Author Topic: [GB] Phantom Parts and Assembly Services (Update Posted 2018/07/23)  (Read 441296 times)
Offline daerid
    • Rossipedia
Re: [GB] Phantom Parts and Assembly Services (Acquiring Pricing)
« Reply #200 on: Mon, 07 January 2013, 03:18:45 »
Yeah, I'd love to have a few extra days for my check to come in :(
Offline TheProfosist
  • Custom Layouts Only!
« Reply #201 on: Mon, 07 January 2013, 22:03:21 »
yes were still waiting on a quote for the plates sorry
and thanks for clarifying that for me jdcarpe
i would not recommend trying to use the PLU's plate it may not align perfectly.
no the form will be up for one week, sorry about all of the wait id have it up if I could.
and no the phantom is not full led compatible.
« Reply #202 on: Tue, 08 January 2013, 07:32:03 »
In for switches! (came from the PCB thread :) )
Offline bpiphany
Offline FabsSpeed
« Reply #205 on: Tue, 08 January 2013, 13:09:22 »
I  would like you to built mine also ... I got two phantoms on the order. Any chance of getting a nice aluminum case for it? I wanted the MKS one, but was too late for the group buy. Any idea?
| Wanted: KMAC  & KMAC 1.2, 356 Mini, 456 GT |
Offline nebo
« Reply #206 on: Tue, 08 January 2013, 13:14:00 »
The MKC one might not be compatible and I think only 6 total were made/sold. There are quite a few cases in the work, just have to see which ones come out and fit your needs and budget. I doubt they will be out in time for the GB nor included. It should only take 10 minutes and a flathead or allan wrench to install the PCB with switches into a case.
Offline gizzard
« Reply #207 on: Tue, 08 January 2013, 22:42:36 »
Don't suppose there is pricing on plu switch removal and case modding without assembly?   Want to leave the hard stuff for you and enjoy the easy part myself :p.
Offline KuhnTang
  • Game of Thrones
« Reply #208 on: Wed, 09 January 2013, 00:34:14 »
I want to order some stabilizers and switches, where is the order form?
So that I ensure I'm in before this closes, I want:
1 set cherry stabalizers
1 set costar stabalizers
180 clears
15 mx DarkGrey
10 mx White
« Last Edit: Wed, 09 January 2013, 01:33:22 by KuhnTang »
Offline Glod
  • Also Known As Ergonomech
    • YouTube Channel
« Reply #209 on: Wed, 09 January 2013, 01:51:07 »
A form will be up when he is done acquiring pricing. A new closing date will be set as well.
Offline llovro
« Reply #210 on: Wed, 09 January 2013, 08:57:02 »
A bit noobish and awkward question but how hard would it be to move everything (by everything I mean pcb with switches and all the other stuff) from plu case to other case?
Thanks in adcance!
Offline SmallFry
« Reply #211 on: Wed, 09 January 2013, 09:02:07 »
jdcarpe, you are both a gentleman and a scholar.  :D
Your good looks are only exceeded by your kindness and generosity.
Thanks in adcance!
If you know how to solder, not too hard at all. If not, you may have some difficulties.
Offline nebo
« Reply #212 on: Wed, 09 January 2013, 11:51:03 »
I just noticed that you're also offering white switches. Are these 55cN or the 80cN? I'd guess the later since those are "modern".
EDIT - Also just realized, the plates aren't going to support a short right shift + extra key are they? :(  Without it I can't get the right part of the keyboard to be:
Code: [Select]
7 8 9
4 5 6
1 2 3
0   .
with a fn layer for the normal keys that go there.
« Last Edit: Thu, 10 January 2013, 17:08:41 by nebo »
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #213 on: Fri, 11 January 2013, 03:03:11 »
definitely interested in both Cherry and Costar stabilizers.
Offline FabsSpeed
« Reply #214 on: Sat, 12 January 2013, 04:14:19 »
When will this be ready to order?
Offline snoopy
  • The Flying Ace
  • Gone with the Wind
« Reply #215 on: Sat, 12 January 2013, 04:33:04 »
If you didn't order a Phantom pcb you're already too late...
