Author Topic: [GB] Filco tenkeyless custom ATmega32u4 controller - All gone, that's it folks.  (Read 376111 times)
Offline TheProfosist
  • Custom Layouts Only!
Re: [GB] Filco tenkeyless custom ATmega32u4 controller.
« Reply #550 on: Fri, 07 December 2012, 11:18:36 »
Anybody have luck with V+ and V- keyboard calls?  media keys and everything else are working...
Strange
Im using firmware Tranquilite modified from Hazu's code for me and everything works here.
« Reply #551 on: Fri, 07 December 2012, 11:21:32 »
I still have the stock firmware on mine. *shame*
Does Tranquilite's have support for PS/2? With the stock firmware it only works over USB.
« Reply #552 on: Fri, 07 December 2012, 11:22:37 »
It has NKRO if that way you mean i think it might only work over USB though which i believe is a standard feature of Hazu's firmware
« Reply #553 on: Fri, 07 December 2012, 11:29:42 »
My PC motherboard is weird. When it boots, I can't choose anything on the GRUB menu (which OS to boot) using a USB keyboard. Only PS/2. But when I plug my Filco with HLD controller into the PS/2 port, it's not recognized.
Just means I need to hurry up with my new PC build. I have all the components, just need to get it done.
Offline alaricljs
  • I be WOT'ing all day...
« Reply #554 on: Fri, 07 December 2012, 11:31:25 »
... feature of Hazu's firmware ...
ok, that's 3 times in a row so it's obviously not a typo.   Dude's handle is hasu not Hazu.
jd - I've never seen a PS/2 firmware for atmega's.
« Last Edit: Fri, 07 December 2012, 11:33:36 by alaricljs »
Filco w/ Imsto thick PBT
« Reply #555 on: Fri, 07 December 2012, 11:33:09 »
me bad :( id get own wrong if hadnt been using it for years. hasu I apologise.
Offline gizzard
« Reply #556 on: Fri, 07 December 2012, 14:07:19 »
ok, figured it out.. usb hub was being weird.. Volume stuff works now..
this may seem silly.. but what else are people macro-ing up for their keyboards?  Other than media keys and calculator.. im surprising out of ideas :-p  Is it easy to macro application launches (i would suspect no)
« Reply #557 on: Fri, 07 December 2012, 14:18:44 »
Idk i working on making my KPAD a macro pad though so ill let you know what i come up with.
Offline alaricljs
« Reply #558 on: Fri, 07 December 2012, 14:22:27 »
App launches you would generally take care of in the OS, so AHK for Windows and whatnot.
« Reply #559 on: Fri, 07 December 2012, 14:27:27 »
I did it on the KPAD pretty easily though it is a tad more easy to configre
Offline Index
« Reply #560 on: Fri, 07 December 2012, 18:06:05 »
Hey does anyone know the HID code for eject in OSX/Windows7?
Gaming Keyboard: Leopold FC200RT/ABN
Work Keyboard: HHKB Pro 2 PD-KB400B
Offline alaricljs
« Reply #561 on: Fri, 07 December 2012, 20:45:42 »
Apparently the Apple Eject key does not produce a HID code... hmmm. weird.
For Windows it is likely that some keyboards are using the Eject symbol for the 'MEDIA SELECT' keycode.  Which is MC_MSEL in hasu's firmware.
« Last Edit: Fri, 07 December 2012, 20:48:04 by alaricljs »
« Reply #562 on: Fri, 07 December 2012, 20:52:35 »
I thought eject was just F15 (or one of the F keys anyway) in OSX, though I could be wrong on that.
Offline SmallFry
« Reply #563 on: Fri, 07 December 2012, 20:53:32 »
I thought so too, but I haven't used my family's Mac in ages.
Offline alaricljs
« Reply #564 on: Fri, 07 December 2012, 21:01:20 »
Just picked through google and BootCamp has a driver you install in Windows to make the Eject button do useful things.  Like eject.
Aside from that some old Apple technical reference with all the keycodes for their board had NO code for eject.
Offline alaricljs
« Reply #565 on: Fri, 07 December 2012, 21:03:39 »
Ooooh, found an AHK script that's supposed to enable the eject key... reading it now to decipher how.
edit:
So the AHK script uses a DLL to hook into things, but the basic idea is that the Eject key gets it's own HID endpoint (device) and does not send a key code at all.  This matches up with all the other information I found (and mentioned above).
« Last Edit: Fri, 07 December 2012, 21:07:22 by alaricljs »
Offline hasu
  • @tmk
« Reply #566 on: Fri, 07 December 2012, 22:22:38 »
This commit seems to add EJECT HID usage.
