Author Topic: Best typing feel, Double Shot ABS or PBT Keycaps?  (Read 73811 times)
Offline Hyde
  • White Tofu Extraordinaire
« on: Wed, 10 October 2012, 18:55:25 »
I'm trying to upgrade from my stock Filco keycaps, I want something that feels more solid.
I'm currently eyeing thick PBT keycaps, but double shot ABS also seems quite popular so I'm just wondering which would "feel" better to type on?
Re: Best typing feel, Double Shot ABS or PBT Keycaps?
« Reply #1 on: Wed, 10 October 2012, 19:02:58 »
PBT has the best feel.
Look at decades-old Model M keys that have millions of strokes on them and still look good.
- D Trump 2026-10-24
Offline Hyde
« Reply #2 on: Wed, 10 October 2012, 20:26:34 »
lol model m come with PBT?
Offline hashbaz
  • Grand Ancient One
  • * Moderator Emeritus
« Reply #3 on: Wed, 10 October 2012, 20:34:22 »
Yes, Model M caps are PBT.  The general consensus around here is that PBT feels the best under your fingers.
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #4 on: Wed, 10 October 2012, 20:39:21 »
The profile is what is important to me. As long as it is Cherry I don't care so much about the material. I use doubleshots the most, but I don't have any full pbt Cherry sets that aren't lasered yet.
Offline The_Beast
  • I like wood ಠ_๏
« Reply #5 on: Wed, 10 October 2012, 20:40:22 »
It's a toss up for me, I could use either. But I've heard that PBT caps last much much longer than DS ABS
Offline hashbaz
  • Grand Ancient One
« Reply #6 on: Wed, 10 October 2012, 21:33:42 »
I don't think they last any longer per se (under sane conditions), but they do retain their texture more or less indefinitely.
Offline jeroplane
« Reply #7 on: Wed, 10 October 2012, 21:36:31 »
I'd say PBT. Thick ABS doubleshots are a huge improvement from the stock Filco thin ABS, but in my opinion the PBTs on my brother's Leopold outshone both ABS in terms of feel. And those were thin PBT. I definitely prefer how doubleshots look, however.
« Last Edit: Wed, 10 October 2012, 21:39:48 by jeroplane »
My signature hasn't changed since 2012. I should really update it.
Offline thegunner100
  • (╯'□')╯︵</3 ノ( '-'ノ)
    • The Emotional Skyscraper
« Reply #8 on: Wed, 10 October 2012, 21:36:57 »
Subjective, but i'd say PBT.
Input Devices:CM QF Rapidx2 ~ REALFORCE 87uw 45/55g ~ Logitech G5v2 ~ Wacom Bamboo CTH-460
Audio Setup: look me up on head-fi
Check out my blog on touhou/doujin music, audiophile gear, and doujin games!
Offline MissMurd3r84
  • In IRC wondering why Kmiller8 is yelling.
« Reply #9 on: Thu, 11 October 2012, 02:34:56 »
I say POM or PBT personally. I have the ability to shine ABS so fast though :(
KBC Poker - Red switches. Noppoo Choc Mini - Black switches. Leopold FC700R (White) - Blue switches. Ducky YOTD - Brown switches. Razer BW - Blue switches and rusted.
Offline jil_jil32
  • Tokyo Press <3
« Reply #10 on: Thu, 11 October 2012, 03:07:59 »
My hands love the feeling of Topre caps best <3
Offline sherryton
  • Kībōdo
    • Originative
« Reply #11 on: Thu, 11 October 2012, 19:03:53 »
What people mean by last longer is the wear.  ABS will turn yellow-ish after sitting in direct sunlight while PBT is more resistant against direct sunlight.  Profile is where it's at!
Offline Hyde
« Reply #12 on: Thu, 11 October 2012, 19:50:46 »
Mmmmmmm sounds like I should get some cherry profile thick PBT from imsto, it's like best in both worlds.  Too bad it's only blue and grey color so far >______>
I must wait for the beige / light grey patiently ahhhhhhhhhh, so tempted to jump the gun and just get the grey or blue.
Offline WhiteFireDragon
    • youtube
« Reply #13 on: Fri, 12 October 2012, 11:28:11 »
Feel is personal preference. I personally like thick PBT with o-rings.
« Reply #14 on: Sat, 13 October 2012, 14:06:59 »
Which are PBT.
PBT 'caps don't go yellow like some ABS, though I suspect that the additives to ABS make it more resistant to that than the 18-year-old yellow keycaps you see on WYSE. PBT is harder than ABS, (and more brittle. It will shatter instead of deforming if you hit it with a hammer, this is not a recommended use, though.) and also much more resistant to corrosion, so it should not wear out very quick at all.
I really like PBT. I suspect the porosity affects the surface boundary layer of the textured mould, making the characteristic roughness different? This is jsut a theory, but it would explain why everyone likes PBT keytop's texture, but you can still make PBT smooth (Like the sides of Model M keycaps)
Offline Dabboo
« Reply #15 on: Sun, 14 October 2012, 00:34:51 »
I really enjoy the texture of the PBT caps far more than the stock ABS caps on my Cm Storm. They also produce a deeper, nicer sound on the MX Blues which I also like. But that may be due to the thickness more than anything.
