Author Topic: DSA Retro Set (SHIPPED!)  (Read 1957103 times)
Offline samwisekoi
  • MAWG since 1997
    • Tweet samwisekoi
Re: DSA Retro Set (SHIPPED!)
« Reply #1850 on: Thu, 13 June 2013, 09:35:00 »
Sam any ideas on that spacebar? It won't work on my ducky, gets stuck down when I put it on.
The spacebars fit, and I can measure them when I get to the office, but I think they are the same length as the DCS universal.  But the stems might be slightly different and the material might be thicker.
But me, personally, I'd suspect skewed stabilizers.  Get them just slightly out of alignment and they stick.  This happens to me about 20% of the time when assembling new keyboards, regardless of stabilizer type.
Does it work with an SP DCS spacebar?
 - Ron | samwisekoi
« Reply #1851 on: Thu, 13 June 2013, 09:44:53 »
 - Ron | samwisekoi
Yeah the problem isn't on the poker, I was just seeing if it would fit on it, the problem is on my ducky shine II.
I've used the spacebar from CCnG and am currently using an imsto thick pbt spacebar on it just fine.
Offline Lighthouse1
« Reply #1852 on: Sat, 15 June 2013, 09:52:09 »
All arrived safely thank you very much!
Really nice to type on I prefer a flat keyboard so this has worked well and is faster and more accurate, excellent stuff. I like the flat space bar in particular.
Also thanks to the people posting tips on how to make the inserts fit on the stabilised keys so they don't fall out during fitting, a little piece of cling film has worked nicely!
Poor picture of the variant I am sticking with currently (I like the plum ones but this feels quite Commodore!).
Excellent GB experience, thanks for all the hard work to the organisers. Glad I picked up all the parts of the sets I did, there was loads of it!
Offline sicaine
« Reply #1853 on: Sun, 16 June 2013, 07:30:40 »
Still nothing in germany. Just as an information for other fellow germans you are not alone!
Offline oldskulrulz
« Reply #1854 on: Sun, 16 June 2013, 12:32:22 »
Photo looks delicious!
...and WHO will the first paint keyboard case beige for these caps?
Offline Photoelectric
« Reply #1855 on: Sun, 16 June 2013, 12:53:48 »
I planned to paint my case copper for these, but then I changed my mind and will be using Round2 PBT caps instead and the case became copper anyway :)
Offline ApocalypseMaow
  • Kitteh Overlord
  • Say WHAAT...
« Reply #1856 on: Sun, 16 June 2013, 14:50:28 »
Looks really good!
Offline stoic-lemon
« Reply #1857 on: Sun, 16 June 2013, 21:15:02 »
Has anyone had problems with the 6.25 spacebar? I think I've ended up with one that is lazy and just wants to stay stuck down on the stabilizers!!
Yeah I have the same problem. I couldn't really fix it, so I'm just using the Ducky spacebar, which drops on with no probs.
Offline Glod
  • Also Known As Ergonomech
    • YouTube Channel
« Reply #1858 on: Sun, 16 June 2013, 21:20:17 »
i'm painting my phantom either beige or with a color testers makes called navy aggressor gray. its not beige, its obviously gray but it looks great with the retro because its more a retro gray color.  I had a test piece of plastic i sanded, primed, sprayed, clear coated. but i cant seem to find it to take a picture grrrr but i havent decided if i want the gray or the beige
Offline hoasican2004
« Reply #1859 on: Mon, 17 June 2013, 02:40:25 »
Alu case is very nice ^_^
Offline quochung1989
  • Vintage Cherry Collector
  • Frenzy Classic.
« Reply #1860 on: Mon, 17 June 2013, 02:45:00 »
Alu case or copper case? I think this is copper case. Right?
Offline usopia
« Reply #1861 on: Mon, 17 June 2013, 07:08:54 »
Some german buyers have already received their caps. I have been delivered a week ago. Probably depends also on your customs office.
My package has not been stopped by customs and I had to pay nothing. Others had probably pay customs duties.
Offline domoaligato
« Reply #1862 on: Tue, 18 June 2013, 22:19:46 »
anyone interested in a set of RGBY DSA Mods?
http://geekhack.org/index.php?topic=44912
Offline bazemk1979
« Reply #1863 on: Tue, 18 June 2013, 23:01:24 »
I joined, GB should run for a month so hoping will hit 75 on the RGBY
  • Kitteh Overlord
  • Say WHAAT...
