Author Topic: Simple Questions, Simple Answers (FAQ in the OP)  (Read 6213850 times)
« Reply #1000 on: Wed, 24 April 2013, 14:45:54 »
Ok I think I've made stupid noob mistake.
I just purchased the Ducky DK9008 Shine II White LED Backlit Mechanical Keyboard (Clear Cherry MX) and I ordered a set of KBC Gray Dyesub "Thick" PBT Cherry MX Key Caps (105 keys included) now what do I do about the 4 keys about the numberpad? Doh!  :confused:
19724-0
Offline Tarzan
  • formerly known as Greystoke
« Reply #1001 on: Wed, 24 April 2013, 14:49:12 »
Add four Brobots to your keyboard?
 :p
Offline Bencze
« Reply #1002 on: Wed, 24 April 2013, 15:05:13 »
noob
Can't you order 4 blank caps of same type? Who cares about those buttons anyway, I'd use them as decoration or nothing at all.
-= QFR w/ mx blues - HPE87 w/ mx browns - Ducky 1087XM w/ green alps =-
« Reply #1003 on: Wed, 24 April 2013, 15:06:21 »
I vote for 4 GirlDC caps :P
« Reply #1004 on: Wed, 24 April 2013, 15:10:04 »
ray you're gonna have a hard time finding any keyset that has those four keys. Spend $1000 on 4 girldcs like CPT suggested :p
« Reply #1005 on: Wed, 24 April 2013, 15:14:18 »
Well if my wife didn't already spend all my money I'd go for that  :-[ :-X
I just feel stupid I'm sitting here looking at the keyboard and realize there are four extra keys....doh!  :rolleyes:
Offline esoomenona
  • Gnillort?
« Reply #1006 on: Wed, 24 April 2013, 15:15:04 »
Or time to start searching for dem clickclacks.
Offline Tarzan
« Reply #1007 on: Wed, 24 April 2013, 15:18:05 »
I had the same issue with the CM Storm Trigger.  Bought a 104-key set of black side-printed PBT keycaps, then realized there were five additional macro keys on the left.  D'oh!
Realistically, doesn't look too bad with the stock caps on those keys, they're black as well.  Not sure what you'll find to fill in, but there are a lot of options for that row!
Offline blututh
« Reply #1008 on: Wed, 24 April 2013, 15:47:22 »
which is better? thick pbt or abs gmk?
« Reply #1009 on: Wed, 24 April 2013, 15:50:24 »
That's like asking which is better, Ferrari or Lamborghini? :P
They're both awesome.
« Reply #1010 on: Wed, 24 April 2013, 16:03:45 »
Guys is it normal for some keys to have letters than are 'off' take these functions keys as an example, the bottom of the F is partially covered on some of them....
tl;d looking at F6 then the others they look weird
Also are there supposed to be holes in the tops of the keys? You can see the backlight coming through.
« Last Edit: Wed, 24 April 2013, 16:15:08 by ray4jc »
« Reply #1011 on: Wed, 24 April 2013, 16:12:05 »
Omg. I'm putting that in the OP. LMAO
Offline Jocelyn
  • 조셀린
« Reply #1012 on: Wed, 24 April 2013, 16:12:54 »
Lies, one is awesome and one is almost awesome :)
Offline SmallFry
« Reply #1013 on: Wed, 24 April 2013, 16:20:54 »
Moped.
« Reply #1014 on: Wed, 24 April 2013, 16:24:35 »
I've got thick pbts and they're awesome. I'd still prefer some GMK doubleshots though - they're the ultimate caps in my mind.
« Reply #1015 on: Wed, 24 April 2013, 16:30:20 »
I believe that the Ducky caps are just painted so maybe its bad quality control? And maybe those holes are from the tooling? I don't have a Backlit Ducky so I'm not sure
Offline Lunartuna
  • Good bye money!
« Reply #1016 on: Wed, 24 April 2013, 16:49:04 »
The slight imperfections in the legends seems to be common. I have some on my Ducky and some on my GF's Ducky as well.
The small holes on the back of the keycaps is where the caps themselves break off of the plastic sprue.
These are both things that your only going to notice if you are actually looking for them unless you're a dwarf sitting at a high desk with your nose on the keyboard :)
If your looking that hard for imperfections, your going to find them on every keyboard you buy.
