Author Topic: Simple Questions, Simple Answers (FAQ in the OP)  (Read 6213528 times)
0 Members and 6 Guests are viewing this topic.
Offline badcop
  • thorpe thocking master race
« Reply #150 on: Fri, 08 March 2013, 07:31:33 »
I've never had a full set of POM but I do have a few single caps. They feel like slicker ABS caps imo. And they seem to already have a bit of shine because of the material properties.
My PBT caps seem to keep their texture better than my ABS caps though.
has anyone had issues with desoldering leds on a poker?  i'm having one hell of a time with it.  flux, wick, pump nothing is working right.  :confused:
Try tinning your tip first. Put some solder onto the tip. Make it almost silver and then touch it to the joint. I also prefer wicks.
yeah its tinned.  im only getting the solder thats on the surface not inside the hole.  hmmm
« Reply #151 on: Fri, 08 March 2013, 08:00:50 »
Gotta use something that "sucks" :P  Also get some flux on there.  It will prevent oxidation with the reheat and it helps to distribute heat too.
« Reply #152 on: Fri, 08 March 2013, 08:20:09 »
Try adding more solder, then using the pump. That's been the only method that works for me. Just get a big glob of solder melted on there, then suck it with the pump. Should bring the stuff up through the hole.
Offline singaporean123
  • I like keycaps and I cannot lie
« Reply #153 on: Fri, 08 March 2013, 08:33:26 »
can pcb mount switches be soldered with a plate?
i understand that pcb mount switches = 4 pins while plate mounted switches = 2 pins..
Offline bavman
« Reply #154 on: Fri, 08 March 2013, 08:36:22 »
Yes but you need to cut them off or else they won't fit in the pcb
or you mean like use a plate on a pcb mounted board?
Offline SmallFry
« Reply #155 on: Fri, 08 March 2013, 08:37:50 »
Unless the PCB has those holes. :P The Phantom PCB for example.
Offline bavman
« Reply #156 on: Fri, 08 March 2013, 08:38:58 »
What's that?
« Reply #157 on: Fri, 08 March 2013, 08:39:12 »
And KMAC.  Has the PCB mount holes even though it is plate mount. I design my own boards that way, too.  Keep those options open!
Offline alaricljs
  • I be WOT'ing all day...
« Reply #158 on: Fri, 08 March 2013, 08:40:06 »
Plated board with PCB switches and a proper PCB to accept them is a very solid keyboard to type on.  Even more solid when you stick it in a 8lb case like the 456GT  :)
Filco w/ Imsto thick PBT
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #159 on: Fri, 08 March 2013, 09:58:10 »
Couple questions
1.   Anyone here have any affiliation with or know how to get in contact with http://www.originativeco.com/?   Reason for asking is I was wondering about their SSL status when placing an order as the other day I was at the checkout page and noticed the page was not secure so I backed out.  I then went to their facebook page and asked about this and have not heard any response back.
2.  How do the different weight springs on that site compare to the springs in clears and browns?
3.  Also would like to know how many springs come in an order from that site.
4.  If their SSL issues don't get sorted out does anyone know where I can get a set of keys for TKL board with the two tone grey theme similar to the ones at orininatice but with custom legends on the front of the key for the function layer I am currently in the process of attempting to build?
5.  When desoldering a key on my Phantom board I accidently ripped the small copper pad off the side of the board between the PCB and the plate.  Will this cause the board/key to never work again or can do I not need to worry about this as it was only the pad on the once side of the PCB?
Melvang
« Reply #160 on: Fri, 08 March 2013, 11:15:01 »
Couple questions
Melvang
I'm at work right now so I can't get on originativeco to look up your other questions. But you can message the guy who runs it here on GH. His name is Sherryton. You can also find him in his vendor subforum.
« Reply #161 on: Fri, 08 March 2013, 11:55:47 »
I've already made a thread in the DIY section, but I thought I'd post here too.. Does anyone know exactly what screws are used to secure the filco plate/pcb to the bottom half of the case? Thanks!
« Reply #162 on: Fri, 08 March 2013, 18:29:51 »
Couple questions
Melvang
2) Browns have a 45cN actuation force w/ a peak at 55cN. Clears are 55cN actuation with a 65cN. 1 cN is about 1 gram of force. And I believe the Korean springs count the peak actuation. So browns are 55g and clears are 65g.
3) I can't find pictures or any amount. I'd PM sherryton. He's usually quick to respond on GH. The word is there should be 100 springs per pack.
4) Sounds like you might have to snag a WYSE keycap set and then see if WASD keyboards can put custom legends on the caps. WYSE can be found in GH and DT classifieds I think. I believe I recently saw some for relatively cheap in the GH classifieds. Custom legends I'm a bit fuzzy on.
