Author Topic: Simple Questions, Simple Answers (FAQ in the OP)  (Read 6213808 times)
« Reply #350 on: Fri, 22 March 2013, 10:34:14 »
jd i am getting the $40 PCB that is presoldering and paying for assembly..i don't have any soldering experience or equipment. i plan on getting hhkb layout if that makes a difference. i just want the basic stabilizers, as long as they are easy to switch out keycaps.
Yes, then you should get PCB mount Cherry stabilizers. This goes for anyone else who doesn't know which to order. :)
« Reply #351 on: Fri, 22 March 2013, 10:36:52 »
Are you assembling this yourself? Cherry PCB mount stabilizers should probably be listed as the default option. They are the easiest to install, if you are new to DIY. The plates might require some sanding/filing to work well with Costar stabilizers.
Can you explain a little more about Costar stabilizers and how they're installed? I prefer Costar stabilizers and GH60 will be my first DIY board.
Offline whiskytango
  • Don't touch the trim
« Reply #352 on: Fri, 22 March 2013, 10:52:58 »
Is there a difference in the feel of Cherry PCB vs Cherry plate mounted stabilizers?
I have access to costar and cherry plate mount boards but never tried a board with cherry pcb mount stabilizers. Thanks
Edited to show what I meant to ask. Difference between the two types of Cherry stabs. Thanks jd
« Last Edit: Fri, 22 March 2013, 11:18:19 by whiskytango »
« Reply #353 on: Fri, 22 March 2013, 10:57:06 »
Is there a difference in the feel of cherry PCB vs plate mounted stabilizers?
Costars feel crispy to me while Cherry stabilizers can feel a bit mushy. However Costars have the annoying inserts and take a little more time to swap caps out. Cherry stabs you just pop the cap off and put a new cap on.
« Reply #354 on: Fri, 22 March 2013, 10:59:22 »
He didn't mention Costar....
« Reply #355 on: Fri, 22 March 2013, 10:59:44 »
I don't think there is a difference in feel between the two types of Cherry stabilizers.
« Reply #356 on: Fri, 22 March 2013, 11:00:59 »
Hooray for mis-reading! -_-
Offline whiskytango
« Reply #357 on: Fri, 22 March 2013, 11:06:39 »
Thanks. I ask because I'm trying to decide between the universal plates and the ones that accept plate mounted cherry stabs... I have both types of stabs from parting out old wyse boards
Really I hate changing caps on the costars so much, I'm definitely going with cherry stabs one way or the other. Plus then I won't have to buy any :-)
Edit: yeah I could have worded that better. I was specifically wondering about Cherry PCB vs Cherry Plate Mount
« Last Edit: Fri, 22 March 2013, 11:11:41 by whiskytango »
Offline Jocelyn
  • 조셀린
« Reply #358 on: Fri, 22 March 2013, 11:12:16 »
Go with plate mount cherry stabs!
My question is (lol) why is it so hard to find aluminum Poker cases and why we're so few made?
Edit - lol don't answer my question
« Last Edit: Fri, 22 March 2013, 11:22:29 by Jocelyn »
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #359 on: Fri, 22 March 2013, 11:33:53 »
The best Cherry stabs are the original PCB mount design that bolt on.
« Reply #360 on: Fri, 22 March 2013, 11:55:00 »
I've never even seen those.
Offline alaricljs
  • I be WOT'ing all day...
« Reply #361 on: Fri, 22 March 2013, 12:24:18 »
Instead of the pinch pin at one end it's a hollow pin and there's a screw you screw into it once it's on the PCB.  Wyse terminal boards have these on the space bar.
Filco w/ Imsto thick PBT
« Reply #362 on: Fri, 22 March 2013, 12:32:59 »
Yes, but also the keycap side insert have a different design, which dosen't have the dampener for bottom out.
Offline alaricljs
« Reply #363 on: Fri, 22 March 2013, 12:37:07 »
The ones I have do but of a different design... there is a plastic leaf spring protruding from the housing that the stem lands on.
16560-0
« Last Edit: Fri, 22 March 2013, 12:40:02 by alaricljs »
« Reply #364 on: Fri, 22 March 2013, 12:37:08 »
Yeah, they need to bring those back. I've only ever seen them on those WYSE terminal boards.
« Reply #365 on: Fri, 22 March 2013, 12:39:38 »
The ones I have didn't. They came from a PCB mount board DEC type layout copy from 1985 I got for like $8 that was broken. I used them on my GH60. Also on my Commodore and Amiga they have these type. Both of those are old too, made in 1985 and 1987.
Offline alaricljs
« Reply #366 on: Fri, 22 March 2013, 12:41:28 »
I purchased a new stab set that is very similar to what I have off the Wyse, however the key stem is only 2mm long... very odd.
Offline Dubsgalore
« Reply #367 on: Fri, 22 March 2013, 12:58:35 »
Can i map any key to any position on the GH60? i want this layout
Offline alaricljs
« Reply #368 on: Fri, 22 March 2013, 13:01:15 »
Yes
Offline SmallFry
« Reply #369 on: Fri, 22 March 2013, 13:05:20 »
Gosh, I'd love if we could dye sub onto darker keys. Green on black... so nice.
Offline Jocelyn
  • 조셀린
« Reply #370 on: Fri, 22 March 2013, 13:07:29 »
I'd be happy with black on very dark gray :)
Offline SmallFry
« Reply #371 on: Fri, 22 March 2013, 13:22:38 »
Like the RF's? Meh, IMO.
