Author Topic: Simple Questions, Simple Answers (FAQ in the OP)  (Read 6214679 times)
« Reply #500 on: Thu, 04 April 2013, 06:48:30 »
Heat guns are meant for melting solder paste,  not desoldering normal solder.
Offline iri
« Reply #501 on: Thu, 04 April 2013, 07:42:48 »
hmmm, i can desolder a 104 in an hour or so. qfr is a tkl board, isn't it?
Try heat gun, it should help clear pcb of switches in few minutes.
may a welder be even faster?
Terrible advice, unless you'd rather have melted switches.
do you use the same desoldering iron tip to desolder bigger and smaller joints? i found that my desoldering iron removes bigger joints very effectively, but isn't that good on smaller ones; sometimes applying wick is required. or is there a technique to desolder all sizes of joints with the same tip?
also -- do you plan to upload your lubing videos? i really look forward to know why proper lubing takes 1.5 hours.
-Ray Bradbury
« Reply #502 on: Thu, 04 April 2013, 07:45:33 »
Rofl iri. You're right, a welder is sure to speed the process up   ;)
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #503 on: Thu, 04 April 2013, 08:04:30 »
Ha. Yes it will be great if you only want to disassemble and not use anything at all afterwards.
Offline iri
« Reply #504 on: Thu, 04 April 2013, 08:15:12 »
sure. who needs those damn switches and pcb's.
-Ray Bradbury
« Reply #505 on: Thu, 04 April 2013, 08:32:14 »
I recently desoldered a complete 101-key board in only 15 minutes. Oh yeah, forgot to mention I was using my Hakko 808 desoldering gun.
I use the same tip for all solder joints. I usually have to add solder to smaller joints, such as LEDs, etc., to remove the solder effectively. I have never been able to use braid.
Offline iri
« Reply #506 on: Thu, 04 April 2013, 09:42:37 »
uh huh. i can buy a $170 desoldering station any day.
-Ray Bradbury
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #507 on: Thu, 04 April 2013, 09:50:03 »
I have been using the radio shack desoldering gun working so far for me just a novice on it.  the mistakes i have made with it was all operator error not equipment malfunction.  Speaking of which any suggestions on cleaning it if it needs it??
Offline iri
« Reply #508 on: Thu, 04 April 2013, 09:51:48 »
use a wire brush, luke.
-Ray Bradbury
« Reply #509 on: Thu, 04 April 2013, 09:53:44 »
When the tip gets dirty while you're soldering, you can also try wiping on a sponge that's wetted with water.
« Reply #510 on: Thu, 04 April 2013, 10:21:12 »
Also, buy out Radio Shack of all the replacement tips they have. Before I got my Hakko, I would do this every time I went into Radio Shack. The tips wear out after about a keyboard-and-a-half, even with cleaning. I have some that have a hole worn through the side of the tip.
Offline The_Beast
  • I like wood ಠ_๏
« Reply #511 on: Thu, 04 April 2013, 10:22:27 »
Then you're getting cheap tips. I've soldered at least 3 pokers and haven't replaced a tip and this was a soldering iron in a lab, so I'm sure I wasn't the only one using it
« Reply #512 on: Thu, 04 April 2013, 10:26:19 »
You were using the Radio Shack iron with bulb? There is only one option for tips for those...
« Reply #513 on: Thu, 04 April 2013, 10:29:02 »
The Radioshack desolder tips suck, they are made out of poor brass alloy and get all melted and deformed by the hot solder. Especially old lead free solder, will destroy them really fast.
Offline The_Beast
  • I like wood ಠ_๏
« Reply #514 on: Thu, 04 April 2013, 10:29:28 »
Nope, a decentish Weller. It's the station with coiled iron holder, the sponge underneath and a temp dial
Offline boost
  • BOSTMOBILE
  • NY Giants!!!
