Author Topic: Simple Questions, Simple Answers (FAQ in the OP)  (Read 6214294 times)
« Reply #750 on: Mon, 15 April 2013, 15:24:20 »
This is an honest question because I really don't know the answer......
For those with a tenkeyless or smaller keyboard without a dedicated delete key how do you (or do you?) press ctrl-alt-delete....
I'm looking for a board for work and we have to use that key combo to login everytime.
Offline Jocelyn
  • 조셀린
« Reply #751 on: Mon, 15 April 2013, 15:30:05 »
Poker ctrl-alt-delete would be ctrl-alt-FN + Z or FN + /
I usually right click the taskbar instead :)
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #752 on: Mon, 15 April 2013, 15:44:03 »
I use my Poker at work and they have the old ctrl+alt+del to logon, an extra key to press and it is right near the Fn key anyway, it's not really a problem.
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #753 on: Mon, 15 April 2013, 16:18:24 »
Pics or it didn't happen! :D And I'm glad you got your help
[/quote]
Pics will be posted as soon as i get the LED's installed.  Missed the delivery today due to buying a car.  Got me an 03 Park Ave for under 5k
Offline Melvang
« Reply #754 on: Mon, 15 April 2013, 17:54:42 »
here is the pic for ya
Edit:  Missed the delivery for the LED's today will get them tomorrow not sure when I will get a chance to install them.  At the latest this weekend
Offline Capitalistix
  • Cherry MX Green Disciple
    • Uncanny Electronics
« Reply #755 on: Mon, 15 April 2013, 20:32:45 »
So are MX greys non clicky Greens? I.e. do they feel the same withought the sound?
« Reply #756 on: Mon, 15 April 2013, 20:35:56 »
MX Greys are stiffer Clears.
MX Dark Greys are stiffer Blacks.
« Reply #757 on: Tue, 16 April 2013, 12:45:24 »
Hell yeah! That looks awesome. I demand pics of the lit-up LEDs as well :D
« Reply #758 on: Tue, 16 April 2013, 13:07:52 »
There used to be clicky greys with 105cN known as grey36 part number MX1A-B1NW/N. I am not entirely sure when they were discontinued but I think it was around the same time the original whites were. There were also super blues with a deep navy blue color with around 180cN but the part number is unknown to me as I have never seen it mentioned in any catalog or data sheet and may have been a special order switch.
Cherry has the switches listed officially as brown at 55cN, clears at 65cN, while its grey39 counterpart is at 80cN. Similarly with red at 50cN, black at 60cN and grey37 at 80cN. Blue at 60cN with white and green both at 80cN.
« Reply #759 on: Tue, 16 April 2013, 13:10:39 »
Ivan...you're supposed to help me answer questions, not drop this behemoth on my lap!! :P
« Reply #760 on: Tue, 16 April 2013, 13:12:11 »
That was me answering Capitalistix question. TLDR, green and grey have the same spring weight.
« Reply #761 on: Tue, 16 April 2013, 13:13:09 »
I apologize oh wise Cherry master. Please forgive my transgression.
« Reply #762 on: Tue, 16 April 2013, 14:58:04 »
Ok maybe someone can make sense of this.
I didn't like cherry mx reds, browns were ok, blues were nice but I couldn't handle the noise and cherry ml is tolerable.
Where do I go next? clears maybe?
Offline esoomenona
  • Gnillort?
« Reply #763 on: Tue, 16 April 2013, 15:00:18 »
Whites have less noise when they click.
« Reply #764 on: Tue, 16 April 2013, 15:08:24 »
I suggest white with light springs mod. They really are quite nice with a soft click more tactile than browns without the noise of blues.
Offline whiskytango
  • Don't touch the trim
« Reply #765 on: Tue, 16 April 2013, 15:24:49 »
So... would a blue stem with a grey spring be pretty much identical to a green?
« Reply #766 on: Tue, 16 April 2013, 15:50:21 »
Yes, it would be the same thing except the wrong stem color naturally.
Offline Gupgup
« Reply #767 on: Tue, 16 April 2013, 15:52:07 »
How many Rosegold Ironman are there?
Gupgup
Offline CommunistWitchDr
  • >implying keyboards
« Reply #768 on: Tue, 16 April 2013, 15:52:54 »
With a pure it's fn+shift
Don't use it on linux anyway though.
« Reply #769 on: Tue, 16 April 2013, 16:01:46 »
I second this motion. I tried ergo-whites on the universal switch tester and they were phenomenal. I liked than way more than ergo-clears.
Gupgup
The last sale of girldc caps on TechKeys had 10 or 20 of each set of caps. I believe anything metallic had a count of 10 and anything else had 20. But the only person who would truly know is girldc. You may want to ask this in the Team Redline subforum, in the "Post your girldc" caps, or PM girldc/someone from TeamRedline.
Offline Gupgup
« Reply #770 on: Tue, 16 April 2013, 16:06:02 »
Gupgup
The last sale of girldc caps on TechKeys didn't have any rosegold ironmen :/
Gupgup
« Reply #771 on: Tue, 16 April 2013, 16:22:09 »
GupGup, I'm using that sale as a reference to how many were made.
Offline Gupgup
« Reply #772 on: Tue, 16 April 2013, 16:28:25 »
Ahhhh I thought you meant how man rosegolds were made, my bad!