« Last Edit: Fri, 08 March 2013, 19:21:34 by CPTBadAss »
Offline Jocelyn
  • 조셀린
« Reply #163 on: Fri, 08 March 2013, 18:37:16 »
I thought clears had a 65cN actuation force w/ peak of 80cN. I'm asking, not stating :)
« Reply #164 on: Fri, 08 March 2013, 19:21:08 »
I just took the numbers from the Deskthority Wiki. I think this is why mkawa is started that project to get accurate measurements.
Offline SmallFry
« Reply #165 on: Fri, 08 March 2013, 19:40:43 »
Will Sherry ever get his act together? I need SSL, a decent buying interface, and a site that doesn't take forever to load. When will this happen?
« Reply #166 on: Fri, 08 March 2013, 19:41:56 »
A wise man once told me this nugget of wisdom: It shall be here "SoonTM"
Offline The_Beast
  • I like wood ಠ_๏
« Reply #167 on: Fri, 08 March 2013, 19:43:22 »
EA?
« Reply #168 on: Fri, 08 March 2013, 19:46:38 »
EA?
And Blizzard
Offline SmallFry
« Reply #169 on: Fri, 08 March 2013, 19:50:37 »
And Sherry apparently.
Offline WhiteFireDragon
    • youtube
« Reply #170 on: Sat, 09 March 2013, 12:16:44 »
What profile is ISO-Enter, numpad-Enter, and numpad "+"
Offline Gupgup
« Reply #171 on: Sat, 09 March 2013, 12:57:19 »
How do I put an image in my signature?
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #172 on: Sat, 09 March 2013, 13:08:21 »
For Cherry enter for either ANSI, ISO or J and + is C profile, and numpad 1x2 enter can come in either A or B profile.
Offline absyrd
  • CPT HYPE PADAWAN
« Reply #173 on: Sat, 09 March 2013, 13:10:23 »
Use the usual [.img][/img.] tags (take out the "."s). May be a size restriction, though.
Offline SmallFry
« Reply #174 on: Sat, 09 March 2013, 13:11:03 »
Code: [Select]
[img]INSERT IMAGE URL HERE[/img]I think. Not positive.
« Reply #175 on: Sat, 09 March 2013, 13:11:34 »
Images in your signature must be no greater than 777x70 pixels
Offline Gupgup
« Reply #176 on: Sat, 09 March 2013, 22:10:15 »
How many Rosegold ironmen were made?
Offline Reluctant member
« Reply #177 on: Sun, 10 March 2013, 06:02:39 »
Hi,
Could anyone tell me what type of key caps were used on the Heathkit H9 and does anyone know where I can get some please?
Many thanks for any help you can give, I've been trying to find these for years!
RM
« Last Edit: Sun, 10 March 2013, 06:04:49 by Reluctant member »
« Reply #178 on: Sun, 10 March 2013, 09:22:37 »
Hi,
RM
Those look like relegendable keycaps. I believe they have and ABS base with a Polycarbonate overcap. You can either find an old board that has them and salvage them, such as that Heathkit H9 or Cherry Point of Sales keyboards. You can also find them at Signature Plastics. Check out this link and this link.
Offline ComradeSniper
  • HHKB Pro
« Reply #179 on: Mon, 11 March 2013, 17:57:37 »
Where can I get a QFR with Greens?
« Reply #180 on: Mon, 11 March 2013, 18:00:52 »
Supposedly CM will be carrying them again and I've heard rumors that MK.com should be as well. But I'm not sure there's any out there right now.
Offline zoolzoo
« Reply #181 on: Tue, 12 March 2013, 05:26:06 »
Is there a retail outlet online that sells MX clears?
Leopold FC660C, Topre 45g | CM QFR, MX Blue | Rosewill RK-9000v2, MX Red | Cherry Slimline G84-4100, ML | Ducky One2 Mini RGB, MX Red
Offline alaricljs
« Reply #182 on: Tue, 12 March 2013, 05:32:09 »
If by that you mean switches... Mouser or OnlineComponents
Offline zoolzoo
« Reply #183 on: Tue, 12 March 2013, 05:33:03 »
Yes the entire switch. No retailers sell just stems right?
Offline alaricljs
« Reply #184 on: Tue, 12 March 2013, 05:34:14 »
No they certainly do not.
Offline Lunartuna
  • Good bye money!
« Reply #185 on: Tue, 12 March 2013, 09:31:18 »
Here we go:
I'm curious about how durable the springs are in Cherry MX switches.
Do heavier keys like metal ones(1x1, backspace, space bar) wear out springs quicker?
By wearing out I mean is does it ever come to a point where a switch spring can't hold the keycap up any more and it just rests in the pressed down position on its own?
Part 2:
Do stabilizers add more weight to a key? I mean cherry stabilizers rest in the down position. You push the keycap down onto the stab +'s and then the switch pulls the stabilizer up, does this add weight?
