Author Topic: [GB] Phantom Parts and Assembly Services (Update Posted 2018/07/23)  (Read 437307 times)
Offline TheProfosist
  • Custom Layouts Only!
Re: [GB] Phantom Parts and Assembly Services (Acquiring Pricing)
« Reply #100 on: Tue, 25 December 2012, 02:19:19 »
Well, thanks for letting us all know what you personally would or would not do. I'm sure we were all wondering.
And thank you as well for cluttering up this established member's thread with your comment.
Pointing to the fantastic job he did on that KMAC doesn't back up my link text if interpreted literally. Seems to me you're a wee bit trigger happy.
Thanks for the props, though next time maybe make it a wee bit more obvious because sadly sarcasm does not have it own font :(
Just wanted to say, us Canadians tend to use sarcasm in text format quite often. Universally it fails quite often, but we get it up in this heartless frozen north :D
I'm just glad you didn't get my KMAC LE to build....that plate...ugh.
yea what a mess. did you get a new one yet?
One is in the works, just have to wait to get it here in Canada. Which will take awhile for shipping this time of year. In the meantime, I'm really considering getting SMD diodes instead of thru-hole...although I did mod all those switches already.....
I can give you the mouser number if you need it for the SMD diodes.
« Reply #101 on: Tue, 25 December 2012, 02:20:33 »
^Yea lemme know what it is, I'll write it down if I decide to order them.
« Reply #102 on: Tue, 25 December 2012, 02:35:20 »
here ye go http://tinyurl.com/ctc6fjw
« Reply #103 on: Tue, 25 December 2012, 02:38:04 »
Bookmark added! Cheers mang
Offline TheQsanity
  • SmallFry Lovin'
« Reply #104 on: Tue, 25 December 2012, 16:30:47 »
Will plu-87 work with 7-bit layout?
SmallFry! <3
Offline baldgye
  • Will Smith Disciple
« Reply #105 on: Tue, 25 December 2012, 17:00:20 »
Hey given the close date I think I'm going to have to have my PCB sent to you guys for building it up.. but I'm still not 100% sure on what switches I want to use on it... when do you need to know all the details on what we want 'building' ??
Offline Batmann
« Reply #106 on: Tue, 25 December 2012, 17:25:38 »
5$ for harvesting switches on a PLU, this is cheap! I spent almost 4 hours desoldering my poker (with a crappy iron and a cheap pump but still!)
Very nice prices, you guys rock
Offline SmallFry
« Reply #107 on: Tue, 25 December 2012, 17:33:03 »
Holy cow Batmann! Desoldering my entire Leopold and resoldering it back together after I installed different springs (ergo clears) took me less than 4 hours.
Offline Batmann
« Reply #108 on: Tue, 25 December 2012, 17:46:33 »
Yeah i know this is very slow!
I use a 30W iron with a cheap pump and i often have to add flux because i don't always manage to remove all the solder on the first attempt
This is painfull!
Lubing and changing stems or spring is piece of cake with Beast tools
« Reply #109 on: Tue, 25 December 2012, 18:51:39 »
Yes I will have to modify the PLU case ill add that to the op.
Offline akuJIWA
  • Lock 'N Load!
« Reply #110 on: Tue, 25 December 2012, 21:02:02 »
How do you sign up actually?
The Cheat - B/R/B ; Clear switch with 62g springs
quit
Offline gameaholic
« Reply #111 on: Wed, 26 December 2012, 02:12:16 »
I'm in.  I have some vintage blacks that I would like to go into this.  I would like to pair them with 55g Korean Springs (once I can find those).  I'd also like them lubed.  What lube will you guys be using?
« Last Edit: Wed, 26 December 2012, 02:15:47 by gameaholic »
IBM Model M SSK, Filco MJ2 Ninja TKL with Reds ergo-clears, CM Storm QFR 55g Whites, Poker II with Reds
Offline zyth3x
« Reply #112 on: Wed, 26 December 2012, 03:33:49 »
Interested in some Clear switches, will you ship to Australia?
Re: Re: [GB] Phantom Parts and Assembly Services (Acquiring Pricing)
« Reply #113 on: Wed, 26 December 2012, 13:37:24 »
there will be a form as soon as i have acquired pricing for everything.
« Reply #114 on: Wed, 26 December 2012, 13:38:05 »
sounds fine with me just remember to select the corrent service when you fill out the form.
« Reply #115 on: Wed, 26 December 2012, 13:38:27 »
yes this GB is international.
Offline samwisekoi
  • MAWG since 1997
    • Tweet samwisekoi
« Reply #116 on: Wed, 26 December 2012, 13:53:51 »
Am I losing my mind, or is there no form URL in this thread?
 - Ron | samwisekoi
Offline korne
    • comscan
« Reply #117 on: Wed, 26 December 2012, 13:55:17 »
I wan't some 7x stab
Re: Re: Re: [GB] Phantom Parts and Assembly Services (Acquiring Pricing)
« Reply #118 on: Wed, 26 December 2012, 13:55:58 »
 - Ron | samwisekoi
no form url yet as im still missing pricing on some items.
Offline Glod
  • Also Known As Ergonomech
    • YouTube Channel
« Reply #119 on: Wed, 26 December 2012, 14:18:58 »
i'm down for parts: PLU-87 disassembled and the plate (which i'm guessing is related to the interest check)
ill fill out the form when it becomes available  :D
« Reply #120 on: Thu, 27 December 2012, 02:41:49 »
Trying to track down the remaining parts but i may not get a quote on the plates until after new years (which is after the GB for the PCBs ends) :( it really depends on home quick people get back to me.