Offline Jocelyn
  • 조셀린
« Reply #372 on: Fri, 22 March 2013, 13:24:11 »
No, that's already been done and those are way too light! More like HHKB and at least it's doable  :p
Offline SmallFry
« Reply #373 on: Fri, 22 March 2013, 13:25:14 »
This is true. I'd prefer secondary legends dye subbed on like that. That would be cool.
Offline iri
« Reply #374 on: Fri, 22 March 2013, 13:26:16 »
rf's very dark grey is a very pleasant color.
-Ray Bradbury
Offline Jocelyn
  • 조셀린
« Reply #375 on: Fri, 22 March 2013, 13:28:00 »
Yes!I neeeeeeeeeeeed those in Thick PBT :)
« Last Edit: Fri, 22 March 2013, 13:29:47 by Jocelyn »
« Reply #376 on: Fri, 22 March 2013, 13:30:46 »
I will do those in PBT buy #3 if no one takes it first.
Offline ping111
« Reply #377 on: Fri, 22 March 2013, 16:50:03 »
Rosewill RK9001BR - Mac compatible?
In My Possession:
Max Keyboard Nighthawk X8 Mechanical Keyboard - Cherry MX Brown - Blue LED Backlighting
Wanted:
KBTalking PURE - Tenkeyless - Cherry MX Brown - Green LED Backlighting
Offline SmallFry
« Reply #378 on: Fri, 22 March 2013, 16:51:25 »
Yep. I think it's 100% compatible.
Offline Lastpilot
  • Power stance
« Reply #379 on: Sat, 23 March 2013, 10:39:04 »
I couldn't find this in the Originative vendor forum, and it's too small of a question to make a whole thread on...soooo....
Who is the manufacturer for the upcoming Dolch sets? Is it SP or GMK or ...?
« Reply #380 on: Sat, 23 March 2013, 10:46:01 »
Don't worry. They might add them to that store you can't buy from eventually and you can look at the nice picture.
Offline iri
« Reply #381 on: Sat, 23 March 2013, 10:51:44 »
hahaha. this is how i feel about elitekeyboards.
-Ray Bradbury
Offline ping111
« Reply #382 on: Sat, 23 March 2013, 17:23:52 »
I'm just gonna bounce Mac compatibility questions offa you guys:
Max Durandal G1NL?
In My Possession:
Wanted:
« Reply #383 on: Mon, 25 March 2013, 12:13:26 »
Max Durandal G1NL?
According to this link, it is not compatible.
Offline Dubsgalore
« Reply #384 on: Mon, 25 March 2013, 12:18:55 »
what's the point of switch stickers?
« Reply #385 on: Mon, 25 March 2013, 12:24:19 »
The claim is that the switches are slightly wobbly when installed onto the plate and the switch stickers eliminate the stickers. But the common consensus seems to be that the stickers don't really do much besides look cool.
Offline Dubsgalore
« Reply #386 on: Mon, 25 March 2013, 12:33:24 »
how are they applied?
Offline The_Beast
  • I like wood ಠ_๏
« Reply #387 on: Mon, 25 March 2013, 12:35:13 »
Open top of switch, apply the sticker to the switch bottom and put the top back on
Offline Lunartuna
  • Good bye money!
« Reply #388 on: Mon, 25 March 2013, 13:15:01 »
For me, when I put on red oring switch dampeners. It also really helped with switch wobble when holding down. That's one thing that bugged me when holding shift to run in a game. I really noticed wobble. Red oring helped a ton.
Sorry cornfield bad writing. Doing this from my phone.
Edit: ROFL autocorrect! Cornfield = for the
« Last Edit: Mon, 25 March 2013, 13:17:01 by Lunartuna »
Shine 2 TKL - Choc Mini
Offline Dubsgalore
« Reply #389 on: Mon, 25 March 2013, 13:19:55 »
wait is it even visible then?
« Reply #390 on: Mon, 25 March 2013, 13:28:29 »
Dubsgalore, check out this thread for some pics and vids
Offline jincuteguy
« Reply #391 on: Mon, 25 March 2013, 13:30:47 »
Does anyone know if those Das keyboards use the Cherry or CoStar stabilizers for the Space bar?
Offline esoomenona
  • Gnillort?
« Reply #392 on: Mon, 25 March 2013, 13:32:40 »
Which Das keyboard are you speaking of? Maybe a picture? There are different versions which use different stabilizers.
Offline SmallFry
« Reply #393 on: Mon, 25 March 2013, 13:36:45 »
Das I was a dome board, Das II was a Cherry stabilized board, and the Das III is a Costar Stablized board. The Das II internals can be swapped with a G80-3000 (winkey) internals.
Offline esoomenona
  • Gnillort?
« Reply #394 on: Mon, 25 March 2013, 13:38:27 »
I suppose I could've said that, huh? Does the latest Das have Costar stabs as well?
Offline esoomenona
  • Gnillort?
« Reply #395 on: Mon, 25 March 2013, 13:39:18 »
Also, how do you fix a sticking buckling spring? The Enter on my numpad will stay down unless I press it a very particular way (I have to press the very front of it; not on top, but the front side).
Offline Dubsgalore
« Reply #396 on: Mon, 25 March 2013, 13:44:21 »
thanks
Offline SmallFry
« Reply #397 on: Mon, 25 March 2013, 13:53:06 »
I think it does, Hyde was on the quality checking of the latest model last I heard. Perhaps PM him?
Also, most buckling spring problems are fixed by reseating the keycap. If not, a picture may help. :)
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #398 on: Mon, 25 March 2013, 14:00:25 »
Not really.
« Reply #399 on: Mon, 25 March 2013, 14:18:14 »
Does anyone have a picture of a BMX Clack?