« Reply #1864 on: Thu, 20 June 2013, 16:14:12 »
Everyone get their orders...  ;D
« Reply #1865 on: Fri, 21 June 2013, 04:21:16 »
DSA Retro is very nice, but it's low profile  :(
my Poker
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #1866 on: Fri, 21 June 2013, 04:33:28 »
it's not a bug. it's a feature :)
Offline Batmann
« Reply #1867 on: Fri, 21 June 2013, 04:34:42 »
copper was definitely a nice match
true, typing experience is really weird, I couldn't get used to it (I didn't give it much time though)
Offline GeorgeK
« Reply #1868 on: Fri, 21 June 2013, 05:31:45 »
I couldn't get used to it to begin with but after a couple of days I could and I like it :D
I have noticed that I must 'slide' my fingers back from the top row to the home row however as I sort of catch my fingers on the top of the home row keys...  Still nice though :)
Offline bazemk1979
« Reply #1869 on: Fri, 21 June 2013, 07:23:30 »
my Poker
looks like the keys are floating, makes ur custom poker even more unique
Offline oldskulrulz
« Reply #1870 on: Fri, 21 June 2013, 09:44:59 »
!!! EXACTLY !!!
I selected my previous keyboard because time of the purchase (1997) Cherry ML4100 was the only 60% board here. I did not know about "mechanical switches" at that time, so I was lucky with it :)
As I remember, I get used with the totally ugly laptop layout in 1 month.  After that I typed as fast as on a regular layout.
I don't remember that flat keytops blocked me - instead I just slide with my fingers on the keys while I looking at the monitor and can reach specified keys without looking them.
Recently I bought a CMstorm QuickFire: so, now my fingers always blocked  by the common keytops when I trying to sliding on them :) Also, it was 3-4 days to re-civilisationing myself to a normal layout :)
I like to remark that ML4100 having a light cylindrical top instead of DSA's spherical one, so maybe this is the problem for someone (?). I think I prefer cylindrical tops, however I used spherical keys only on my ♥ C64, long time ago. BTW recently I pulled-off a key to test maybe it works on MX RED - but was no success  :D
ORIGINAL C64 logo key photos attached ;) ...that IS the real doubleshot - eh?
« Last Edit: Fri, 21 June 2013, 09:52:45 by oldskulrulz »
Offline ishtob
« Reply #1871 on: Fri, 21 June 2013, 09:51:31 »
i actually find the flat profile more comfortable.. probably because I used laptop scissor switches throughout college
Offline aggiejy
« Reply #1872 on: Fri, 21 June 2013, 11:55:07 »
I like the flat profile on scissor switch boards and laptops fine.  But some reason, DSA feels like it's convex in the middle.  My fingers drag across keys when moving between top and bottom rows.  I love the look, I wish I liked typing on them.
  • Kitteh Overlord
  • Say WHAAT...
« Reply #1873 on: Fri, 21 June 2013, 14:51:05 »
It's ok to hate them, I'll take them off your hands....
Offline aggiejy
« Reply #1874 on: Fri, 21 June 2013, 19:45:49 »
Sold them a week after I got them.
Offline Glod
    • YouTube Channel
« Reply #1875 on: Sat, 22 June 2013, 02:53:31 »
i am not ashamed with liking DSA
Offline samwisekoi
  • MAWG since 1997
    • Tweet samwisekoi
« Reply #1876 on: Sat, 22 June 2013, 11:17:47 »
To all those who asked if they could contribute frunds to cover the unexpected overruns on Retro DSA costs:
We are good with funds, and have managed to keep this within a range we can support.  And we are certainly grateful for the show of support, so no cash money at this time.
However, if you want to do something for the Retro DSA organizers, especially something that will encourage us to move on the Elvish, Nuclear Green and SA-lectric Blue Retro Group Buys, please leave us some Heatware feedback.
Matt3o:  http://www.heatware.com/eval.php?id=81720
samwisekoi:  http://www.heatware.com/eval.php?id=82246
We worked hard to make a big group buy be successful, and it would be gratifying if we could get some kudos where they will help us do more of these.
So go the the URLs above, or just click on the little flame icons below our avatars, and tell the world if you thought we did a good job.
Thanks in advance,
 - Ron | samwisekoi (on behalf of both of us.)
Offline stoic-lemon
« Reply #1877 on: Sat, 22 June 2013, 17:23:49 »
I love using this set every day. I wish I'd got more.
Offline TD22057
« Reply #1878 on: Sat, 22 June 2013, 18:06:57 »
I wish I'd started looking at keyboards soon enough to get in at all :)  Especially seeing the markup people are getting in the classifieds section for some of these kits.
Offline rknize
    • metaruss
« Reply #1879 on: Mon, 24 June 2013, 11:18:49 »
Heat left for both of you.
Russ
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #1880 on: Mon, 24 June 2013, 11:54:29 »
I can resist...
I can resist...
I can resist...
No I can't...