Reason I ask is I didn't like the feel too much of my left shift when I was gaming. Tried some lube, still didn't like the feel.
So basically I took the 2 stems and the metal wire out of the stabilizer and left the part that the key actually lands on in. I put o-rings on all three stems of the shift key so it has a nice landing on the switch and the  landing part of the stab, and stuck it back on. Feels amazing now but I'm starting to worry about if the shift keycap weight might were out the spring? They are cherry blacks.
Am I committing switch suicide? If not I'm considering doing this to all my stabilized keys(except space bar) if not.
Shine 2 TKL - Choc Mini
« Reply #186 on: Tue, 12 March 2013, 09:41:33 »
Cherry MX switches are tested to last for 50 million actuations.  I doubt the weight of the keys makes any difference at all.  They always go back to the same position regardless.
The only problem I see is that your switch is no longer stabilized, so if you hit the key off-center, it will not depress evenly.  Still probably won't damage the switch, it just won't feel right.
« Last Edit: Tue, 12 March 2013, 09:44:24 by metalliqaz »
Offline Lunartuna
  • Good bye money!
« Reply #187 on: Tue, 12 March 2013, 09:59:21 »
That's what I was hoping. I have tiny fingers and my pinky always lightly hits near the centre of the shift key so hopefully this will work out.
Feels amazing compared to before and its nice sounding.
Offline mushupork
  • I am not knowing
« Reply #188 on: Tue, 12 March 2013, 10:11:47 »
What is the difference between a Tsangan kit and a Moogle?  Is a Tsangan kit a moogle kit for specific keyboards?  If so, which ones?
Wanted:  Windowed capslock for a QFR
« Reply #189 on: Tue, 12 March 2013, 10:33:56 »
This has been asked several times, but essentially...
Key set       ->   needs this kit       ->   for these boards
key set with old-fashioned 1.5x mods/off-center caps -> moogle kit -> modern board (Filco, etc)
key set for modern filco-type board -> tsangan kit -> old-fashioned board (cherry, KMAC, etc)
« Last Edit: Tue, 12 March 2013, 10:35:51 by metalliqaz »
Offline mushupork
  • I am not knowing
« Reply #190 on: Tue, 12 March 2013, 10:46:12 »
So ...
Old keyset on new keyboards needs moogle.
New keyset on old keyboards needs tsangan.
If it is roughly accurate that will be easy for me to remember.  Thanks for the fast reply.
« Reply #191 on: Tue, 12 March 2013, 11:12:35 »
Yep, that's pretty much it.  Although tsangan kits are needed for more than old boards.  Many Korean custom boards also need them.  Usually you can just look at the mods for a good rule of thumb.
If you need some 1.5x mods/7x space to get your key set to fit on your board, you need a tsangan.
If you need some 1.25x mods/6.25x space to get your keys to fit on your board, you need a moogle.
« Reply #192 on: Tue, 12 March 2013, 12:53:51 »
Or if people simply stopped calling them nicknames and say 1.25 kit, 1.5 kit... there would be less confusion since it is literal.
Offline Lunartuna
  • Good bye money!
« Reply #193 on: Tue, 12 March 2013, 13:15:19 »
Do metal cases for Ducky exist? Aluminum or SS?
I was thinking of trying to mod a filco/vortex aluminum case until I noticed the LED holes on the front.
Offline 1839cc
« Reply #194 on: Wed, 13 March 2013, 11:25:35 »
I think that's for light gray/dark gray/green switches. Clear springs are very close to blacks.
i have seen unix admins with john deere trucker hats, and even seen a man in a nascar shirt correct a passerby's klingon.
« Reply #195 on: Wed, 13 March 2013, 11:38:27 »
Clear spring actuate at 65cN, but bottom out is 100cN according to Cherry datasheet. So while actuation force is close to black, bottom out is lighter at 80cN.
« Last Edit: Wed, 13 March 2013, 11:40:13 by IvanIvanovich »
Offline Jocelyn
  • 조셀린
« Reply #196 on: Wed, 13 March 2013, 11:40:15 »
Haha I was just about to link a post of yours about this :)
Offline 1839cc
« Reply #197 on: Wed, 13 March 2013, 12:22:47 »
So how much force does it take for the three I mentioned? 80/150?
« Reply #198 on: Wed, 13 March 2013, 13:22:50 »
Has Filco ever produced a board with clears? Also, what's the difference between white and green mx?
« Last Edit: Wed, 13 March 2013, 13:49:31 by noisyturtle »
« Reply #199 on: Wed, 13 March 2013, 13:22:57 »
Sadly those are missing nice graphs in the datasheet. If you look more towards the end on the pages that are sideways it does give the operating forces, but not the bottom out.
