Author Topic: Simple Questions, Simple Answers (FAQ in the OP)  (Read 6276925 times)
Offline MJ45
  • HHKB Pro
« Reply #100 on: Thu, 28 February 2013, 19:26:17 »
I'm new to mechanical keyboards I only have four so far but my question is what are the benefits of putting stickers in MX switches.
« Reply #101 on: Thu, 28 February 2013, 19:30:45 »
Apparently the MX switches are slightly wobbly and stickers reduce that wobble. I don't really believe it myself.
« Reply #102 on: Thu, 28 February 2013, 19:31:32 »
Short answer: it is debatable that they do anything at all.
Long answer: Cherry MX switches have a casing that is two halves clipped together in the middle.  The sticker goes between them and makes it a tighter fit.  This is supposed to keep the switch housing from moving ever so slightly when under pressure.  Perhaps it is also supposed to absorb vibration.  Anyway the koreans like 'em so everyone here pays for 'em (even me, and I firmly believe that they don't make any difference)
Offline Jocelyn
  • 조셀린
« Reply #103 on: Thu, 28 February 2013, 19:32:56 »
I'll have to agree about them reducing the wobble being nonsense. They're really just for looks, and even then you're not really going to see them unless you're replacing caps.
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #104 on: Thu, 28 February 2013, 19:34:56 »
I've got boards with and without and I can't tell any real difference.  My brain tries to say "Oh but maybe the switch feels slightly different/whatever" but yeah, I can't tell any difference.
Offline SmallFry
« Reply #105 on: Thu, 28 February 2013, 19:35:51 »
No, M0110 have these:
Oh, right. My bad... :/
Offline L4yercake
« Reply #106 on: Thu, 28 February 2013, 19:36:47 »
I didn't believe it until I got my Vintage Blacks recently and it was visibly obvious the top / bottom wobble against each-other because the spring is pushing the top up and they don't sit flush. I'd say they help if you can actually see the wobble. I guess there are varying factory qualities though.
Offline Grimey
« Reply #107 on: Fri, 01 March 2013, 12:12:19 »
What are the part numbers for Cherry Plate Stabilizers for 1X2 and standar spacebar (?1x6.25 or something)?  And if this is answered where is the best place to order these from?
Erlang your pants off
Offline alaricljs
  • I be WOT'ing all day...
« Reply #108 on: Fri, 01 March 2013, 12:16:22 »
Standard Cherry part numbers found in their datasheet.  No where to order 6.25x from since they "don't exist".  Mouser and OnlineComponents are where you want to look.
That said, I do still have a few sets of plate mount stabs for TKL boards w/ 6.25x space bars.
« Last Edit: Fri, 01 March 2013, 12:19:40 by alaricljs »
Filco w/ Imsto thick PBT
Offline Grimey
« Reply #109 on: Fri, 01 March 2013, 12:20:39 »
That said, I do still have a few sets of stabs for TKL boards w/ 6.25x space bars.
So if need to order a set for a poker plate/pcb combo that I got from iMav I should order...
G99-0224 X4
and which of the following for the space bar..
G99-0226
G99-0226
G99-0379
Offline alaricljs
« Reply #110 on: Fri, 01 March 2013, 12:23:01 »
Either the 0226 or 0379 and then bend and cut for 6.25.   0226 will give you more room to maneuver since it's longer.
« Reply #111 on: Fri, 01 March 2013, 12:25:18 »
I've recently done some bending and it is totally hard to get it just right.  Thank god the cherry wires are so much simpler than the costar.
« Reply #112 on: Fri, 01 March 2013, 13:33:37 »
That's the wonderful thing about getting your plate mount Cherry stabs from old WYSE boards. They have a 10x spacebar wire, so you just use an existing 6.25x or 7x wire to measure, and bend at 90 degrees with a pair of pliers. :D
Offline SmallFry
« Reply #113 on: Fri, 01 March 2013, 13:34:58 »
Hey! You update your signature!
« Reply #114 on: Fri, 01 March 2013, 13:35:28 »
I found that method insufficient.  I took a hint from SmallFry and locked it in a vice and hammered it over.  Gives a nice 90 bend.  With hand tools it was too round which doesn't fit well into the stabilizer blocks, and will make the space feel weird.
