I might have to pass the torch if you go that route then. Java is a poor option. Python probably would be better, but hey I'm no expert.
Cheers,
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #731 on: Wed, 31 October 2012, 16:41:50 »
I don't really know much about gtk+, but it looks like it just needs to be compiled into an exe via mingw. Since Sun dosen't seem to do anything about java being a broken mess of security threat, it not even on my machines anymore. I think I would prefer it being not java too.
Offline The_Beast
  • I like wood ಠ_๏
« Reply #732 on: Wed, 31 October 2012, 16:44:29 »
I have no idea what anyone has been talking about in this whole page. I'll I want it to do is have multiple layers, hardware programmable buttons, works with Windows and a nice GUI if at all possible.
Offline mkawa
« Reply #733 on: Wed, 31 October 2012, 16:50:06 »
ORACLE, SIR
« Reply #734 on: Wed, 31 October 2012, 17:02:46 »
Right, I keep forgetting. Either way...
Offline komar007
    • komar's blog
« Reply #735 on: Wed, 31 October 2012, 17:05:26 »
Each time I want to send this PCB project I find something else I can do better...
I think it's time to stop.
Offline nebo
« Reply #736 on: Wed, 31 October 2012, 17:14:09 »
Either way, I'm in to help depending on when the work is done. Java/C++/Python, I don't care, code is code.
Offline SmallFry
« Reply #737 on: Wed, 31 October 2012, 17:18:09 »
Send it to get prototyped! We can fix outstanding things for the final PCB. Great work and I can't wait for the group buy/files to be released, since I might not be able to afford the GB, thus I can get the parts later via the files, if need be.
Thanks again for your work Komar!
Offline mkawa
« Reply #738 on: Wed, 31 October 2012, 17:36:12 »
we can wait komar, if you need some rerouting time. just submit for a netlist review before you send to press
god knows alaric has nothing better to do... HAH!
Offline komar007
    • komar's blog
« Reply #739 on: Wed, 31 October 2012, 17:42:26 »
Okay.
This is what I consider final.
The kicad files are already pushed to the repo.
Offline mkawa
« Reply #740 on: Wed, 31 October 2012, 17:49:41 »
__red__, can you and your script take a quick look?
Offline SmallFry
« Reply #741 on: Wed, 31 October 2012, 18:05:17 »
Mmmmm Gerber files. :) Thanks Komar!
Offline __red__
« Reply #742 on: Wed, 31 October 2012, 21:42:23 »
NOt until tomorrow at work.  The last version looked good as far as schematic -> PCB went.  I don't know enough about the hardware side of MX keyboards (stabilizers et al) to comment.  I'll be reviewing the schematic tomorrow.
Red
Offline OrangeJewce
  • ssk.ℜ
  • King of the Jewce
« Reply #743 on: Wed, 31 October 2012, 22:40:14 »
If it's done in python I'm sure something passable can be thought up. I'll just have to wait and see what comes out in terms of firmware. Regardless, I'm sure the features you want will be available.
Cheers,
Offline SmallFry
« Reply #744 on: Wed, 31 October 2012, 22:44:31 »
Cheers,
LoL. "Something passable"
Offline The_Beast
  • I like wood ಠ_๏
« Reply #745 on: Wed, 31 October 2012, 22:52:35 »
Cheers,
I don't mind editing text to change keys, as long as someone gives me some kind a direction to start from. A GUI would make it easier for those of us who are not software inclined.
« Reply #746 on: Thu, 01 November 2012, 01:25:25 »
For me i just need the layout setup once maybe twice if i need a slight change.
Offline nebo
« Reply #747 on: Thu, 01 November 2012, 11:48:54 »
Cheers,
That's what I'm thinking. If I do this I have no idea where to start because I've never even seen what is expected out of a GUI for this so I fully intend to hack it to hell and back. If anyone has some idea of what they want it might be best to post ITT w/ pictures or sketches.
Offline komar007
    • komar's blog
« Reply #748 on: Thu, 01 November 2012, 12:07:04 »
Yes, you just have to wait;)
We need working hardware first.
Offline JBert
« Reply #749 on: Thu, 01 November 2012, 14:30:06 »
I'm interested as long as the ISO 1.25 Winkey PCB + Plate goes through.
BTW: what bootloader are you putting on those Atmels, or do we still need to program them and solder it to the PCB upon arrival?
The storage list:
Currently ignored by: nobody?
[/SIZE]