« Reply #515 on: Thu, 04 April 2013, 10:32:02 »
Need the standoff height on the poker case. This is where the PCB screws into th case
-Enzo Ferrari
« Reply #516 on: Thu, 04 April 2013, 14:11:08 »
Anyone know where you can buy MX Whites or what the Chinese word is for them (I know they call them Milks) so I can find them on Taobao?  I'm thinking of getting the GH60 and putting whites on it.
Also, any recommendations on dremel tips for modding a plate so that the Cherry housing can be removed without desoldering?
Offline Jocelyn
  • 조셀린
« Reply #517 on: Thu, 04 April 2013, 14:16:09 »
I've searched high and low on Taobao, and have not found any MX White (Milk) Switches.
Offline Dubsgalore
« Reply #518 on: Thu, 04 April 2013, 14:27:04 »
Mx whites were on QWERkeys...not sure if they still are
« Reply #519 on: Thu, 04 April 2013, 14:36:17 »
Just checked and they are, but it would be obscenely expensive.  It would be cheaper to buy a Pure with whites from MechanicalKeyboards.com and harvest the switches from that than to buy the switches from Qwerkeys.  I'd almost rather just go with some cheap used Clears again, buy some used Blues and experiment with ways of muffling the click, or toss my Clear springs in Reds and use those.
« Reply #520 on: Thu, 04 April 2013, 14:42:12 »
Best source for switches is through 7bit, but you might have to wait awhile for certain types.
« Reply #521 on: Thu, 04 April 2013, 14:46:30 »
Is he on here too or just DT? And the GH60 is still a little while out, so waiting a little while shouldn't be too much of an issue unless we're talking 6 months to a year.
« Reply #522 on: Thu, 04 April 2013, 14:47:16 »
They have an account here, but I am not sure if they visit here as often. I think they are working on supplying switches along with the GH60 pcbs and such also.
« Last Edit: Thu, 04 April 2013, 14:53:21 by IvanIvanovich »
Offline mushupork
  • I am not knowing
« Reply #523 on: Thu, 04 April 2013, 16:31:12 »
Can anyone link to a photo or diagram of a Poker and a Pure keyboard side by side to show the difference in key layout?  (Single picture)
Wanted:  Windowed capslock for a QFR
« Reply #524 on: Thu, 04 April 2013, 16:36:09 »
Are you sure the Pure has whites? They said that the new Ducky had whites and it was a mistranslation. The switches turned out to be clears. They said the same might happen with the Pures and were waiting on the shipment to verify.
I'm at work so I can't make a single picture for you but try these links:
Pure
Poker
Pure has a shoft right shift and I think Smallfry said the top row of keys had a weird profile.
Offline esoomenona
  • Gnillort?
« Reply #525 on: Thu, 04 April 2013, 16:38:09 »
« Last Edit: Tue, 27 October 2015, 09:10:04 by esoomenona »
« Reply #526 on: Thu, 04 April 2013, 16:38:21 »
Only difference between Poker and Pure is the right shift / tilde key.
« Reply #527 on: Thu, 04 April 2013, 16:59:59 »
Nope, I'm not sure.  I know the whole Clear/White thing makes for fun with Chinese orders.  I'd love some Whites, but I really don't want to spend more than $50, $60 on the high end, for them for the GH60.  If I can't find them, I'll just toss my Clear springs in the Reds I have and toss them on the GH60.  That will be free.
« Reply #528 on: Thu, 04 April 2013, 17:02:37 »
Why is it Alps keyboards feel better to type on when they're in your lap?
Offline remedyhalopc
« Reply #529 on: Thu, 04 April 2013, 17:50:26 »
does anyone know what type of LEDs I should be buying for my QFR? I want to get a less bright or less harsh color. Maybe Amber or blue.
« Reply #530 on: Thu, 04 April 2013, 17:58:41 »
I like these personally for LED. The 'blue lagoon' color is pretty nice.
