Author Topic: {LF}Tipro caps  (Read 3835 times)
Offline The_Beast
  • Trade Count: (0)
  • I like wood ಠ_๏
{LF}Tipro caps
« on: Sat, 19 January 2013, 23:24:46 »
I'm looking for clear topped Tipro caps. I'd love this keyboard for work if I could label the layers (Autocad short cuts on layer two would make me jizz). The current caps are in German and it's hard to know what keys are where
  • Trade Count: (3)
{LF}Tipro caps
« Reply #1 on: Sat, 19 January 2013, 23:33:51 »
Could you use cherry relegendables?
Offline The_Beast
  • Trade Count: (0)
  • I like wood ಠ_๏
Re: {LF}Tipro caps
« Reply #2 on: Sat, 19 January 2013, 23:55:46 »
Should work, the 2x keys will still be a bit confusing. They might be a bit too tall depending on profile. Tipro caps are pretty low in terms of cherry profile
  • Trade Count: (3)
Re: {LF}Tipro caps
« Reply #3 on: Sun, 20 January 2013, 00:01:15 »
Is it your grey cased tipro? Can't you change the 2x caps into 1x caps? If so, might be easier to find a ton of relengendable cherry caps. Unless you need certain row profiles, that may get tricky.
Offline The_Beast
  • Trade Count: (0)
  • I like wood ಠ_๏
Re: {LF}Tipro caps
« Reply #4 on: Sun, 20 January 2013, 00:02:50 »
You can change to 1x keys easy, but sometimes you want a 2x (like shift, control, spacebar.....)
  • Trade Count: (3)
Re: {LF}Tipro caps
« Reply #5 on: Sun, 20 January 2013, 00:03:45 »
True true. Perhaps find some POS caps that say something decent. Just trying to throw more options at you :)
Offline The_Beast
  • Trade Count: (0)
  • I like wood ಠ_๏
Re: {LF}Tipro caps
« Reply #6 on: Sun, 20 January 2013, 00:04:50 »
Thanks for the tip. Doesn't SP have relegeables?
  • Trade Count: (3)
Re: {LF}Tipro caps
« Reply #7 on: Sun, 20 January 2013, 00:06:11 »
From looking at their in stock caps, they seem to. Ima go take a peek now.
  • Trade Count: (3)
Re: {LF}Tipro caps
« Reply #8 on: Sun, 20 January 2013, 00:06:58 »
http://keycapsdirect.com/inventorypdfs/DSAInventory.pdf
Have 1x relengedable caps, those are DSA...so flat profile? Perhaps contoured is in order..
http://keycapsdirect.com/inventorypdfs/DCSABSInventory.pdf
If those are typical relegendable, looks like there are 2x abs ones there.
Offline The_Beast
  • Trade Count: (0)
  • I like wood ಠ_๏
Re: {LF}Tipro caps
« Reply #9 on: Mon, 21 January 2013, 21:16:51 »
Email sent to sales
I really hope I can get the ones on the far left since it allows two legends.
Now to find a program to print all of them off
Offline CeeSA
  • Trade Count: (0)
Re: {LF}Tipro caps
« Reply #10 on: Tue, 22 January 2013, 02:09:33 »
What series of tipro caps are you looking for? MID or FREE Series?
What color do you need (black, beige, grey)?
Offline The_Beast
  • Trade Count: (0)
  • I like wood ಠ_๏
Re: {LF}Tipro caps
« Reply #11 on: Wed, 23 January 2013, 11:10:40 »
I have these two:
I'd like the smaller one since I would mainly be using it for AutoCAD hotkeys at work. However I can't program it so I received the gray one that is programmable with my system.
However I did just get these in the mail so I should be able to get some caps off that:
If I need any I'll hit you up.
SP got back to me, $1.60 per cap, so ~$100 just for caps (not that much I know, but I don't want to pay for this out of pocket to work faster)
