Author Topic: [Video] Removing Cherry MX switch tops (PCB-mounted) and modding them  (Read 14524 times)
Offline DanGWanG
  • Higher Standards
    • DanGWanG's Keyboard Blog
Coming back from a wake n' bake sesh earlier [7], I wanted to fix one of the switches from the NCR I tuned up yesterday.  Something in those trees in my forest made me feel a little dangerous today, so I decided to make a video of my "repair" process.
A few disclaimers before you proceed:
1.  Yes, I just woke up =)
2.  I don't get too explicit on the details mostly because MMB has an excellent guide on this already.  MMB and Limmy are the master lubricaters!
3.  Most of the modding stuff was from Limmy's "Mod Package" (Item 2)
4.  Sorry the camera is out of focus so much, I'm pretty crappy with video and I had to zoom in quite a bit =/
Credits:
- MagicMeatball's Guide:  http://geekhack.org/index.php?topic=34332.0
- Limmy's Mod Kit and Switch top removal:  http://deskthority.net/post43053.html#p43053
« Last Edit: Sat, 15 September 2012, 14:07:16 by DanGWanG »
Offline absyrd
  • CPT HYPE PADAWAN
Re: [Video] Removing Cherry MX switch tops (PCB-mounted) and modding them
« Reply #1 on: Sat, 15 September 2012, 13:52:06 »
Nice roach-clip technique. I have made the mistake of getting my hands too lubed up and making a mess on a couple of occasions.
Offline DanGWanG
  • Higher Standards
« Reply #2 on: Sat, 15 September 2012, 13:53:44 »
gross bro...
Offline The_Beast
  • I like wood ಠ_๏
« Reply #3 on: Sat, 15 September 2012, 13:54:09 »
That binder clip thingy would have been super useful last night since I was doing the same kinda thing as you. Would you mind getting a better pic of it for me dan?
Offline MMB
« Reply #4 on: Sat, 15 September 2012, 13:55:39 »
hehehehe ;)
Offline MMB
« Reply #5 on: Sat, 15 September 2012, 13:56:51 »
You so high, bro.
Offline DanGWanG
  • Higher Standards
« Reply #6 on: Sat, 15 September 2012, 13:57:07 »
Sure, it's Limmy's technique =)  He's posted some great photos here:  http://deskthority.net/post43053.html#p43053
Offline The_Beast
  • I like wood ಠ_๏
« Reply #7 on: Sat, 15 September 2012, 13:58:59 »
Yea that one looks way better. I was using this to pry up the tab ONE at a time using the leg of the binder clip
Offline absyrd
  • CPT HYPE PADAWAN
« Reply #8 on: Sat, 15 September 2012, 14:01:29 »
gross bro...
You took it there. Not I. :P
Offline 1stGenRex
« Reply #9 on: Sat, 15 September 2012, 14:11:49 »
Would you mins posting a link to where I can get one of those mod kits?
Offline DanGWanG
  • Higher Standards
« Reply #10 on: Sat, 15 September 2012, 14:35:12 »
The Mod Kit was something that I begged Limmy for =)  It wasn't anything that he sold regularly and was just helping a brotha out.
Offline 1stGenRex
« Reply #11 on: Sat, 15 September 2012, 14:49:40 »
Damn :/
But thanks for the video! I checked out your blog, and was pretty jelly of a few things there.
Offline nntnam
« Reply #12 on: Sun, 16 September 2012, 12:10:35 »
Just made myself a binder clip and tried lubricating my dolch pac board's spacebar. The result is amazing! Thanks you Dan for the tutorial and thanks limmy for the lube ^^.
░▒▓ KMAC | FILCO MJ2 | HHKB | PHANTOM ▓▒░
Offline DanGWanG
  • Higher Standards
« Reply #13 on: Sun, 16 September 2012, 12:14:45 »
Damn :/
Thanks for the support dude =)  And yeah, sometimes it makes haters like cactux so jelly that it requires him to spam my threads
Offline WRXChris
« Reply #14 on: Sun, 16 September 2012, 12:59:57 »
hahaha solid 7 for sure Dan :D  I've thanked limmy and MM for their lube advice, but I have yet to thank you!  So, thanks!
I'm still not looking forward to desoldering / resoldering my ergo clear filco AGAIN, but you were right, it's totally worth it! (At least I used lead solder so the desoldering won't be nearly as bad as the RoHS stuff!)
Offline SmallFry
« Reply #15 on: Sun, 16 September 2012, 13:15:39 »
I'll do that for you WRXChris. If you'd like that is... :)
Offline WRXChris
« Reply #16 on: Sun, 16 September 2012, 21:58:24 »
haha no thanks smallfry! It's part of the fun, but desoldering 174 pins just takes so long without a hakko 808 that I despise it sometimes!
Offline squarebox
  • In Omnia Paratus
« Reply #17 on: Mon, 17 September 2012, 21:10:46 »
I did a video a long, long, long time back...
Two-angled tweezers would've been perfect but I only have a pair at that time.
Filco Yellow Edition  | Filco Brown | Filco 2 Brown TKL | G80-1950 | G80-3494 | G80-11900 | Leopold FC500R | Noppoo Choc Mini
Offline alixinhzai
« Reply #18 on: Mon, 17 September 2012, 21:33:47 »
it killed me :((
Offline kilogeek
  • Nostalgy of a time when quality was a value
« Reply #19 on: Tue, 21 January 2014, 00:56:20 »
THX alot, that's exactky
Thx alot, that's exactly what I was looking for ! Methods shown on youtube with screwdriver are messy, takes longer and u can easily break a top if getting nervous^^
"Ne pas subir" - Devise de Saint-Cyr.
« Reply #20 on: Tue, 21 January 2014, 01:11:16 »
Offline kilogeek
« Reply #21 on: Tue, 21 January 2014, 04:03:41 »
yes and then ? :p
about Limmy's technique   http://deskthority.net/post43053.html#p43053
I just built these 2 parts, it works very well once inserted in the holes, but inserting is not so easy
as these clips are made of a bit too thick wire, so I had to use a file to make them easier to use,
just making the ends smoother.
