Author Topic: [GB] Phantom Parts and Assembly Services (Update Posted 2018/07/23)  (Read 437310 times)
Offline csimi
Re: [GB] Phantom Parts and Assembly Services (Acquiring Pricing)
« Reply #250 on: Tue, 15 January 2013, 03:08:50 »
Yeah, one stem/spring swap assembly and the PLU pcb/plate/remaining parts also sent in pieces.
Offline TheProfosist
  • Custom Layouts Only!
« Reply #251 on: Tue, 15 January 2013, 03:16:45 »
I'm going for a black case with lubed red switches costar stabilizers and the same layout as my filco TKL.
Some questions before I fill out the form.
1.  About the plates.  I already ordered 2 of WFD's universal plates (1 to go in this and one for my filco) and he is doing my assembly so I should already be good and not need any of the other plates right?
2. If I order the black PLU 87 with Red Switches that covers the case and switches then I just need to order a few extra red switches in case they are bad.
(I will also be ordering some clear switches to go in my GH60-how many of those will I need?).
3. No purple or white LEDs?
if he is doing your assembly and is one of the builders in this GB select the type of assembly that you want and leave his name in the notes so that the needed parts get shipped to him. No you shouldnt need any other plates.
yes a few extra would be good also dont forget stabilizers i recommended cherry with the mod
white is what comes with the phantom and no no purple those are usually UV
« Reply #252 on: Tue, 15 January 2013, 03:17:31 »
alright ill modify your order for you
edit: modified
« Last Edit: Tue, 15 January 2013, 03:20:39 by TheProfosist »
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #253 on: Tue, 15 January 2013, 03:28:05 »
sorry if I missed something, but are these the plates from the IC http://geekhack.org/index.php?topic=38623.0 ?
« Reply #254 on: Tue, 15 January 2013, 03:29:00 »
yep theres a note way at the bottom of the OP sorry it doesnt stick out more
« Last Edit: Tue, 15 January 2013, 03:34:56 by TheProfosist »
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #255 on: Tue, 15 January 2013, 03:33:32 »
you are right, sorry dude, didn't notice the notes were updated.
« Reply #256 on: Tue, 15 January 2013, 03:34:43 »
not a problem their not very noticeable lol
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #257 on: Tue, 15 January 2013, 03:45:04 »
still undecided if I should get a full PLU or just the plate...
Offline BimboBB
« Reply #258 on: Tue, 15 January 2013, 03:46:23 »
form filled for parts only order. (but had to mark all the other stuff with zero)
Offline kmiller8
  •  Post Reporting Timeout
  • Who is that kmiller8 guy?
« Reply #259 on: Tue, 15 January 2013, 03:50:58 »
^this
That's reallllly annoying.
« Reply #260 on: Tue, 15 January 2013, 03:55:36 »
^this
sorry but i set i up that way purposefully so hopefully having to mark 0 would force you to really look over what your ordering and not miss anything.
Re: [GB] Phantom Parts and Assembly Services (Taking Orders)
« Reply #261 on: Tue, 15 January 2013, 04:12:39 »
topic updated
Offline Amr0d
« Reply #262 on: Tue, 15 January 2013, 04:57:43 »
Can we get Purple LED?
Filco MJ2 TKL browns | Race 75% LE reds | Phantom GH Edition soon™
HeatWare
Offline Dgsbllx
« Reply #263 on: Tue, 15 January 2013, 05:11:34 »
Are LEDs actually needed at all?
« Reply #264 on: Tue, 15 January 2013, 05:13:03 »
dont forget if you guys are looking for a nice custom cable for your phantom get in touch with MiMiC also check out his thread here.
« Reply #265 on: Tue, 15 January 2013, 05:13:43 »
no, you get white ones in the kit the ones i offer are if you want a different color.
Offline okooko
  • afk.
« Reply #266 on: Tue, 15 January 2013, 05:16:26 »
Form submitted, thanks for the clarifications.
Offline Dgsbllx
« Reply #267 on: Tue, 15 January 2013, 05:18:40 »
So I don't even need the white ones on either?
Cheers for quick response
« Reply #268 on: Tue, 15 January 2013, 05:25:57 »
yep no problem, and yes its fine we can ship it to you built without a case.
« Reply #269 on: Tue, 15 January 2013, 05:30:48 »
also as a note if anyone is planing on ergo clears youll need select at least the stem or spring swap service and buy clears, along with either providing me with springs or buying another type of switch for the springs. This is only if you are have me build ergo clears and remember all extra parts will be returned to you with your phantom.
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #270 on: Tue, 15 January 2013, 05:51:01 »
okay took a plate, if I get it right it will be SS, but ALU is also good for me
Re: Re: [GB] Phantom Parts and Assembly Services (Taking Orders)
« Reply #271 on: Tue, 15 January 2013, 06:08:13 »
yes plates are made of stainless
Offline Gupgup
« Reply #272 on: Tue, 15 January 2013, 07:35:11 »
Form filled, can't wait!
Offline FabsSpeed
« Reply #273 on: Tue, 15 January 2013, 07:38:06 »
Sent me order for the two Phantoms! Thank you very much for the great support Prof:)
| Wanted: KMAC  & KMAC 1.2, 356 Mini, 456 GT |
Offline agor
« Reply #274 on: Tue, 15 January 2013, 08:41:40 »
Order sent, thanks
KBD8X II - MX 5000 - Realforce 88UB - Phantom - GH60
Offline mashby
  • What Up Shoney? (ツ)_/¯
    • Mashby
« Reply #275 on: Tue, 15 January 2013, 09:14:45 »
Form filled.
