Author Topic: [RIP] No More Elvish (Sindarin) Keycap Set  (Read 164610 times)
Re: [GB] Elvish (Sindarin) Keycap Set - Group Buy Open Through 14-Jan-2013
« Reply #50 on: Fri, 14 December 2012, 20:55:40 »
I believe it's impossible to have a perfect color match, and if can't match then it's better to make it completely different.
This is very true. I have one of the /kl SP PBT sets, which I used for several months. SP PBT is indeed pretty awesome, but the "almost" spacebar was really annoying. I eventually replaced it with one of those red ones feng got us.
Therefore, I propose a darkgreen spacebar for all sets. It'll match both the green and the beige.
Also, I will fill the form out once I know I can afford it :)
Offline cytoSiN
  • ATCG
« Reply #51 on: Fri, 14 December 2012, 21:10:58 »
Any chance I could mod a QFR case to LOOK like wood?  That's my current plan :D
Sure.  Pretty easy.  Look here:  http://www.mnpctech.com/Wood_Laminate_Film_Simulated.html
 - Ron | samwisekoi
Awesome.  Now to find the proper laminate...
Model M 1391401 1989 || Ducky DK9008G2 Pro LE || XArmor U9BL-S LED || CM Storm QuickFire Rapid
Offline Kaysa
« Reply #52 on: Fri, 14 December 2012, 21:14:22 »
This is the closest we can get to the real colors I believe, but I do not have access to the color ring. Spacebar color is to be disputed.
On a side note... I bet everyone gets what's in the ESC key, right?
These look a bit different....
the pearl.... it doesn't look as "pearly"? The green not as opaque...
I like the Esc Key, compare to the Dragon logo key, is it "GeekHack"?
For the spacebar, I m also worry about it's keyboard compatibility to keyboards,
I m using the notorious Leopold 500R series ..zzzz
Currently Using:
HHKB Pro2 Black with Pink blank keycaps
Topre Realforce 10th Anniversary 2nd Batch "Silent" Varied Weight force.
Offline alaricljs
  • I be WOT'ing all day...
« Reply #53 on: Fri, 14 December 2012, 21:19:37 »
SP has a 'universal' mold for space bars... Forget quite what all it's compatible with.  They just need to specify that's what spacebar they want in the set.
Filco w/ Imsto thick PBT
« Reply #54 on: Fri, 14 December 2012, 21:23:26 »
Unless I'm mistaken, SP's "Universal" spacebar will fit the Leopold FC200R, but NOT the FC500R. No aftermarket spacebar will fit the 500R, AFAIK.
Offline Kaysa
« Reply #55 on: Fri, 14 December 2012, 21:27:44 »
so I can now knock my head on the wall, or better - on the keyboard.
..... or perhaps I should've just smash the keyboard on the wall.
Currently Using:
« Reply #56 on: Fri, 14 December 2012, 21:32:34 »
Probably the best thing for a Leopold. Next time get a Filco?
Offline Sai
« Reply #57 on: Fri, 14 December 2012, 21:59:28 »
I believe we can make this GB last a little longer, but let set it to 1 month for now.
Also, samwisekoi please update the image in the first post with the keyboard I posted few posts ago. It has better colors accuracy.
That is good. That way my wallet can survive for a little longer.  :p :p
Offline GMC
  • Shiny.
« Reply #58 on: Sat, 15 December 2012, 04:48:43 »
Would like the mods, but not the full set and the price is a bit high for just that. Great work though.
WASD V1 - waiting on R4... - MX Brown
KBT Pure - Zinc caps - MX Brown
Cherry G80-1800 ISO WKL - SkiData caps - MX Clear
Offline Kaysa
« Reply #59 on: Sat, 15 December 2012, 11:24:51 »
got one and sold out because the blue switch not suit me...
am gonna sell my Leopold and get a filco or ducky so that all my keys can have a keyboard to put on.
I m trying to get some people to join me in from a Malaysia forum,
will be getting one set at for myself at least.
