Author Topic: GHpad FTW (10-Key Pad for GH60)  (Read 715024 times)
Offline Defying
  • (suffer on)
Re: GHpad FTW (10-Key Pad for GH60)
« Reply #600 on: Mon, 28 October 2013, 17:10:37 »
Got the case and I have no idea how to assemble it.  ;D
Offline TheFlyingRaccoon
  • HHKB Pro
  • Cable maker and future engineer
« Reply #601 on: Mon, 28 October 2013, 17:15:10 »
Well you put all the layers together then put the screws through. Here is the order of the layer.
http://geekhack.org/index.php?topic=38963.msg1046650#msg1046650
HHKB Pro 2   SmallFry Keyboard
Offline Defying
  • (suffer on)
« Reply #602 on: Mon, 28 October 2013, 17:38:36 »
I have the top part of the case screwed properly, but for the bottom, I have no idea. There's these small screws that don't thread to anything and don't go all the way through, then there's longer screws that are way too long that go through the whole case and more, and then these hex bolts that fall through the hole and don't hold the top layer on. I'm confused  :confused:
Offline MOZ
  • KING OF THE NEWBIES
  • Busy making stuff
« Reply #603 on: Mon, 28 October 2013, 17:48:08 »
The hex bolts were extra, just in case you wan tot use those, you did get washers right?
To assemble, do you have brass standoffs? I don't think so, TFR has to ship them to you, only then will you be able to assemble.
I might put a small tutorial on how to put these together.
  • HHKB Pro
« Reply #604 on: Mon, 28 October 2013, 17:53:53 »
When I get the cases, I can make a video or picture guide on how to assemble them.
For shipping, I still need to figure out how to ship everything. The case shouldn't be difficult, I'm mostly worried about how to pack the electronic components. Also I'm not sure about the box. I was thinking maybe the small Flat Rate boxes? They are $5.15 to ship within the US. Dimensions are 8-5/8" x 5-3/8" x 1-5/8". Not sure if that would fit everything though.
Offline Defying
  • (suffer on)
« Reply #605 on: Mon, 28 October 2013, 17:54:48 »
These are all the types of screws that it came with:
Offline MOZ
  • Busy making stuff
« Reply #606 on: Mon, 28 October 2013, 17:57:36 »
Check again, there must be 3 different flat head screws.
Edit: Since in your case, I got the holes cut larger than everyone else's, I forgot to include the washers. Sorry. Anyway, you want to use the flatheads.
  • HHKB Pro
« Reply #607 on: Mon, 28 October 2013, 17:58:50 »
You are missing the brass standoffs that I will send you with the other components and PCB. They look like this:
Offline Defying
  • (suffer on)
« Reply #608 on: Mon, 28 October 2013, 17:59:36 »
There's only two types.
Offline MOZ
  • Busy making stuff
« Reply #609 on: Mon, 28 October 2013, 18:11:15 »
Alright, it's 4:30 in the morning here so my brain isn't exactly working at pace, but yeah I just recalled there should ONLY be TWO types of flat head screws, you should have quite a number of those small flatheads, they are 6mm. And the longer ones are 20mm.
So what you do is, once you get the brass stand offs, you insert them into the hex cutout in the the 3 middle layers, then take a 6mm flat head and screw from the top and bottom layers, remember you don't want to go all the way from either the top or the bottom, as then there wouldn't be enough "space" in the brass stand off for the other scre.
See this graphic:
Red --> Brass standoffs
Blue --> 20mm flat head screws
Green --> 6mm fat head screws
Black --> Acrylic layer.
« Last Edit: Mon, 28 October 2013, 18:12:55 by MOZ »
Offline Defying
  • (suffer on)
« Reply #610 on: Mon, 28 October 2013, 18:15:05 »
See this graphic:
Cool. Was hoping that it was something simple. :)
Really love this case, MOZ! Now I just need everything else to finish it :P
Offline dragonxx21
« Reply #611 on: Mon, 28 October 2013, 21:07:33 »
ughhh now I really can't wait for mine P:
Keyboards Owned:
Realforce Topre 91 Key JIS Profile - Main
CM Quickfire Rapid Blue Switches
IBM Model M in Industrial Shell
Offline Pacifist
  • on hiatus
« Reply #612 on: Mon, 28 October 2013, 22:13:02 »
So who do I contact to get these wounderful numpads?
