Author Topic: Simple Questions, Simple Answers (FAQ in the OP)  (Read 6213535 times)
0 Members and 6 Guests are viewing this topic.
Offline DavinDidIt
« Reply #200 on: Wed, 13 March 2013, 18:04:44 »
Do metal cases for Ducky exist? Aluminum or SS?
I was thinking of trying to mod a filco/vortex aluminum case until I noticed the LED holes on the front.
Nope :(
but if you can get it made, let me know!
KMAC 2, HHKB
« Reply #201 on: Wed, 13 March 2013, 18:06:27 »
Nope :(
Pretty sure the custom metal cases you see are for TKL/60% only and even then it's only for a few boards, Ducky not being one of them.
Offline Jocelyn
  • 조셀린
« Reply #202 on: Wed, 13 March 2013, 20:29:07 »
Poker question. I'm using my left Win key as function, which works fine, but I can't switch L FN and ALT and I'd really like to (Alt changes and works, but FN doesn't work). Probably not a simple question, but my L CTRL Caps lock switch is also not working. Is it possible dip switches 2 & 3 could be broken? 1 & 4 currently work.
« Last Edit: Wed, 13 March 2013, 20:34:55 by Jocelyn »
« Reply #203 on: Wed, 13 March 2013, 20:34:52 »
Simple Questions Jocelyn!! Just kidding, lemme see if I can scrounge an answer up or if someone else pops in with some knowledge.
Offline SmallFry
« Reply #204 on: Wed, 13 March 2013, 20:37:41 »
SmallFry to the rescue! http://geekhack.org/index.php?topic=32804.0 The poker manual is wrong, some of the dip switches are backwards.
« Reply #205 on: Wed, 13 March 2013, 20:38:46 »
Did you unplug the Poker before changing the DIP switch setting?
Offline Jocelyn
  • 조셀린
« Reply #206 on: Wed, 13 March 2013, 20:50:20 »
Yes, I'm already aware of it being backwards. Thanks SmallFry :)
Yes. I even tried unplugging for a minute lol.
So individually, 1 and 4 do what they're supposed to do, while 3 kinda works and 2 doesn't work at all.
3 - FN_L(Window L) , ALT_L Swap Position (per backwards manual) Alt changes, while L WIN/L FN does not. I've tried it with WIN and FN and neither work as the inside key.
I want my FN Keys on the inside :(
2 - Caps Lock , Ctrl L Swap Position (per backwards manual) no swapping at all. I could live without this one, but I was surprised when it didn't work.
Edit - Rebooted and now 2 is working! Will edit again in a minute :)
« Last Edit: Wed, 13 March 2013, 20:52:58 by Jocelyn »
Offline The_Beast
  • I like wood ಠ_๏
« Reply #207 on: Wed, 13 March 2013, 20:55:14 »
That sucks. I love mine with 1 and 3 on. That gives me FN keys to the left and right of the spacebar. It takes away one of my alts, but I don't use it that often anyways
Offline Jocelyn
  • 조셀린
« Reply #208 on: Wed, 13 March 2013, 21:05:19 »
Yes, I really wish I knew what was going on, I want 1 & 3!!!!
So 1,2, and 4 work, while 3 swaps Fn/Win with Alt and allows alt to work, but I get no Win or Fn. Win/Fn and Alt do work in their normal position with 3 off, so hmmm wonder what it could be.
Thanks everyone...
Edit - It's almost as if 4 (Win Lock) is traveling with 3 even though it's not.
Could they possibly be tied together on my Poker somehow, as in 3 does 3 & 4 and 4 does 4? My guess is no, but you people who solder would know more than me.
« Last Edit: Wed, 13 March 2013, 21:56:42 by Jocelyn »
Offline Jocelyn
  • 조셀린
« Reply #209 on: Thu, 14 March 2013, 16:19:52 »
So do I own a retarded Poker? :(
Offline esoomenona
  • Gnillort?
« Reply #210 on: Thu, 14 March 2013, 16:22:50 »
It's okay, Jocelyn. Mine is kind of retarded as well. My g is pretty lame. A little hard to get it to register consistently.
« Reply #211 on: Thu, 14 March 2013, 16:23:54 »
Who knows? I don't use the DIP switches, specifically because of these issues. This is one of two main reasons we created the GH60, so that you can program every key to what YOU want it to be. :P
Offline Jocelyn
  • 조셀린
« Reply #212 on: Thu, 14 March 2013, 16:26:35 »
Thanks for the encouragement you two lol :)
« Reply #213 on: Thu, 14 March 2013, 16:29:45 »
See what happens when you ask complicated questions? Your keyboard is designated as retarded! :P
Offline esoomenona
  • Gnillort?
« Reply #214 on: Thu, 14 March 2013, 16:30:46 »
jd, can I program my g to be a g?
