Author Topic: [GB] Phantom Parts and Assembly Services (Update Posted 2018/07/23)  (Read 437308 times)
Offline TheProfosist
  • Custom Layouts Only!
Re: [GB] Phantom Parts and Assembly Services (Acquiring Pricing)
« Reply #150 on: Sun, 30 December 2012, 20:13:34 »
looks like MiMiC cable wont happen as part of the GB but if you still want one just contact him direct for one or fill out his form in his thread, links are in a note in the OP
« Reply #151 on: Sun, 30 December 2012, 20:20:38 »
added pricing for cherry stabilizers
Offline Acetrak
  • ssk.ℜ
  • gnawm_
« Reply #152 on: Sun, 30 December 2012, 20:22:16 »
I am assuming the same goes for the detachable mini USB mod?
« Reply #153 on: Sun, 30 December 2012, 20:33:12 »
yea that should be possible idk if he has do any trial and error with that though get
Offline nebo
« Reply #154 on: Mon, 31 December 2012, 16:14:01 »
From looking at the PCB I don't think it's possible, but if I missed it, is adding leds to certain keys supported and if so could you do that?
« Reply #155 on: Mon, 31 December 2012, 16:20:29 »
you can have leds in caps lock and scroll lock if you dont want the ones in the normal Filco positions.
« Reply #156 on: Tue, 01 January 2013, 08:31:45 »
Corrected some formatting of the OP and added a note about ordering a few extra switches when you order.
Offline Rendom
« Reply #157 on: Tue, 01 January 2013, 12:54:32 »
Costar stabilizer better or the cherry one ?
QFR - MX Blue
« Reply #158 on: Tue, 01 January 2013, 12:56:31 »
I prefer cherry with the mod.
Offline Rendom
« Reply #159 on: Tue, 01 January 2013, 13:03:30 »
what sort of mod can we do on cherry ? Sorry I'm new to all these
QFR - MX Blue
« Reply #160 on: Tue, 01 January 2013, 13:10:17 »
there are little legs on the bottom you remove which make them feel much less mushy.
Offline Rendom
« Reply #161 on: Tue, 01 January 2013, 13:49:56 »
I see thank you sir. Probably getting each.
QFR - MX Blue
Offline rindorbrot
« Reply #162 on: Tue, 01 January 2013, 17:33:10 »
Will you also offer custom springs and switch stickers? That would be awesome!
If I only order some parts, no full assembly, will you still do the Cherry stabilizer mod for example?
And how about if I would want both LED spots populated (Filco style + in switch, total of 4 LEDs), could you offer the parts for that too?
« Reply #163 on: Tue, 01 January 2013, 17:39:26 »
I have no source of custom springs or stickers
I can do the cherry stab mod theres also a good video about it up on GH some where (try the KMC DITY thread [not my build log thread])
with the wiring of the phantom board you cant have both spots populated but we do offer different colors leds and their matching resistors
Offline rindorbrot
« Reply #164 on: Tue, 01 January 2013, 17:42:21 »
I thought I've read it somewhere that it is possible if you use a third resistor. Have to look that up again...
Edit:
Found it in the DT Thread for the Phantom.
Quote from: Deskthority-thread
Quote from: gimpster
Quote from: fruktstund
Question: is it possible to have LEDs both in the switches and between the six pack and Pause/Printscreen/Rollen keys? :)
Yes. It's definitely possible. I think you need 3 resistors, instead of 2, though. If I remember correctly, the Scroll Lock shares a resistor between the key light and the case light, but the Caps Lock has a separate location for the resistor used by the key light that is next to the switch.
And thank you very much gimpster, tried it out, and it did work! I just soldered 3 resistors on because it seemed right, so I don't have any idea if it would work with only two, but I think not.
« Last Edit: Tue, 01 January 2013, 17:51:04 by rindorbrot »
« Reply #165 on: Tue, 01 January 2013, 17:53:56 »
Edit:
ok well there are 3 resistor positions and 4 leds so you have to figure out the circuit that has 2 leds in it and see how it wired once that firgure out the correct resistor could be selected but to mu understanding the boar was never meant to run 4 leds at the same time.
Offline takaki
« Reply #166 on: Wed, 02 January 2013, 02:31:44 »
the boar ? :D
Don't know about 4 LEDs but it can run a monkey.