I don't know how this works in actually in windows/ osx.
https://github.com/tufty/tmk_keyboard/commit/97d7ca33cea562291429bd0536850a4eb20d2a00
« Reply #567 on: Fri, 07 December 2012, 23:52:26 »
Voted and stuff... hmm I should actually program my controller :\ been really lazy lately.
Offline damorgue
    • Personal portfolio
« Reply #568 on: Sat, 08 December 2012, 06:44:40 »
I like your software hasu, and I just wanted to say thanks.
Do you know how hard it would be to add macros? Defining a string, and then make a key press activate a function which outputs the string, character by character, with at a 50ms interval or something?
Offline Index
« Reply #569 on: Sat, 08 December 2012, 17:36:27 »
My friend figured out how to add in the eject for OSX. It's the 16 bit consumer code 0x00E9. He added it as KC_EJECT. We haven't tested it in Windows yet so we'll see about that.
I've also added profiles to the firmware. Basically it just enables you to switch to different permanent layouts with their own set of layers.
Better explanation:
// Default Profile 0
[default layer 0, layer 1,..., layer 7],
// Profile 1
// Profile N
The fork on github is https://github.com/callenrosario/tmk_keyboard. It's not finished and it only works for the HID Liberation so far (still need to refactor some code and fix the other firmwares).
Offline Tranquilite
« Reply #570 on: Sun, 09 December 2012, 00:23:58 »
I recommend going into the bios and turning on "legacy keyboard support", or "legacy USB support". If either of those two options are already on, then try turning them off, if that doesn't work/those options are not available, then proceed to get a new computer :P
Offline hasu
  • @tmk
« Reply #571 on: Sun, 09 December 2012, 23:31:19 »
I've ween  working on 'new keycodes' this several weeks to support new features including macro like you described. But I'm being stuck for a while and struggling now.
Recently I came across this very neat firmware for kinesis project which already has fancy features like macro and mousekeys and full programmability with virtual machine. Porting the firmware to this controler might be very interesting.
http://geekhack.org/index.php?topic=37991.0
Offline hasu
  • @tmk
« Reply #572 on: Sun, 09 December 2012, 23:40:56 »
Thanks. I'll looking into your repository later.
0x00E9? You mean 0x00B8 in report.h?
Looking HID usage specification I'm expecting a code for eject should be 0x00B8 or 0x00CC.
Better explanation:
// Profile 1
// Profile N
Offline Index
« Reply #573 on: Mon, 10 December 2012, 01:54:45 »
Oh yeah, I mean 0x00B8. =)
Better explanation:
// Profile 1
// Profile N
Offline damorgue
« Reply #574 on: Mon, 10 December 2012, 16:31:02 »
Looks interesting. It seems to be made for the atmeaga32 already as well. Looking forward to whatever happens. Not that it matters for many applications, but my Cherry board allows for the intervals at which the characters are activated to be adjusted. Would this be possible with this as well?
« Last Edit: Mon, 10 December 2012, 16:32:48 by damorgue »
Offline DrSchlock
« Reply #575 on: Mon, 10 December 2012, 16:33:49 »
I don't suppose there are any more of these laying around? :)
Offline KennyR
« Reply #576 on: Sat, 22 December 2012, 04:42:18 »
I DID IT!
My first SMD-soldering job, with simple tools and after looking at some tutorials about soldering.
It came out pretty nice in my opinion, but damn, that atmega is a *** to solder...  ;D
Anyway, if people without SMD-soldering experience want to try this, here is a big tip: GET SOME FLUX! I'm serious, it's like magic.
Some pics, sorry for the bad lighting, I don't understand cameras  :confused:
I tested the controller with the code from Bpiphany, the man himself, and everything works.
Now I'll try to make it work with PS/2 and different layers: QWERTY layer, COLEMAK layer and DVORAK layer.
Wish me luck  :D
Offline bpiphany
« Reply #577 on: Sat, 22 December 2012, 23:29:39 »
God job =) Nice to see someone else build one for a change... First one I know of to have done it. I think I am up to at least 100 by now. To me the ATmega is no problem at all. I just point solder them 2 leads at a time. There is a video somewhere.. The crystal on the other hand wasn't even designed to be hand soldered. I would say that is the trickiest part.
« Reply #578 on: Sat, 22 December 2012, 23:37:50 »
bpiphany, with over 100 of those things, you should have had a laser cut solder paste stencil and a hot air reflow station. You could crank them out like a boss. Not that you aren't already, soldering those things by hand. :D
Offline bpiphany
« Reply #579 on: Sun, 23 December 2012, 03:37:13 »
Actually I think even someone else should have had a stencil, someone with a pick and place machine... Problem was I didn't know how many I would really sell. Ordering a lot of extra PCBs was not a big cost. Ordering components for them all at the same time would have been a bigger risk. And I also underestimated the time it would take per controller =P Any future drop in replacement controllers will have other components (among them AT90USBxxx) that will require re-flow soldering. So by then there will be a stencil at least. Perhaps me hand placing everything though.
