Author Topic: Poker Mods - What Am I Missing?  (Read 2737 times)
Offline mashby
  • What Up Shoney? (ツ)_/¯
    • Mashby
« on: Thu, 20 December 2012, 17:28:49 »
After getting a Vortex/KBT Race and playing with it for the past week, I've convinced myself that a Vortex/KBT Poker is a better fit. Being new to the scene, I've been reading through the forums to see what are some of the more common modifications and tweaks and I'm just curious if I'm missing anything.
Poker Mods / Customizations:
  • Installing foam under the PCB [link]
  • Remounting the Switches to a Stainless Steel Plate [link]
  • Switching to a custom metal case [link]
  • Changing springs and/or stems [link]
  • Inserting Stickers between the top and bottom switch housings on the switches [link]
  • Lubing the switches [link]
  • Soft-Landing Pads [link]
  • O-Ring Switch Dampers [link]
  • Custom USB Cable [link]
  • and of course... Swapping Key Caps
Am I missing anything?
« Last Edit: Thu, 20 December 2012, 18:50:56 by mashby »
Offline The_Beast
  • I like wood ಠ_๏
Re: Poker Mods - What Am I Missing?
« Reply #1 on: Thu, 20 December 2012, 17:42:26 »
That looks like a pretty complete list but I would skip the soft landing pads and O-rings. I don't really like the feel of o-rings
Offline mashby
    • Mashby
« Reply #2 on: Thu, 20 December 2012, 18:16:13 »
What is it you don't like about those two mods?
Also, does that mean you do like the sticker mod?
Offline TheQsanity
  • SmallFry Lovin'
« Reply #3 on: Thu, 20 December 2012, 18:21:03 »
post pics when you do them.
O-rings and pads are okay. I have some on my pokers. mostly the outside switches. I cant tell enough to tell. hehe
SmallFry! <3
Offline The_Beast
  • I like wood ಠ_๏
« Reply #4 on: Thu, 20 December 2012, 18:22:52 »
The plate has made the biggest difference out of all of those. Lubing would come second.
Stickers are, IDk, not really worth the time unless you have time to waste. If you really think about what they do, it's not much.
« Reply #5 on: Thu, 20 December 2012, 18:40:12 »
Don't forget about swapping stems and/or springs. You can try different switches if you have the stems and springs for it, without even desoldering the switches.
Offline mashby
    • Mashby
« Reply #6 on: Thu, 20 December 2012, 18:51:21 »
Added. Thank you for reminding me of that option!
Offline TheQsanity
  • SmallFry Lovin'
« Reply #7 on: Thu, 20 December 2012, 18:52:39 »
I prefer pbc, does poker plate make that muchof a difference?
SmallFry! <3
Offline SmallFry
« Reply #8 on: Thu, 20 December 2012, 18:55:41 »
Yes, indeed it does.
Offline mashby
    • Mashby
« Reply #9 on: Thu, 20 December 2012, 18:56:21 »
From what I've read, it provides a more solid feel and doesn't have as much flex. Someone that has one can probably speak to it better than me though.
« Reply #10 on: Thu, 20 December 2012, 18:58:53 »
Eliminates PCB flex. I defy anyone to install a stainless steel plate on their Poker, then provide measurable evidence of flex using some sort of device. It just ain't there.
Offline The_Beast
  • I like wood ಠ_๏
« Reply #11 on: Thu, 20 December 2012, 19:06:55 »
Like I said, it's the one that makes the most noticeable difference. I didn't hate my poker before plate modding it, but it's for sure my favorite keyboard after adding the plate.
Offline samwisekoi
  • MAWG since 1997
    • Tweet samwisekoi
« Reply #12 on: Thu, 20 December 2012, 19:39:15 »
I have been working on yet another Poker mod for the past week; fixing the evil Escape/tilde bug and (optionally) moving the up-arrow key off of the Shift_R key.
The Escape key mod takes two small wires, one cut trace and two lines of xmodmap or AutoHotKey.
Details to follow...
 - Ron | samwisekoi
Offline TheQsanity
  • SmallFry Lovin'
« Reply #13 on: Thu, 20 December 2012, 20:05:47 »
Does it feel okay? say for something like a QFR. Is the Poker plate better in any way or would you say it is the same or unnoticeable.
SmallFry! <3
Offline WhiteFireDragon
    • youtube
« Reply #14 on: Thu, 20 December 2012, 22:49:06 »
I personally like O-rings. I have them on all my keyboard for the purpose of shortening travel distance and dampens the harsh clacks of bottoming out. I've noticed that with O-rings, people will either love them or hate them, not much of an in between. It's a cheap mod though and very easy to reverse, so it doesn't hurt to try yourself.
Offline TheQsanity
  • SmallFry Lovin'
« Reply #15 on: Thu, 20 December 2012, 22:54:08 »
Eh with my reds I don't notice flex or bottom out. I like to think of my poker as a portable mechanical keyboard.
SmallFry! <3
Offline mashby
    • Mashby
« Reply #16 on: Fri, 21 December 2012, 08:34:00 »
I'm not familiar with this bug. Can you explain exactly what this mod does?
« Reply #17 on: Fri, 21 December 2012, 08:42:51 »
When the Poker has the 'Esc-lock' on (Fn-"Q"), the "~" key acts as Esc. You should be able to press Fn-"~" in that mode to use the "~" character, but it doesn't work. It still sends the Esc character.