I'm typing from a CM Quickfire with MX Blues.I'm also on a constant search for cool keycaps.
PM me if you've got any you'd like to send to Australia, I'm happy to buy!
« Reply #16 on: Sun, 14 October 2012, 00:35:30 »
I prefer PBT, feels really smooth when you press on them. Doubleshots are for the looks :P
Offline jil_jil32
  • Tokyo Press <3
« Reply #17 on: Sun, 14 October 2012, 00:57:24 »
I like the feeling over Topre caps not only it is made of PBT, but also its top surface has very nice texture. I can't feel the same with the imsto's PBT. SP's PBT is quite good but not the same as Topre too. The Cherry RGB PBT is really good but I don't have the full set yet so can't say much about it.
Offline TheProfosist
  • Custom Layouts Only!
« Reply #18 on: Sun, 14 October 2012, 00:57:51 »
PBT + the more texture the better!!!
Offline TheQsanity
  • SmallFry Lovin'
« Reply #19 on: Sun, 14 October 2012, 11:50:27 »
What is shinning and what is wrong with it? I wouldn't mind my keycapds getting a little "shiny"?
SmallFry! <3
« Reply #20 on: Sun, 14 October 2012, 12:18:09 »
Colorchange... is it possible? Remember hypercolor? That would be sick.
« Reply #21 on: Sun, 14 October 2012, 12:42:11 »
You will wear down ABS keycaps over time. As this happens, the surface texture is smoothed out, and will be shiny. A lot of people don't like this, especially as it will occur to more frequently used characters first (Making the keyboard uneven).
Offline Hyde
« Reply #22 on: Sun, 14 October 2012, 13:44:51 »
I don't care about yellowing key caps, texture, or becoming shiny.  What I do care about is text that changes color - that bugs the crap out of me!
I find Das Keyboard's laser etched does that pretty fast.  Like it's not worn out but the lettering is definitely "grey" now from getting dirty / usage ... etc.
« Reply #23 on: Sun, 14 October 2012, 16:22:35 »
Thats because you have probably worn the infill of and all thats left is the laser etch.
Offline Hyde
« Reply #24 on: Sun, 14 October 2012, 19:23:48 »
lol ahhhhh oh well, it's ok the next few items on my purchase list are:
1. Cherry Profile Thick PBT Keycaps
2. IBM Model M
3. Topre Realforce
Coincidentally they all use PBT keycaps  :P
Offline Hyde
« Reply #25 on: Mon, 15 October 2012, 21:41:07 »
By the way, since IBM model M uses PBT keycaps, anyone know if Unicomp keyboards also still uses PBT keycaps?
« Reply #26 on: Mon, 15 October 2012, 22:26:03 »
yep they do, their also dyesub.
Offline squarebox
  • In Omnia Paratus
« Reply #27 on: Tue, 16 October 2012, 00:10:15 »
I would say POM gives the best typing feel. PBT keycaps always feels sandy/powdery to me. ABS are just normal.
Rank:
1. POM
2. ABS
3. PBT
Filco Yellow Edition  | Filco Brown | Filco 2 Brown TKL | G80-1950 | G80-3494 | G80-11900 | Leopold FC500R | Noppoo Choc Mini
« Reply #28 on: Tue, 16 October 2012, 04:41:35 »
Rank:
1. POM
2. ABS
3. PBT
Good to see someone else here shares the POM love. Now if only more people sold them, I can't find anything other than rainbow sets at the moment.
Offline TheQsanity
  • SmallFry Lovin'
« Reply #29 on: Tue, 16 October 2012, 13:09:35 »
So does every one agree PBT is tthe worst of the three?
SmallFry! <3
« Reply #30 on: Tue, 16 October 2012, 13:43:40 »
Rank:
1. POM
2. ABS
3. PBT
you can get POM keycaps on a the black PLU-87 I believe.
no PBT is my favorite and i prefer is over ABS anyday.
Offline TheQsanity
  • SmallFry Lovin'
« Reply #31 on: Tue, 16 October 2012, 14:01:40 »
Seems very opinion based lol.
SmallFry! <3
« Reply #32 on: Tue, 16 October 2012, 16:56:39 »
Rank:
1. POM
2. ABS
3. PBT
Sorry, I meant more like a POM set that I could use on my current keyboards.
Offline sovano
« Reply #33 on: Tue, 16 October 2012, 17:09:16 »
I really like my PBT keycap set to be honest. It sure beats some of the standard keycaps you get with mechanical keyboards. I personally like the feel of PBT.
Offline Hyde
« Reply #34 on: Tue, 16 October 2012, 17:38:34 »
lol now the question is, regular PBT vs thick PBT?  Does it have a noticeable difference?
« Reply #35 on: Tue, 16 October 2012, 17:51:27 »
Ive never had thick PBT once one of the groupbuys goes through for imsto's caps ill have some though from what everyone else has said ill probably like them more though i think i like more texture more than a thicker cap.
