Author Topic: Simple Questions, Simple Answers (FAQ in the OP)  (Read 6214163 times)
Offline jincuteguy
« Reply #400 on: Mon, 25 March 2013, 14:28:39 »
Das I was a dome board, Das II was a Cherry stabilized board, and the Das III is a Costar Stablized board. The Das II internals can be swapped with a G80-3000 (winkey) internals.
Where do you see DAs II and III? I went to their website and all I saw was the Clicky and the Silent version!
Offline jincuteguy
« Reply #401 on: Mon, 25 March 2013, 14:52:44 »
Also, does anyone know where I can get custom keycap for backlit keyboard? Like the LED underneath the keycap will shine through?
I looked at WASD website for keycaps, but I couldn't find any information, all i saw was the option for either Laser Etched or Engraved? any help would be appreciated.
« Reply #402 on: Mon, 25 March 2013, 14:55:44 »
Please don't doublepost, just edit your old posts. You might be able to snag a set of Ducky's caps or I think you c an get transluscent caps from SignaturePlastics.
Offline jincuteguy
« Reply #403 on: Mon, 25 March 2013, 15:05:32 »
Yea I don't want to get those transluscent caps, I just want whatever the legend ie. letter or picture on the keycap get shined through.  So I guess Ducky is the only company that made these.  I thought WASD is the best when it comes to keycaps.
Offline esoomenona
  • Gnillort?
« Reply #404 on: Mon, 25 March 2013, 15:18:07 »
« Last Edit: Tue, 27 October 2015, 09:14:43 by esoomenona »
« Reply #405 on: Mon, 25 March 2013, 15:26:11 »
There's no "best" when it comes to buying keycaps. It is very dependent on what you're looking for.
Offline MJ45
  • HHKB Pro
« Reply #406 on: Mon, 25 March 2013, 15:48:17 »
Realforce keyboards have a dip switch setting to enable firmware update, has anyone done that ? If so where is the driver or flash come from Topre?
Offline esoomenona
  • Gnillort?
« Reply #407 on: Mon, 25 March 2013, 15:52:10 »
« Last Edit: Tue, 27 October 2015, 09:14:54 by esoomenona »
Offline scumyc
« Reply #408 on: Mon, 25 March 2013, 16:04:59 »
quick noob question: were vintage blacks made for plate mount, pcb mount (with the little plastic legs), or both?
Offline SmallFry
« Reply #409 on: Mon, 25 March 2013, 16:05:51 »
They are mainly plate, they came from WYSE terminal keyboards. Welcome to Geekhack, by the way. :)
Offline mushupork
  • I am not knowing
« Reply #410 on: Mon, 25 March 2013, 16:29:05 »
Who on this forum has done bolt modding for others?  (I got a Model M board before the forum crashed and now I cannot check via PMs etc. to find out who I dealt with :D)
Wanted:  Windowed capslock for a QFR
Offline SmallFry
« Reply #411 on: Mon, 25 March 2013, 16:30:25 »
Fohat.Digs has done them before, I was going to, but have not done so yet. So many rivets for so few that are broken. I know that dfj has also done them, though you'd have to hit him up on the IRC.
Offline esoomenona
  • Gnillort?
« Reply #412 on: Mon, 25 March 2013, 16:31:23 »
« Last Edit: Tue, 27 October 2015, 09:15:06 by esoomenona »
« Reply #413 on: Mon, 25 March 2013, 16:36:21 »
And another question: how do you know when a Model M needs a bolt mod? And what does a floss mod do?
Here's a link on the Floss Mod.
And here are some links for the Bolt Mods:
Offline SmallFry
« Reply #414 on: Mon, 25 March 2013, 16:38:52 »
Moose, bolt mods are only to replace the rivets once they've broken off from being brittle. There's also layout changes that you can do, but people don't typically mod to ANSI from ISO or vice versa since both flavors can be had in rather abundant sources.
« Reply #415 on: Mon, 25 March 2013, 18:08:34 »
What's the size of a TKL board in percent? Is it 80%?
