Author Topic: EK Landing Pad For Futaba Switch?  (Read 2604 times)
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« on: Mon, 31 December 2012, 10:57:19 »
Has any ever one tried using  EK's landing pads on a "futaba" switch? I have a Chicony 5191 with Russian layout that is a decent board, but reverberates a serious thunk when typing. Slightly tactile without a click, but bottoms out crazy.
I have another board with futaba's that is tactile and clicky without the big thump.........., so they are definitely not all the same.
Not sure if EK's pads have a large enough diameter to fit over the switch? The outside of the futaba switch dimension is 5/16".
If someone has one of EK's landing pads could you check the inside diameter?
Luga G80-1865/MX Reds + Dolch G80-1813/MX Blues + G80-3700HQAUS + DK9008G2 Pro/MX Browns Thick PBT + DK9008G2 Pro/MX Clears Thick PBT +  QFR TKL/Ghetto Greens + Cherry G80-1800/MX Blues + IBM Model M SSK Bolt Modded + IBM Model M + IBM Model F + IBM AT F + Cherry G80-1000 (HAD)/MX Vintage Blacks + Razer BWU/MX Blues + Leading Edge DC2214/Blue Alps + Compaq MX11800/Browns + Chicony 5181/Monterey Blues + Chicony 5161/MX Black Cherry Clone + Focus 2001/White Alps + Chicony 5191/White Futabas + Olivetti ANK27-101 + Dell (Old Logo) AT101/Black Alps + NMB RT8255C+/Black Space Invaders + Unitek K260/Green Alps + Apple M0116/Orange Alps + AEK II M3501/Cream Alps + AEK M0115/Orange Alps + NEC  APC412/Blue Sliders + NEC APC410/Blue Sliders + Omnikey /White Alps + Wang/Yellow Alps (Omrons) + Laser/White SMK + Fame/Blue Aruz + AEK II M3501/Salmon Alps + Zenith ZKB-2R/Green Alps + Wang 724/Orange Alps + DK1087/Green Alps + Zenith ZKB-2/Yellow Alps + Dell Old Logo AT101/Salmon-Pink Alps + Leading Edge AK1012/White SMK's + Magitronic SK-1030/White (Linear) Futaba's + Packard Bell/White (Clicky) Futaba's + Datacomp DFK101/White  Alps + SGI AT101/Dampened White Alps + NMB AQ6RT-72511/Grey Space Invaders (Hi-Tek) + Datacomp/Blue Alps + Phillips 2812/White Space Invaders (Linear) + Dah Yang K251/Vintage MX Blues + Chicony 5161/DS Caps/Vintage MX Blue + Archie-NMB AQ659ZRT-725/Black Space Invader (Tactile) + IBM Model M 71G4644 (RD) Bolt Modded with Soarers Converter + IBM Model M Silver Label 1390131 + Cherry G80-1501/Vintage MX Clears + Focus FK8000/Linear Futabas + Gateway 2000 Anykey Programmable/Maxi-Switch + Dell GY13PVAT101/Dye Sub Caps/Salmon Alps + Chicony 5161/White Alps + AST K0B101/Slider over RD + Qtronix QX-32H + Everex/NMB RT8255CW+ Black Space Invaders-Split Erase + Tandon/NMB AQ659ZRT-101A/Beige Space Invaders + Cherry G80-11903 MNRUS/MX Blacks + Apple IIGS A9M0330/SMK Whites + WYSE PCE/MX Blacks + Chicony 5160AXT/Clicky Futaba + Cherry G80-0528/Vintage MX Blacks + Dell AT101/Linear (Modded) Black Alps+Topre 55g
Offline absyrd
  • CPT HYPE PADAWAN
Re: EK Landing Pad For Futaba Switch?
« Reply #1 on: Mon, 31 December 2012, 11:13:11 »
My futabas actuate and click right AT the bottoming-out point. I'd think that pads may cause some problems with actuation.
Offline TotalChaos
  • Indy Game Coder
« Reply #2 on: Mon, 31 December 2012, 12:13:05 »
Just 4 u:
I measured mine and I get
Inner Diameter 3/16"
Outer Diameter 6/16"
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #3 on: Mon, 31 December 2012, 12:27:14 »
i just checked and mine actuate with a slight tactile bump about 2/3rds of the way down before the bottoming out point.  you are probably correct though as the pad would hang on, be snug to the switch riding or traveling up and down. still i do not know if the the pad inside diameter would allow me the room to place on the switch?
Offline absyrd
  • CPT HYPE PADAWAN
« Reply #4 on: Mon, 31 December 2012, 12:30:26 »
I think it stretches quite a bit. You could also exacto knife the holes a bit bigger if you wanted.
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #5 on: Mon, 31 December 2012, 12:48:45 »
thanks..............so the 3/16 would be right where the inside diameter of a mx cap should be and answers my question.
EK landing pads on futabas.............OUT :eek:
will have to look into my ghetto toolbox
Just 4 u:
Offline TotalChaos
  • Indy Game Coder
« Reply #6 on: Mon, 31 December 2012, 12:50:04 »
If u had a hole punch of the right size u could just make the holes bigger and it would work, theoretically.  But the sides would then be very thin and weak so it might get kinked up in your switch.  Good luck  :)
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #7 on: Mon, 31 December 2012, 13:32:09 »
right...........a hole punch could open a tad.
i found these that would probably work, but am a little scared of the 70a durometer rating- maybe to hard?
there 5/16 ID and 7/16 OD with a thickness of 1/16. 1/16 is right about what i have left on the downward stroke where it actuates. if some of the switches are a little touchy i need a little more travel which the 70a might be to hard and allow it to actuate.
am trying to find the size in a 40a or 50a.
http://www.amazon.com/dp/B000FMYOK0/ref=biss_dp_t_asn
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #8 on: Mon, 31 December 2012, 13:46:19 »
ok..............ghetto mode- the old dental band trick
i forgot about these............ http://www.ebay.com/itm/5-16-Heavy-4-5oz-CLEAR-ORTHODONTIC-ELASTIC-BRACES-BANDS-DENTAL-/130770637204?pt=LH_DefaultDomain_0&hash=item1e72899194
they probably will break easy, but under 6 bux what the heck
Offline TotalChaos
  • Indy Game Coder
« Reply #9 on: Tue, 01 January 2013, 04:53:57 »
@terrpn
Try the dental bands thing.  And try to find a tool to make your perfect size hole.
I also need a tool / set of tools that can make any size hole I need for a project that I need.
If u then msg me in 30 days I should have found the material we need to make this work by then.  cyaz