Offline suka
« Reply #1881 on: Wed, 26 June 2013, 06:54:37 »
Heat added, and a little sneak preview of my newest prototype featuring the great retro caps:
« Last Edit: Wed, 26 June 2013, 06:58:27 by suka »
  • Kitteh Overlord
  • Say WHAAT...
« Reply #1882 on: Wed, 26 June 2013, 07:41:42 »
Is it wrong to want to make love to that?  :confused:
« Reply #1883 on: Wed, 26 June 2013, 08:03:54 »
Whoah... it's a baby ErgoDox!  :eek:
Which key(s) are your spacebar key?  The blank ones?
Offline suka
« Reply #1884 on: Wed, 26 June 2013, 08:24:11 »
It's the innermost left thumb key (Menu). Their double-usage currently is defined as:
Code: [Select]
Esc Tab  Space |  Backsp Return -  # when pressed & released by themselves
Alt Ctrl -     |  Shift  M3     M4  # when pressed with another key
Offline samwisekoi
  • MAWG since 1997
    • Tweet samwisekoi
« Reply #1885 on: Wed, 26 June 2013, 08:41:23 »
Wow!  Cool.
That would save on keycaps -- if you could buy those alone!
 - Ron | samwisekoi
"Thoriated like Tungsten"
Offline wasabah
« Reply #1886 on: Wed, 26 June 2013, 09:04:04 »
Woot, that looks awesome!!
I want it.. :D
ErgoDox Classic | Logitech G400 | Logitech Marble | Logitech M570 | Logitech M235 | Logitech M305
Offline raisinbun
« Reply #1887 on: Wed, 26 June 2013, 10:01:43 »
I think I missed out a set I want :( Both the colour and the profile...
« Reply #1888 on: Wed, 26 June 2013, 12:28:35 »
not sure what just happened ignore please
Offline thadood
« Reply #1889 on: Wed, 26 June 2013, 13:11:36 »
Maybe there will be enough interest for another GB down the road - I'd be in on that. This is basically my dream set and I found out about it way too late lol.
Offline TD22057
« Reply #1890 on: Wed, 26 June 2013, 13:32:01 »
If you want more DSA (and you know you do), please register your interest for these possible future GB's:
Red Alert DSA
Two tone white/beige DSA
Offline sicaine
« Reply #1891 on: Thu, 27 June 2013, 05:38:16 »
My Set arrived today at the old paypal address : /. I'm pretty sure I specified my new address.
Anyhow my mother might be able to bring it with her but it will take a week before i can check the content of it.
Offline samwisekoi
  • MAWG since 1997
    • Tweet samwisekoi
« Reply #1892 on: Thu, 27 June 2013, 11:30:16 »
Sorry about that.  In some cases PayPal was quite insistent about using the verified address.  I'm glad it made it through Customs, however!
Who else is still missing their sets?  I know Slavfot of Deskthority is waiting, and last time I checked, there was at least one person in Korea.
Please advise as I am holding up final replacements until we get the last set accounted for.  Because nothing will be served after we call for final rounds.
 - Ron | samwisekoi
Offline Hahnebambel
« Reply #1893 on: Thu, 27 June 2013, 11:58:44 »
I'm still waiting.
Offline Rendom
« Reply #1894 on: Fri, 28 June 2013, 14:42:07 »
Any one have any extra set? Would really love one, and also one of those 1x backspace. : x
QFR - MX Blue
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #1895 on: Wed, 03 July 2013, 00:45:43 »
Call to action!
Did anyone receive two 1! keys? Please speak out, there's a fellow Deskthorian who misses it and we don't have the replacement for it yet.
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #1896 on: Thu, 04 July 2013, 07:28:52 »
I received some spares from samwisekoi, going to ship missing caps to:
laladila
fireglow
madscientist46
hzza
please also review my previous message
« Last Edit: Thu, 04 July 2013, 07:45:56 by Matt3o »
Offline Slavfot
« Reply #1897 on: Sat, 06 July 2013, 12:28:42 »
Still haven't recieved my caps :(
Offline Hak Foo
  • Make America Clicky Again!
« Reply #1898 on: Tue, 09 July 2013, 01:18:43 »
Surprise information:
Remember the picture of a keyboard with a green 1x return, plum and brown keys, and a phone-style numeric keypad?  that got us all on the kick of "Let's add green and plum?"
It appears this is the keyboard of the ICL OPD "One-Per-Desk"
http://www.old-computers.com/museum/computer.asp?c=275
Although we all said "C64 style", the history of the OPD says it's got Sinclair guts!
Overton130, Box Pale Blues.
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #1899 on: Tue, 09 July 2013, 01:58:53 »
Discovered hidden treasure
+100XP
LEVEL UP!
