Author Topic: [IC] GMK Electronics (Cherry OEM) Colored Esc's, Modifier Sets, CMYK, Number Row  (Read 163254 times)
Offline phetto
  • HHKB JP
Yes it would be awesome, i've only seen one photo of windowed F-Row caps, I think they were dyesub.
Offline IvanIvanovich
  • Mr. Silk Underwear
I had a function row like that from Alcatel 40x9-MMK, I sold it to someone here, they were pad print like all windowed keys.
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
ditto....
Coffee and cream set looks brilliant. I would buy that in an instant.
Luga G80-1865/MX Reds + Dolch G80-1813/MX Blues + G80-3700HQAUS + DK9008G2 Pro/MX Browns Thick PBT + DK9008G2 Pro/MX Clears Thick PBT +  QFR TKL/Ghetto Greens + Cherry G80-1800/MX Blues + IBM Model M SSK Bolt Modded + IBM Model M + IBM Model F + IBM AT F + Cherry G80-1000 (HAD)/MX Vintage Blacks + Razer BWU/MX Blues + Leading Edge DC2214/Blue Alps + Compaq MX11800/Browns + Chicony 5181/Monterey Blues + Chicony 5161/MX Black Cherry Clone + Focus 2001/White Alps + Chicony 5191/White Futabas + Olivetti ANK27-101 + Dell (Old Logo) AT101/Black Alps + NMB RT8255C+/Black Space Invaders + Unitek K260/Green Alps + Apple M0116/Orange Alps + AEK II M3501/Cream Alps + AEK M0115/Orange Alps + NEC  APC412/Blue Sliders + NEC APC410/Blue Sliders + Omnikey /White Alps + Wang/Yellow Alps (Omrons) + Laser/White SMK + Fame/Blue Aruz + AEK II M3501/Salmon Alps + Zenith ZKB-2R/Green Alps + Wang 724/Orange Alps + DK1087/Green Alps + Zenith ZKB-2/Yellow Alps + Dell Old Logo AT101/Salmon-Pink Alps + Leading Edge AK1012/White SMK's + Magitronic SK-1030/White (Linear) Futaba's + Packard Bell/White (Clicky) Futaba's + Datacomp DFK101/White  Alps + SGI AT101/Dampened White Alps + NMB AQ6RT-72511/Grey Space Invaders (Hi-Tek) + Datacomp/Blue Alps + Phillips 2812/White Space Invaders (Linear) + Dah Yang K251/Vintage MX Blues + Chicony 5161/DS Caps/Vintage MX Blue + Archie-NMB AQ659ZRT-725/Black Space Invader (Tactile) + IBM Model M 71G4644 (RD) Bolt Modded with Soarers Converter + IBM Model M Silver Label 1390131 + Cherry G80-1501/Vintage MX Clears + Focus FK8000/Linear Futabas + Gateway 2000 Anykey Programmable/Maxi-Switch + Dell GY13PVAT101/Dye Sub Caps/Salmon Alps + Chicony 5161/White Alps + AST K0B101/Slider over RD + Qtronix QX-32H + Everex/NMB RT8255CW+ Black Space Invaders-Split Erase + Tandon/NMB AQ659ZRT-101A/Beige Space Invaders + Cherry G80-11903 MNRUS/MX Blacks + Apple IIGS A9M0330/SMK Whites + WYSE PCE/MX Blacks + Chicony 5160AXT/Clicky Futaba + Cherry G80-0528/Vintage MX Blacks + Dell AT101/Linear (Modded) Black Alps+Topre 55g
Offline The_Beast
  • I like wood ಠ_๏
Can GMK do windowed keys? That would be pretty sweet
Yes, they use them a lot on thier WEY keyboards. But they can also do clear first shot which make window keys look lazy and sucky.
Offline phetto
  • HHKB JP
Perhaps you guys should check if that is possible?
I would dig that =D
« Reply #156 on: Sun, 09 December 2012, 16:56:55 »
You mean the clear legends? I thought they looked pretty intriguing. Although I think straight up windowed caps are nicer.
Offline Caaaarrrt
Voted, would also be in for some 7x spacebars.