LEDs do not have a resistance rating on it, so one resistor to control the current supplied to the LEDs are more than enough.
You can consider using a lower rated resistor to adjust the brightness among the LEDs you wanna add in.
« Reply #167 on: Wed, 02 January 2013, 05:21:29 »
What matters is if their wired in series or parallel. As that will control if its possible and what resistor to use.
« Last Edit: Wed, 02 January 2013, 05:36:35 by TheProfosist »
« Reply #168 on: Wed, 02 January 2013, 05:40:44 »
Lets get back on topic in this thread please if you want to talk more abou what can be done to the phantom i would suggesting the phantom building thread.
Offline r3dx
« Reply #169 on: Wed, 02 January 2013, 08:53:55 »
I'd be interested in some Cherry stabilizers and switches, although I'm still trying to decide which switches to get.  :-\
Decisions, decisions...
Filco MJ2 Ninja | CM Storm QFR | CM Storm QFR | IBM Model M | IBM Model M SSK | ErgoDox |
LZ-GH
Offline KuhnTang
  • Game of Thrones
« Reply #170 on: Wed, 02 January 2013, 12:55:13 »
Prof,
Are the only cases you're offering going to be the PLU's?  I need two cases, but I don't like the PLU's.
In another thread you mentioned you were interested in a stainless case but that no one designed it and it would be expensive.  I'd buy one if you can make it happen.  I'm sure at least a few more people would jump in as well.
Offline Leewei
« Reply #171 on: Wed, 02 January 2013, 22:51:35 »
There is a pure alu case being made from what I know, it will be out this week so just be on a lookout for it =)
Filco Majestouch 2 Beige TKL with MX Reds
Qsenn dt-35
Offline KuhnTang
  • Game of Thrones
« Reply #172 on: Wed, 02 January 2013, 23:02:00 »
What do you mean "out this week"?  As in up for group buy, or on the open market?
Offline Leewei
« Reply #173 on: Wed, 02 January 2013, 23:03:33 »
Out on GH forum and it will probably be a groupbuy. Out this week means that they will announce more details and information sometime in the coming 7 days.
Qsenn dt-35
Offline KuhnTang
  • Game of Thrones
« Reply #174 on: Thu, 03 January 2013, 00:25:43 »
Thanks.... guess I was just hoping that it wouldn't be another 3 to 4 month adventure.
Offline nebo
« Reply #175 on: Thu, 03 January 2013, 00:33:48 »
Welcome to the hobby. For perspective, the R4 GB if including interest check is coming up on 1.5 years soon. A few months for a solid case to have for such a sweet board is a small price to pay.
That said, this is TPs thread for building phantoms so let's not crap it up.
Offline Amarok
« Reply #176 on: Thu, 03 January 2013, 14:20:03 »
Are we still waiting on anything aside from plate pricing and case moding pricing?
Realforce 87u 55g
Re: Re: [GB] Phantom Parts and Assembly Services (Acquiring Pricing)
« Reply #177 on: Thu, 03 January 2013, 23:48:20 »
im doing the case moding so ill just have to decide on a price all that im waiting on besides this is the plates then...
O i almost forgot im looking into the additonal color plu cases and should hear back soon. Sorry for now updating the thread recently, and ill start working on the form so i can get it up asap once everything has pricing.
Offline WhiteFireDragon
    • youtube
« Reply #178 on: Fri, 04 January 2013, 00:55:05 »
Did you get any quotes back yet? I still haven't gotten any from the local places around me.
« Reply #179 on: Fri, 04 January 2013, 00:56:35 »
nope if i dont get a reply soon ill send a follow up email.
Offline Paranoid
« Reply #180 on: Fri, 04 January 2013, 04:23:33 »
regarding the Cherry Stabilizers, is there a difference for ANSI/ISO or does it work for both? Or is everything included for both perhaps.
And the same question about the spacebar sizes :)
Offline Oproer
« Reply #181 on: Fri, 04 January 2013, 12:07:26 »
With the PCB GB being closed I am not sure what else I need to order in a GB separate from this. I need a plate from WhiteFireDragon's GB as well right?
And then I only need to participate more in this GB and in a GB once someone makes a decent looking case to replace the PLU-87?
I'm kinda lost on building designing my own keyboard.. I'm not even sure which layout I want it to have but I kinda like the one without the windowskeys but there's no case to make this look nice..