« Reply #416 on: Mon, 25 March 2013, 21:19:47 »
From IRC. SmallFry determined TKL should be 84%; although I'm sure 80% would work just as well. Math is sexy
« Last Edit: Mon, 25 March 2013, 21:21:18 by CPTBadAss »
Offline The_Beast
  • I like wood ಠ_๏
« Reply #417 on: Mon, 25 March 2013, 21:49:35 »
Well then a poker is a 58%
So should we rename it the GHsomewherebetween57%and62%
Offline Jocelyn
  • 조셀린
« Reply #418 on: Mon, 25 March 2013, 21:51:38 »
59% You need to round 58.65 up :)
Offline bazemk1979
« Reply #419 on: Mon, 25 March 2013, 21:55:20 »
They're older versions. The current one is either considered the 3rd revision, or 4th, depending on who you ask. It looks the same, but is made by a different company and has some differences, the most notable being the media keys. Here you can see revs 1, 2, and 3.
wow rev 1 looks like IBM case, did Unicomp made that case?
Offline The_Beast
  • I like wood ಠ_๏
« Reply #420 on: Mon, 25 March 2013, 21:56:54 »
Well suck it :P
:P
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #421 on: Mon, 25 March 2013, 21:59:14 »
Except the GHwhateversizeitis would have a different number depending on what layout you choose.  The one I'm going with, for example is 57.69230769230769230(it keeps going)%.  Going by number of keys on the board is stupid.
In fact, tkl would be two sizes based on that (at minimum), too because of winkey vs winkeyless.
« Reply #422 on: Mon, 25 March 2013, 22:05:02 »
I'm making the executive decision and calling TKL boards 80%. :P
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #423 on: Mon, 25 March 2013, 22:07:18 »
No, I outrank you as King.
I demand sacrifice.
Offline The_Beast
  • I like wood ಠ_๏
« Reply #424 on: Mon, 25 March 2013, 22:13:08 »
I demand sacrifice.
King of purple stepping in on this matter
TKL stays TKL
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #425 on: Mon, 25 March 2013, 22:19:19 »
I demand sacrifice.
TKL stays TKL
I conferred with my queen, Scarlett Johansen eating popcorn, and I agree with my fellow King.
« Reply #426 on: Mon, 25 March 2013, 22:20:42 »
I thought jdcarpe was King of Purple @.@
« Reply #427 on: Mon, 25 March 2013, 22:24:14 »
Screenshotted as proof if I decide to call my case something including 80.
Offline Novus
  • Formerly the1onewolf
  • Mondai nothing~
« Reply #428 on: Mon, 25 March 2013, 23:05:46 »
I demand sacrifice.
TKL stays TKL
Scarlett Johansson > Scarlett Johansen
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #429 on: Mon, 25 March 2013, 23:07:21 »
I demand sacrifice.
TKL stays TKL
That's where I'm afraid that you're completely correct.
I knew I should have googled it.
« Reply #430 on: Mon, 25 March 2013, 23:45:48 »
I decree that all purple TKL keyboards be deemed 80%.
Further, that purple GH60s of any layout configuration are considered 60%.
As it is written, so shall it be.
Offline jincuteguy
« Reply #431 on: Tue, 26 March 2013, 02:14:08 »
I'm looking at the Max Nighthawk X8 and X9 keyboards.  Does anyone know if these have CoStar stabilizers or Cherry?
Offline Novus
  • Mondai nothing~
« Reply #432 on: Tue, 26 March 2013, 02:22:46 »
I see your spock avatar.
IDIC
Offline BlueBär
« Reply #433 on: Tue, 26 March 2013, 08:01:00 »
Are there any cons of using a backlit keyboard? Haven't really found anything about it but I know that I read somewhere that it could make it harder to change the switch if you would want to or something similar. I'm close to pull the trigger on a KBT Pure with browns, with or without blue backlight. This will be my first mech (or my second if you count the Model M) btw.
