Author Topic: [WTS] Poker acrylic case [Shipping Done]  (Read 185660 times)
Offline alixinhzai
  • Trade Count: (0)
Re: [WTS] Poker acrylic case, Vietnamese keychain
« Reply #200 on: Wed, 10 April 2013, 10:25:38 »
U like Italy style?
18296-0
Offline guilleguillaume
  • Trade Count: (0)
« Reply #201 on: Wed, 10 April 2013, 10:37:28 »
Are we forced to use plate mounted switches on your case?
I'm actually confused with that acrylic plate to be honest. I thought we could just fit in there a standard Poker.
Offline Turkishrambo
  • Trade Count: (0)
« Reply #202 on: Wed, 10 April 2013, 10:38:05 »
Can u extend the close date till the same day GH60 closes? Was going to talk to people at work and see if they are interested in purchasing one of these. This is looking like the most affordable case for GH60 so far. Not everyone can afford a 200$ aluminum case lol
also, is there an option for ansi 1.5? or would it just be better to use a metal plate from the gh60 GB?
« Last Edit: Wed, 10 April 2013, 10:40:18 by Turkishrambo »
Offline Sai
  • Trade Count: (0)
« Reply #203 on: Wed, 10 April 2013, 10:50:37 »
yep. i'd prefer this as well but the OP said something about doing 2nd round after GH60 GB. so idk.
Offline cyberwave
  • Trade Count: (0)
« Reply #204 on: Wed, 10 April 2013, 11:22:25 »
it's actually the PCB that matters. as long as the PCB supports PCB-mounted switches, u can use PCB-mounted switches.
  • Trade Count: (0)
« Reply #205 on: Wed, 10 April 2013, 11:25:40 »
I already know that but I'm refering to the fact that it seems that there will be an acrylic plate included in the case and I don't know if it's mandatory to use it or not.
  • Trade Count: (1)
« Reply #206 on: Wed, 10 April 2013, 11:33:11 »
It seems you have to use the plate, as that (the 3mm "spacer" plate) is how the PCB mounts to the case.
Offline jcrouse
  • Trade Count: (0)
Re: Re: [WTS] Poker acrylic case, Vietnamese keychain
« Reply #207 on: Wed, 10 April 2013, 11:37:42 »
Yes, the 3mm plate is actually the middle layer when looking at the side of the case, hence as you state, really connects the switches, pcb (and metal plate, if used) to the case.
John
Offline Permeability
  • Trade Count: (0)
« Reply #208 on: Wed, 10 April 2013, 12:32:10 »
I would like  Filco 87 case when you get those started.
Keyboards:
'The Cheat' - lubed 62g Clears
Ducky Shine 3 TKL lubed 45g Reds (Work)
Offline MKULTRA
  • Trade Count: (0)
  • telling it how it is
« Reply #209 on: Wed, 10 April 2013, 14:19:06 »
But if we use a metal plate it will sit on top of the acrylic?
If I am following this properly...
1. You can get the acrylic plate with openable or non openable switches (the notches)
2. Openable can only use cherry pcb mount stabilizers, while non openable can use plate mounted costar
3. You can use PCB or plate mounted seitches.
Offline Dsan
  • Trade Count: (0)
« Reply #210 on: Wed, 10 April 2013, 14:42:45 »
If I plan to do a poker layout using a Gh60 universal plate,will it be compatible with the acrylic gh60 poker (Using both plates together)?
  • Trade Count: (1)
« Reply #211 on: Wed, 10 April 2013, 14:50:28 »
Yes, that's correct.
Correct.
No, you can only use Cherry PCB mount stabilizers. You cannot use Costar with these at all, due to the 3mm spacer plate.
Correct.
Yes, it will be compatible using the GH60-Poker layout.
Offline Gupgup
  • Trade Count: (0)
« Reply #212 on: Wed, 10 April 2013, 14:54:03 »
Shouldn't this be moved to the GB thread?
  • Trade Count: (1)
« Reply #213 on: Wed, 10 April 2013, 14:58:52 »
He's not really organizing a buy from a supplier, using the buying power of many buyers to get a volume discount. So, really, it's just a sale.
Offline gnubag
  • Trade Count: (0)
« Reply #214 on: Wed, 10 April 2013, 15:01:40 »
did alixinhzai just changed that the case can only use cherry pcb mount stabs even if we have a metal plate?
i am pretty sure that in the beginning the acrylic plate only supports pcb mount cherrys and that it doesnt matter if we use metal plates.
please clarify ~.~
Offline phetto
  • HHKB JP
  • Trade Count: (0)
« Reply #215 on: Wed, 10 April 2013, 15:05:22 »
  • Trade Count: (1)
« Reply #216 on: Wed, 10 April 2013, 15:05:47 »
please clarify ~.~
The OP states that you can only use Cherry PCB mount stabilizers.