Offline FabsSpeed
« Reply #216 on: Sat, 12 January 2013, 06:33:38 »
I ordered two!!! :)
« Reply #217 on: Sat, 12 January 2013, 16:05:36 »
as soon as we have complete pricing for plates this wikll start and a form will go up we will be working on taking orders for 1 week.
Offline metafour
« Reply #218 on: Sat, 12 January 2013, 16:11:39 »
I thought you both got quotes back as mentioned in the IC thread.
« Reply #219 on: Sat, 12 January 2013, 19:24:22 »
yea my place was knocked out of the running and i did get a price from WFD but idk if its for alu or SS
I also might be able to get colored PLU cases instead of just then standard ones if theres enough interest.
« Reply #220 on: Mon, 14 January 2013, 20:56:22 »
working on the form as wek speak guys
« Reply #221 on: Mon, 14 January 2013, 22:39:14 »
« Last Edit: Mon, 14 January 2013, 23:24:18 by TheProfosist »
Offline AKIMbO
  • HHKBro
« Reply #222 on: Mon, 14 January 2013, 22:45:32 »
There's no pricing in the form for the stabilizers (cherry and costar).
| KBD75 (box reds)
Offline nebo
« Reply #223 on: Mon, 14 January 2013, 22:45:56 »
Done!
« Reply #224 on: Mon, 14 January 2013, 22:51:19 »
thanks form will be down for a bit as its being fixed also some fields arnt showing up... itll be a couple of min
Offline Germiphene
« Reply #225 on: Mon, 14 January 2013, 22:54:34 »
Hey!  Grats on the form going up.  Going to fill it out soon!
HHKB pro | RF 87U | RF 87U uni-45g | CM QFR | Steelseries 6Gv2 | Filco MT2 | IBM model M | IBM SSK '87
Offline KuhnTang
  • Game of Thrones
« Reply #226 on: Mon, 14 January 2013, 22:58:37 »
I just read that the dark grey (linear) is used as the SB for MX Blacks and that the regular grey (tactile) is used for the SB on Clears.  Being that you're not offering blacks currently, can you swap out dark grey for grey, or just add grey as an option?
Dark Grey: http://deskthority.net/wiki/Cherry_MX_Dark_Grey
Grey        : http://deskthority.net/wiki/Cherry_MX_Grey
I do realize that you may not be able to get them, just a humble request.
thanks prof.
« Reply #227 on: Mon, 14 January 2013, 23:11:05 »
form fixed sorry about that anyone who already submitted is safe still and good to go though
http://tinyurl.com/abblp6v
« Reply #228 on: Mon, 14 January 2013, 23:19:37 »
thanks prof.
whats up there is what i can get thats in stock. there still may be a possibility of black and green the form and thread wil be updated if that is the case.
« Reply #229 on: Mon, 14 January 2013, 23:20:39 »
If anyone has questions please post there here so that other can see the answers as well, thanks.
Offline Amarok
« Reply #230 on: Mon, 14 January 2013, 23:21:16 »
Ordered. Thanks!
Realforce 87u 55g
Offline okooko
  • afk.
« Reply #231 on: Mon, 14 January 2013, 23:23:58 »
Hi Prof,
Just looking through the form, I'm semi-clueless as to what many of the options actually are.
If I tell you what I'm after, then perhaps you can tell me what options I should go for?
Just a plain phantom with MX clears, perhaps MX black on the space and all put together, thats about it.
Just a few questions
1. Not really wanting a PLU87 case, there are a few on the drawing board might wait for one of those.
2. and I've got no idea regarding
2a. resistor swaps
2b. lubed switches
2c. stabiliser mods
Id be getting a plate so i'd need the plate mounted stabilisers?
If you can give me a clue what is involved in a normal assembly (minus the case i guess for now) that would be amazing
Thanks again.
This might also be useful for others that are as clueless as me.