Offline esoomenona
  • Gnillort?
« Reply #434 on: Tue, 26 March 2013, 08:01:32 »
How long does it generally take for laser etched legends on Cherry caps to start wearing off? I feel bad for typing on them knowing that they're in nice shape and one of the rarer(?) sets I have...
Offline esoomenona
  • Gnillort?
« Reply #435 on: Tue, 26 March 2013, 08:03:35 »
Almost all backlit boards I've seen have been plate mounted, so swapping switches is a bit rough in and of itself, requiring desoldering of the switch to do so (unless you have installed a custom plate that makes it easier to swap the switches, and even then, you would have had to desolder at least once). LEDs generally have to be desoldered to be able to remove the switch, but you can modify the top of the housing to be able to remove the switch around the LED.
Also, just read more of your post. A Pure would require you to desolder all of the LEDs to swap the stems and springs out, or you would have to mod the housings. It's not that hard to do. Just a couple clips with something, or a Dremel, as someone else suggested.
« Reply #436 on: Tue, 26 March 2013, 08:58:53 »
According to this thread, they use Costar stabilizers.
If you look on Youtube for a review, maybe you can find a video of someone pulling the caps off so you can see em. Just to double check.
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #437 on: Tue, 26 March 2013, 09:42:36 »
All iOne made keyboard use costar like stabilizer.
Offline esoomenona
  • Gnillort?
« Reply #438 on: Tue, 26 March 2013, 10:37:05 »
Laser etched POM to be exact.
Offline iri
« Reply #439 on: Tue, 26 March 2013, 11:05:11 »
irrelevant answer was here
-Ray Bradbury
Offline Skull_Angel
« Reply #440 on: Tue, 26 March 2013, 16:49:11 »
I've had some laser etched letters on POM keycaps start fading after a couple of months with heavy use. My fingers don't normally put out a lot of oils, but can during heated gaming; I do practice good keyboard hygiene most of the time though, so not a sloppy person. They just don't last well with heavy use.
Offline esoomenona
  • Gnillort?
« Reply #441 on: Tue, 26 March 2013, 16:50:32 »
I figured as much. Did you notice much wear on the caps themselves, aside from the legends?
Offline Skull_Angel
« Reply #442 on: Tue, 26 March 2013, 16:59:51 »
Nope, the material (POM) is solid, not a hint of wear; they should also take much longer to (completely) shine than standard ABS (most POM normally have a bit more base shine than ABS that I'm aware of).
Offline esoomenona
  • Gnillort?
« Reply #443 on: Tue, 26 March 2013, 17:02:17 »
Yes, this is my second set of POM caps, and I do notice the base shine, as you mention. Perhaps I'll swap them out with some Cherry DS. Or maybe I should just type on them, being that I enjoy looking at them.
Offline mushupork
  • I am not knowing
« Reply #444 on: Wed, 27 March 2013, 13:55:42 »
Is it true that on a keyboard with PCB mounted switches you change from Blue switches to Brown by just swapping out the stems and springs?  (no soldering)
Offline esoomenona
  • Gnillort?
« Reply #445 on: Wed, 27 March 2013, 13:56:45 »
Yes sir. You can take a look at my thread, Moose's Mods, to see me doing just that. You can also do the same thing with plate mounted boards that have specialized switch openings to allow it.
« Reply #446 on: Wed, 27 March 2013, 13:57:21 »
Can you provide a link?
Offline mushupork
  • I am not knowing
« Reply #447 on: Wed, 27 March 2013, 14:05:32 »
^^ yeah what he said :D
Offline esoomenona
  • Gnillort?
« Reply #448 on: Wed, 27 March 2013, 14:54:16 »
I mean, I'll provide a link, but I gave you the exact title, and it took me exactly what it would've taken you to find it...: type that shiz into the search bar.
But here you go: http://geekhack.org/index.php?topic=41162
« Reply #449 on: Wed, 27 March 2013, 14:59:12 »
My bad Moose, I was in a meeting before. Couldn't really search.