Offline Leewei
« Reply #276 on: Tue, 15 January 2013, 09:52:28 »
Form filled. Thanks =)
Filco Majestouch 2 Beige TKL with MX Reds
Qsenn dt-35
Offline longweight
  • philanthropist
« Reply #277 on: Tue, 15 January 2013, 14:05:22 »
So are the LEDs for all of the caps? Per set?
« Reply #278 on: Tue, 15 January 2013, 15:09:44 »
nope there only 2 leds on the board the price for the leds will be adjusted later today hopefullly when i have time to price out the leds and resistors
Offline nebo
« Reply #279 on: Tue, 15 January 2013, 15:22:59 »
I have a question, how are you planning on modifying the PLU case for the 7bit num block? Might end up wanting to get one seeing as cases are still probably a few months out...
« Reply #280 on: Tue, 15 January 2013, 15:30:01 »
using my skill and a dremel, the same way that I did mine, their not perfect those were also my first attempts at it but I will make it look as clean as possible
Offline Acetrak
  • ssk.ℜ
  • gnawm_
« Reply #281 on: Tue, 15 January 2013, 15:32:23 »
TheProfosist is gonna karate chop them
« Reply #282 on: Tue, 15 January 2013, 15:44:24 »
submitted my order.  Interested to use a prof-layout for a full day of work.
Offline nebo
« Reply #283 on: Tue, 15 January 2013, 16:02:21 »
I think I'll wait until the 20th (this closes the 21st right?) until I change my order to get a case as well in case something comes up.
Offline AKIMbO
  • HHKBro
« Reply #284 on: Tue, 15 January 2013, 16:03:10 »
How are we doing on switches Prof?  Anywhere near 1000 yet?
| KBD75 (box reds)
« Reply #285 on: Tue, 15 January 2013, 17:08:17 »
Well I'm about to order at least 180 more.. gonna be building a lot more than a Phantom! :)
« Reply #286 on: Tue, 15 January 2013, 17:15:41 »
sounds fine to me just maksure you get your order in before the loose deadline
« Reply #287 on: Tue, 15 January 2013, 17:15:56 »
clears alone are well over the 1000
Offline nebo
« Reply #288 on: Tue, 15 January 2013, 17:19:17 »
Already got it in just to be safe. Worst case I have to use my super duper dremel skills on a case I get from classifieds.
« Reply #289 on: Tue, 15 January 2013, 18:39:30 »
ok an update on switches (the OP and form will be updated shortly):
there will be more switch types coming (still no blacks). green and grey were added.
white's and dark grey's price has to be raised $0.05 a switch
and i was informed that there are now limited stocks on hand for switches and any switches order over those amounts would be back ordered ~2 months
sorry to bring the semi disheartening news but I dont have much control over this, for those who dont want to wait but are over the limited amount of instock switches i could look into getting some from mouser or like likes but the pricing even at 500 switches is much higher. Also if you ordered switches before this announcement and would like to cancel because of it please send me a pm.
« Last Edit: Tue, 15 January 2013, 18:45:36 by TheProfosist »
« Reply #290 on: Tue, 15 January 2013, 18:46:03 »
here is the updated switch list
Code: [Select]
$0.60 - MXBLUE     (MX1A-E1NN)
$0.60 - MXBROWN     (MX1A-G1NN)
$0.60 - MXRED     (MX1A-L1NN)
$0.60 - MXCLEAR     (MX1A-C1NN)
$0.85 - MXGREEN     (MX1A-F1NN)
$0.65 - MXWHITE     (MX1A-A1NN)
$0.85 - MXGREY     (MX1A-D1NN)
$0.85 - MXDARKGREY     (MX1A-21NN)
Offline nebo
« Reply #291 on: Tue, 15 January 2013, 18:46:54 »
An extra $5 for white switches? Worth it.
Offline AKIMbO
  • HHKBro
« Reply #292 on: Tue, 15 January 2013, 18:56:51 »
Heck yes it is.
| KBD75 (box reds)
« Reply #293 on: Tue, 15 January 2013, 19:09:02 »
MXWHITE now on backorder
« Reply #294 on: Tue, 15 January 2013, 19:12:30 »
OP and Form now fully up to date!
Offline AKIMbO
  • HHKBro
« Reply #295 on: Tue, 15 January 2013, 19:13:46 »
| KBD75 (box reds)
Offline nebo
« Reply #296 on: Tue, 15 January 2013, 19:21:55 »
Does it affect you if the order was already in?
« Reply #297 on: Tue, 15 January 2013, 19:26:56 »
Nooo!!!1
dont worry you two and everyone that ordered before I announced they were on back order got there orders in for instock switches
Offline AKIMbO
  • HHKBro
« Reply #298 on: Tue, 15 January 2013, 19:30:31 »
Nooo!!!1
| KBD75 (box reds)
Offline gameaholic
« Reply #299 on: Tue, 15 January 2013, 20:30:22 »
Form Filled.  I've never tried cherry stabilizers.  Gonna trust you on this one.
IBM Model M SSK, Filco MJ2 Ninja TKL with Reds ergo-clears, CM Storm QFR 55g Whites, Poker II with Reds