Offline SmallFry
« Reply #115 on: Fri, 01 March 2013, 13:36:28 »
Also, I used copper wire for my stab recently. Doesn't affect the feel whatsoever. Plus, it was easier to bend.
« Reply #116 on: Fri, 01 March 2013, 13:44:52 »
That actually describes my method more accurately. I hold the wire with the pliers, and bend it by hand to 90 degrees. Gives it a nice sharp angle, since the sides of the pliers are flat. ;)
Offline whiskytango
  • Don't touch the trim
« Reply #117 on: Fri, 01 March 2013, 13:45:11 »
I am planning on doing this for my phantom with some of the WYSE stabs I have, but my problem is that I do not have a 7x wire to use as a template, or a 6.25 for that matter. Any suggestions? I guess I could try measuring the distance between the stabs once they are on the plate and try to duplicate that...
Offline SmallFry
« Reply #118 on: Fri, 01 March 2013, 13:48:01 »
I'll take some pictures when I get home of what I did. Er, wait. I glued my stabs in. I took one end, put it in like normal. Then I put the other one in but not into the bent part. Mark the middle of the stab and then bend at that point... If that made any sense whatsoever.
Offline whiskytango
« Reply #119 on: Fri, 01 March 2013, 13:50:24 »
Yeah, that's kinda what I meant when I said "measure". I was thinking to use the wire as a ruler and just mark it where the bend needs to be. If that has worked for you then I will go with that method probably. Unless I can get my hands on a 7x wire, but I only need one so then there'd be no point in bending another.... I will just go with what I have on hand I think
« Reply #120 on: Fri, 01 March 2013, 13:52:01 »
I'm sending you those blue switches on Monday. Send me a spacebar wire, and I'll send you a 7x bent one. :) If you want a 6.25, I can do that, too.
Offline Grimey
« Reply #121 on: Fri, 01 March 2013, 13:56:28 »
So the alternative would be to buy Costar style stabs + wires and file (cut, whatever) the plate to fit those then?  I assume this is also possible?
Offline alaricljs
« Reply #122 on: Fri, 01 March 2013, 13:59:35 »
yes for 6.25.  If you want Costar 7x then you need to bend that.  :)
Offline whiskytango
« Reply #123 on: Fri, 01 March 2013, 14:01:16 »
Ok, that works for me. I just need the 7x I think. Don't have any plans to put cherry stabs in anything that uses 6.25... yet anyway. I will go ahead and get your stuff ready and ship it out from this end too. Thanks
Offline Grimey
« Reply #124 on: Fri, 01 March 2013, 14:01:52 »
Thanks, I think I will try this path with one of my poker plates I got.  The stabilizer spacing seems fine for width, but the holes are not tall enough for the wire holder to fit in properly.  I think a bit of filing or grinding could solve that issue (especially as I already have plenty of the costar style elements sitting around).
Offline Skull_Angel
« Reply #125 on: Fri, 01 March 2013, 14:06:38 »
(not sure how "simple" this question/answer is)
What's required to swap Costar plate mount stabilizers to Cherry plate mount? (figure there'll be soldering work)
Offline The_Beast
  • I like wood ಠ_๏
« Reply #126 on: Fri, 01 March 2013, 14:13:10 »
Desolder all the switches from the plate and the find a new plate that supports cherry stabilizers
Offline Jocelyn
  • 조셀린
« Reply #127 on: Sun, 03 March 2013, 18:33:46 »
I want to buy a stepped caps lock, so Is a Poker's Caps lock center or off-center stem? I don't have my Poker or a Caps lock in front of me :(
Center stem
Figured it had to be. Thank You :)
« Last Edit: Sun, 03 March 2013, 18:36:01 by Jocelyn »
« Reply #128 on: Sun, 03 March 2013, 18:34:36 »
Center stem
Offline whiskytango
« Reply #129 on: Sun, 03 March 2013, 18:40:38 »
Does anyone do printing on blank keycaps? Say, if you bought some of the blank caps from SP's inventory page, is there a way to get some sort of legends printed on them?