Shine 2 TKL - Choc Mini
« Reply #1017 on: Wed, 24 April 2013, 16:54:31 »
 :-[ So what if I'm short  :'(
 :p
no really i am  :confused:
Offline Lunartuna
  • Good bye money!
« Reply #1018 on: Wed, 24 April 2013, 16:55:40 »
Well ****e.  :D
Offline Lunartuna
  • Good bye money!
« Reply #1019 on: Wed, 24 April 2013, 16:56:14 »
Woops! You can't swear on the internet!
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #1020 on: Wed, 24 April 2013, 17:38:57 »
 ray4jc, maybe order some 8bit hearts from tech keys. Color is not the same, but they are the same PBT keys.
Offline heedpantsnow
  • Old enough to know better
« Reply #1021 on: Wed, 24 April 2013, 19:06:23 »
Anyone know if a Cherry G80-8113HRBUS-2 is plate or pcb mounted switches/stabs?  I googled but can't seem to tell from pictures.
I'm back.
Offline bavman
« Reply #1022 on: Wed, 24 April 2013, 19:23:41 »
Looks pcb mounted
« Reply #1023 on: Wed, 24 April 2013, 19:41:48 »
Looks pcb mounted
Thanks, I think so too, but I need to be sure.
I'm back.
« Reply #1024 on: Wed, 24 April 2013, 19:44:18 »
Wait for Lysol to answer. He knows all Cherry. :D
Offline SmallFry
« Reply #1025 on: Wed, 24 April 2013, 20:13:35 »
All Cherry boards are PCB mounted.
« Reply #1026 on: Wed, 24 April 2013, 20:33:56 »
I guess SmallFry will do :D
« Reply #1027 on: Wed, 24 April 2013, 20:40:54 »
why didn't i think about this earlier when i made an order from techkeys.... :confused:
« Reply #1028 on: Thu, 25 April 2013, 07:15:04 »
Generally Cherry G80 is PCB mount, but not ALL of them. Though the platemount models like the 045*, 077*, 092* are not come across too often in the open market. The new 3850 is also a platemount.
However it is still safer to assume it is PCB mount as that is far more common with Cherry. MX 8000 series is all PCB mount.
« Last Edit: Thu, 25 April 2013, 07:18:06 by IvanIvanovich »
Offline SmallFry
« Reply #1029 on: Thu, 25 April 2013, 09:13:10 »
Ah, suppose I knew that. Oh well.
Offline Dreamre
    • kbdlife
« Reply #1030 on: Thu, 25 April 2013, 13:31:26 »
Is there anyway of lubing my switches on my Filco MJ2? Or will I need to unsolder them before I can take the top off?
« Reply #1031 on: Thu, 25 April 2013, 13:34:30 »
There's a lube guide here but I believe you'll have do desolder the switches before lubing them. Some people have said you can flood the switch with lube but it sounds like a bad idea.
Offline Dreamre
    • kbdlife
« Reply #1032 on: Thu, 25 April 2013, 13:36:49 »
Thanks! I guess since the Filco is plate mounted, there is no way of taking the tops off without desoldering it first :(.
« Reply #1033 on: Thu, 25 April 2013, 13:37:53 »
Some plates do allow it but those are custom ones (The_Beast and WFD made those plates IIRC). The stock ones that come w/ the boards don't have those cutouts that allow you to remove the tops.
Offline Dreamre
    • kbdlife
« Reply #1034 on: Thu, 25 April 2013, 13:40:55 »
Ah okay, thanks so much!
Much appreciated! Have a great day :D.
« Reply #1035 on: Thu, 25 April 2013, 13:42:03 »
No worries. Pretty sure I gave you accurate info but check back to see if anyone corrects me :D
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #1036 on: Thu, 25 April 2013, 14:44:12 »
Within the firmware for the Phantom is it possible to reassign keys to mouse clicks and scroll wheel functions?
If so would it be theoretically possible to hack the firmware in a Razer Naga Epic to plug it directly into an additional port on a Phantom so that the firmware just sees this as an extended 10 key pad?
What i would LOVE to do would be this so I can bind Fn commands to the mouse at the firmware level.  The 12 buttons on the side of the mouse show up to the computer as keyboard keys anyway.  Just wondering if this is possible?