Keen for this to happen :)
Metal Grey LZ-GH - 62g Clears | White HHKB Pro2 |KBC Poker - Lubed Reds w/ Plate and Red Imsto case | Duck Poker |  CM QuickFire Rapid - Blues w/ red case
Clear legends would be excellent for backlit keyboards.  Given the current dearth of decent backlightable keycaps, GMK could make a killing!
Offline phetto
  • HHKB JP
I vote **** clear legends, windows ftw! :-D
« Reply #160 on: Sun, 09 December 2012, 17:16:26 »
Clear legends on brown? Clear as mud is what we'll call them.
LOL. I was thinking about making a lock pack (caps, num, scroll) with clear legend as many board have those as only led key. Then if they look good consider a full set for backlight board. If that's not popular, then windowed set of lock keys would be ok. So many thing I want to do, as I am sure many of you are compiling huge wish list as well. Like matching Cprofile 1.75 control and Bprofile 1.25/1.5 caps lock... another thing high on my list of little things.
Offline MadScientist46
  • Snaged his first CCs -> HappyScientist now ^_^
Voted as well. You guys are doing a fantastic job!
(btw, windows/clear legends would be the shiznit!)
Noppoo Choc mini MX-Reds | KBT Pure MX-Reds/Green LEDs
This.  LOL.
Offline eyesmiles
 Voted. The thought of light green on purple for an Esc key made me feel warm and tingly inside. Dat purp!
... Nothing wrong with Barney or ... Hulk for that matter!  :D
Offline Broadmonkey
LOL. I was thinking about making a lock pack (caps, num, scroll) with clear legend as many board have those as only led key....
I would buy a set, or we could maybe just include a single capslock with clear legends in the modifier pack?
Lock pack is only an idea for now. It would have to be offered at another time. There is already a lot of keys in the modifier pack, I don't see adding more or making one key different than the rest.
Offline DanGWanG
  • Higher Standards
    • DanGWanG's Keyboard Blog
Way too busy over the weekend.  Thanks lysol for covering ground =)
Offline danielucf
  • Horrible Mailman
  • Hmmmm beer.
How about a "Delete", "End", and "PgDn" set in white on black?
Adapter packs will be offered when run full set. It should be cheaper then to run extra of same keys as what would be in full set.
Offline hashbaz
  • Grand Ancient One
  • * Moderator Emeritus
Ooh, this is an excellent idea.
I was planning on making a pack with center stem caps, 1.25 bottom row key, ansi enter, 1.5 \|, 2.75 shift, 2 units 0, nav block, function row in white/black and black/beige. Should be all that is needed to complete any set from 8113/1800. This will be done later with full set options.
Offline hashbaz
  • Grand Ancient One
Even better. :thumb:
Offline magey
Just to be clear, the caps lock in the modifier set is off-center right? so it can fit on Cherry boards like the G80-3000.
Offline boost
  • BOSTMOBILE
  • NY Giants!!!
Form Filled....
-Enzo Ferrari
Offline Noko
  • jolonarr: a tough dude who takes no esses!
    • Noko's Leatherworks
I've decided to register and jump in to (hopefully) my first group buy.
Just ordered my first keys from techkeys yesterday, I can see myself spending a lot on this stuff now that I'm committed! :o
Noko's Leatherworks - Handmade Custom Leather Wrist Rests -  http://www.noko.ca
Sales Thread: http://geekhack.org/index.php?topic=51762.0
Build Log: http://geekhack.org/index.php?topic=47704.0
magey, you will get both style caps lock, stepped off center and fulltouch centered stem. This way any board you have or may have and you are covered.
Welcome to GH jolonnar.
« Last Edit: Mon, 10 December 2012, 14:40:31 by lysol »
Offline guilleguillaume
Seeing that the NCR G80-0528 has Control on Caps Lock placement do you think GMK may have that option?
I think it's a nice key to add since it isn't really popular on any Cherry keyboard.
Offline silat
Or clear legends on purple. Purple Haze.......
Fighting the Christian American Taliban daily with my Deck Legend loaded with Cherry MX Clears //
Deck Legend Ice Clears // Deck Legend Frost Clears // Ducky Shining Purple Browns//QPAD MK85 Browns //
From what GMK has said so far, it sounds like anything Cherry made in doubleshot, they have it.