Offline AKIMbO
  • HHKBro
« Reply #232 on: Mon, 14 January 2013, 23:29:21 »
Form submitted....hope we can get 1000 white switches!
| KBD75 (box reds)
Offline KuhnTang
  • Game of Thrones
« Reply #233 on: Mon, 14 January 2013, 23:32:52 »
did I read the form correctly:
2 resistors + 2 LED's = $5
« Reply #234 on: Mon, 14 January 2013, 23:33:53 »
akimbo i dont see yours did you already submit? if so could you try again? sorry
« Reply #235 on: Mon, 14 January 2013, 23:47:08 »
looking at exact pricing now on that prices may go down
« Reply #236 on: Tue, 15 January 2013, 00:01:37 »
Hi Prof,
2a. resistor swaps
2b. lubed switches
2c. stabiliser mods
Thanks again.
select basica assembly then and you probably dont want a black spring for the spacebar with clears as black is actually lighter
1. yo udont need to order a case but you will have to order a plate if you want me to assemble it for you.
2. what are yo uasking?
2a. thats if you want different caps and scroll lock leds
2b. its as it sounds I crack open every switch and lube them the by one with krytox 205\
2c. basically makes a cherry stabilizer feel closer to a costar
yes you will need plat mount stabilizers as that is all the phantom supports
hopefully this helps if you have any more questions please ask
« Reply #237 on: Tue, 15 January 2013, 00:06:04 »
got your order and just so you all know we only need a total of 1000 switches to order not 1000 of each type
Offline AKIMbO
  • HHKBro
« Reply #238 on: Tue, 15 January 2013, 00:10:12 »
^Then we are at least 1/10th of the way there.  XD
| KBD75 (box reds)
Offline nebo
« Reply #239 on: Tue, 15 January 2013, 00:22:25 »
2/10
TP, are those the only plates officially? I ordered the ANSI150  but was hoping for something like this but with standard FN row.
« Reply #240 on: Tue, 15 January 2013, 00:39:49 »
2/10
these are the only plates that are made currently i believe WFD said we had to have at leas 15 people interested to get another design...
(sorry cant find that exact post but its mentioned in the IC thread a bunch of times)
« Reply #241 on: Tue, 15 January 2013, 00:41:01 »
fixed the links for the pics for the plates in the description
Offline zyth3x
« Reply #242 on: Tue, 15 January 2013, 01:25:39 »
Form filled for some Clear switches.
Offline Glod
    • YouTube Channel
« Reply #243 on: Tue, 15 January 2013, 01:35:23 »
the gates have opened!! wooooo
parts-only order submitted :)
« Reply #244 on: Tue, 15 January 2013, 01:51:51 »
some orders and just so you all rmember if your going to use the right side as a numpad or use my layout youll need more switches please dont forget to take that into account
Offline reality404
« Reply #245 on: Tue, 15 January 2013, 02:54:28 »
Form filled for parts-only order. Thanks for the group buy.
« Reply #246 on: Tue, 15 January 2013, 02:57:58 »
thanks for the parts orders guys
Offline csimi
« Reply #247 on: Tue, 15 January 2013, 03:00:17 »
I wrote in the notes to also reassemble the PLU but I think this would be a great chance to learn soldering so please send it in parts.
Offline gameaholic
« Reply #248 on: Tue, 15 January 2013, 03:02:47 »
I'm going for a black case with lubed red switches costar stabilizers and the same layout as my filco TKL.
Some questions before I fill out the form.
1.  About the plates.  I already ordered 2 of WFD's universal plates (1 to go in this and one for my filco) and he is doing my assembly so I should already be good and not need any of the other plates right?
2. If I order the black PLU 87 with Red Switches that covers the case and switches then I just need to order a few extra red switches in case they are bad.
(I will also be ordering some clear switches to go in my GH60-how many of those will I need?).
3. No purple or white LEDs?
IBM Model M SSK, Filco MJ2 Ninja TKL with Reds ergo-clears, CM Storm QFR 55g Whites, Poker II with Reds
« Reply #249 on: Tue, 15 January 2013, 03:04:09 »
that means you only want the stem/spring swap assembly too correct? not the basic assembly in addition?