Currently Using:
Offline asura
  • not a duck
« Reply #60 on: Sat, 15 December 2012, 11:37:13 »
"Phone Number for Shipper *
They often require this."
It should be number for the addressee, as you'll be the shipper, and I don't know your phone number  :p
Regardless, I knew what you meant.
Oops... realise I miss-read the sentence and it does make sense as is, apologies.
« Last Edit: Sat, 15 December 2012, 11:41:33 by asura »
Offline Kaysa
« Reply #61 on: Sun, 16 December 2012, 12:35:49 »
am thinking of getting a Ducky keyboard....
but not sure the spacebar from this set can fit on to it or not...?
is ducky using the standard spacebar?
the one I m looking at now is DK9087G2pro PBT version or something...
Currently Using:
« Reply #62 on: Sun, 16 December 2012, 17:34:50 »
This GB is too pricey for me. Besides, I do not enjoy when all keys are at the same height.
Offline samwisekoi
  • MAWG since 1997
    • Tweet samwisekoi
« Reply #63 on: Sun, 16 December 2012, 17:37:58 »
They are not all the same height.
SP DCS Profile keycaps.
 - Ron | samwisekoi
Offline Kaysa
« Reply #64 on: Sun, 16 December 2012, 21:16:13 »
 - Ron | samwisekoi
are they spherical top?
Currently Using:
« Reply #65 on: Sun, 16 December 2012, 21:16:16 »
I think ducky might be using the same spacebar. You might also want to look into the QFR. I know that if you can get a few orders together, and talk with our excellent CM representative about it, they might be able to mail it directly to you internationally. Note: The QFR is TKL, though. One plus for the ducky is that you can sell the PBT off it pretty easily.
Ron, can you post updates to the OP when we hit 25,50, etc sets?
Offline samwisekoi
  • MAWG since 1997
    • Tweet samwisekoi
« Reply #66 on: Sun, 16 December 2012, 21:27:03 »
I will, of course.
Offline sherryton
  • Kībōdo
    • Originative
« Reply #67 on: Tue, 18 December 2012, 02:58:15 »
Sorry, I just filled it out today.  This is freaking awesome!
I thought this was the Skyrim set for some reason..., and that is why I always overlooked this thread.
I just rewatched the LotR again this week, and I was like "Elvish sounds familiar...".
Offline Scirocco
  • Not the usual grandma!
Put my order in. This is fantastic. ;)
Offline RougeR
i kinda want this haha, price is a bit high for the novelty though
Buckling spring warrior!
Offline cytoSiN
  • ATCG
Only 6 orders so far?!  :(  Doesn't everyone realize how epic this is?!
It's even worse than you think. Because I would hope that samwisekoi and Matt3o are two of those six orders. I'm the third. Only 3 other people signed up? Didn't this pass an IC?
Offline cytoSiN
  • ATCG
Good point....sad face.
[GB] Order your Elvish (Sindarin) Keycap Set - From Tolkien's The Hobbit & LOTR
« Reply #73 on: Thu, 20 December 2012, 14:03:25 »
I'm in those 6! I'm planning on making an earthen board just for them!
Some vendors should get involved to boost numbers!
Offline samwisekoi
  • MAWG since 1997
    • Tweet samwisekoi
There seem to be fewer buyers than there were interested parties, even though the few buyers are very excited.
 - Ron | samwisekoi
Offline nebo
I'm still considering this, just haven't pulled the trigger yet.
Offline cytoSiN
  • ATCG
Me too, sort of.  Been scouring teh interwebs for a wooden case (hopefully to replace a QFR case), but can't find anything (except an old wooden case that someone had made for a Filco with a CNC router), so I might look into making something myself.  Either way, this set is amazing and people should place orders!
Offline frostwoozle
It seems to me that this GB is a little overambitious. The quotes are far too high (unavoidable I know) to attract your average fan who'd use them for a week and then swap out everything but the White Tree. Something like a numeral set* (1 - 0) centered with none of that %≈tree silliness would get more orders. I'm avoiding this both because of my empty pockets and all the liberties taken in transliteration. I understand you fellows have worked hard on this, and I'd like to see LotR keys, but those feet aren't touching the ground :|
OT but, come to the February Toronto meetup frostwoozle!