If you use your own metal plate, you would be able to use Costar stabilizers, if there were no 3mm acrylic spacer plate between the metal plate and the PCB. That spacer plate is what attaches the PCB to the case, as there are no standoffs or anything. That acrylic plate would prevent you from using Costar stabs, because the Costar stabs (and Cherry plate mount stabs) need clearance under the metal plate in order to mount.
Offline MKULTRA
  • Trade Count: (0)
« Reply #217 on: Wed, 10 April 2013, 15:35:33 »
How solid do you reckon this is compared to a metal plate?
Offline gnubag
  • Trade Count: (0)
« Reply #218 on: Wed, 10 April 2013, 16:42:16 »
please clarify ~.~
 so would it be possible to create that clearance using a file/dremel so cherry plate mount stabs would fit?
or just make the cutouts for the stabs on the crylic plates bigger for plate mounted stabs.
« Last Edit: Wed, 10 April 2013, 18:12:40 by gnubag »
  • Trade Count: (1)
« Reply #219 on: Wed, 10 April 2013, 16:45:37 »
please clarify ~.~
I would think so, yes.
Offline alixinhzai
  • Trade Count: (0)
« Reply #220 on: Wed, 10 April 2013, 19:47:07 »
I do! Get dat for me!
plz order this 3mid Milk White, Top cover green, Bottom cover red, Plate red and sw type u need :D
@thk jdcarpe help me answer T_T I'm not good at english :D
Update OP for stabilizer can use If u change metal 1/16" plate:D
Offline gnubag
  • Trade Count: (0)
« Reply #221 on: Wed, 10 April 2013, 20:29:53 »
<3
  • Trade Count: (3)
« Reply #222 on: Wed, 10 April 2013, 20:31:42 »
I filled out the form last night for one. So hard with all those options! Love it!
Offline jcrouse
  • Trade Count: (0)
« Reply #223 on: Wed, 10 April 2013, 21:11:22 »
What "options" did you choose?
John
Offline alixinhzai
  • Trade Count: (0)
« Reply #224 on: Wed, 10 April 2013, 21:39:18 »
18366-0
  • Trade Count: (3)
« Reply #225 on: Wed, 10 April 2013, 21:52:42 »
Oh my! That's going to look so good on the poker I'm using it for!!
Offline affect656
  • Trade Count: (0)
« Reply #226 on: Thu, 11 April 2013, 02:03:31 »
So hard to decide color combinations I might go with 3
I like linear.
Offline Tarzan
  • formerly known as Greystoke
  • Trade Count: (0)
« Reply #227 on: Thu, 11 April 2013, 07:49:52 »
You should see if a slightly darker color of green is available, I think a case with green top/bottom panels, and milk-white center would look fantastic with the CCoG keyset.
18381-0
Just doing my bit to suggest options.   :p
Offline Paranoid
  • Trade Count: (0)
« Reply #228 on: Thu, 11 April 2013, 08:11:39 »
looks promising :) I'll be waiting for a second or third batch ^^
Offline alixinhzai
  • Trade Count: (0)
« Reply #229 on: Thu, 11 April 2013, 08:34:51 »
Full image of my case :D
Offline Dsan
  • Trade Count: (0)
« Reply #230 on: Thu, 11 April 2013, 08:43:20 »
That's amazing  :eek: but it's not possible with the option of colours you're giving this time,right? :)
  • Trade Count: (1)
« Reply #231 on: Thu, 11 April 2013, 08:55:35 »
Sure it is... Isn't that the Royal Blue?
Offline Dsan
  • Trade Count: (0)
« Reply #232 on: Thu, 11 April 2013, 09:10:22 »
My bad,I mean the blue mid layer shouldn't be possible if I'm not wrong.Sorry for bad English :)
Offline rurushu
  • Trade Count: (0)
« Reply #233 on: Thu, 11 April 2013, 09:12:39 »
OMG... that case looks so delicious!!! reminds me of a kind of appetizer...  :D
guess i will wait for round 2.... too many things happening now... not enough money and time for new stuffs..  :'(
hmm... yea, was wondering about that also... why not allow the middle layer to have an option to be same color like the top and bottom cover?