« Last Edit: Fri, 04 January 2013, 12:10:02 by Oproer »
Offline samwisekoi
  • MAWG since 1997
    • Tweet samwisekoi
« Reply #182 on: Fri, 04 January 2013, 12:32:06 »
Is there a fancy form yet?
« Reply #183 on: Fri, 04 January 2013, 12:43:03 »
no I still dont have pricing on plates which are rather important part of building a phantom
« Reply #184 on: Fri, 04 January 2013, 12:46:36 »
ansi/iso use the same stabilizers so everything is included.
« Reply #185 on: Fri, 04 January 2013, 12:47:03 »
well this GB will have everything that you need but the PCB.
Offline samwisekoi
  • MAWG since 1997
    • Tweet samwisekoi
« Reply #186 on: Fri, 04 January 2013, 12:58:38 »
That's cool.  You just have a close date that I don't want to miss.
 - Ron | samwisekoi
« Reply #187 on: Fri, 04 January 2013, 13:03:40 »
 - Ron | samwisekoi
yes ill be extended probably ill have at least 1 week for thus GB to be open
Offline rindorbrot
« Reply #188 on: Sat, 05 January 2013, 07:39:19 »
I have another question regarding the Cherry stabilizers you will offer.
Cherry Stabilizers: $8 per set (will outfit a standard TKL keyboard)
Does "standard TKL" mean there will be only 6.25x spacebar stabilizers? Or will I be able to choose in the ordering for if I want a Cherry kit with 6.25x or 7x spacebar stabilizer?
« Reply #189 on: Sat, 05 January 2013, 10:41:59 »
youll be able to choose when ordering which spacebar you want.
Offline rindorbrot
« Reply #190 on: Sat, 05 January 2013, 10:57:56 »
OK, and how will it work with the plates exactly?
I understand that you will offer the ones being discussed in WFDs IC thread. Will your GB be the only spot to order those plates or will we be able to order them from WFD himself directly, too?
« Reply #191 on: Sun, 06 January 2013, 01:15:14 »
i believe ill be selling them though that may change depending on who gets the best pricing or actually gets a quote first lol
Offline TheQsanity
  • SmallFry Lovin'
« Reply #192 on: Sun, 06 January 2013, 16:30:48 »
Is order form up yet?
SmallFry! <3
Offline metafour
« Reply #193 on: Sun, 06 January 2013, 20:10:53 »
Doesn't look like it. I believe they're waiting on quotes for the plates.
Offline mashby
  • What Up Shoney? (ツ)_/¯
    • Mashby
« Reply #194 on: Sun, 06 January 2013, 20:30:56 »
I apologize if this has already been discussed, but I don't know what the following options are:
  • LED and Resistor Swap
  • Black or Clear Spring for Spacebar: $0 (free) per phantom
  • Cherry Stabilizer Mod: $0 (free) per phantom
May I buy a clue?  ;)
« Reply #195 on: Sun, 06 January 2013, 21:50:27 »
1. If you want to use a different LED color than the white LEDs supplied. Different LEDs have different voltages, and so require different resistor values.
2. Sometimes you want your spacebar to have a stiffer spring than the rest of your switches. For instance, if you have a board with reds, you want a black spacebar spring to provide more resistance.
3. Cherry stabilizers can feel mushy to some people. There is a mod where you clip a piece of the stabilizer insert to make it feel less so.
Offline mashby
    • Mashby
« Reply #196 on: Sun, 06 January 2013, 21:57:39 »
jdcarpe, you are both a gentleman and a scholar.  :D
Thank you for explaining everything so plainly. Now I know what additional options I should add to my future order.
Offline mashby
    • Mashby
« Reply #197 on: Sun, 06 January 2013, 22:58:08 »
The PLU-87 comes with a plate, so do we still need to source a plate from WFD's Plate GB?
Offline alaricljs
  • I be WOT'ing all day...
« Reply #198 on: Sun, 06 January 2013, 23:29:48 »
Well, you won't be able to stem/spring swap with that one and you want have as many layout options... and it'll only have costar? stabs (PLU uses costar, right?).  But it should technically work.
Filco w/ Imsto thick PBT
Offline TheQsanity
  • SmallFry Lovin'
« Reply #199 on: Mon, 07 January 2013, 02:19:00 »
is the deadline still in two days? I feel like it should be extended.
Is Phantom Full LED compatible?
SmallFry! <3