Offline MOZ
  • Busy making stuff
« Reply #613 on: Mon, 28 October 2013, 22:19:37 »
Please read the thread.
We are currently beta testing, this is far from complete. The next stage is to test new PCBs, only after that will we move to GB stage.
Offline Pacifist
  • on hiatus
« Reply #614 on: Mon, 28 October 2013, 22:23:15 »
Ah I see. I'll wait for the GB stage. jdcarpe should update the OP with a bit of information
Offline MOZ
  • Busy making stuff
« Reply #615 on: Wed, 30 October 2013, 18:23:21 »
Looks like the cases were delivered to TFR according to the USPS tracking.
Hopefully we can get some shots soon and distributed to everyone.
  • HHKB Pro
« Reply #616 on: Wed, 30 October 2013, 18:48:00 »
Yes cases were just delivered! I should be studying but I can't help myself.  :rolleyes: I will have to repackage most of the stuff to ship but I will try to get everything packaged and shipped ASAP.
Offline AlexJP
« Reply #617 on: Wed, 30 October 2013, 19:04:38 »
pictures?   ;D
  • HHKB Pro
« Reply #618 on: Sun, 03 November 2013, 12:50:41 »
Here are some pictures of the case and an assembly guide
Everything included for the case. Most of it you will not use.
Step 1: Assemble the three middle layers and insert the brass standoffs so they are in the middle.
Step 2: Put on the plate and screw in the short flat-head bolts. DO NOT TIGHTEN THESE
(No picture)
Step 3: Put on the back cover. Screw in the bottom two short flat-head bolts. Make sure these are tight.
Step 4: Assemble the feet. I found 5 layers has the best angle for me. Use the longer flat-head bolts. Make sure these are tight.
Done!
Alternate method
Instead of using the acrylic feet, you can use rubber thingies.
Pic of it assembled
Also, I am packing up all the orders today and should have everything shipped out today or tomorrow.
« Reply #619 on: Sun, 03 November 2013, 14:10:52 »
Man, that's awesome.  Congrats!  :cool:
I much prefer the one with the rubber feet things.
BLUUUUUUUUE!
Offline dragonxx21
« Reply #620 on: Sun, 03 November 2013, 14:24:25 »
Those rubber thingies look really cool actually. Where did you pick them up TFR?
Keyboards Owned:
« Reply #621 on: Sun, 03 November 2013, 14:39:36 »
You can get 'em anywhere.  Google "bumpon"
  • HHKB Pro
« Reply #622 on: Sun, 03 November 2013, 14:51:16 »
BLUUUUUUUUE!
Yeah the blue looks awesome! Moz did a really good job with the cases. And I agree, I like the rubber feet much better.
What metalliqaz said  :D
Offline Pacifist
  • on hiatus
« Reply #623 on: Sun, 03 November 2013, 15:02:29 »
(No picture)
Done!
Alternate method
Pic of it assembled
I counted 22 keys. Don't normal 10 key pads have 17 keys? It seems like there's an extra row
« Reply #624 on: Sun, 03 November 2013, 15:09:55 »
It's not just a number pad.
See one with key caps here
http://geekhack.org/index.php?topic=38963.msg1060274.msg#1060274
Offline catnipz0098
« Reply #625 on: Sun, 03 November 2013, 15:12:47 »
Very Nice!
I want one  :thumb:
Offline AlexJP
« Reply #626 on: Sun, 03 November 2013, 15:54:54 »
so much win! very nice
Offline Pacifist
  • on hiatus
« Reply #627 on: Mon, 04 November 2013, 17:24:55 »
How remappable are these keys? IE can I change the location of the numlock key and change what pressing numlock changes to the keys?
« Reply #628 on: Mon, 04 November 2013, 17:30:54 »
Completely programmable.  Keep in mind that how NumLock is interpreted is determined by the PC, not the keyboard.
If you want to change the meaning of the keys, you change NumLock to some kind of Fn toggle.
  • HHKB Pro
« Reply #629 on: Mon, 04 November 2013, 21:05:20 »
All orders with the cases are going out in the mail tomorrow! Just need boxes for the orders without cases then they will be shipped.
