Author Topic: DSA Retro Set (SHIPPED!)  (Read 1957101 times)
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
Re: DSA Retro Set (SHIPPED!)
« Reply #1950 on: Wed, 04 December 2013, 13:43:41 »
personally I'm against round 2s.
the set should be one of a kind limited edition :)
I will definitely work on new group buys, but in different colors/materials.
Offline Krogenar
  • The Kontrarian
    • Buried Planet
« Reply #1951 on: Wed, 04 December 2013, 14:02:53 »
Artists don't repeat themselves!  :thumb:
Quote from: Samuel Adams
Offline oluf
  • formerly olaph
« Reply #1952 on: Wed, 04 December 2013, 17:18:12 »
I agree... And, I'm excited to see what you come up with next! =D
Offline deSheol
  • Thorpe
« Reply #1953 on: Sat, 07 December 2013, 00:46:44 »
Anyone have an extra 7x spacebar? T_T
Offline Hellmark
« Reply #1954 on: Mon, 16 December 2013, 14:47:52 »
Personally, I'd love a set with black background, white foreground. If I could still get the brown set, I'd want all browns anyway. I like monochrome schemes.
Offline Rendom
Re: DSA Retro Set (SHIPPING!)
« Reply #1955 on: Sat, 21 December 2013, 09:30:14 »
Having the same problem as this with my Phantom, and my Ducky. Anyone know how can I fix it? Do I really have to deassemble it? (0% soldering skills.)
I do not own a Ducky, but I have the same problem with my poker (beast plate + plate mounted cherry stabs).
The DSA spacebar fits in the stabilizers correctly and everything seems fine but it doesn't go up easily. If I press hard the spacebar can stay stuck at the lower position. I believe there some friction on the stabs that makes harder the spacebar to go up.
There is no problem like that with DCS spacebars from SP I have.
This is a bit off this thread's topic but I had the same problem as you and figured I'd chime in.
If you are installing a plate with cherry stabilizers you need to make sure the space bar stabilizer wire looks like this with a flat wire. And not like this with a curve in the center. It may depend on the height of curve but in my case it grinded against the plate and prevented the space bar from moving smoothly.
I figured this out too late and ended up having to pull the cherry stabilizers out of the already installed plate which ended up damaging the stabilizers.
Thanks but the wire I have is flat. I'm using a DCS spacebar without any problem.
If it's possible I wouldn't mind using a DCS retro spacebar if there is some available...
QFR - MX Blue
« Reply #1956 on: Sat, 21 December 2013, 09:35:31 »
^^ I couldn't use DSA space bar on my ducky, it fit but wouldn't go up and down properly.
Offline yasuo
  • spanengan puyeng newbie
« Reply #1957 on: Sat, 21 December 2013, 09:37:16 »
what difference feel DSA than DCS OEM
Logitech MK220 Colemak DH
Offline Rendom
« Reply #1958 on: Sat, 21 December 2013, 12:56:44 »
That's my problem too, it won't even go up for me as soon as I press it down. lol
QFR - MX Blue
Offline oldskulrulz
« Reply #1959 on: Sat, 21 December 2013, 13:29:40 »
Try out a good old C64 :thumb:
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #1960 on: Thu, 26 December 2013, 02:11:21 »
would anybody be interested in DSA Retro but in SA fragrance?
« Last Edit: Thu, 26 December 2013, 03:22:13 by Matt3o »
Offline nuclearsandwich
« Reply #1961 on: Thu, 26 December 2013, 02:20:04 »
Does anybody would be interested in DSA Retro but in SA fragrance?
OMYES
Offline pasph
« Reply #1962 on: Thu, 26 December 2013, 10:10:58 »
Yes
Offline domoaligato
« Reply #1963 on: Thu, 26 December 2013, 12:05:57 »
yes
« Reply #1964 on: Thu, 26 December 2013, 14:14:20 »
Don't tease us :eek:
Offline Loligagger
« Reply #1965 on: Thu, 26 December 2013, 18:47:55 »
Sure, go for it.