Offline simkev
« Reply #580 on: Wed, 26 December 2012, 06:40:23 »
100+ and still counting! Thats impressive bro.  :eek:
JAG ÄR LIVRÄDD FÖR ATT LEVA & JAG ÄR DÖDSRÄDD FÖR ATT DÖ
| Poker X - Ergo Clears & Red Alert 2.0 | Majestouch 2 TKL - Browns & Blue Cream Cheese |
Offline bpiphany
« Reply #581 on: Wed, 26 December 2012, 07:45:54 »
I've sent 105 to be exact (and 20 DIY kits). Two of them were lost in transit, and I've got 4 more sitting around. One PCB mysteriously disappeared. I probably put it somewhere safe... I want to keep a bare PCB and a completed unit for myself. I ordered 160 PCBs and components for 150, so there are still some work to do, and some controllers to sell =)
Offline Wildcard
  • When caffeine isn't enough
« Reply #582 on: Thu, 27 December 2012, 01:00:43 »
Good work on this bpiphany, love my controllers so far :)
Offline bisl
« Reply #583 on: Fri, 28 December 2012, 10:53:19 »
Just popping in to say that I don't think I'll switch to any other keyboard any time soon--when using other keyboards over the holidays I kept finding myself reaching for the Fn key I have on the CapsLock. Made me a little sad to find it missing, ha.
« Reply #584 on: Sat, 29 December 2012, 15:32:48 »
I just got my HID liberation device to 'crash' or something like that.  I haven't spent much time typing on it until now, and it seemed like once I started typing really fast, it somehow refused the "unpress" the shift key.  Windows was selecting all the text on the screen and the only fix was to unplug it.  Anyone else had that problem?  I have the firmware that came installed "from the factory"
Offline alaricljs
« Reply #585 on: Sat, 29 December 2012, 19:47:31 »
I had to change the dbl-shift to boot loader command to avoid crashing when typing at speed.
« Reply #586 on: Sat, 29 December 2012, 20:49:31 »
Hmmm..  Perhaps I am paying the price for not reading this thread.  What is this command you speak of?
Offline alaricljs
« Reply #587 on: Sat, 29 December 2012, 20:56:11 »
Holding both shifts on the stock firmware will kick the Atmega into the bootloader.
Offline moogatronic
« Reply #588 on: Sun, 30 December 2012, 10:03:51 »
No doubt! I'm curious about this as well. I would love to enhance my filco's with this!
Offline Glissant
« Reply #589 on: Sun, 30 December 2012, 12:14:00 »
I keep getting alt or shift key stuck from time to time. Hate me for not reading the thread, but I am hoping someone could point me to where someone is working on firmware. Just link me a post or wiki page if you have the time for that. Or flame. doesn't matter to me =p.
« Last Edit: Sun, 30 December 2012, 15:53:23 by Glissant »
Offline bpiphany
« Reply #590 on: Sun, 30 December 2012, 13:03:43 »
Sure it isn't a case of pressing both shifts at the same time? Windows can apparently act a bit strange if the keyboard simply disappears...  If you haven't updated the firmware I don't think that is your problem though. I'm not sure I had implemented that when I sent yours =) Does the keyboard still function, only with shift pressed?
« Reply #591 on: Sun, 30 December 2012, 13:38:41 »
I'm pretty sure that I didn't press both shifts, since I was typing normally.  My shift got stuck.  The gf doesn't seem to be having problems, but she types at about half my speed when I'm warmed up.
Offline bpiphany
« Reply #592 on: Sun, 30 December 2012, 13:53:38 »
You can always have a try at hasu's tmk firmware. It was always my hope that others more experienced in programming would come along and clean that part up...
I don't actually use the device myself that much, but I use my firmware on other keyboards. The only thing I ever noticed is chattering. But then I am not using Windows either...
Offline oneproduct
  • @Ubisoft
« Reply #593 on: Thu, 03 January 2013, 10:17:36 »
Just flashed to hasu's firmware with Index's profile addition and it works great. I've got a profile for Colemak and for Qwerty that each have a function layer similar to this:
Ignore the Esc and `~ which were there for first layer on 60% keyboard layouts. I also added media keys to the arrows and lower 3 of the sixpack.