Offline mushupork
  • I am not knowing
« Reply #531 on: Thu, 04 April 2013, 18:16:54 »
Thanks anonemoose!  I thought there was more difference.  Maybe in the function layers?
« Reply #532 on: Thu, 04 April 2013, 18:22:21 »
Yes, the function layers are different. But the only difference in physical layout is what moose pictured. :)
« Reply #533 on: Thu, 04 April 2013, 21:19:56 »
Binge, what you like to do in your lap is not really anyone's business on GH but your own :P
Offline Permeability
« Reply #534 on: Fri, 05 April 2013, 11:21:08 »
What keyboards allow you modify the switches without desoldering? (Besides the Poker)
Keyboards:
'The Cheat' - lubed 62g Clears
Ducky Shine 3 TKL lubed 45g Reds (Work)
« Reply #535 on: Fri, 05 April 2013, 11:23:08 »
I believe that it depends on the plate in the keyboard. I'm not sure a stock poker allows you to mod the switches.
Offline The_Beast
  • I like wood ಠ_๏
« Reply #536 on: Fri, 05 April 2013, 11:23:20 »
Most cherry boards are PCB mount
Offline Jocelyn
  • 조셀린
« Reply #537 on: Fri, 05 April 2013, 11:23:33 »
Anything that doesn't have a plate or LEDs. Sorry for not having a list :)
Offline The_Beast
  • I like wood ಠ_๏
« Reply #538 on: Fri, 05 April 2013, 11:24:31 »
It does except for the 7 keys that have LEDs
Caps, ~, spacebar, Rwin, menu, Rctrl, Rshift
« Reply #539 on: Fri, 05 April 2013, 11:35:56 »
You can change switch internals easily on
PCB mount:
Vortex Poker, Pure, Race
Cherry G80-XXXX
Plum 96, Neo Zelia
Kit boards
« Reply #540 on: Fri, 05 April 2013, 11:39:54 »
I'm lazy and on my phone. So I'm just going to quickly ask. Looks like the plate with ergodox is capable of switch swapping. True or false.
« Reply #541 on: Fri, 05 April 2013, 11:52:13 »
true.. says so on the massdrop page
« Reply #542 on: Fri, 05 April 2013, 12:21:33 »
danke mein fraulein
Offline esoomenona
  • Gnillort?
« Reply #543 on: Fri, 05 April 2013, 12:35:33 »
Boards with modified plates, a la WFD's Universal plate.
Offline Joxx
« Reply #544 on: Fri, 05 April 2013, 12:52:39 »
Very noobish question, is it possible to buy a keycaps set and rearrange the letters around? (I own an azerty keyboard).
Ducky 9087 MX Brown | Blackwidow  MX Blue  | CM TK MX Red | Looking for a QFR MX Blue!
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #545 on: Fri, 05 April 2013, 12:53:37 »
yes, but the profile of the keys can be different and lead to an uneven typing surface.
Offline Joxx
« Reply #546 on: Fri, 05 April 2013, 12:54:51 »
So basically, it's pointless for me to buy a set of keycaps since I'll have a high chance of not having an even typing surface or am I misunderstanding?
« Reply #547 on: Fri, 05 April 2013, 12:57:24 »
The profile of the a and the q caps are different. So if you swap them they'll be slightly off when you type. You can do it. But it won't be even. I had cherry alphas with OEM mods and the differences in keycap heights annoyed me so much I sold my alpha caps. You might not be bothered though.
Offline Joxx
« Reply #548 on: Fri, 05 April 2013, 13:00:06 »
I most likely will be bothered by it lol. Anyway thanks for the replies, I guess I won't be able to custom my keys besides the F's and the esc button lol.
Offline Jocelyn
  • 조셀린
« Reply #549 on: Fri, 05 April 2013, 13:00:57 »
This OMG this^
I would just but a second set of blanks if possible and use those for any "off keys". You could always go with all blanks as well :)