Offline reziak
  • Topre/60% Enthusiast
« Reply #1966 on: Fri, 27 December 2013, 20:57:57 »
Any known fixes for this? I just bought a set and the spacrbar is usable - just feels like crap...
HHKB Pro 2 | FC660C | HHKB Pro 2 Type-S
« Reply #1967 on: Fri, 27 December 2013, 23:13:44 »
Is your space bar warped at all?  If you put it on a flat surface, does it lie completely flat?
Offline reziak
« Reply #1968 on: Sat, 28 December 2013, 05:05:29 »
That's a really good question. I'm away from home a week or so, but I'll check when I get back. If it is, is there an easy way to bend it back?
« Reply #1969 on: Sat, 28 December 2013, 19:02:57 »
The two generally accepted methods are to heat it with a hair dryer or immerse it in hot water.
Then place it on a completely flat surface with something heavy (but not TOO heavy!) on top until it cools.
Offline reziak
« Reply #1970 on: Sun, 29 December 2013, 09:07:32 »
I'll give it a shot when I get home and report back!
Offline mapple
« Reply #1971 on: Thu, 02 January 2014, 08:05:03 »
hey guys two questions :
1) anyone have them on white backlight? i would very much appreciate some pictures.
2) any1 in europe wanna resell them?
In God We Trust
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #1972 on: Thu, 02 January 2014, 08:11:52 »
I would really like them on amber backlight actually :)
« Reply #1973 on: Thu, 02 January 2014, 10:28:52 »
Hear hear! Darkish gold case with amber LEDs. When GON's NeRD 108 boards are ready I think that's what I'll be doing with one.
Offline CrapTypist
    • http://www.georgecochrane
« Reply #1974 on: Fri, 03 January 2014, 14:59:54 »
YUSSSS
« Reply #1975 on: Fri, 03 January 2014, 15:03:19 »
In my experience they do a good job of blocking LED light, so any backlights are only going to show along the edges.
Offline mapple
« Reply #1976 on: Fri, 03 January 2014, 17:46:57 »
ok that would be enough. now your experience is based on having ones or just seeing? where i'm going with it is another question. Does anyone who bought that retro set have put them on backlight cause letters/digits are white do they glow?
In God We Trust
Offline usopia
« Reply #1977 on: Sat, 04 January 2014, 00:25:13 »
no, the LEDs do not shine through. I've tested it with red and blue lighting. It's like metalliqaz said before.
« Reply #1978 on: Sat, 04 January 2014, 15:29:00 »
I own them and they are installed on my backlit qazpad... as shown in my avatar...
The white letters don't glow at all.  Remember they are all center printed, so the letters are over the stem.
Offline skuphundaku
« Reply #1979 on: Mon, 13 January 2014, 12:00:23 »
YEEEAAAAHHHH!!!!!
Offline mapple
« Reply #1980 on: Tue, 14 January 2014, 02:30:13 »
k, based on that info i did ordered dsa white pbt from keycaps direct  hopefully those ones will pass some light i'll upload a photo as soon they'll arrive.
In God We Trust
Offline sean4star
« Reply #1981 on: Sat, 18 January 2014, 00:06:35 »
Does anyone have a spare 6.2u dsa profile spacebar?
I picked up a set from the classified section, kit 1 and 3 with a spacebar, but the spacebar was the dcs profile and I don't like it as well.
I'm also looking for a kit 4, the number pad. Anyone willing to sell?
Offline kaltar
« Reply #1982 on: Sat, 25 January 2014, 00:25:46 »
Are you kidding? Artists DO repeat themselves all the time. That's how they are known for a "style".
Heck, even JS Bach repeated the same melodies multiple times in different works!
I'm all in for a new round!
Offline DamienG
    • DamienG
« Reply #1983 on: Sat, 25 January 2014, 11:34:58 »
Bear in mind the 6.2u DSA spacebar mounting points were not universal hence why a universal 6.2u DCS was offered. Measure how far yours are from the center stem - if they are 50mm you're good to go. Would hate to see you track one down only to find it didn't fit!