Offline frostwoozle
I might do. Will keep an eye on things at any rate. The Chicago thread makes me think a good meeting room and take-away would be the best plan.
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
we have been open to layout design for month and actually the layout is not set on stone yet. So suggestions are welcome, I am by no means an Elvish guru.
Apart from that, I did not yet sent my order. I'm waiting till the very end because I might take more than one set if that helps reaching the tier.
 - Ron | samwisekoi
Oh, I won't put in for the IC until I know I can afford it. That's why I'm happy this has sort-of a longer IC period, so I can wait a bit.
Offline danielucf
  • Horrible Mailman
  • Hmmmm beer.
This is a bad time of the year for an expensive set group buy. If you delay for February/March then more people will feel they have money and can participate. Just let it run for awhile, not like any of the current 6 are going to drop, you can only get more orders in this scenario. I want to order a set, but will not have money for it until February most likely.
Offline esoomenona
  • Gnillort?
Yes, I'm waiting to put my name in when I have some expendable funds. I'm also waiting until that time to determine whether I would like one set of two...
Offline Sai
i am same like you. Already planned to spend for things untill Feb :D
Offline JSaintS
  • Formerly eNrageDSainT
    • JSaintS
In for a set :D I convinced my parents to offer me it (nice christmas gift ^^) thanks for this, I love the lord of the ring (I love it at the point I got my name tattooed in my elvish)
just to be sure, it will happen, whatever the number of sets we have to order, right?
« Last Edit: Fri, 21 December 2012, 17:08:26 by eNrageDSainT »
I'd be willing to wait till Feb to let this gather more orders, only means some more disposable income....hopefully :)
Offline haskellelephant
  • haskell is everywhere! What are we going to do?
I'm gonna fill in an order sometime early in January. I was just waiting for the price! I just see a registration form, is there any form of payment up yet?
Offline samwisekoi
  • MAWG since 1997
    • Tweet samwisekoi
Nope, We're just going to build up an order backlog, then once we have enough people to make the buy we will collect money.
Also, this will stay up longer to let volume go u-p and prices come down.
 - Ron | samwisekoi
Offline esoomenona
  • Gnillort?
I can't remember if I filled the form for this. Can we have a list of people who ordered? Or at least can I be reminded if I ordered or not...? Thanks!
Offline samwisekoi
  • MAWG since 1997
    • Tweet samwisekoi
Yes to both!  See OP+1.
 - Ron | samwisekoi
Offline esoomenona
  • Gnillort?
Thank you very much, Ron.
Offline Magnusian
Now if only we could convince Feng to bring back the green spacebar to go with this set.
Model M 1390120 1986  | Unicomp Customizer 104 1-Piece Keys | Franken M IBM 1390120 1987/Unicomp U4044A 2007 hybrid | CM QFR Cherry MX Greens
Offline Glod
  • Also Known As Ergonomech
    • YouTube Channel
I'm on the fence for this; I'm spending so much money lately, maybe i should exhibit some self control.
Offline esoomenona
  • Gnillort?
It's almost midnight. I thought I was going to go a full day without seeing something ridiculous.
Offline Glod
    • YouTube Channel
 :-\ damn geek hack, every day something cool I want to or will buy
Offline moogatronic
No Doubt. I have several unplanned purchases this month, of supremely awesome things as a result of coming to this site.
Offline samwisekoi
  • MAWG since 1997
    • Tweet samwisekoi
Updated the OP with a new mock-up.  (I'm experimenting with more realistic keyboard mock-ups.)
11249-0
Updated keyboard mock-up as of 04-Jan-2013.
 - Ron | samwisekoi
Offline esoomenona
  • Gnillort?
Ooh, did we do something about the spacebar color?
Offline KangarooZombies
  • HHKB Pro
  • ʕ•ᴥ•ʔ
Love the set. Looks amazing. Not too crazy about the price unfortunately. (at least not yet)
Having a bad day?
