Author Topic: KBC Poker Question  (Read 2946 times)
Offline Cobertt
    • Control on Caps
KBC Poker Question
« on: Sun, 07 October 2012, 00:47:14 »
So I am getting one of the KBC Pokers from the recent group buy and I wanted to know if the keys were special, as in for the OKCK Orange and Charcoal group buy will I have to get an add on kid or will the standard be just fine. I really like the orange and charcoal look and wanted to make sure I had my facts straight. Thanks ;D
HHKB Pro2 | Mira SE | FJELL | KARA HAZE | CW88 FNF WKL Wine | HHKB Prophet | Al.6 | Tengu | Prototype CW60 HHKB Skunkworxxx | Prototype K80 | Tokyo60 | Gingko65 |  Midway LE |  Kei | Frog TKL | Saturn60 | NRD Kaze | Panda Korn | Iron 165 FE | Caerdroia | Safa TKL
Offline The_Beast
  • I like wood ಠ_๏
Re: KBC Poker Question
« Reply #1 on: Sun, 07 October 2012, 00:49:47 »
"standard" will work
Offline Cobertt
    • Control on Caps
« Reply #2 on: Sun, 07 October 2012, 00:51:41 »
and standard is also known as "ansi" right, just trying to make an effort to learn the lingo XD
Offline jeroplane
« Reply #3 on: Sun, 07 October 2012, 02:03:10 »
ANSI and ISO are the acronyms used to describe the two most common keyboard layouts. ISO is notable for having a large Enter key and shorter Shift keys, and is more common in Europe. There's really no such thing as "standard", but yes ANSI is probably the most common, which is what your Poker will be. Your Poker is an ANSI keyboard with the Function keys, Arrows, Keypad, etc. chopped off, leaving only the main block of keys.
You will have no problem participating in group buys for Cherry MX keycaps - the base set will almost always fit.
« Last Edit: Sun, 07 October 2012, 02:11:40 by jeroplane »
My signature hasn't changed since 2012. I should really update it.
Offline WhiteFireDragon
    • youtube
« Reply #4 on: Sun, 07 October 2012, 02:11:33 »
For the Poker, a standard TKL set will be fine, with extra keys to spare. The Pure is nearly identical (physically) to the Poker, except it has a 1.75x right shift + 1x extra key instead of a 2.75x larger right shift found in the poker, in which case you'll need the "tsangan" addon kit for these two keys. This doesn't pertain to the Poker, I just kinda told you that for your own info...
Offline Cobertt
    • Control on Caps
« Reply #5 on: Sun, 07 October 2012, 11:37:35 »
Thanks for the info guys, I really appreciate it. :)
Offline TheQsanity
  • SmallFry Lovin'
« Reply #6 on: Sun, 07 October 2012, 14:26:34 »
Just wondering if any of you guys know who designed this board and will there be and updated version coming out in the future? I'm not even sure that kbc has a web site.
Also heard some rumors that the Poker stopped production.
SmallFry! <3
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #7 on: Sun, 07 October 2012, 14:37:45 »
Well yes and no. It's still available to order, but need to meet the factory MOQ. But no, they aren't just making them regularly anymore.
Offline 0100010
  • Not Sure
« Reply #8 on: Tue, 09 October 2012, 09:51:04 »
Anyone know what the MOQ is?
Offline The_Beast
  • I like wood ಠ_๏
« Reply #9 on: Tue, 09 October 2012, 09:58:23 »
200 AFAIK
Offline dippingriz
« Reply #10 on: Thu, 11 October 2012, 00:42:16 »
$200 for a Poker?
Offline kravlin
  • Look for me on IRC
« Reply #11 on: Thu, 11 October 2012, 01:27:05 »
$200 for a Poker?
No, that they have to have a sale of at least 200 units. If i have my lingo correct.
Offline TheQsanity
  • SmallFry Lovin'
« Reply #12 on: Thu, 11 October 2012, 01:28:59 »
SmallFry! <3
KBC Poker Question
« Reply #13 on: Thu, 11 October 2012, 01:30:42 »
Offline TheQsanity
  • SmallFry Lovin'
« Reply #14 on: Thu, 11 October 2012, 01:39:31 »
How did beast find out the MOQ? do they have a site?
SmallFry! <3