[)amien
Offline samwisekoi
  • MAWG since 1997
    • Tweet samwisekoi
« Reply #1984 on: Mon, 17 February 2014, 20:40:23 »
I might have a spacebar. Where in the world are you?
 - Ron I samwisekoi
Offline Krogenar
  • The Kontrarian
    • Buried Planet
« Reply #1985 on: Tue, 18 February 2014, 11:03:36 »
[)amien
Yeah, this. I have a DSA spacebar and it doesn't actuate or mount properly on my Ducky fullsize keyboard, so I switched to DCS (of the proper color) and have no problems with the set.
« Reply #1986 on: Tue, 18 February 2014, 11:10:06 »
[)amien
Had the same problem!
Offline sean4star
« Reply #1987 on: Tue, 18 February 2014, 11:19:56 »
Right now I have the caps on a Poker II.  Looks like the spacebar uses the center mount with the stabilizers on the far ends.  I just measure these at 50mm from the center.  So I think I should be good.  Thanks for the help!
Ron, I sent you a PM.
Offline sean4star
« Reply #1988 on: Mon, 03 March 2014, 10:15:29 »
Thanks Ron, for the spacebar!  The mount spacing fits my Poker 2 perfectly.
I'm still looking for the kit 4 number pad if anyone has one for sale.
Offline typedd
« Reply #1989 on: Tue, 22 April 2014, 06:25:53 »
Will this Group Buy be happening again? Can't find anything similar anywhere!!!
Offline Hellmark
« Reply #1990 on: Tue, 22 April 2014, 10:24:55 »
Typedd, I don't think they'll do another retro.
I am in the very, very early stages of trying to figure out a group buy for a similar set. Black DSA with white legend.
« Reply #1991 on: Tue, 22 April 2014, 15:17:10 »
Welcome to Geekhack!
Based on the popularity and the number of requests for a round 2, it is possible that this might happen again at some stage.
But AFAIK no-one is planning anything at the moment.
Offline kektr0city
« Reply #1992 on: Tue, 22 April 2014, 15:36:44 »
If a round 2 were to happen, it would likely happen via the SP GB website.  They currently have the set up as an expired GB.
http://www.pimpmykeyboard.com/deals/dsa-retro-set/
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #1993 on: Tue, 22 April 2014, 17:22:29 »
the set was meant to be a "limited edition".
I might run an SA (instead of DSA) round 2 though.
Offline mashby
  • What Up Shoney? (ツ)_/¯
    • Mashby
« Reply #1994 on: Tue, 22 April 2014, 17:35:49 »
Offline Hofy
  • Voids Warranties
« Reply #1995 on: Tue, 22 April 2014, 18:34:00 »
You tease.
Poker II Cherry MX Blue
Filco TenKeyless Zero Fukka
Cherry ML4100
IBM Model M 1391401 Buckle Spring Luvin
Offline Oobly
« Reply #1996 on: Wed, 23 April 2014, 02:51:55 »
I would get in on that :) (if it's the full sculpted profile, not just row 3 for everything).
Buying more keycaps,
it really hacks my wallet,
but I must have them.
« Reply #1997 on: Wed, 23 April 2014, 05:04:55 »
SA would be even more like the C64 keycaps.
Offline isaske
  • Stop whining!
« Reply #1998 on: Wed, 07 May 2014, 06:00:12 »
The more i'm watching those past GB's that included the DSA family, the more I'm telling myself that I can't miss the next one.
Beautiful sets. How different does DSA feel from the ordinary DCS family?
HOW DO I COMPUTER?
« Reply #1999 on: Wed, 07 May 2014, 19:27:58 »
DSA is a uniform profile whereas DCS, OEM, and Cherry profile are sculpted. In other words, if you took a DCS set and wanted to switch to some other layout like Dvorak or Coleman your keys would feel all wonky because the E key is designed for the top alpha row. With DSA that's not an issue because the profile on every key is "flat". In my experience it works really well on clicky and tactile switches but I'm not sure how I like it on linear switches. I also think it feels better on on keyboards that have relatively shallow typing angles from the bottom row to the top and looks amazing on boards where the top of the case is the switch plate like this one.