SP inventory site I am referencing: http://keycapsdirect.com/key-capsinventory.php
Thanks
Offline ComradeSniper
  • HHKB Pro
« Reply #130 on: Sun, 03 March 2013, 19:15:30 »
I found a Focus FK2001 for 50 cents at Goodwill so I bought it, but it has what I think is an AT style connector. The adapter that was hooked up to it is missing some pins on the PS/2 end and doesn't work. Would one of these work?
http://www.amazon.com/Belkin-F2N017-Keyboard-Adapter-MiniDin6/dp/B00000J1UB
« Reply #131 on: Sun, 03 March 2013, 19:35:01 »
Thanks
Easiest route is WASDkeyboards.com.  They will etch anything you want onto keycaps for you.  You don't even have to provide the blanks.
« Reply #132 on: Sun, 03 March 2013, 19:46:39 »
After being educated by my keyboard professor SmallFry, I have learned that yes, that converter will work. He also recommends this adapter. I like how you'll be spending 4x the amount of money on the adapter :D
Offline SmallFry
« Reply #133 on: Sun, 03 March 2013, 19:55:16 »
The longer wire one takes the stress off your PS/2 port.
  • HHKB Pro
« Reply #134 on: Sun, 03 March 2013, 20:33:22 »
Great, thanks guys.
Offline CaptainAsshat
« Reply #135 on: Mon, 04 March 2013, 17:05:34 »
Why do the cherry mx plate mount cutouts I see on plans around the forum have extra slots on the sides of the main square, even though the cherry mx datasheets just have the square?
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #136 on: Mon, 04 March 2013, 17:06:39 »
So you can open the switches to exchange stem and spring without having to unsolder the switches.
« Reply #137 on: Mon, 04 March 2013, 17:08:03 »
Cool thanks!
Offline Harryboii
« Reply #138 on: Tue, 05 March 2013, 07:09:30 »
what does double shot mean? I am new to the world of mechanical keyboards and geekhack and would love to get to know everything. Thank you.
Offline llovro
« Reply #139 on: Tue, 05 March 2013, 07:19:35 »
It means that the keycap is molded around a plastic or metal insert, which makes the keycap very durable but more expensive too.
« Reply #140 on: Tue, 05 March 2013, 11:23:17 »
To expand on that, the purpose of doubleshot is that the legend of the key (what is printed on it) is plastic that runs all through the key. Effectively it will never wear off until a hole is created through the entire keycap. It has a superior durability to the typical pad printed or lasered legends.
Offline OnTheBrink
  • Work Hard. Play Harder.
    • Wired In Store
« Reply #141 on: Wed, 06 March 2013, 01:06:03 »
Oo oo can you be my professor then? You my go to guy anyway!
Offline SmallFry
« Reply #142 on: Wed, 06 March 2013, 01:09:43 »
By that process, you ask him, he asks me, I tell him, he tells you. :P
« Reply #143 on: Wed, 06 March 2013, 21:52:41 »
There can only be one pupil to the grandmaster :P
Offline Reomero
  • Manual breather
« Reply #144 on: Thu, 07 March 2013, 23:38:12 »
How do POM keycaps differ from the more familiar ABS and PBT keycaps?
Offline WhiteFireDragon
    • youtube
« Reply #145 on: Fri, 08 March 2013, 01:19:41 »
I've mainly only seen POM in clear caps, whereas ABS or PBT are solid colors. I think ABS can also be translucent although not that common, and PTB must be a solid color.
« Reply #146 on: Fri, 08 March 2013, 06:31:13 »
I've definitely seen solid black POM.  I've heard that POM has even better texture robustness than PBT or ABS, but I don't know first hand.
Offline badcop
  • thorpe thocking master race
« Reply #147 on: Fri, 08 March 2013, 06:51:58 »
has anyone had issues with desoldering leds on a poker?  i'm having one hell of a time with it.  flux, wick, pump nothing is working right.  :confused:
« Reply #148 on: Fri, 08 March 2013, 06:54:44 »
I've never had a full set of POM but I do have a few single caps. They feel like slicker ABS caps imo. And they seem to already have a bit of shine because of the material properties.
My PBT caps seem to keep their texture better than my ABS caps though.
Try tinning your tip first. Put some solder onto the tip. Make it almost silver and then touch it to the joint. I also prefer wicks.
« Reply #149 on: Fri, 08 March 2013, 07:00:26 »
Wicks are not very good for getting all the solder out of through holes.  I'd rather hard to get it all.  I use a desoldering iron.