« Reply #215 on: Thu, 14 March 2013, 16:40:26 »
Hey if that's what you're into, who am I to judge?
Offline WarNutts
« Reply #216 on: Fri, 15 March 2013, 01:23:51 »
I'm confused about keycap "profile"
If I get dyesub thick pbt's and vortex dye sub pbts will they be matching sets in terms of height and how they fit on my keyboard?
Im currently using a filco with regular caps.
Offline Jocelyn
  • 조셀린
« Reply #217 on: Fri, 15 March 2013, 01:27:38 »
They will match only if you buy the Vortex dye sub pbt from Feng's GB (white, blue, purple, light gray, rainbow, etc,.) Vortex black on black dye sub pbt is higher oem profile and thin unlike the other two sets you mentioned.
Offline iri
« Reply #218 on: Fri, 15 March 2013, 03:07:28 »
you own a female poker!
-Ray Bradbury
« Reply #219 on: Fri, 15 March 2013, 07:08:26 »
...and we have a new master troll
Offline Gupgup
« Reply #220 on: Fri, 15 March 2013, 10:19:41 »
How much is a bloodbath brobot worth?
« Reply #221 on: Fri, 15 March 2013, 10:25:07 »
Please use this thread for Price Checks.
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #222 on: Fri, 15 March 2013, 10:40:32 »
WarNutts, it depends which Vortex set are you referring to? They have had both OEM and Cherry profile set.
Offline mushupork
  • I am not knowing
« Reply #223 on: Fri, 15 March 2013, 11:08:32 »
The "GMK/Cherry doubleshot modifer packs" Group Buy ... http://geekhack.org/index.php?topic=41017.90
Seems like a lot of keys are included but many of them are variations on the same key.  Is that to accommodate all the different size of keys on various boards?
For example, I like the idea of CMYK modifiers but unless I am missing something (very possible) it is looks like you get 16 keys total but only 6 would be usable on a particular board (2 x Shift, 2 x CTRL, 2 x Alt) depending on the board's particular key spacing/layout.
CMYK (black on color keycap) modifiers pack - 16 key set - price: €25.00 / $33.00
    Shift – Yellow (4 keys):  1.25, 1.75, 2.25, 2.75 B profile
    Ctrl – Magenta (6 keys; 2x each):  1.0. 1.25, 1.5 B profile
    Alt – Cyan (3 keys; 1x each):  1.0, 1.25, 1.5  B profile
    Alt Gr – Cyan (3 keys; 1x each):  1.0, 1.25, 1.5  B profile
Order Form: https://docs.google.com/spreadsheet/viewform?formkey=dEZqaXRZUUFXcExHRGhvbjBucEpkY0E6MQ#gid=0
Wanted:  Windowed capslock for a QFR
Offline The_Beast
  • I like wood ಠ_๏
« Reply #224 on: Fri, 15 March 2013, 11:10:56 »
Yes, it accommodates more people which should lead to more orders.
Plus instead of have 3 different kits, you only have one. It makes the kit slightly more expensive, but then you don't need to hunt for those rare kits once you get a board with a unique layout (which you more than likely will, even if you don't think you will now)
« Reply #225 on: Fri, 15 March 2013, 11:15:27 »
Right, so one set fit all. You could use it on a Filco or similar with 1.25 in ANSI or ISO, older winkeyless, kit or stuff like iOne with 1.5 ANSI or ISO, or non standard like Choc mini that have both 1.5 and 1, and G80-1800 with 1 unit. I just piled it all into one set to streamline ordering. For some people it may be possible to fit more than one board with a single set depending on which keyboards.
Offline esoomenona
  • Gnillort?
« Reply #226 on: Fri, 15 March 2013, 11:17:08 »
It would be even MORE possible with more shift keys! :­D
« Reply #227 on: Fri, 15 March 2013, 11:20:39 »
But then you wouldn't have to order more sets and reaching MOQ would be even harder  ;)
Offline mushupork
  • I am not knowing
« Reply #228 on: Fri, 15 March 2013, 11:20:47 »
Thanks - did not want to pollute the Group Buy thread with this since everyone seemed to get it.
Offline The_Beast
  • I like wood ಠ_๏
« Reply #229 on: Fri, 15 March 2013, 11:21:21 »
Quite the balance you have there! :P
Offline esoomenona
  • Gnillort?
« Reply #230 on: Fri, 15 March 2013, 11:21:30 »
Reaching MOQ would be even easier with less Shift keys! :­D
Offline Jocelyn
  • 조셀린
« Reply #231 on: Fri, 15 March 2013, 11:22:27 »
And Blanks!