I PMd girldc :D
Gupgup
Offline Lighthouse1
« Reply #773 on: Tue, 16 April 2013, 18:01:32 »
Very newbie question, how easy is replacing the top cover on a TKL Filco or CM keyboard?
There's a thread about purchasing a coloured top for a board and I like the idea (I am lost, first it was new keys..now cases, this is like drugs) but I am not sure how difficult or otherwise it is, I build my own PCs etc so I am not completely stupid with unscrewing stuff with circuits in it, but I don't want to break my keyboards into bits accidentally.
Thanks for answering the dumb Q!
Offline Gupgup
« Reply #774 on: Tue, 16 April 2013, 18:21:12 »
Hey there, I was just about to reply in the GB :D
It is very easy! There are two little tabs you can pop up on the top and bottom of the case using a credit card or something.
Gupgup
Offline ComradeSniper
  • HHKB Pro
« Reply #775 on: Tue, 16 April 2013, 20:19:34 »
This isn't exactly keyboard related, but do posts on off topic not add to your post count? I noticed I have been stuck at 155 for a little while.
Offline Dubsgalore
« Reply #776 on: Tue, 16 April 2013, 20:23:52 »
>156
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #777 on: Tue, 16 April 2013, 20:24:26 »
Gupgup
Don't forget one screw in the bottom of the case.
Depends on which thread, I think.
« Reply #778 on: Tue, 16 April 2013, 20:34:29 »
No they dont.
  • HHKB Pro
« Reply #779 on: Tue, 16 April 2013, 20:40:06 »
No they dont.
Ok, that makes sense then.
Offline Lighthouse1
« Reply #780 on: Wed, 17 April 2013, 09:59:54 »
Gupgup
Excellent thanks, I asked here as after I posted in your GB thread I thought it was a really stupid question! Thanks for the answer and now for the order form!
Thanks also to tjcaustin I would have been there breaking my credit card without the screw info. :)
« Reply #781 on: Wed, 17 April 2013, 10:06:06 »
Gupgup
There are very few stupid questions. I made this thread so that people could freely ask things and I could learn in the process. No worries man :D
Offline Lighthouse1
« Reply #782 on: Wed, 17 April 2013, 10:08:21 »
Excellent, its very useful to have somewhere to noob  :D
« Reply #783 on: Wed, 17 April 2013, 10:09:45 »
Just FYI, I'm pretty new myself. Only been on GH for 4 months. I just spam like I'm trying to catch SmallFry in the post race.
Offline SmallFry
« Reply #784 on: Wed, 17 April 2013, 10:27:25 »
Your tries are futile young one.
« Reply #785 on: Wed, 17 April 2013, 10:28:44 »
As my keyboard professor, you're supposed to encourage me. Not tell me my efforts are futile.
« Reply #786 on: Wed, 17 April 2013, 10:34:14 »
 If I'm looking at keyboards on a site like buychina.com or offerany.com i know that tea axis = brown and most say that green actually means blue so how do I find green?
And no I haven't been drinking....
« Reply #787 on: Wed, 17 April 2013, 10:37:57 »
Why not use google translate to get the word for brown or green and then search for it on taobao?
« Reply #788 on: Wed, 17 April 2013, 10:41:30 »
Did that and so far it only seems to be getting be backlighting colors....not switch colors
« Reply #789 on: Wed, 17 April 2013, 10:47:07 »
Jocelyn, didn't you post something on how to search Taobao somewhere? Can you help me out? :D
« Reply #790 on: Wed, 17 April 2013, 10:57:06 »
http://www.offerany.com/p-16969507670-87-108-Keyboard-37-Hat.html
Well I found this one and one of the options is "Blu-ray ONE108 milk axis" so that would most likely be a full size board with white switches....
Offline Melvang
« Reply #791 on: Wed, 17 April 2013, 11:52:55 »
Could someone post a pic of the switch housing disassembly tool that The_Beast sold through his GB?  The pics on the thread are all broken aside from one that just shows the end of them.
« Reply #792 on: Wed, 17 April 2013, 11:55:13 »
I got a set over the weekend. I'll take pics for you later.
Offline Melvang
« Reply #793 on: Wed, 17 April 2013, 12:18:55 »
cool thanx
Offline mushupork
  • I am not knowing
« Reply #794 on: Wed, 17 April 2013, 13:36:46 »
is there a "how to" for posting an embedded you tube video on Geekhack?  (like for the "what are you listening to now thread")
Wanted:  Windowed capslock for a QFR
Offline lazerpointer
  • ya gotta stay phresh
« Reply #795 on: Wed, 17 April 2013, 13:48:12 »
19059-0
i type, therefore i geekhack
Offline mushupork
  • I am not knowing
« Reply #796 on: Wed, 17 April 2013, 13:57:44 »
Yes, I see the button but it does not appear to work.
Find video, copy URL, click You Tube button, paste URL, all you get is the following line of text ... no embedded video
Not a valid youtube URL
« Reply #797 on: Wed, 17 April 2013, 14:00:17 »
You MUST use the short url youtu.be/whatever or it won't work.
Offline mushupork
  • I am not knowing
« Reply #798 on: Wed, 17 April 2013, 14:05:22 »
Excellent - thanks Ivan
Offline Tarzan
  • formerly known as Greystoke
« Reply #799 on: Wed, 17 April 2013, 14:15:55 »
I've tried that a couple of times, and the post does show a blank "video" window.  Only one problem, there's no video.  Gives me an "unexpected error, try again later" message when I click on it.