« Reply #121 on: Thu, 27 December 2012, 07:13:39 »
updated some content in the OP and fixed some formatting
« Reply #122 on: Thu, 27 December 2012, 07:26:04 »
added pricing for costar stabilizers
Offline baldgye
« Reply #123 on: Thu, 27 December 2012, 07:28:16 »
what diffrence does lube make to the switches??
« Reply #124 on: Thu, 27 December 2012, 07:37:55 »
makes them buttery smooth in my experience
« Reply #125 on: Thu, 27 December 2012, 07:42:28 »
add the Assembly option of modded cherry stabilizers for FREE!!!
« Reply #126 on: Thu, 27 December 2012, 07:49:21 »
clarified what would happen to any extra or leftover parts for your phantom in the OP
Offline inlikeflynn
  • file not found
----------- __o
--------- _`\<,_
BRAAP(>)/ (*)
« Reply #129 on: Fri, 28 December 2012, 04:34:02 »
Pink PLU-87 added as an option for a case and switch source
Offline Rendom
« Reply #130 on: Fri, 28 December 2012, 15:08:31 »
If i want to buy switches and stabilizer do I just post it or via pm ? btw a 87 keys keyboard need how many set of stabilizer?
QFR - MX Blue
« Reply #131 on: Sat, 29 December 2012, 05:42:03 »
there will be a form up once I have pricing for everything, please use that to order.
« Reply #132 on: Sat, 29 December 2012, 05:43:56 »
Clarified about how to order and when the order form will be up in the OP.
« Reply #133 on: Sat, 29 December 2012, 06:39:17 »
corrected the price of the Pink PLU-87
Offline takaki
« Reply #134 on: Sat, 29 December 2012, 07:39:07 »
I just tried to desolder 87 blue keys today, you only charging $5 for it ? wow.
« Reply #135 on: Sat, 29 December 2012, 09:36:25 »
Yes to desolder the PLU-87's its only $5 if you wish to use those switches.
Offline mashby
  • What Up Shoney? (ツ)_/¯
    • Mashby
« Reply #136 on: Sat, 29 December 2012, 10:15:24 »
looks like you can also get other color cased PLU's from taobao
http://item.taobao.com/item.htm?spm=2013.1.0.80.CWdJTq&scm=1007.152.0.0&id=10039960685&pvid=ff229498-7608-4196-9719-459726091f29&ad_id=&am_id=&cm_id=&pm_id=
ill look into those. Im already looking into the pink ones as well
Profosist -- thank you for doing all this work.
If it's not too much trouble, I'd be very interested in a red PLU-87.  :-*
Offline takaki
« Reply #137 on: Sat, 29 December 2012, 10:28:16 »
I would seriously prefer to solder than to desolder something.
Just commenting on you rates :) I would prefer to assemble the phantom myself and use something other than PLU87 casing.
« Reply #138 on: Sat, 29 December 2012, 10:33:57 »
yea im working on those but since everyone is on holiday its takes a while for responses.
« Reply #139 on: Sat, 29 December 2012, 10:34:26 »
Thats fine you will be able to just order parts from this GB as well.
Offline takaki
« Reply #140 on: Sat, 29 December 2012, 15:45:20 »
I may be interested in getting my switches from you ! are you going to order or you already have stocks ?
Offline TheQsanity
  • SmallFry Lovin'
« Reply #141 on: Sat, 29 December 2012, 18:41:31 »
Is LED resistor swap for the top right LED?
Is Phantom able to add LED onto the switches?
SmallFry! <3
Offline takaki
« Reply #142 on: Sun, 30 December 2012, 02:55:44 »
Looking at the PCB design, I don't think you can add LED to every switch on the keyboard, there are only some keys with holes for the LED.
Offline Oproer
« Reply #143 on: Sun, 30 December 2012, 06:10:14 »
Are there any other cases I could use with this PCB? The PLU case is only meh it seems, and it doesn't seem to allow for a winkeyless layout..
« Reply #144 on: Sun, 30 December 2012, 08:28:17 »
The Phantom PCB was designed to fit inside the Filco TKL case.
"Winkeyless" layout is possible using any case, if you use an 86-key layout with a 1x key between each Ctrl and Alt. 84-key layout is possible by not installing switches in those positions, but there isn't (yet) a case with a top cover that has cutouts to cover those positions. Maybe someone is working on one...
Offline Acetrak
  • ssk.ℜ
  • gnawm_
« Reply #145 on: Sun, 30 December 2012, 11:20:44 »
A dedicated case would surely boost the appeal of the Phantom :))
« Reply #146 on: Sun, 30 December 2012, 19:45:13 »
I will be ordering them from a place that has them in stock.
« Reply #147 on: Sun, 30 December 2012, 19:50:13 »
yea the swap would be to change the color of the leds.
you can choose to put leds in caps and scroll lock instead of in the dedicated led holes if you want but those are the only switches that you can put leds in.
« Reply #148 on: Sun, 30 December 2012, 19:57:00 »
thanks jdcarpe
« Reply #149 on: Sun, 30 December 2012, 19:57:36 »
agreed it would but i dont know it will happen for Phantom R2 maybe for phantom v2 though?