Offline alixinhzai
  • Trade Count: (0)
« Reply #234 on: Thu, 11 April 2013, 09:17:00 »
yes, this time I can't get this mid color like this in mass order :(
@jdcarpe: it's coban blue...  my camera is bad to get true color :(
  • Trade Count: (1)
« Reply #235 on: Thu, 11 April 2013, 09:19:14 »
Ahhh, okay. I was really liking that sandwiched look, and was about to PM you with some color changes/ :D :) :(
Offline MKULTRA
  • Trade Count: (0)
« Reply #236 on: Thu, 11 April 2013, 09:28:11 »
That is beautiful.  When are we paying and when will manufacturing start?
Offline alixinhzai
  • Trade Count: (0)
« Reply #237 on: Thu, 11 April 2013, 09:36:24 »
tomorrow order close :D payment collect in one week :D and manufacturing after this. Manufacturing time  will be send after I send quantity to manufacturer :D
Offline cyberwave
  • Trade Count: (0)
« Reply #238 on: Thu, 11 April 2013, 09:38:15 »
when is round2/3/4/5/...??
im really liking the top/middle/mid plate sandwich colour scheme  ;)
Offline samwisekoi
  • MAWG since 1997
  • Trade Count: (0)
    • Tweet samwisekoi
« Reply #239 on: Thu, 11 April 2013, 09:46:09 »
Can my special version be in that order?
Poker-H
 - Ron | samwisekoi
« Last Edit: Thu, 11 April 2013, 09:52:40 by samwisekoi »
  • Trade Count: (1)
« Reply #240 on: Thu, 11 April 2013, 09:46:53 »
 - Ron | samwisekoi
You haz speshul? I want! I can haz?
Offline Dsan
  • Trade Count: (0)
« Reply #241 on: Thu, 11 April 2013, 10:06:25 »
If it's not asking too much,could you please take some front pics of the clear acrylic layers?I plan to do a similar case to yours with Coban blue but I'm not sure If i like a clear layer between the white ones or a simply 3 mid white layers case.Thank you,can't wait to order one of these sweet cases :D
Offline samwisekoi
  • MAWG since 1997
  • Trade Count: (0)
    • Tweet samwisekoi
« Reply #242 on: Thu, 11 April 2013, 10:15:39 »
Poker-H
 - Ron | samwisekoi
Up to OP.  I asked for a version with a 2.5x block in each lower corner, letting me use a Poker board (or ANSI GH60) with a 1.25 - 6.25 - 1.25 - 1.25 bottom row.  Swap CAPS/Cntrl-L and map Win-R to CAPS and there is Alt-Space-Fn-Caps on the bottom row and Ctrl-L under Tab.
 - Ron | samwisekoi
  • Trade Count: (1)
« Reply #243 on: Thu, 11 April 2013, 10:27:51 »
 - Ron | samwisekoi
Nice!
Offline alixinhzai
  • Trade Count: (0)
« Reply #244 on: Thu, 11 April 2013, 11:51:06 »
after GH60 payment deadline :D
Poker-H
 - Ron | samwisekoi
sure :D
Offline cyberwave
  • Trade Count: (0)
« Reply #245 on: Thu, 11 April 2013, 12:07:12 »
awesome! looks like i can order a GH60 without worrying about not being able to find a case for it :D
Offline blueasjim
  • Trade Count: (0)
« Reply #246 on: Thu, 11 April 2013, 13:04:53 »
I do have a question. Is there a tutorial anywhere about transplanting a Vortex Pure into a case like this? I cannot seem to find one.
Would that be difficult?
Vortex KBT PURE [MX Red] | CM Storm [MX Blue] | CM Storm [MX Red]
  • Trade Count: (1)
« Reply #247 on: Thu, 11 April 2013, 13:25:21 »
1. Remove keycaps.
2. Remove PCB from case by unscrewing 6 screws.
3. Desolder all LEDs and remove.
4. Desolder all switches and remove from PCB.
5. Mount switches in acrylic plate.
6. Install mounted switches onto spacer plate.
7. Mount this assembly onto PCB, and solder all switches.
8. Replace all LEDs, and solder.
9. Stack layers together, insert screws and bolt together.
Done!
Offline blueasjim
  • Trade Count: (0)
« Reply #248 on: Thu, 11 April 2013, 13:27:47 »
1. Remove keycaps.
Done!
Ah, yes, so I'm going to have fun. lol.
Offline Tarzan
  • Trade Count: (0)
« Reply #249 on: Thu, 11 April 2013, 13:30:41 »
I went ahead and ordered two of the cases.  I'm planning to use the nifty stainless steel plates I got from The_Beast's sale, with the PCBs from the GH60 GB, but I didn't see any option to de-select the "plate" from my order.  I don't mind if I get the acrylic plates anyway, but it seems a bit wasteful if I'm not going to use them...
Or am I missing something?  I read the description of how the five layers are supposed to go together, but I may have overlooked the steel plate option.