« Reply #232 on: Fri, 15 March 2013, 11:28:05 »
No, not for everything. Then some things are even less likely to reach moq without the most common ones to give aid. I look at it like this. Some people may feel they don't need something, until they decide they want to buy some other board and suddenly may need other size key, or even if not that you will have some other keys for trading. Also if later on one decided that they aren't so into them you have triple the chance of a sale due to the flexibility of the sets.
It didn't really occur to me many people would want all blank ABS. The blank keys that are offered in the purple set was more out of necessity due to lack of wanted legends to add more compatibility than anything.
« Last Edit: Fri, 15 March 2013, 11:31:39 by IvanIvanovich »
Offline esoomenona
  • Gnillort?
« Reply #233 on: Fri, 15 March 2013, 11:29:44 »
I were jokin'
Offline Jocelyn
  • 조셀린
« Reply #234 on: Fri, 15 March 2013, 11:54:34 »
« Last Edit: Fri, 15 March 2013, 12:00:31 by Jocelyn »
Offline Lastpilot
  • Power stance
« Reply #235 on: Fri, 15 March 2013, 12:18:01 »
Added to my Poker :
IronMan SE Gold on Black & Graphite Set <3
I tried PMing Anynoupy a while ago but to no avail. Anybody know who made this Graphite set, and where these kinds of legends are from? That arrow under the enter key is dead sexy.
Offline esoomenona
  • Gnillort?
« Reply #236 on: Fri, 15 March 2013, 12:21:44 »
Those are the same legends on the Korean CCnG, so I suppose them?
« Reply #237 on: Fri, 15 March 2013, 12:22:17 »
I will auction the samples if money need to be raised if there is order shortfall. Otherwise if not I will raffle them at the end of the buy and some lucky person will get them in their order. You may find it shocking I am not using them and only put them on a board once to take the photos  :eek: they are just sitting unloved in a little baggie.
Offline SmallFry
« Reply #238 on: Fri, 15 March 2013, 12:23:45 »
The Graphite Set was made by one of the Korean communities, though I don't recall OTD or KBDMania. The legends were completely custom and nobody really liked them, so it wasn't produced for very many sets. The only two sets I've ever seen were CCnG (Korean) and the Graphite sets.
Offline Lastpilot
  • Power stance
« Reply #239 on: Fri, 15 March 2013, 12:25:45 »
Heart is broken.
Edit: But thanks for the quick answer! Really appreciate it :D
Offline SmallFry
« Reply #240 on: Fri, 15 March 2013, 12:26:16 »
I have a set, though I won't let it go for cheaply.
Offline esoomenona
  • Gnillort?
« Reply #241 on: Fri, 15 March 2013, 12:28:47 »
Go ahead and just drop them in my order.
« Reply #242 on: Fri, 15 March 2013, 12:57:15 »
I have one of each of those Korean sets, and I feel the same. :)
I personally like the legends.
Offline khaangaaroo
« Reply #243 on: Fri, 15 March 2013, 20:07:18 »
How come there isn't a standardized way of rating springs? Can someone put together a chart of Cherry and Korean springs on the same scale?
« Reply #244 on: Fri, 15 March 2013, 21:19:41 »
There's only two standards, not really that complicated.  Aftermarket springs are measured at the bottom, OEM are measured at activation.
Offline Jocelyn
  • 조셀린
« Reply #245 on: Sat, 16 March 2013, 01:47:06 »
Do cherry profile 1.75x R Shifts exist, and if so are they all ABS? I'm on the lookout if something like this exists, but have a feeling all of them have been made by SP.
Edit - An 1800 R Shift would work I think, but is this cherry profile?
http://item.taobao.com/item.htm?spm=a230r.1.10.13.VBzjrN&id=15962128659
« Last Edit: Sat, 16 March 2013, 02:10:33 by Jocelyn »
Offline Jocelyn
  • 조셀린
« Reply #246 on: Sat, 16 March 2013, 07:02:51 »
I fixed it! The leaf spring on the Alt key was a little too far away/seperated to actuate, and I was mistaken about the Alt key working in it's normal position. Esoomenona, you should try looking at your G's leaf spring.
Thanks everyone, my 1 & 3 are now working perfectly :)
« Reply #247 on: Sat, 16 March 2013, 07:45:37 »
Leaf spring?  I do not think it means what you think it means.
Offline Jocelyn
  • 조셀린
« Reply #248 on: Sat, 16 March 2013, 07:52:01 »
lol I thought I've seen it referred to as "leaf spring", but whatever. All I know is that the "rail" wasn't touching the "leaf" and I fixed it.
Offline Lunartuna
  • Good bye money!
« Reply #249 on: Sat, 16 March 2013, 08:42:59 »
How come the Noppoo Choc Mini doesn't get more love?
Is it not plate mounted w/ costar stabs and affordable?
Shine 2 TKL - Choc Mini