All this talk of green and purple - we have green and purple (and yellow) trains in Victoria: http://en.wikipedia.org/wiki/VLocity
They are DMUs which go further out than the reach of the electrified sections of metropolitan lines.
Offline phetto
  • HHKB JP
No one picking up on my idea with windowed F-keys? :P
If its 10 MOQ I can pick up 10 sets alone :)
Offline damorgue
    • Personal portfolio
I like windowed keys, in whatever form. This doesn't seem to be its time though, but I am with you on that in the future. FN lock with a window which can be put instead of scroll lock on any programmable bord, yes please. It would indicate that the second layer is activated and all that.
Offline DanGWanG
  • Higher Standards
1 more day to get your opinions in
I'm pretty sure blue will win. :( It has a pretty big lead. Ranks still look pretty close to last time.
Offline jeroplane
PLAYOFF PUSH PLAYOFF PUSH
(for green or purp pls)
On the upside, I hope the blue matches this (which it looks like it might):
« Last Edit: Mon, 10 December 2012, 20:35:54 by jeroplane »
My signature hasn't changed since 2012. I should really update it.
That's the blue I had in mind, well what it would be if it wasn't faded like in that example. Lemme see if I can find a more accurate example.
photo credit to precarious:
« Last Edit: Mon, 10 December 2012, 20:58:41 by lysol »
Offline OrangeJewce
  • ssk.ℜ
  • King of the Jewce
FWIW I voted purple. (Well other for mod set..everything else purple)
Cheers,
IBM Model M 1390120, Otaku Unicomp+RGB, CM QFR Green, Ducky YOTD Red, SSK MKII,
ErgoDox Blue, ErgoDox White
Offline jeroplane
I remember that image, lysol. That blue is a really good match for the off-white/light grey keys. I much prefer it to the "royal blue" of those CCnB examples. I have a feeling a lot of the voters for blue are those that wanted CCnB, however I hope they realise the blue here is not what was proposed for CCnB.
Offline Acetrak
  • ssk.ℜ
  • gnawm_
I think regardless of what the results are, it's an all around win :cool:
Just hope we can hit the high MOQ fast to ensure a good experience for all parties.
Baby blue?
Offline aggiejy
Blue is the safest color in the book across it's entire shade range, goes with anything, and doesn't clash with anything.  And is one of, if not the most, popular colors in the world.  Which is why I can't wait for someone to do a CCnB (or better, a STARK WHITE and blue) full set.   I might do one from SP out of impatience.  Just can't decide on shade.  Would be nice in baby blue, royal blue, or dark blue.
This blue right here... (pics from imsto, not mine)
Offline alaricljs
  • I be WOT'ing all day...
That's not just a shade of blue tho, that's also got some very specific reflective and refractive properties that you aren't going to get in plastic to make it look like that.  It does look awesome tho.  They all do.
Filco w/ Imsto thick PBT
Offline precarious
  • LOOK MOM, I'M A DRAGONZORD! DOOOO DODOODODODOODOO
if it's the light blue
Yeah, I was beginning to wonder if the blue in question happened to be the same color as that key.  If so, I can say it would definitely be better than a "royal" blue or something of that nature.
Offline GMC
  • Shiny.
C'Mon folks more Brown votes, ignore the bright purple and blue colours... After all, you don't really want your keyboard to look like it was bought from the early learning centre, do you?  :P
WASD V1 - waiting on R4... - MX Brown
KBT Pure - Zinc caps - MX Brown
Cherry G80-1800 ISO WKL - SkiData caps - MX Clear
Offline tjcaustin
  • King Klaxon
    • Buy stuff
But I want it to look like I bought it from an estate sale from an old widow whose husband used to be in IT in the 70s?
Offline Shadovved
  • King of Stickers (and GBs)
Of course! Old stuff are worth more today aren't they  :p :p :p :p
Offline GMC
  • Shiny.
you understand!
I knew they were wrong about you :P
Edit, the 70's wasn't that long ago by the way...
Offline KuhnTang
  • Game of Thrones
Whatever color gets voted on, I want some!
