Author Topic: Does a non-print KBT Pure with Browns exist?  (Read 1930 times)
Offline naisanza
« on: Tue, 16 October 2012, 16:04:52 »
Not really sure if this was ever made without having to buy non-print keys to replace them myself. Just wondering and seeing if this is one of the versions of the Pure. I haven't found one yet, so I'm guessing it does not. In that case, any recommendations on what keycaps to get to for the KBT Pure?
| HHKB2ProOtaku | KBCPokerOtaku(MXblue) | KBTPureOrangeBrown | Heatware
Offline absyrd
  • CPT HYPE PADAWAN
Re: Does a non-print KBT Pure with Browns exist?
« Reply #1 on: Tue, 16 October 2012, 16:54:04 »
I do not believe they come retail in that configuration. As far as keycap sets go, you have to recognize that the small right shift and ~ will be hard to find a match for both size and profile-wise.
You can explore group buys that include "tsangan kits", but none of them thus far have been aimed at backlit boards (no translucent legends). Do you have a backlit pure?
Offline naisanza
« Reply #2 on: Tue, 16 October 2012, 20:40:48 »
I should have one by now, but my order for one was canceled a few days ago because I didn't order in time.
It's nowhere in stock and that got me thinking 'what if I just got a non-print Pure?' I have a non-print HHKB and I like it a lot. The only reason I wanted the Pure was because I needed a keyboard for work and I happen to like the tenkeyless and 60% design and the orange LED looked pretty good. I figured if I can't have the LED version, I mind as well try and get a non-print version, because without the backlight there's no reason for the lettering.
What are 'tsangan kits'?
Offline shibbyllama889
« Reply #3 on: Wed, 17 October 2012, 13:38:04 »
Tsangan kits are this: http://geekhack.org/index.php?topic=35600.0
What you're after is the short right-shift and the R1 1x1 keycap for the `~ key. Those are the two oddball keycaps for the Pure. I believe that some ISO kits that are sold in group buys also provide the necessary short right-shift and R1 `~ key, but I'm not 100% on that. But if you want blank keys on a Pure, I'm pretty sure your only option is to buy the blank keys separately from the board.
Offline naisanza
« Reply #4 on: Wed, 17 October 2012, 13:52:55 »
That's great information! Thank you!
By the way why is it called the R1 key? What does the R stand for?
Offline laffindude
« Reply #5 on: Thu, 18 October 2012, 23:08:25 »
Row 1. They're usually not labeled as such under the caps like the other rows.
Offline naisanza
« Reply #6 on: Thu, 18 October 2012, 23:10:16 »
Oh cool! I just learned something.