Melvang
« Reply #1037 on: Thu, 25 April 2013, 15:05:03 »
Melvang
Isn't that the whole point of the Synapse software?
« Reply #1038 on: Thu, 25 April 2013, 15:12:02 »
wonder if anyone would be interested in trading anything for steam games?
Offline Melvang
« Reply #1039 on: Thu, 25 April 2013, 19:14:19 »
Melvang
It is but there isn't any way to set it up for a modifier key to transfer over to the mouse.  That was why I was wondering if there was a way to plug the mouse into the keyboard as a 10 key extension of said keyboard.
Melvang
Offline speedkills
« Reply #1040 on: Thu, 25 April 2013, 19:54:37 »
Simple questions, simple answers, love this idea and wish every forum had a thread like this.  Here goes my noob questions.  I am building a ergodox and have ordered a set of blue switches but I am not sure if I am going to love them.  The ergodox is a plate mount board (although the pcb supports pcb mounted switches) so knowing nothing about disassembling and modding switches, if I plate mount them do I need to unsolder them to be able to modify the internals, say I wanted to to make my blues ergo clears, or jailhouse blues, could I do that all from on top of the plate, or would it require unsoldering the switches?
If the plate is a problem, could I just use pcb mounted switches instead and just cut out the center part of the layer that has the switch plate so I could get to it easily later?  I want to be able to tweak this keyboard and am ready to solder my switches in but am hesitant now that I am to the stage where I would solder the switches on with the plate in between the switches and the pcb as I really don't want to be in a situation where I have to unsolder every damn switch if I decide I want stiffer springs on my home keys or something like that.
-Shane
« Reply #1041 on: Thu, 25 April 2013, 20:03:01 »
Please dont use this thread for trading/buying/selling. I'm sure if you post in the classifieds you'll find out.
« Reply #1042 on: Thu, 25 April 2013, 21:44:27 »
Sorry, will do!
Back on topic does anyone have a switch keychain collection?
« Reply #1043 on: Thu, 25 April 2013, 21:45:36 »
Sorry, will do!
I'm starting one and I'm pretty sure Sifo's gotta thread in the media subforum with all his hotness XD
Melvang
Melvang
I feel bad since I never know how to answer your questions man. Help a brother out guys ^_^
Offline Dreamre
    • kbdlife
« Reply #1044 on: Fri, 26 April 2013, 11:40:35 »
Does anyone know where I can find an OEM Filco shift key (R1 1x2.75)? Mine came scratched when I bought it :(.
Offline esoomenona
  • Gnillort?
« Reply #1045 on: Fri, 26 April 2013, 11:44:52 »
You could get a black shift, OEM profile, from wasdkeyboards. Might not be a perfect match, but probably as close as you'll get without starting a WTB and hoping someone will break their set, or maybe have to just buy a whole new set. Or join a GB!
Offline Dreamre
    • kbdlife
« Reply #1046 on: Fri, 26 April 2013, 11:51:02 »
Thanks for the reply!
Is the finish from WASD a bit different than the ones from the OEM Filcos? The WASD's look more textured while the OEM Filcos look more satin-smoothish.
I'm a long way from being able to create a WTB tread D: .
Offline Melvang
« Reply #1047 on: Fri, 26 April 2013, 12:08:27 »
So how do you guys store/organize all your extra key cap sets?
Melvang
« Reply #1048 on: Fri, 26 April 2013, 12:11:32 »
Melvang
Closed
Open
And the thread I was talking about earlier was this. More info on those keycap set boxes can be found here.
true would probably work on a non stepped cap though.  I would love to get on IRC with you and bounce some ideas but i have to say I am up WAY past my bed time with working 12 hour days for the next week and a half or so.  Plus its 7pm to 7 am.  I probably can't give you a reliable time of when i will be on this weekend but will be on monday morning after work.
Melvang out for the weekend
You guys are worse crack for me than Farcebook.  and even WoW.
Melvang, I'm often on IRC as well if you wanna hop in and chat about ideas. :D
« Last Edit: Fri, 26 April 2013, 17:35:59 by CPTBadAss »
Offline Melvang
« Reply #1049 on: Fri, 26 April 2013, 12:16:50 »
well i was wondering cause i have a small tackle box (made in the USA) but it is filling up very fast