« Reply #630 on: Mon, 04 November 2013, 21:05:46 »
I SEE MY BOX <3
Offline Pacifist
  • on hiatus
« Reply #631 on: Mon, 04 November 2013, 21:13:46 »
Dam when is this going into GB stage?
  • HHKB Pro
« Reply #632 on: Mon, 04 November 2013, 21:15:26 »
No idea. This was just the beta, there is going to be a groupbuy with the universal layout PCB regack designed.
« Reply #633 on: Mon, 04 November 2013, 21:19:25 »
woot!
Offline Pacifist
  • on hiatus
« Reply #634 on: Mon, 04 November 2013, 21:21:10 »
When it does, do you know how much it will cost? Don't want to get overly invested and then my wallet can't keep up
Offline dragonxx21
« Reply #635 on: Mon, 04 November 2013, 21:22:46 »
I never would have guessed that I would be a top and CPTDatAss would be a bottom. You learn something new every day.
Keyboards Owned:
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #636 on: Mon, 04 November 2013, 22:25:28 »
I am too lazy to go looking for it, but I read somewhere in this thread that the approximate cost will be about $45, but I am not sure if that included a case and switches and stuff.  It is in the thread if you feel like looking for it.  Probably around page 18 or so...
Offline dragonxx21
« Reply #637 on: Mon, 04 November 2013, 22:45:41 »
That was the price we figured out just to get the parts for the 10 prototype testers. Not to mention, in reality, the amount spent was far higher than the anticipated and TFR actually ended up losing quite a lot of money. The estimated cost is subject to change and in a GB setting it depends wildly on the amount of interest and the discount achieved through bulk ordering.
Keyboards Owned:
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #638 on: Mon, 04 November 2013, 22:50:56 »
Ya, we will see what the pricing works out to.  I think it will remain reasonable and it is going to be kick ass, so can't wait...  :)
Offline dragonxx21
« Reply #639 on: Mon, 04 November 2013, 22:52:45 »
Even for upwards of $60 I believe it would be a fair price, considering what the final product will be able to do.
Keyboards Owned:
Offline neoezekiel
    • My GW2 Guild - The Fallen Souls [SouL]
« Reply #640 on: Tue, 05 November 2013, 16:31:44 »
Any clue when this will be up for GB? I am so excited :3
WTB: Cherry G80-2550, GnCC/CCnG sets, led mx greens, mx dark greys, Plate Design Service, Case Design Service
Offline Pacifist
  • on hiatus
« Reply #641 on: Tue, 05 November 2013, 16:33:14 »
$60 without switches, stabs, and caps? So just the PCB+case?
« Reply #642 on: Tue, 05 November 2013, 16:34:37 »
Nobody knows yet what this will cost. The best thing to do is save your money and wait until the group buy happens.
« Reply #643 on: Tue, 05 November 2013, 16:42:00 »
Based on my experiences with this stuff, I would expect the PCB to be under $10, fully assembled assuming a big GB, and the acrylic sandwich case being under $40.  Low interest could expand those numbers by 2x, but I have a feeling that wouldn't happen given the popularity of the GH60.
« Reply #644 on: Wed, 06 November 2013, 08:25:22 »
Sometimes I don't want to be big spoon.
Offline Mine
« Reply #645 on: Wed, 06 November 2013, 10:56:34 »
I have a question . how to make firmware, I will make a PCB,but no have .hex file
  • HHKB Pro
« Reply #646 on: Wed, 06 November 2013, 17:57:00 »
All packages are shipped! Please let me know if you receive your package and I forgot to include something. Thanks.  :D
Offline Defying
  • (suffer on)
« Reply #647 on: Wed, 06 November 2013, 17:59:42 »
Will be looking for it :D thanks TFR. Can't wait for it!
Offline dragonxx21
« Reply #648 on: Wed, 06 November 2013, 18:01:17 »
Any sort of definite list of what we should be expecting in the package?
Case
LEDs
Switches (if purchased from MOZ)
Diodes
PCB
That's all I can get off the top of my head.
Keyboards Owned:
Offline regack
« Reply #649 on: Wed, 06 November 2013, 19:18:22 »
Case
LEDs
Diodes
PCB
love