The only thing that doesn't seem to be working for me of what I've tried is KC_PEQL which is the numpad equals key. The rest of the numpad keys seem to work fine. I actually used regular numbers instead of numpad numbers in the embedded number pad because then I can also hold shift to get the symbols associated with them (!@#$%^&*().
I'll put up a little tutorial for people who are daunted by fiddling with this kind of stuff. Hopefully late tonight when I get back from work, otherwise this weekend. I have a feeling that most people aren't really making the best use of the HID Liberation device because they aren't playing with the firmware. I certainly know that I wasn't until just now.
Edit: Just for the sake of amusement. The magnet that I've been using to trigger the reed switch is one of these:
« Last Edit: Thu, 03 January 2013, 10:31:03 by oneproduct »
Layout: Colemak
Offline tjweir
« Reply #594 on: Thu, 03 January 2013, 10:30:20 »
Looks like a sensible layout, nice work.
Offline bisl
« Reply #595 on: Fri, 04 January 2013, 09:59:42 »
I love you for using ESDF and not WASD.
« Reply #596 on: Fri, 04 January 2013, 13:02:05 »
Just managed to get this to goof again.  My 'Y' key suddenly stopped working.  The keyboard still worked although I didn't rigorously test the rest of the keys.  Unplugging fixed it.
Offline hasu
  • @tmk
« Reply #597 on: Sat, 05 January 2013, 20:50:01 »
Could someone with ISO keyboard try this firmware and see if ISO specific keys work well? This firmware includes fix for ISO suggested from bpiphany.
http://dl.dropbox.com/u/1033342/hid_liber_pjrc.hex
Key next to left Shift and next to Enter are said ISO keys(In UK layout they will be \ and #).
This firmware outputs ANSI backslash keycode for ISO key next to Enter, I'm interested in whether this keycode works or not with ISO layout on Mac/Windows.
And I believe this firmware will also work on ANSI keyboard without problem, can someone try?
Plz let me know the result, your layout and OS.
Thanks in advance.
If you are interested about fix, see this patch to https://github.com/tmk/tmk_keyboard/tree/master/keyboard/hid_liber
Code: [Select]
diff --git a/keyboard/hid_liber/keymap.c b/keyboard/hid_liber/keymap.c
index 55fe872..e0ba1e7 100644
--- a/keyboard/hid_liber/keymap.c
+++ b/keyboard/hid_liber/keymap.c
@@ -136,7 +136,7 @@ static const uint8_t PROGMEM keymaps[][MATRIX_ROWS][MATRIX_COLS] = {
     GRV,   1,   2,   3,   4,   5,   6,   7,   8,   9,   0, MINS,  EQL, BSPC,  INS, HOME, PGUP, \
     TAB,   Q,   W,   E,   R,   T,   Y,   U,   I,   O,   P, LBRC, RBRC, BSLS,  DEL,  END, PGDN, \
     FN1,   A,   S,   D,   F,   G,   H,   J,   K,   L, SCLN, QUOT,       ENT,                   \
-    LSFT, NO,   Z,   X,   C,   V,   B,   N,   M, COMM, DOT, SLSH,      RSFT,         UP,       \
+    LSFT, NUBS, Z,   X,   C,   V,   B,   N,   M, COMM, DOT, SLSH,      RSFT,         UP,       \
     LCTL, LGUI, LALT,             SPC,                RALT, RGUI, APP, RCTL, LEFT, DOWN, RGHT),
 /*  EXAMPLE ISO keymap, see the NUBS and NUHS keycodes
@@ -172,7 +172,7 @@ static const uint8_t PROGMEM keymaps[][MATRIX_ROWS][MATRIX_COLS] = {
     GRV,   1,   2,   3,   4,   5,   6,   7,   8,   9,MUTE, VOLD, VOLU, BSPC,  INS, HOME, PGUP, \
     TAB,   Q,   W,   E,   R,   T,   Y,   U,   I,MSTP,MPLY, MPRV, MNXT, MSEL,  DEL,  END, PGDN, \
-    LSFT, NO,   Z,   X,CALC,   V,   B,   N,   M, COMM, DOT, SLSH,      CAPS,         UP,       \
+    LSFT, NUBS, Z,   X,CALC,   V,   B,   N,   M, COMM, DOT, SLSH,      CAPS,         UP,       \
Offline damorgue
« Reply #598 on: Sun, 06 January 2013, 07:56:36 »
Before I do, what was wrong with ISO before? It worked just perfect so I don't know just quite what to look for.
Offline bpiphany
« Reply #599 on: Sun, 06 January 2013, 08:37:24 »
The ISO key next to left shift was defined as null in hasu's code. Me and him have had a little conversation on what keycodes ISO keyboards really send =) Now the key should work as expected producing <>| for us with a Swedish layout.