« Reply #36 on: Tue, 16 October 2012, 19:07:09 »
Does Noppoo have the best quality POM keycaps?
I have no clue but it seems only the weird chinese offbrands have POM keycaps.
« Reply #37 on: Wed, 17 October 2012, 09:00:01 »
Indeed, but keyboards is very much a subjective area. Here are some facts:
PBT is harder and denser than ABS
PBT is more porous than ABS
PBT has a much better solvent/corrosion resistance than ABS
PBT undergoes less wear than ABS
Black cherry lasered keycaps are POM. They are pretty awesome.
Offline TheQsanity
  • SmallFry Lovin'
« Reply #38 on: Wed, 17 October 2012, 14:48:05 »
As long as if I don't scratch off the lettering I guess. That would annoy me. There a lot of keyboards with rubber coating, that coats either ABS or PBT, I forgot which. I do like that feeling but it also gives me the feeling of scratching it off. The WASD keycaps from the Crossair k60 and the CM QFR has nice versions of these. I also like the smooth surface of my Das Ultimate. I am guessing that it is ABS.
Other than all of that I, for the most part love O-rings on my keycaps.(I am using dental bands atm).
Does O-rings make any keycap feel the same? At least the pressing feeling, not the surface feeling.
I hear that people say that landing pads are the same as O-rings. I assume that they must be different. O-rings prevent the keycap to bottom out while landing pads dampens the key when it does bottom out.
I hear that most people say that it is the same. Anyone disagree and feel that there is a difference or anyone disagree and say that the difference is unnoticeable.
SmallFry! <3
« Reply #39 on: Wed, 17 October 2012, 15:26:29 »
The rubber coating is on clear ABS caps
the das caps are just standard OEM ABS caps
I love orings as well especiallly the 40A-R from wasd the ones that are now blue.
no it shortens the the stroke a little and if you using 40A ones its a tad squishy which helps if you bottom out.
landing pads are no where near the same they fell much different in my opinion the feel horrible compared to orings because even the firm ones are way too soft so you compress them ehn you bottom out basically making  the switch feel heavier.
Offline TheQsanity
  • SmallFry Lovin'
« Reply #40 on: Wed, 17 October 2012, 15:36:11 »
I was thinking that the blue ones would be my favorite too but I have not yet tried them. Thickness wise, are all the O-rings the same or unnoticeable? I would think that I would like a thicker/taller one so it would lower my travel difference.
SmallFry! <3
« Reply #41 on: Wed, 17 October 2012, 15:39:25 »
well you could try the 40A-L which are thinner and wont reduce the travel as much but also wont cushion as well when you bottom out also if you use cherry or sp profile caps you have to use the 40A-L because the 40A-R are too thick for those keycap profiles you bearely hit the actuation point of the switch
Offline TheQsanity
  • SmallFry Lovin'
« Reply #42 on: Wed, 17 October 2012, 16:06:15 »
50A-R are basicly the same length as the 40A-R but do they feel like the same length? The 50A-R are harder so I assume that they must feel similar to bottoming out with a shorter travel distance. While the 40A-R are the same but cushions more.
SmallFry! <3
Offline phetto
  • HHKB JP
« Reply #43 on: Wed, 17 October 2012, 16:07:15 »
PBT > all
« Reply #44 on: Wed, 17 October 2012, 16:09:13 »
PBT > all
QFT...
« Reply #45 on: Wed, 17 October 2012, 16:09:48 »
yes 40A-R and 50A-R are the same thickness. yes 50A-R feel like bottoming out with very little give but quiets the bottoming out. with 40A-R there is just a light about of give that cushions bottoming out just a little bit.
« Reply #46 on: Wed, 17 October 2012, 16:54:35 »
I prefer thin PBT on Cherry Brown, and thick ABS on Cherry Blue and Clear. Cherry profile.
I have a couple of sets of thick PBT keys, but I have not really used them very long.
Cherry's black PBT keys are too slick for my taste. Not enough surface texture... if you don't count the legends, which can be felt.
« Reply #47 on: Thu, 18 October 2012, 00:03:52 »
I'm almost positive Cherry's Black lasered keycaps are POM, which does have a much lower coefficient of friction, which also makes them really easy to change, and also need plastic baggies on the stabilizers (as I found out yesterday)
They might say "PBT" on the underside, but I suspect they use the same moulds, as PBT and POM have similar shrinkage ratios (I believe)
I will say that the infilling on the legends isn't as nice: I'd much prefer POM with a flat top.
Offline Hyde
« Reply #48 on: Thu, 18 October 2012, 19:19:46 »
lol if this group buy goes through then I'll be able to find out, my first set of PBT keycaps, jump directly into cherry profile thick PBT LOL  :)
http://geekhack.org/index.php?topic=31861.0
Offline TheQsanity
  • SmallFry Lovin'
« Reply #49 on: Thu, 18 October 2012, 20:06:51 »
Are thick PBTs rare?
SmallFry! <3
